Oneri istegi - Veritabanindaki bilgiyi decode etmek ?
Başlatan gumush, 25 Mayıs 2016, 09:11:59
gumush
Alanda kullandigimiz bir program var , programin bazi hesaplamalari dogru yapmadigi suphemiz oldu. Bu nedenle ham verileri incelemek istiyorum.
Programin veritabanina eristik , burada okumak istedigimiz kisim blog olarak depolanmis.
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
Veriler bir zaman serisini iceriyor.
Ornegin ilk veri icin tahminen
128   9993361
128   10089718
128   10116128
128   10140827
128   10165754
128   10190920
128   10216321
128   10241956
128   10267836
128   10293970
128   10320368
128   10347029
128   10373964
128   10401188
benzeri bir veri olmasini bekliyoruz ( 285 satir var )
Bunu cozebilmek icin alternatif yontem ornekleriniz olabilir mi ?
Hikmet Gumus  izmir
Bu hangi vt ve alan in turu nedir ? Sanki cok kulanilan sayi srring felan degilde image felan gibi bu veriler
LG-D723 cihazımdan Tapatalk kullanılarak gönderildi
Binary olarak yazilmis olabilir mi
bocek
Veriyi bir Hex Editör ile incelerseniz daha kolay çözersiniz.
Tavsiyem Hex Workshop'tur.
http://www.bpsoft.com/
1 ya da 0. işte 'bit'ün mesele..
bocek
İşiniz görülmüş ama işlem sıralamasında gözden kaçan bir şeye düzeltme getireyim.
Alıntı Yap..ama orada decode edilmiş kısım ne print edilebiliyor ne de kopyalanabiliyor, bu sefer "Hex Editor Neo" ile açtım ve o script i şu şekilde değiştirip uyguladım
Breakpoint Hex Workshop programında, structure viewer'da sağ tuşa tıkladığımızda "Export Contents" ile decode edilen veriyi dışarı alabiliyoruz.
Bu durumda Hex Editor Neo'ya gerek kalmıyor.
gumush
Harikasiniz gercekten  cok tesekkur ederim. Base64 mysql'de de sifreleri saklamak icin kullandigim bir islem oldugundan boyle oldugunu dusunup benzer bir online ceviricide cevirmeyi denemis ama sonraki kismi anlamlandiramadigim icin farkli bir sey oldugunu dusunmustum.
Simdi sizin cizdiginiz yoldan giderek cozmeye calisacagim.
Not: Muhittin hocam ozledim vallahi ne guzeldi toplantilarimiz. Firsat olursa tekrar goruselim isterim.
Ekstra degerlerin neden oldugunu anlamaya calisacagim , ama bunun bilerek yapilmis bir hilesi olabilir mi diyede dusunuyorum. Gelisme olunca buradan tekrar yazacagim.
Hikmet Gumus  izmir
Hocam ilk firsatta izmir e gelecegim. Yeminle izmir baskaymis.
