Problems with residual voltage to PWM.
Başlatan buntger, 20 Haziran 2016, 20:24:21
buntger
Hello,
I want to regulate a motor with PWM and regulate I'm using a handlebar equipped with accelerator Hall effect (View photo).
The problem is the residual voltage of 0.8V.
The handlebar is fed to 5V.
At full throttle at the output provides a voltage 4.3V only.
Using this formula this means to regulate the PWM with 0.8V
I'm 84 steps of 255, without doing anything.
As I can make as smooth regulation of 0-255.
Without having to start 84.
Device = 18F26K22
    Xtal = 16
Config_Start
 FOSC = INTIO67
 PLLCFG = On 'On      ' Oscillator multiplied by 4
 PRICLKEN = On     ' Primary clock enabled
 FCMEN = OFF           ' Fail-Safe Clock Monitor disabled
 IESO = Off            ' Internal/External Oscillator Switchover mode disabled
 PWRTEN = On           ' Power up timer enabled
 BOREN = SBORDIS       ' Brown-out Reset enabled in hardware only (SBOREN is disabled)
 BORV = 190            ' Brown Out Reset Voltage set to 1.90 V nominal
 WDTEN = Off           ' Watch dog timer is always disabled. SWDTEN has no effect.
 WDTPS = 128           ' Watchdog Timer Postscale 1:128
 CCP2MX = PORTC1       ' CCP2 input/output is multiplexed with RC1
 PBADEN = Off          ' PORTB<5:0> pins are configured as digital I/O on Reset
 CCP3MX = PORTC6       ' P3A/CCP3 input/output is multiplexed with RC6
 HFOFST = On           ' HFINTOSC output and ready status are not delayed by the oscillator stable status
 T3CMX = PORTC0        ' Timer3 Clock Input (T3CKI) is on RC0
 P2BMX = PORTB5        ' ECCP2 B (P2B) is on RB5                   (EXTMCLR = Enable MCLR/Disable RE Input)
 MCLRE = INTMCLR       ' MCLR pin enabled, RE3 input pin disabled  (INTMCLR = Disable MCLR/Enabled RE Input)
 STVREN = Off          ' Stack full/underflow will not cause Reset
 LVP = Off             ' Single-Supply ICSP disabled
 XINST = Off           ' Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
 Debug = Off           ' Disabled
 Cp0 = Off             ' Block 0 (000800-001FFFh) not code-protected
 CP1 = Off             ' Block 1 (002000-003FFFh) not code-protected
 CP2 = Off             ' Block 2 (004000-005FFFh) not code-protected
 CP3 = Off             ' Block 3 (006000-007FFFh) not code-protected
 CPB = Off             ' Boot block (000000-0007FFh) not code-protected
 CPD = Off             ' Data EEPROM not code-protected
 WRT0 = Off            ' Block 0 (000800-001FFFh) not write-protected
 WRT1 = Off            ' Block 1 (002000-003FFFh) not write-protected
 WRT2 = Off            ' Block 2 (004000-005FFFh) not write-protected
 WRT3 = Off            ' Block 3 (006000-007FFFh) not write-protected
 WRTC = Off            ' Configuration registers (300000-3000FFh) not write-protected
 WRTB = Off            ' Boot Block (000000-0007FFh) not write-protected
 WRTD = Off            ' Data EEPROM not write-protected
 EBTR0 = Off           ' Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
 EBTR1 = Off           ' Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
 EBTR2 = Off           ' Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
 EBTR3 = Off           ' Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
 EBTRB = Off           ' Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
Config_End
Declare Adin_Res    = 10   ' Resolution 10 BITS
Declare Adin_Tad    = FRC  ' Oscilator RC AD
Declare Adin_Stime  = 100  ' AD samples 100uS
Declare CCP1_Pin PORTC.2   ' Select Hpwm port and bit for CCP1 module (ch 1)
ANSELA = 00001111  ' Port A4-A7 Digital=0 / A0-A3 Analog
TRISA  =   00101111  ' Port A  I/O
ADCON1 = %1000000    ' Right justified
ADCON2 = %1000000    ' Right justified
Dim DUTY As Byte                       ' Duty PWM
Dim TENSION As ADRESL.Word      ' Voltage
Dim VALOR_GAS As Float
Dim VOLT As Float
VOLT=0
DUTY=0
VALOR_GAS=0
CLS
Main:
GoSub ADC_Handlebar
    Print At 4,6,Dec2 VOLT ," - ", Dec DUTY     'Display
     HPWM 1,DUTY,20000
 DelayMs 100
Goto Main
ADC_Handlebar:
   TENSION = ADIn 1                         ' Conversor AD
   VALOR_GAS = 489 *(TENSION / 10)  ' 489 = (5V/1023) 10Bits / Vref 5V
   VOLT = (VALOR_GAS / 10000)          ' Value in Volts
         DUTY=(255/4.3)*VOLT             ' Calculates PWM (4.3V  full throttle not 5V )
Return
END
Picture:
THX.
