CCS C ile Projeler
Başlatan ipek, 07 Ekim 2005, 00:46:27
ipek
http://www.vermontficks.org/pic.htm
evet arkadaslar word kazan biz kepce arayislar devam
bu verdigim linkleri daha evvel gorenleriniz olmuştur fakat
yeni arkadaslarimiza fikir vermek istedim bu tur projeleri agir ustalarimizdan da bekliyoruz....
dostar ccs cile yazilmislar DATA LOGGER ve CHARACTERIZER kusursuz calisiyor digerlerini denemedim
iyi calismalar ......
projeler.
1) DATA LOGGER measures and stores voltage at specified intervals and dumps to RS232. Now with 8192 samples
2) BATTERY CHARACTERIZER loads charged NiCad and NiMH battery packs and measures milliamp hour capacity.
3) Underground locator generator for Radiodetection® RD400 LLTS Precision Line Trace unit (underground cable locator)
4) GPS REPEATER displays NMEA-0183 data from a GPS, battery voltages, etc.
5) TRACK CONTROLLER FOR AWANA® GRAND PRIX (also Pinewood Derby) measures and displays fi
6) Experimental PELLET STOVE CONTROLLER
7) LIQUID LEVEL TRANSMITTER/RECEIVER SYSTEM
8) GPS-based COMPASS DISPLAY uses RS232 data stream from GPS receiver
9) DIESEL TACHOMETER uses "tach" signal from alternator
10) DARKROOM EXPOSURE SYSTEM controls safelamp and enlarger lamp, measures exposure
11) REMOTE CONTROL for Raymarine ST4000 Autopilot uses Raytheon's Seatalk® communications protocol
12) ADC EXAMPLE for 16F87x PICs and similar
13) ADDRESSABLE ADC and controller receives serial command then 1) returns ADC measurement, and 2) writes output port
14) MORSE CODE DISPLAY hears Morse code from shortwave receiver, displays text on LCD display
15) Rx/Tx pulse stretcher for LED that monitor serial Rx/Tx lines
16) COMBINATION LOCK for home door, 4x4 matrix keyboard, master combination plus four programmable combinations,
17) COMBINATION LOCK single button, for car liftgate
18) DELAYED-SHUTTER CONTROL for the (now obsolete) Kodak DC-20 digital camera
19) AUDIBLE EMERGENCY LOCATOR ALARM for lost (and possibly "re-kitted") radio-control planes
20) Radio-control SERVO EXAMPLES
21) Solar-powered DOCK or MOORING BUOY LAMP FLASHER
22) AUTOMATIC THROTTLE CONTROL
23) REMOTE SWITCH for radio-control aircraft accessories
sercan_600
