Sinyal ureteci ama hangi model?
Başlatan vedo35, 17 Ocak 2017, 15:16:29
vedo35
Arkadaslar elimdeki yillar once aldigim 5mhz sinyal uretecini yanlis voltaj vererk yaktim.  :-\  Benim icin simdilik en dusuk 10mhz lik olacak birde sinus, kare, testere ve ucgen dalga versin yeter. Fiyat olarak en fazla 55-60 euro verebilirim. Ali expresten epey model buldum ama tam olarak hangisi iyidir birde bazilari cince birde tolerans ve gurultu ile ilgili birseyler yaziyor kafam karisti. Sizin bu konuda bilgi ve tavsiyelerinize ihtiyacim linkler asagida. Sizin buldugunuz ideal link varsa sevinirim.
https://www.aliexpress.com/item/Mini-Digital-Signal-Generator-DDS-Function-Signal-Source-Generator-Dual-channel-Arbitrary-Waveform-Frequency-Meter200MSa-s/32642068081.html?spm=2114.01010208.0.0.9qXZk5
https://www.aliexpress.com/item/Full-set-of-DDS-driver-board-with-the-store-all-kinds-of-DDS-module-button-AD9854/32759024204.html?spm=2114.01010208.0.0.RmwnMV
https://www.aliexpress.com/item/UDB1005S-Function-Signal-Generator-Source-Frequency-Counter-DDS-Module-Wave-5MHz/1419249050.html?spm=2114.01010208.3.41.hBOjnV&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10000009_10084_10000025_10083_10080_10000029_10082_10081_10000028_10110_10111_10060_10112_10113_10062_10114_10115_10056_10055_10037_10054_10059_10032_10099_10078_10079_10000022_10077_10000012_10103_10073_10102_10000015_10096_10000018_10000019_10052_10053_10107_10050_10106_10051,searchweb201603_1,afswitch_5,single_sort_2_default&btsid=dab3d6dd-b95c-4eda-9af9-4ea23fdeecfd
https://www.aliexpress.com/item/DDS-Function-Signal-Generator-Module-Waveform-Sine-Triangle-COUNTER-Frequency/32781104892.html?spm=2114.01010208.3.236.6pCGbQ&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10000009_10084_10000025_10083_10080_10000029_10082_10081_10000028_10110_10111_10060_10112_10113_10062_10114_10115_10056_10055_10037_10054_10059_10032_10099_10078_10079_10000022_10077_10000012_10103_10073_10102_10000015_10096_10000018_10000019_10052_10053_10107_10050_10106_10051,searchweb201603_1,afswitch_5,single_sort_2_default&btsid=dab3d6dd-b95c-4eda-9af9-4ea23fdeecfd
Birde bunu buldum ama bundan birsey anlamadim bu nasil sizce:
http://www.ebay.com/itm/FG085-DDS-Function-Signal-Generator-Module-Sine-Triangle-Square-Wave-New-/141750274527?hash=item2100f989df:g:KXEAAOSw~gRV1C61
Biliyormusun dedi, ben ne yaptiysam kader icabi yaptim dedi. Ben gene sustum.... Kimbilir sende belki kaderin memurusun vazifeni yapiyorsun dedi.
ipek
Direnc.net'te yeni gelenler arasında grafik ekranlı dokunmatik ekran,arbitrary generatör görmüştüm sanıyorum AD9833 ,4 ,5 gibi birşeydi bi incele istersen,eğer alırsan sonucu bizede bildir,bu aletlerde aradığımız tek özellik sweep yani frekansı bir noktadan ,diğer bir noktaya süpürebilsinki filitreleri falan inceleyebilelim, ikinci önemli nokta Constant Trackin Amplitude yani örnek 50 hz çıkış genliği 50mV olsun bunu 50KHz yaptığımızda'da genliği koruyabiliyorsa yararlıdır..
vedo35
Bumu ipek kardesim?
https://www.direnc.net/ads9833-dds-dokunmatik-ekran-sinyal-jeneratoru
yanliz 261 lira kdv dahilmis bu turkiyede niye cok pahali?  Ben aynisini aliexpreste buldum
28-bit resolution: 0.1 Hz at 25 MHz reference clock
25 mhhz diyor
tum ozellikler asagida ustelikte 39 euro. Bence turkiyeden daha ucuz.
https://www.aliexpress.com/item/AD9833-DDS-sine-wave-amplifier-square-wave-triangle-color-touch-screen-module/32736355103.html?spm=2114.01010208.3.124.qwbIGc&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10000009_10084_10000025_10083_10080_10000029_10082_10081_10000028_10110_10111_10060_10112_10113_10062_10114_10115_10056_10055_10037_10054_10059_10032_10099_10078_10079_10000022_10077_10000012_10103_10073_10102_10000015_10096_10000018_10000019_10052_10053_10107_10050_10106_10051,searchweb201603_1,afswitch_5,single_sort_2_default&btsid=0cfa4c02-d3ea-4c21-bf9d-3e7e2b222b9f
Feature:
Digitally programmable frequency and phase
12.65 mW power consumption at 3 V
0 MHz to 12.5 MHz output frequency range
Sinusoidal, triangular, and square wave outputs
2.3 V to 5.5 V power supply
No external components required
3-wire SPI interface
Extended temperature range: −40°C to +105°C
Power-down option
10-lead MSOP package
Qualified for automotive applications
APPLICATIONS
Frequency stimulus/waveform generation
Liquid and gas flow measurement
Sensory applications: proximity, motion,
and defect detection
Line loss/attenuation
Test and medical equipment
Sweep/clock generators
Time domain reflectometry (TDR) application
comme_il_faut
ISDS205B tavsiye ederim. Sinyal jeneratoru, osiloskop, spektrum analizör bütünleşik. PC programı sayesinde IIR-FIR filtre tasarlayıp gerçek zamanlı sinyale uygulayabiliyorsun.
Tam olarak hatırlamasam da, almadan önceki araştırmalarımda içindeki sinyal üretecinin AD98xx serisinden bir sinyal üreteci ile aynı PC programını kullandığını görmüştüm.
https://www.aliexpress.com/item-img/New-INSTRUSTAR-ISDS205B-PC-Based-USB-Digital-Oscilloscope-Spectrum-Analyzer-DDS-Sweep-Data-Recorder-FREE-SHIPPING/32353150677.html?spm=2114.10010108.1000017.1.8RbP85
vedo35
Tesekkur ederimde. Benim sadece sinyal uretecine ihtiyacim var. Verdiginiz linkteki cihazin ozelliklerine baktim benim gibi amator hobi olarak ugrasanlar icin ideal bir cihaz gorunuyor. Ileride dusunebilirim. Pc ye bagli sinyal osilatoru kullanmayi simdilik dusunmuyorum.   Cunku her defasinda  laptobu acmaniz lazim. En ufak bir deney ihtiyaci icin bile laptobu acip ondan sonra o ufak deneyi yapmaniz lazim geliyor. Ben sadece el kadar bir cihazla bu isi yapmak istiyordum. Her defasinda bir laptoba bagli kalmak istemiyorum. Sirf bu yuzden Pc osilaskoba bile simdilik mesafeliyim. Ama ucuz, esnek ve sinyalin goruntusunu kayit v.s gibi  bircok esnek yanlari var tabi bu ileride dusunebilecegim bir cihaz. Yukaridaki linkte dokunmatik uretec icin gorusunuz nedir?
comme_il_faut
Daha önce dds sinyal jeneratörü bakarken notlar almıştım. İçinde hatalı kısımlar olabilir, değiştirmeden paylaşıyorum:
UDB1008s(37 dolar) fiyat-kalite olarak uygun bulunmuştur.
8MHz'e kadar dds sinyal üretir, ttl çıkışı, amplitude ayarı,duty ayarı, counter çıkışı, sweep, save-load, farklı dalga tipleri üretebilir.
* UDB1300 serisinin sinyal çıkışı iki kanallıdır. UDB1200 serisinin ADC girişi bulunur, iki adet sinyal çıkış kanalı vardır.
* AD9851 kullanan display'li moduller (40 dolar civarı) 70 Mhz'e kadar çıkış verebilmekte (sadece kare dalga veya sinus, sabit 1V) ancak opsiyonel özellikler barındırmamakta. Sadece AD9851'i üzerinde barındıran moduller satılmakta (13 dolar), bunlardan alınıp UDBlerin özelliklerine sahip bir dds sinyal jenaratoru yapılabilir.
* MWG20; UDB özelliklerine sahip, 0-20 MHz çalışıyor, ancak daha pahalı (50 dolar).
* AD98XX ve AD99xx serileri analog devices'ın dds sinyal üretmeye yönelik ürettiği çipler.
Maxim
-kendi başına çalışan cihaz alın (usb değil)
-mutlaka kutulu olsun
-220v besleme ile çalışsın
-lcd tft ekranı olsun
-ayar potanslı olsun (dokunmatik vs değil)
-pc programı üzerinden manuel frekans çizebilinsin
vedo35
Tesekkurler maxim bahsettiginiz ozellikte bana uygun fiyatta olani varmi? Biraz daha fazla odeyebilirim. Linki varsa sevinirim. Bu arada yukarida verdigim link nasil hani su dokunmatik olani?
vedo35
Arkadaslar tekrar bir sorum olacak, benim istedigim bircok degisik model sinyal generatorlerinin teknik ozelliklerini inceledigimde sinus olarak 20mhz yada 40mhz yaziyor ancak kare, ucgen ve testere dis sinyallerini en fazla 5mhz olarak verebiliyor. Bunun nedeni nedir acaba? Sinusu 20mhz yapmak digerlerine gore daha kolay ama digerlerini en fazla 5-6mhz, bunun siniri okadarmidir? Yani hepsini  20mhz verecek diye kalkipta 500-600 euro vermeye hic niyetim yok,  onun icin sordum.  Ben bu isi merak ettigim icin tekrar sizleri rahatsiz edeyim dedim.
HexfeT
Sinüsün diğer dalga şekillerine göre çok daha üst sınırlara çıkabilme sebebi ani düşen-çıkan kenarı köşesi olmaması.
