BLDC Seçelim !
Başlatan baran123, 23 Şubat 2017, 18:38:48
baran123
BLDC motor ihtiyacım için araştırma yapıyorum. Bu motorları aliexpress gibi sitelerden almak sağlıklı olur mu ?
Daha önce kullanan/bilen/duyan arkadaşlardan öneriler bekliyorum . :)
1 = https://tr.aliexpress.com/item/Goolrc-s2435-4500kv-sens-rs-z-f-r-as-z-motor-i-in-1-18-1/32679115491.html?spm=2114.010208.3.2.bQDMR2&ws_ab_test=searchweb0_0%2Csearchweb201602_5_10000073_10065_10068_10000077_10000074_10000132_10000033_10000030_119_10000167_10000026_10000175_10000126_10000129_10000023_10000123_432_10000069_10000068_10060_10062_10056_10055_10000062_10054_10000063_10059_10000120_10099_10000020_10000156_10000158_10000013_10000117_10103_10102_10000016_10000114_10096_10000111_10000056_10000059_10052_10053_10050_10107_10051_10106_10000097_10000094_10000090_10000147_10000091_10000144_10084_10000150_10000101_10083_10000100_10000011_10080_10000153_10000104_10082_10000045_10081_10110_10000108_10111_10000191_10112_10113_10000197_10114_10000089_10000086_10000179_10000083_10000042_10000135_10000080_10078_10079_10000039_10073_10000140_10070_10000036_10122_10123_10121_10126_10124_10000187%2Csearchweb201603_10%2Cafswitch_1%2CppcSwitch_5%2Csingle_sort_2_default&btsid=2be2a604-eba0-429f-8fd1-4969d59e58c3&algo_expid=37044cf6-3892-46f1-b797-5f16263866e5-0&algo_pvid=37044cf6-3892-46f1-b797-5f16263866e5
Aynı Fiyata ESC ile birlikte var
2 = https://tr.aliexpress.com/item/F02015-z-A2212-1000KV-Brushless-Outrunner-Motor-13T-30A-Speed-Controller-ESC-RC-Aircraft-4-Axis/575166816.html?spm=2114.010208.3.2.8D34XJ&ws_ab_test=searchweb0_0,searchweb201602_5_10000073_10065_10068_10000077_10000074_10000132_10000033_10000030_119_10000167_10000026_10000175_10000126_10000129_10000023_10000123_432_10000069_10000068_10060_10062_10056_10055_10000062_10054_10000063_10059_10000120_10099_10000020_10000156_10000158_10000013_10000117_10103_10102_10000016_10000114_10096_10000111_10000056_10000059_10052_10053_10050_10107_10051_10106_10000097_10000094_10000090_10000147_10000091_10000144_10084_10000150_10000101_10083_10000100_10000011_10080_10000153_10000104_10082_10000045_10081_10110_10000108_10111_10000191_10112_10113_10000197_10114_10000089_10000086_10000179_10000083_10000042_10000135_10000080_10078_10079_10000039_10073_10000140_10070_10000036_10122_10123_10121_10126_10124_10000187,searchweb201603_10,afswitch_1,ppcSwitch_5,single_sort_2_total_weight_score_desc&btsid=e67b3c77-abe1-491a-bb96-cea4abc1ac80&algo_expid=cdf03d92-f3d3-4cb5-ae81-57dc32c23f03-0&algo_pvid=cdf03d92-f3d3-4cb5-ae81-57dc32c23f03
Bu konu hakkında tavsiyelerinizi bekliyorum.
Bu motorların soketlerinin isimleri nedir acaba ? (3.5mm Banana Connector diye geçiyormuş)
Cemre.
Inrunner bir motor seçmen çalışmalarda işini kolaylaştırabilir. Outrunner motorlar (2 ve 3 numara) dıştan rotorlu yani gördüğün dış metal kılıf dönüyor. Inrunner motorlarda ise bildiğin fırçalı motorlar gibi sadece mil dönüyor.
eeburakdemir
@Cemre. hocam bldc seçerken nelere dikkat etmeliyiz bu verdiğiniz bilgilerden hariç ?
Asla pes etme...
Cemre.
Alıntı yapılan: eeburakdemir - 24 Şubat 2017, 10:24:02
Hocam zor taraftan sordunuz :)
Sensörlü kontrol yapılacaksa hall effect sensörlerin yerleşimi önem kazanıyor. Bazı motorlarda bunu ayarlayabileceğiniz imkanlar sunuluyor.
Sensörsüz kontrolde ise motorun kalitesi çok önemli olabiliyor. İyi dizayn edilmemiş bir motorda BEMF sinyali Trapezoidal'den uzaklaşacaktır. Yine PMSM için ideal sinusten çok uzak bir sinyal elde etmeniz olası.
Baran kendi sensörlü sürücüsünü geliştiriyor bildiğim kadarıyla. O anlamda sensörlü en ucuz motoru da alsa çok sıkıntı çekmez diye düşünüyorum. Sensorsuz bir motor alırsa rotor konumunu tespit edebilmek adına kendi düzeneğini kurmak durumunda kalacak.
Bir de ilan başlıklarında genelde KV cinsinden bir değer görürüz. Bu motor çalışma geriliminiz için Volt başına devir sayısını ifade ediyor. Misal 1000KV bir motor 10V ile çalıştırılırsa erişebileceği en yüksek hız 10000rpm'dir. Tabi belli başlı sınırlamalar dahilinde.
Bu tip motorlar genelde hobiciler tarafindan kullanıldığı için nominal gerilim bilgisi çoğunlukla 3S 4S gibi kaç hücreli LiPo ile çalışabileceği belirtilerek aktarılıyor.
3x3.7V = 11.1V gibi.
eeburakdemir
@Cemre. hocam verdiğiniz bilgileri inceleyeceğim ve anladığım kadarıyla daha bilmediğimiz epey terim ve anlam barındırıyor BLDC motor. Verdiğiniz bilgiler bile şimdilik yeterli sayılır hocam olmadı yine sorarım zaten çok teşekkür ederim  :)
Asla pes etme...
Z80
Harddisklerin spindle motorları işini görmez mi?
baran123
@cemre hocam sensorlu motorlar bir hayli pahali bu yuzden bir ara karakoye gitmek gerek :)
Pkelle hocam o dun aklima geldi fakat elimde bozuk hard disk yok bulursam ilk is sokecegim :)
Sensorsuz kontrol icin BEMF metodu kullaniliyor sanirim fakat asil merak ettigim yontem FOC.
Sanirim FOC da sensorsuz bir kontrol metodu.
Gelismeleri tekrar yazacagim.
Z80
CD-Rom'ların spindle motorları sensörlü BLDC motordur. Floppy'lerde de BLDC motor vardır. Aklında bulunsun.
Bilgisayarcılarda bozuk cd-rom, harddisk, floppy doludur, bedavaya bile verirler.
Cemre.
@baran123 Field Oriented Control, FOC illede sensörsüz olur diye birşey yok.
baran123
@cemre anladım hocam
@pkelle hocam pazartesi ilk iş bir tane alırım o zaman :)
