HAL Kütüphanesi ile Buton Kesmesi
Başlatan Reactionic, 27 Eylül 2017, 11:28:37
Reactionic
Merhabalar STM32F4 Disco'nun üzerindeki butonu kullanarak döngü yerine kesme ile LED yakıp söndürmeye çalışıyorum. Ama kesme için gerekli ayarlamalarda hata yapıyorum sanırım, çalışmadı bir türlü. Cevaplayacaklara şimdiden teşekkürler.
#include "stm32f4xx.h"
#include "stm32f4xx_hal.h"
void SystemClock_Config(void);
void HAL_GPIO_EXTI_Callback (uint16_t GPIO_Pin)
    if (GPIO_Pin == GPIO_PIN_0)
	HAL_NVIC_DisableIRQ(EXTI0_IRQn);
        HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_12);
	HAL_Delay(100);
        HAL_NVIC_EnableIRQ(EXTI0_IRQn);
void EXTI0_IRQHandler(void)
  HAL_NVIC_ClearPendingIRQ(EXTI0_IRQn);
  HAL_GPIO_EXTI_IRQHandler(GPIO_PIN_0);
  /* EXTI line interrupt detected */
  if(__HAL_GPIO_EXTI_GET_IT(GPIO_PIN_0) != RESET)
    __HAL_GPIO_EXTI_CLEAR_IT(GPIO_PIN_0);
    HAL_GPIO_EXTI_Callback(GPIO_PIN_0);
void SysTick_Handler(void)
    HAL_IncTick();
int main(void)
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* Configure the system clock */
  SystemClock_Config();
  /* Initialize all configured peripherals */
        __HAL_RCC_GPIOD_CLK_ENABLE();
	__HAL_RCC_GPIOA_CLK_ENABLE();
	GPIO_InitTypeDef GPIO_InitLED;
	GPIO_InitLED.Pin = GPIO_PIN_12;
	GPIO_InitLED.Mode = GPIO_MODE_OUTPUT_PP;
	GPIO_InitLED.Pull = GPIO_NOPULL;
	GPIO_InitLED.Speed = GPIO_SPEED_FREQ_HIGH;
	HAL_GPIO_Init(GPIOD, &GPIO_InitLED);
	GPIO_InitTypeDef GPIO_InitButton;
	GPIO_InitButton.Pin = GPIO_PIN_0;
	GPIO_InitButton.Mode = GPIO_MODE_IT_RISING;
	GPIO_InitButton.Pull = GPIO_PULLUP;
	GPIO_InitButton.Speed = GPIO_SPEED_FREQ_HIGH;
	HAL_GPIO_Init(GPIOA, &GPIO_InitButton);
	HAL_NVIC_SetPriority(EXTI0_IRQn, 3, 0);
	HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
static void SystemClock_Config(void)
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_OscInitTypeDef RCC_OscInitStruct;
/* Enable HSE Oscillator and activate PLL with HSE as source */
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 25;
RCC_OscInitStruct.PLL.PLLN = 336;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 7;
HAL_RCC_OscConfig(&RCC_OscInitStruct);
/* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2 clocks
dividers */
RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK |
RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5); }
GreeN
Merhaba ,
GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
Dusen kenarda interrupt olusturmak daha mantikli olur ,
  HAL_GPIO_TogglePin(GPIOD,GPIO_PIN_12);
burada calistir. Mesele ledi interrupt ile her butona bastiginda yakip sondurmek ise...
Terörü Lanetliyoruz.
