STM32F303 ADC2 Problemi
Başlatan Mucit23, 11 Şubat 2018, 18:43:33
Selamlar
STM32F303RE çipiyle bir proje geliştirmeye çalışıyorum. Projede ADC2 donanımında 0. kanaldan analog Veri okumam gerekiyor. STM32F3 de yapı genel olarak STM32F4'e benziyor. Bende daha önceki bilgilerimle ve örnekleri inceleyerek bir init kodu hazırladım. ADC+DMA kullanarak Continious modda bir Değişkene sürekli adc verisi taşımam gerekiyor.
Şöyle bir init kodu hazırladım.
void ADC_DMA_Configuration(void)
	ADC_InitTypeDef        ADC_InitStructure;
  ADC_CommonInitTypeDef  ADC_CommonInitStructure;
  GPIO_InitTypeDef       GPIO_InitStructure;
  DMA_InitTypeDef        DMA_InitStructure;
  /* Configure the ADC clock */
  RCC_ADCCLKConfig(RCC_ADC12PLLCLK_Div1);
  /* Enable ADC1 clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_ADC12, ENABLE);
  /* Enable GPIOA and GPIOC Periph clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  /* Enable DMA2 clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
  /* ADC Channels configuration */
  /* Configure ADC2 Channel0 as analog input */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 ;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* DMA configuration */
  /* DMA2 Channel1 Init Test */
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&ADC2->DR;
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&ADCConvertedValue;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = 1;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA2_Channel1, &DMA_InitStructure);
  ADC_StructInit(&ADC_InitStructure);
  /* ADC Calibration procedure */
  ADC_VoltageRegulatorCmd(ADC2, ENABLE);
  /* Insert delay equal to 10 µs */
  Delay(10);
  ADC_SelectCalibrationMode(ADC2, ADC_CalibrationMode_Single);
  ADC_StartCalibration(ADC2);
  while(ADC_GetCalibrationStatus(ADC2) != RESET );
  calibration_value_1 = ADC_GetCalibrationValue(ADC2);
  /* ADC Dual mode configuration */
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Interleave;
  ADC_CommonInitStructure.ADC_Clock = ADC_Clock_AsynClkMode;
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1;
  ADC_CommonInitStructure.ADC_DMAMode = ADC_DMAMode_Circular;
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = 10;
  ADC_CommonInit(ADC2, &ADC_CommonInitStructure);
  ADC_InitStructure.ADC_ContinuousConvMode = ADC_ContinuousConvMode_Enable;
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_ExternalTrigConvEvent = ADC_ExternalTrigConvEvent_0;
  ADC_InitStructure.ADC_ExternalTrigEventEdge = ADC_ExternalTrigEventEdge_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_OverrunMode = ADC_OverrunMode_Disable;
  ADC_InitStructure.ADC_AutoInjMode = ADC_AutoInjec_Disable;
  ADC_InitStructure.ADC_NbrOfRegChannel = 1;
  ADC_Init(ADC2, &ADC_InitStructure);
  /* ADC2 regular channel1 configuration */
  ADC_RegularChannelConfig(ADC2, ADC_Channel_1, 1, ADC_SampleTime_7Cycles5);
  /* Configures the ADC DMA */
  ADC_DMAConfig(ADC2, ADC_DMAMode_Circular);
  /* Enable the ADC DMA */
  ADC_DMACmd(ADC2, ENABLE);
  /* Enable ADC2  */
  ADC_Cmd(ADC2, ENABLE);
  /* wait for ADC1 ADRDY */
  while(!ADC_GetFlagStatus(ADC2, ADC_FLAG_RDY));
  /* Enable the DMA channel */
  DMA_Cmd(DMA2_Channel1, ENABLE);
  /* Start ADC2 Software Conversion */
  ADC_StartConversion(ADC2);
ADC2 kanal 0, PA4'e denk geliyor. Aynı zamanda DMA2 Kanal1'i yönlendirmek gerekiyor. Datashette böyle yazıyor. Buna göre yukarıdaki kodları yazdım ama yapıyı çalıştıramadım bir türlü.
Daha sonra ADC ve ve DMA1 Kanal1 ile deneme yaptım onda çalıştırdım. init kodları aynı. Sadece ADC2 yerine ADC1, DMA2Kanal1 yerine DMA1Kanal1 kullandım. Bu şekilde çalışıyor. Fakat ADC1 De de PA4'e denk gelen kanal yok. O yüzden ADC2 Kanal1'i okumam gerekiyor.
Bu konuda yorum yapabilecek olan varmı? Sabahtan beri uğraşıyorum. Çözemedim.
