Çok Kanallı Sıcaklı Sensorları EMC1822-23-24-25-43
Başlatan M.Salim GÜLLÜCE, 30 Temmuz 2020, 10:17:41
Microchipten bir ürün daha...
I²C ara yüzlü, Çok kanallı, Düşük voltajlı, Basit yarıiletken Sensorlu, DFN kılıf ve sıfırdan 125° ye kadar..
EMC1822-23-24-25-43 olmak üzere beş ayrı model ürün..
•  Measures Temperature Rate of Change Calculation with Preemptive Alert(s) Limits
•  Up to Four External Temperature Monitors:
   – 8-Lead Devices: ±1°C maximum accuracy (-20°C to +105°C TA, -40°C to +125°C TD)
   – ±1.5°C maximum accuracy (-40°C to +125°C TA, -40°C to +125°C TD)
   – 10-Lead Devices: ±1°C maximum accuracy (-20°C to +125°C TA, -40°C to +125°C TD)
•  Internal Temperature Sensor:
   – ±1°C maximum accuracy, -40°C to +125°C
•  Temperature Sensor Resolution (Internal/External): 0.125°C
•  Resistor Programmable System Shutdown Temperature
•  Configurable Alert Pins
•  Operating Voltage: 1.62V to 3.6V
•  Temperature Range: -40°C to +125°C
•  Other Features: Auto-Beta Compensation, Configurable Ideality Factor, Hottest Diode Compare, ResistanceError Correction
•  Available in 8-Lead 2x2 mm WDFN, 10-Lead 2.5x2.0 mm VDFN and 10-Lead MSOP Packages
Typical Applications
•  Temperature Sensitive Storage
•  Industrial
•  IoT for Low System Voltage
•  Portable Electronics
•  Handheld Gaming
•  Computing
•  Food Storage
https://ww1.microchip.com/downloads/en/DeviceDoc/EMC1822-23-24-25-43-Data-Sheet-DS20006048B.pdf
