16 Kanallı HV_Analog Switch
Başlatan M.Salim GÜLLÜCE, 20 Aralık 2020, 15:25:50
HV2607, HV2707, HV2708 Analog bilgi transferinde kullanılabilecek bir çip.
(No High-Voltage Bias, Low Harmonic Distortion, 16-Channel, High-Voltage Analog Switch)
Kullanım alanlarıda ilginç  ::)
Features
•  16-Channel High-Voltage Analog Switch
•  Analog Signal Voltage Up to ±100V
•  Only +5V Bias Supply Required
•  3.3V and 5V CMOS Input Logic Level
•  66 MHz Data Shift Clock Frequency
•  Ultra-Low Quiescent Current < 10 μA
•  Low Parasitic Capacitance
•  Low Harmonic Distortion
•  DC to 100 MHz Analog Small Signal Frequency
•  200 kHz to 50 MHz Large Signal Frequency
•  -76 dB Typical Off Isolation at 5.0 MHz
•  Excellent Noise Immunity
•  Cascadable Serial Data Register with Latches
•  Integrated Bleed Resistors on the Outputs (both sides for HV2707, one side for HV2708)
Application
•  Medical Ultrasound Imaging
•  Non-Destructive Testing (NDT) Metal Flaw Detection
•  Piezoelectric Transducer Drivers
•  Inkjet Printer Head
•  Optical MEMS Module
https://ww1.microchip.com/downloads/en/DeviceDoc/20006390B.pdf
Örnek uygulama.. :D
