HV Input Integrated Switch Step-Down Regulator
Başlatan M.Salim GÜLLÜCE, 19 Ocak 2021, 02:41:31
SOT23-6 kılıfta Yüksek voltaj (30-36V) girişli 1000-1200mA çıkış verebilen Buck (Step-Down) regülatör.
Features:
•  Up to 96% Typical Efficiency
•  Input Voltage Range: -  4.0V to 30V (MCP16301)-  4.7V to 36V (MCP16301H)
•  Output Voltage Range: 2.0V to 15V
•  2% Output Voltage Accuracy
•  Passes Automotive AEC-Q100 Reliability Testing
•  Integrated N-Channel Buck Switch: 460 m
•  Minimum 600 mA Output Current Over All Input Voltage Range (See Figure 2-6 for Maximum Output Current vs. VIN):
-  Up to 1A output current at 3.3V, 5V and 12V VOUT, SOT-23 package at +25°C ambient temperature
•  500 kHz Fixed Frequency
•  Adjustable Output Voltage
•  Low Device Shutdown Current
•  Peak Current Mode Control
•  Internal Soft-Start
•  Internal Compensation
•  Stable with Ceramic Capacitors
•  Cycle-by-Cycle Peak Current Limit
•  Undervoltage Lockout (UVLO): 3.5V
•  Overtemperature Protection
•  Available Package: SOT-23-6
Applications:
•  PIC® Microcontroller and dsPIC® Digital Signal Controller Bias Supply
•  24V Industrial Input DC-DC Conversion
•  Set-Top Boxes
•  DSL Cable Modems
•  Automotive
•  Wall Cube Regulation
•  SLA Battery-Powered Devices
•  AC-DC Digital Control Power Source
•  Power Meters
•D2 Package Linear Regulator Replacement-See Figure 5-2
•Consumer
•  Medical and Health Care
•  Distributed Power Supplies
https://ww1.microchip.com/downloads/en/DeviceDoc/MCP16301-Family-Data-Sheet-DS20005004E.pdf
Melih1802
Veya XL7026 SOP-8 KILIF:
16-90V İNPUT Çıkış gerilimi ayarlanabilir.
600mA 150kHz
https://pdf.ic37.com/ETC/XL7026_datasheet_13551998/XL7026_7.html
