250mA 60MHz Power Opamp: LT1207
Başlatan M.Salim GÜLLÜCE, 22 Kasım 2023, 15:54:16
Yüksek akım çıkışlı Dual Opamp: LT1207
FEATURES:
- 250mA Minimum Output Drive Current
- 60MHz Bandwidth, AV = 2, R L = 100Ω
- 900V/μs Slew Rate, AV = 2, RL = 50Ω
- 0.02% Differential Gain, AV = 2, RL = 30Ω
- 0.17° Differential Phase, AV = 2, RL = 30Ω
- High Input Impedance: 10MΩ
- Shutdown Mode: IS < 200μA per Amplifier
- Stable with CL = 10,000pF
APPLICATIONS:
- ADSL/HDSL Drivers
- Video Amplifiers
- Cable Drivers
- RGB Amplifiers
- Test Equipment Amplifiers
- Buffers
data-sheets/lt1207.pdf
