CCS PIC C de lcd uçları
Başlatan respected, 29 Mart 2006, 13:03:32
respected
Aşağıdaki kodlar ile istediğiniz pinleri data ya da kontrol ucu olarak kullanabilirsiniz.
LCD_RW   0 derseniz LCD nin RW ucunu şaseye bağlamalısınız. Verdiğim bu kodları kaydedip LCD  INC dosyası olarak kullanacaksınız.
#define LCD_DB4   PIN_B4
#define LCD_DB5   PIN_B5
#define LCD_DB6   PIN_B6
#define LCD_DB7   PIN_B7
#define LCD_E     PIN_B3
#define LCD_RS    PIN_B2
#define LCD_RW    0
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
#define USE_LCD_RW   0
#define lcd_type 2        // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
int8 const LCD_INIT_STRING[4] =
0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
0xc,                    // Display on
1,                      // Clear display
6                       // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note:  !! converts an integer expression
// to a boolean (1 or 0).
output_bit(LCD_DB4, !!(nibble & 1));
output_bit(LCD_DB5, !!(nibble & 2));
output_bit(LCD_DB6, !!(nibble & 4));
output_bit(LCD_DB7, !!(nibble & 8));
delay_cycles(1);
output_high(LCD_E);
delay_us(2);
output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine.  For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.
#ifdef USE_LCD_RW
int8 lcd_read_nibble(void)
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_cycles(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
return(retval);
#endif
// Read a byte from the LCD and return it.
#ifdef USE_LCD_RW
int8 lcd_read_byte(void)
int8 low;
int8 high;
output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4) | low);
#endif
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_LCD_RW
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60);
#endif
if(address)
  output_high(LCD_RS);
  output_low(LCD_RS);
delay_cycles(1);
#ifdef USE_LCD_RW
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
#endif
output_low(LCD_E);
delay_ms(15);
for(i=0 ;i < 3; i++)
   lcd_send_nibble(0x03);
   delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
   lcd_send_byte(0, LCD_INIT_STRING);
   // If the R/W signal is not used, then
   // the busy bit can't be polled.  One of
   // the init commands takes longer than
   // the hard-coded delay of 60 us, so in
   // that case, lets just do a 5 ms delay
   // after all four of them.
   #ifndef USE_LCD_RW
   delay_ms(5);
   #endif
void lcd_gotoxy(int8 x, int8 y)
int8 address;
if(y != 1)
  address = lcd_line_two;
  address=0;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
switch(c)
   case '\f':
     lcd_send_byte(0,1);
     delay_ms(2);
     break;
   case '\n':
      lcd_gotoxy(1,2);
      break;
   case '\b':
      lcd_send_byte(0,0x10);
      break;
   default:
      lcd_send_byte(1,c);
      break;
#ifdef USE_LCD_RW
char lcd_getc(int8 x, int8 y)
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7));
value = lcd_read_byte();
output_low(lcd_RS);
return(value);
#endif
zafzaf82
Bu da başka bi kod
//// FLEX_LCD420.C ////
//// Driver for common 4x20 LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// \c Cursor on ////
//// \d Blink character ////
//// \1 Custom character DegC ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
//// lcd_getc(x,y) Returns character at position x,y on LCD ////
//// (C) Copyright 1996,1997 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
// These pins are for the PIC development board:
// B1 enable
// B2 rs
// B3 rw
// B4 D4
// B5 D5
// E1 D6
// E0 D7
#define LCD_E PIN_B1
#define LCD_RW PIN_B3
#define LCD_DB6 PIN_E1
#define LCD_DB7 PIN_E0
// Clear and home
#define LCD_CLR_DISP 0x01 // Clear screen, home cursor, unshift display
#define LCD_RETURN_HOME 0x02 // Home cursor, unshift display
// Set entry mode: display shift on/off, dec/inc cursor move direction
#define LCD_ENTRY_DEC 0x04 // Display shift off, dec cursor move dir
#define LCD_ENTRY_DEC_SHIFT 0x05 // Display shift on, dec cursor move dir
#define LCD_ENTRY_INC 0x06 // Display shift off, inc cursor move dir
#define LCD_ENTRY_INC_SHIFT 0x07 // Display shift on, inc cursor move dir
// Display on/off, cursor on/off, blinking char at cursor position
#define LCD_DISP_OFF 0x08 // Display off
#define LCD_DISP_ON 0x0C // Display on, cursor off
#define LCD_DISP_ON_BLINK 0x0D // Display on, cursor off, blink char
#define LCD_DISP_ON_CURSOR 0x0E // Display on, cursor on
#define LCD_DISP_ON_CURSOR_BLINK 0x0F // Display on, cursor on, blink char
// Move cursor/shift display
#define LCD_MOVE_CURSOR_LEFT 0x10 // Move cursor left (decrement)
#define LCD_MOVE_CURSOR_RIGHT 0x14 // Move cursor right (increment)
#define LCD_MOVE_DISP_LEFT 0x18 // Shift display left
#define LCD_MOVE_DISP_RIGHT 0x1C // Shift display right
// Function set: set interface data length and number of display lines
#define LCD_FUNCTION_4BIT_1LINE 0x20 // 4-bit interface, single line, 5x7 dots
#define LCD_FUNCTION_4BIT_2LINES 0x28 // 4-bit interface, dual line, 5x7 dots
#define LCD_FUNCTION_8BIT_1LINE 0x30 // 8-bit interface, single line, 5x7 dots
#define LCD_FUNCTION_8BIT_2LINES 0x38 // 8-bit interface, dual line, 5x7 dots
#define LCD_CGRAM_BASE_ADDR 0x40 // Set the CGRAM address
#define LCD_DDRAM_BASE_ADDR 0x80 // Set the DDRAM address
// Address positions
#define LCD_LINE_1 0x80 // Position of start of line 1
#define LCD_LINE_2 0xC0 // Position of start of line 2
#define LCD_LINE_3 0x94 // Position of start of line 3
#define LCD_LINE_4 0xD4 // Position of start of line 4
#define LCD_DEGREE_CHAR 0x00 // Ascii 00
BYTE const LCD_INIT_STRING[4] = {
LCD_FUNCTION_4BIT_2LINES | (lcd_type << 2), // Set mode: 4-bit, 2 lines, 5x7 dots
LCD_DISP_ON,
LCD_CLR_DISP,
LCD_ENTRY_INC };
BYTE const LCD_CUSTOM_CHARS[] = {
0x1C,0x14,0x1C,0x00,0x00,0x00,0x00,0x00, // DegC
0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F, // Not used
0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F }; // Not used
BYTE lcd_line;
BYTE lcd_read_nibble() {
BYTE retval;
retval = 0;
output_high(LCD_E);
delay_cycles(1);
output_low(LCD_E);
return(retval);
BYTE lcd_read_byte() {
BYTE low,high;
delay_cycles(1);
return((high << 4) | low);
void lcd_send_nibble( BYTE n ) {
output_bit(LCD_DB4, !!(n & 1));
output_bit(LCD_DB5, !!(n & 2));
output_bit(LCD_DB6, !!(n & 4));
output_bit(LCD_DB7, !!(n & 8));
delay_cycles(1);
output_high(LCD_E);
delay_us(2);
output_low(LCD_E);
void lcd_send_byte( BYTE address, BYTE n ) {
output_low(LCD_RS);
while (bit_test(lcd_read_byte(),7)); // wait until busy flag is low
if (address)
output_low(LCD_RS);
delay_cycles(1);
output_low(LCD_RW);
delay_cycles(1);
output_low(LCD_E);
void lcd_init() {
BYTE i;
lcd_line = 1;
output_low(LCD_RS);
output_low(LCD_RW);
output_low(LCD_E);
delay_ms(15);
for (i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for (i=0;i<=sizeof(LCD_INIT_STRING);++i)
lcd_send_byte(0, LCD_INIT_STRING[i]);
void lcd_init_custom_chars() {
BYTE i;
lcd_send_byte(0,LCD_CGRAM_BASE_ADDR);
for (i=0;i<64;i++) {
lcd_send_byte(1,LCD_CUSTOM_CHARS[i]);
delay_ms(2);
void lcd_gotoxy( BYTE x, BYTE y ) {
BYTE address;
switch(y) {
case 1 : address=LCD_LINE_1; break;
case 2 : address=LCD_LINE_2; break;
case 3 : address=LCD_LINE_3; break;
case 4 : address=LCD_LINE_4; break;
address+=x-1;
lcd_send_byte(0,0x80 | address);
void lcd_putc( char c ) {
switch(c) {
case '\f' : lcd_send_byte(0,LCD_CLR_DISP);
lcd_line=1;
delay_ms(2); break;
case '\n' : lcd_gotoxy(1,++lcd_line); break;
case '\b' : lcd_send_byte(0,LCD_MOVE_CURSOR_LEFT); break;
case '\c' : lcd_send_byte(0,LCD_DISP_ON_CURSOR); break;
case '\d' : lcd_send_byte(0,LCD_DISP_ON_BLINK); break;
case '\1' : lcd_send_byte(1,LCD_DEGREE_CHAR); break;
default : lcd_send_byte(1,c); break;
char lcd_getc( BYTE x, BYTE y ) {
char value;
lcd_gotoxy(x,y);
output_low(LCD_RS);
return(value);
Mikroişlemci bi araçtır, amaç değil.....
alikgul
