program hatası
Başlatan taless, 27 Nisan 2006, 17:03:58
taless
selam..
arkadaşlar devreyi proteusta kuruyorum.simulasyonunu yapıyorum fakat hata veriyor.hata mesajı şöyle:
Revision: <NONE>
Author:   <NONE>
Created:  17/02/05
Modified: 27/04/06
Compiling source files...
Build completed OK.
Compiling netlist...
Linking netlist...
Partition analysis...
Simulating partition 1 [7B4228CE]...
Animation started sucessfully...
PROSPICE Release 6.2 SP0 (C) Labcenter Electronics 1993-2002.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
Net VDD taken as alias for VCC
Net VSS taken as alias for GND
Reading SPICE models...
Building circuit...
Instantiating SPICE models...
[U1] PIC16 model release 6.01.00 simulating PIC1684 device.
[U1] Loaded 64 bytes of persistent EEPROM data.
[U1] Loading HEX file '..\..\Documents and Settings\ARİSTOTALESS\Desktop\bitti\BBSPD14.HEX'.
FATAL: [U1] Program or EEPROM data has invalid address [4000] for this device
Real Time Simulation failed to start
Real Time Simulation FAILED.
PROGRAM İSE ŞU ŞEKİLDE:
; 'e‘¬Œvƒ\[ƒX bb_speed.asm 1.4
; for PIC16F84@20MHz
; –{ƒvƒÂƒOƒ‰ƒ€‚̓gƒCƒKƒ"‚Å"­ŽÃ‹Â‚³‚ê‚éBB'e‚̏‰‘¬‚¨‚æ‚јAŽÃ‹Â‘¬"xԻ'èŠí—p‚Å‚·B
; ‚Ü‚½‚Ü‚½‚Ü‚½—á‚Ì‚²‚Æ‚­–{ƒ\[ƒX‚͏HŒŽÂ‚ÃŒPA.EXEŠg'£ƒCƒ"ƒXƒgƒ‰ƒNƒVƒ‡ƒ"‚ğŽg—p‚µ‚Ä
; ‚¨‚è‚Ü‚·‚Ì‚Å‚ ‚µ‚©‚炸B   2000.11 (c) RUU
; •ÏX—š—ğ
;      2002.04   (1.4) Ի'èÂ¸"x‚ÌŒüÃ£(ƒJƒEƒ"ƒgŽüŠú=1.8us‚ɕύX)
;      2002.02   (1.3) Ի'èÂ¸"x‚ÌŒüÃ£(ƒJƒEƒ"ƒgŽüŠú=3.2us‚ɕύX)
;      2002.02 (1.2) ˜AŽÃ‹Â‘¬"x‚Ì‘ª'è‹@"\'ljÁA‚»‚Ì‘¼‰ü—ǁB
;      2000.12 (1.1) ƒvƒŠƒXƒP[ƒ‰‚ğŽg—p‚µ‚ăJƒEƒ"ƒgŽüŠú‚ğ12.8us‚É‚·‚éB
;                 Â‚±‚ê‚É‚æ‚èTMR0Š„‚èžÂ‚İ‚ğ‚â‚ß‚Ämain"à‚ÅŒo‰ßŽžÂŠÃ”ƒJƒEƒ"ƒg‚ɕύXB
;      2000.11 (1.0) Ã…Â‰Â‚̃o[ƒWƒ‡ƒ"
         .include   16F84.h
         .osc      hs
         .wdt      off
         .pwrt      on
         .protect   off
PT1         equ      ra.3      ; "üŒû‘¤ƒtƒHƒgƒgƒ‰
PT2         equ      ra.4      ; oŒû‘¤
CNT_MIN      equ      45         ; Ã…'áƒJƒEƒ"ƒg'l = 45 (ŒvԻÃ…‘å 987m/s)
CNT_MAX0   equ      64         ; ˜AŽÃ‹ÂƒJƒEƒ"ƒgÃ…‘å(high byte) = 4000h(Ã…‘å 5.24•b)
WAIT_CNT   equ      162         ; 100us‚ÌwaitƒJƒEƒ"ƒg
BB_MIN      equ      10         ; BB'eÃ…'ád—Ê(=0.10g)
BB_MAX      equ      50         ; BB'eÃ…‘åd—Ê(=0.50g)
BB_CNT_MIN   equ      2         ; Ã…'á˜AŽÃ‹'e"
BB_CNT_MAX   equ      20         ; Ã…‘å˜AŽÃ‹'e"
         org      0ch
res         ds      1         ; ƒŠƒUƒ‹ƒgƒR[ƒh
SW2         equ      res.0      ;    Â•\ŽÂ¦Ã˜Â‚è‘ւ¦/UP
SW3         equ      res.1      ;    'ed—ÊSET/DOWN
SW1         equ      res.2      ;    RESET/OK
led_opt      ds      1         ; LED•\ŽÂ¦ÂƒIƒvƒVƒ‡ƒ" Šebit=1‚Å"_""
MSLED      equ      led_opt.0   ;    m/s•\ŽÂ¦
JLED      equ      led_opt.1   ;    J•\ŽÂ¦
P1         equ      led_opt.2   ;    Â¬""_1Œ…–Ú
P2         equ      led_opt.3   ;    Â¬""_2Œ…–Ú
bcdbuf      ds      5         ; BCD(10i)Ši"[ƒGƒŠƒA 5bytes
disp_buf   ds      1         ; •\ŽÂ¦Â—pƒoƒbƒtƒ@
keta_cnt   ds      1         ; •\ŽÂ¦ÂŒÂ…ƒJƒEƒ"ƒ^
count      ds      2         ; PT1-PT2'ʉߎžÂŠÃ”ƒJƒEƒ"ƒ^(16bit)
work      ds      1         ; ˆêŽžŽg—pƒ[ƒN
cnt         ds      1         ; 32bit‰‰ŽZ‚¨‚æ‚Ñwait—pƒJƒEƒ"ƒ^
xd64      ds      4         ; 64bit‰‰ŽZ—p(xd64+xd32=64bit)
xd32      ds      4         ; 32bit‰‰ŽZ—p
xs32      ds      4         ; V
y32         ds      4         ; V
bb_weight   ds      1         ; BB'ed—Ê(*100g)
bb_cnt_num   ds      1         ; ˜AŽÃ‹Â‘ª'è'e"
bb_cnt      ds      1         ; ˜AŽÃ‹'e"ƒJƒEƒ"ƒ^
wsave      ds      1         ; WƒŒƒWƒXƒ^‘Ş"ğ
stsave      ds      1         ; STATUS‘Ş"ğ
         eeorg   0
         eedata   25,10      ; EEPROMÂ‰ÂŠÃº'l(BB'ed—Ê=0.25g, ˜AŽÃ‹Â‘ª'è'e"=10)
         eedata   'BB_Speed 1.4 by RUU -- http://www.mars.dti.ne.jp/~ogura/'
         org      0
         goto   main
         org      4
         goto   intproc
;;;;;;;;;;;; Š„‚èžÂ‚İÂˆÂ— intproc  ;;;;;;;;;;;;
intproc                                 ; ˜AŽÃ‹Â‘¬"xԻ'è‚̃JƒEƒ"ƒgƒAƒbƒv—pŠ„‚èžÂ‚İÂˆÂ—
         mov      wsave,w                  ; WƒŒƒWƒXƒ^‘Ş"ğ
         mov      stsave,status                  ; STATUS‘Ş"ğ
         sub      tmr0,#100 - 2            ; tmr0Ã„İ'è(3.2us*100=0.32msŠÔŠu‚ÅŠ„‚荞‚İ)
         clrb   t0if
         incsz   count[1]               ; ƒJƒEƒ"ƒgƒAƒbƒv
         goto   int_end
         inc      count[0]               ; High byte‚ÖŒ…Ã£Â‚ª‚è
int_end
         mov      status,stsave            ; STATUS–ß‚·
         mov      w,wsave                  ; W–ß‚·
         retfie                        ; •œ‹A
;;;;;;;;;;;; main ;;;;;;;;;;;;
main
         ;; Â‰ÂŠÃºÂ‰Â»
init
         ;; I/Oƒ|[ƒgİ'è
         mov      !ra,#00011000b            ; PT1,PT2‚ğIN‚ɁASEG1`3select‚ğOUT‚É
         mov      !rb,#00000111b            ; RB0`2(SW)‚ğ"ü—́ARB3,RB4`7(BCDo—Í)‚ğo—Í‚É
         clr      ra
         clr      rb
         ;; OPTIONƒŒƒWƒXƒ^İ'è
         setb   rp0
         mov      option,#00000011b         ; ƒ|[ƒgBƒvƒ‹ƒAƒbƒvAƒvƒŠƒXƒP[ƒ‰(1:16)
         clrb   rp0
         ;; Š„‚èžÂ‚İİ'è
         mov      intcon,#00100000b         ; ƒ^ƒCƒ}0Š„‚èžÂ‚İ‹–‰ÂAƒOƒ[ƒoƒ‹Š„‚èžÂ‚İ‹֮~
         ;; EEPROMƒf[ƒ^(BB'eŽÂ¿Â—Ê,˜AŽÃ‹Â‘ª'è'e")ƒ[ƒh
         clr      eeadr
         call   eeprom_read
         mov      bb_weight,eedata
         inc      eeadr
         call   eeprom_read
         mov      bb_cnt_num,eedata
         call   get_key                  ; SW1‚ğ‰Ÿ‚µ‚È‚ª‚ç"dŒ¹ON‚È‚ç˜AŽÃ‹Â‘ª'胂[ƒh‚Ö
         jb      SW1,mode_single
         ;; -------- ˜AŽÃ‹Â‘¬"xԻ'胂[ƒh --------
mode_series
         clr      count[0]               ; ƒJƒEƒ"ƒ^ƒNƒŠƒA
         clr      count[1]
         mov      bb_cnt,#1
         clr      res                     ; ƒŠƒUƒ‹ƒgƒR[ƒhƒNƒŠƒA
loop_0
         jnb      PT1,keychk_0            ; 'e"­ŽÃ‹?
         mov      tmr0,#155               ; TMR0Â‰ÂŠÃºİ'è(100ƒJƒEƒ"ƒg=0.32ms)
         setb   gie                     ; ƒOƒ[ƒoƒ‹Š„‚èžÂ‚İ‹–‰Â
         goto   strt_count_0            ; 'ʉߎžÂŠÃ”‚̃JƒEƒ"ƒgŠJŽn
keychk_0
         call   get_key                  ; SW3‚ª‰Ÿ‚³‚ꂽ‚ç˜AŽÃ‹"İ'è‚ğs‚¤
         jb      SW3,loop_0
         clrb   gie
wait_off_0
         call   get_key
         jnb      SW3,wait_off_0            ; SW3‚ª—£‚³‚ê‚é‚Ü‚Å‘Ò‚Â
         call   set_bb_count
         goto   mode_series
strt_count_0                           ; ˜AŽÃ‹"‚̃JƒEƒ"ƒg
         jb      PT2,next_loop            ; 'e‚Ì'ʉߑ҂¿
         cja      count[0],#CNT_MAX0,err_0   ; Œo‰ßŽžÂŠÃ”ƒ`ƒFƒbƒN
         goto   strt_count_0
next_loop
         jnb      PT1,chk_count_0            ; ŽÂŸÂ‚ÃŒ'e‘Ò‚¿
         inc      bb_cnt
         cje      bb_cnt,bb_cnt_num,end_count_0   ; Ի'è˜AŽÃ‹"‚É'B‚µ‚½‚çƒJƒEƒ"ƒgI—¹
         goto   strt_count_0
chk_count_0
         goto   next_loop
end_count_0
         ;; ˜AŽÃ‹Â‘¬"x("­/sec)•\ŽÂ¦
         clrb   gie
         clr      xd32[0]
         mov      xd32[1],#04h            ; xd32=312500
         mov      xd32[2],#0c4h
         mov      xd32[3],#0b4h
         clr      y32[0]                  ; y32=˜AŽÃ‹"
         clr      y32[1]
         clr      y32[2]
         mov      y32[3],bb_cnt_num
         call   mul64                  ; xd32=312500*˜AŽÃ‹"
         clr      y32[0]                  ; y32=count
         clr      y32[1]
         mov      y32[2],count[0]
         mov      y32[3],count[1]
         call   div32                  ; "­/sec(*100)=312500*˜AŽÃ‹"/count
         call   conv_bcd
         mov      fsr,#bcdbuf
         mov      led_opt,#1               ; 'PˆÊ="­/sec
         call   disp_num
         jnb      SW3,wait_off_0            ; SW3‚ª‰Ÿ‚³‚ꂽ‚ç˜AŽÃ‹"İ'è‚ğs‚¤
         goto   mode_series
err_0
         clrb   gie
         call   disp_err
         goto   mode_series
         ;; -------- 'P"­E'e‘¬‘ª'胂[ƒh --------
mode_single
         clr      count[1]
loop
         jb      PT1,strt_count            ; 'e"­ŽÃ‹?
keychk
         call   get_key                  ; SW3‚ª‰Ÿ‚³‚ꂽ‚çBB'ed—ʐİ'è‚ğs‚¤
         jb      SW3,loop
wait_off
         call   get_key
         jnb      SW3,wait_off            ; SW3‚ª—£‚³‚ê‚é‚Ü‚Å‘Ò‚Â
         call   set_weight
         goto   loop
strt_count                              ; 'ʉߎžÂŠÃ”‚̃JƒEƒ"ƒg
         jb      PT2,end_count            ; 2
         inc      count[1]               ; 1
         snz                           ; 1(2)
         inc      count[0]               ; 1
         snz                           ; 1(2)
         goto   err                     ; (1)   ÂƒJƒEƒ"ƒ^ƒI[ƒo[ƒtƒ[
         goto   strt_count               ; 2      ÂŒv9cycle=1.8us
end_count
         cjne   count[0],#0,disp_ms         ; ƒJƒEƒ"ƒg'l‚Ì"͈̓`ƒFƒbƒN
         cjb      count[1],#CNT_MIN,err
         ;; ‘¬"x(m/s)•\ŽÂ¦
disp_ms
         clr      xd32[0]                  ; xd32=4444444
         mov      xd32[1],#043h
         mov      xd32[2],#0d1h
         mov      xd32[3],#01ch
         clr      y32[1]
         mov      y32[2],count[0]
         mov      y32[3],count[1]
         call   div32                  ; m/s(*100)=4444444/count
         call   conv_bcd
         mov      fsr,#bcdbuf
         mov      led_opt,#1               ; 'PˆÊ=m/s
         call   disp_num
         jnb      SW1,mode_single
         jnb      SW2,disp_j
         call   set_weight
         goto   disp_ms
         ;; ƒpƒ[(J)•\ŽÂ¦
disp_j
         clr      xd32[0]                  ; xd32=count
         clr      xd32[1]
         mov      xd32[2],count[0]
         mov      xd32[3],count[1]
         clr      y32[1]
         mov      y32[2],count[0]
         mov      y32[3],count[1]
         call   mul64                  ; xd32=count^2
         mov      xs32[0],xd32[0]            ; xd32‚ğ‘Ò"ğ
         mov      xs32[1],xd32[1]
         mov      xs32[2],xd32[2]
         mov      xs32[3],xd32[3]
         clr      xd32[0]                  ; xd32=987654
         mov      xd32[1],#00fh
         mov      xd32[2],#012h
         mov      xd32[3],#006h
         clr      y32[0]                  ; y32=bb_weight
         clr      y32[1]
         clr      y32[2]
         mov      y32[3],bb_weight
         call   mul64                  ; xd32=987654*bb_weight
         mov      y32[0],xs32[0]            ; y32=count^2
         mov      y32[1],xs32[1]
         mov      y32[2],xs32[2]
         mov      y32[3],xs32[3]
         call   div32                  ; J(*100)=(987654*bb_weight)/(count^2)
         call   conv_bcd
         mov      fsr,#bcdbuf
         mov      led_opt,#2               ; 'PˆÊ=J
         call   disp_num
         jnb      SW1,mode_single
         jnb      SW2,disp_ms
         call   set_weight
         goto   disp_j
err
         call   disp_err
         goto   mode_single
;;;;;;;;;;;; disp_err ;;;;;;;;;;;;;;
disp_err                                    ; ƒGƒ‰[i'0.00' ‚ğ•\ŽÂ¦A'PˆÊÃ""j
         clr      xd32[0]
         clr      xd32[1]
         clr      xd32[2]
         clr      xd32[3]
         call   conv_bcd
         mov      fsr,#bcdbuf
         clr      led_opt
         call   disp_num
         ret
;;;;;;;;;;;; set_weight ;;;;;;;;;;;;;;
set_weight                              ; BB'e‚̏d—ʐİ'è‚ğs‚¤
         clr      xd32[0]
         clr      xd32[1]
         clr      xd32[2]
         mov      xd32[3],bb_weight
         call   conv_bcd
         mov      fsr,#bcdbuf
         mov      led_opt,#3               ; 'PˆÊ=g
         call   disp_num
         jnb      SW1,write_weight
         jnb      SW2,up_cnt
down_cnt
         cje      bb_weight,#BB_MIN,set_weight
         dec      bb_weight
         goto   set_weight
up_cnt
         cje      bb_weight,#BB_MAX,set_weight
         inc      bb_weight
         goto   set_weight
write_weight                           ; EEPROM‚ɏ‘‚«žÂ‚Ş
         clr      eeadr
         mov      eedata,bb_weight
         call   eeprom_write
         ret
;;;;;;;;;;;; set_bb_count ;;;;;;;;;;;;;;
set_bb_count                           ; ˜AŽÃ‹Â‘ª'莞‚Ì'e"İ'è‚ğs‚¤
         clr      xd32[0]
         clr      xd32[1]
         clr      xd32[2]
         mov      xd32[3],bb_cnt_num
         clr      y32[0]
         clr      y32[1]
         clr      y32[2]
         mov      y32[3],#100
         call   mul64
         call   conv_bcd
         mov      fsr,#bcdbuf
         mov      led_opt,#3               ; 'PˆÊ="­
         call   disp_num
         jnb      SW1,write_count
         jnb      SW2,up_cnt0
down_cnt0
         cje      bb_cnt_num,#BB_CNT_MIN,set_bb_count
         dec      bb_cnt_num
         goto   set_bb_count
up_cnt0
         cje      bb_cnt_num,#BB_CNT_MAX,set_bb_count
         inc      bb_cnt_num
         goto   set_bb_count
write_count                              ; EEPROM‚ɏ‘‚«žÂ‚Ş
         mov      eeadr,#1
         mov      eedata,bb_cnt_num
         call   eeprom_write
         ret
;;;;;;;;;;;; conv_bcd ;;;;;;;;;;;;;;
conv_bcd                              ; xd32‚ğBCD•ÏŠ·‚µ‚Äbcdbuf(5Œ…)‚ÉŠi"[‚·‚é
         mov      fsr,#bcdbuf+4            ; 'Fxd32,xs32,y32‚¢‚¸‚ê‚à•ÏX‚³‚ê‚é
         clr      y32[0]
         clr      y32[1]
         clr      y32[2]
         mov      y32[3],#10               ; y32 = 10
conv_loop
         call   div32                  ; xd32Â€10‚Ì—]‚è‚ğbcdbuf‚Ì5Œ…–Ú‚©‚ç‹tÂ‡Â‚Ɋi"[
         mov      indirect,xs32[3]
         cje      fsr,#bcdbuf,conv_end      ; 5Œ…•ª•ÏŠ·
         dec      fsr
         goto   conv_loop
conv_end
         ret
;;;;;;;;;;;; get_key ;;;;;;;;;;;;;;
get_key
         mov      res,rb
         and      res,#00000111b
         ret
get_key2
         mov      !rb,#00000111b            ; RB0`2(SW1`3)‚ğ"ü—͂ɐ؂è‘ւ¦
         mov      cnt,#10                  ; SW"ü—̓|[ƒgˆÀ'è‚Ì‚½‚ß‚ÌWait
         call   wait100
         mov      res,rb
         and      res,#00000111b
         mov      !rb,#00000000b            ; RB0`2(LED)‚ğo—Í‚É‚·‚é
         ret
;;;;;;;;;;;; disp_num ;;;;;;;;;;;;;;
disp_num                              ; fsr‚©‚ç5Œ…•ª‚ÌBCD(3Œ…+Â¬""_ˆÈ‰º2Œ…)‚ğ—Lο3Œ…‚Å•\ŽÂ¦Â‚·‚é
         and      led_opt,#00000011b
         cjne   indirect,#0,disp_3_0      ; Â¬""_ˆÊ'uŒˆ'è
         inc      fsr
         cje      indirect,#0,disp_1_2
disp_2_1
         setb   P2
         goto   disp_3_0
disp_1_2
         setb   P1
         inc      fsr
disp_3_0
         clc
         mov      keta_cnt,#1
disp_loop                              ; 3Œ…•ª•\ŽÂ¦
         mov      disp_buf,indirect
         swap   disp_buf
         or      disp_buf,led_opt
         clr      ra
         mov      rb,disp_buf
         mov      ra,keta_cnt
         mov      cnt,#50
         call   wait100
         jb      keta_cnt.2,key_chk
         inc      fsr
         rl      keta_cnt
         goto   disp_loop
key_chk                                 ; SW‰Ÿ‰º‚ŃŠƒ^[ƒ"‚·‚é
         clr      ra
         call   get_key2
         cjne   res,#07h,disp_end
         sub      fsr,#2
         goto   disp_3_0
disp_end
         mov      work,res
wait_key_off
         call   get_key
         cjne   res,#07h,wait_key_off
         mov      res,work               ; Œ‹‰Ê‚Íres‚É"ü‚Á‚Ä‚¢‚é
         clr      ra
         clr      rb
         ret
;;;;;;;;;;;; div32 ;;;;;;;;;;;;;;
div32                                 ; xd32 Â€ y32 ‚̏¤‚ğ xd32‚ɁA—]‚è‚ğxs32‚ÉŠi"[‚·‚é
         clr      xs32[0]
         clr      xs32[1]
         clr      xs32[2]
         clr      xs32[3]
         mov      cnt,#32
div32_loop
         clc                           ; ƒLƒƒƒŠ[‚ğƒNƒŠƒA
         rl      xd32[3]                  ; xd32<<1 bitƒVƒtƒg
         rl      xd32[2]
         rl      xd32[1]
         rl      xd32[0]
         rl      xs32[3]                  ; Œ…‚ ‚Ó‚ê‚Íxs32‚É"[‚ß‚é
         rl      xs32[2]
         rl      xs32[1]
         rl      xs32[0]
         mov      W,y32[0]               ; xs32 >= yd32‚©?
         subwf   xs32[0],0
         jnc      div32_nxt
         jnz      div32_sub
         mov      W,y32[1]
         subwf   xs32[1],0
         jnc      div32_nxt
         jnz      div32_sub
         mov      W,y32[2]
         subwf   xs32[2],0
         jnc      div32_nxt
         jnz      div32_sub
         mov      W,y32[3]
         subwf   xs32[3],0
         jnc      div32_nxt
div32_sub                              ; then xs32 = xs32 - y32
         call   sub32
         setb   xd32[3].0               ; xd32[3].0‚̃rƒbƒg‚𗧂Ăé
div32_nxt                              ; else
         djnz   cnt,div32_loop            ; 32bit•ªƒ‹[ƒv
         ret
;;;;;;;;;;;; sub32 ;;;;;;;;;;;;;;
sub32                                 ; xs32 ‚©‚ç y32 ‚ğŒ¸ŽZ‚µAŒ‹‰Ê‚ğxs32‚ÉŠi"[‚·‚é
         sub      xs32[3],y32[3]            ; xs-y [3] Ã…IŒ…‚ÌŒvŽZ
         jc      sub32_2                  ; Œ‹‰Ê‚ªÂ³Â‚Ȃç[2]Œ…ŒvŽZ‚Ö
         sub      xs32[2],#1               ; •‰‚È‚ç‘O‚ÌŒ…‚©‚ç1ˆø‚­(Žc"O‚È‚ª‚çdecf‚ÍŽg‚¦‚È‚¢)
         jc      sub32_2
         sub      xs32[1],#1
         jc      sub32_2
         dec      xs32[0]
sub32_2
         sub      xs32[2],y32[2]            ; [2]Œ…‚ÌŒvŽZ
         jc      sub32_1
         sub      xs32[1],#1
         jc      sub32_1
         dec      xs32[0]
sub32_1
         sub      xs32[1],y32[1]            ; [1]Œ…‚ÌŒvŽZ
         jc      sub32_0
         dec      xs32[0]
sub32_0
         sub      xs32[0],y32[0]            ;
  • Œ…‚ÌŒvŽZ
             ret
    ;;;;;;;;;;;; mul64 ;;;;;;;;;;;;;;
    mul64                                 ; xd32[0,1,2,3](32bit)‚Æy32[0,1,2,3](32bit)‚̐ςğxd64[0,1,2,3,4,5,6,7](64bit)‚ÉŠi"[‚·‚é
             clr      xd64[0]
             clr      xd64[1]
             clr      xd64[2]
             clr      xd64[3]
             mov      cnt,#32
    mul64_loop
             clc
             jnb      xd32[3].0,mul64_nxt
             add      xd64[3],y32[3]
             jnc      mul64_2
             inc      xd64[2]
             jnz      mul64_2
             inc      xd64[1]
             snz
             inc      xd64[0]
    mul64_2      add      xd64[2],y32[2]
             jnc      mul64_1
             inc      xd64[1]
             snz
             inc      xd64[0]
    mul64_1      add      xd64[1],y32[1]
             snc
             inc      xd64[0]
             add      xd64[0],y32[0]
    mul64_nxt
             rr      xd64[0]
             rr      xd64[1]
             rr      xd64[2]
             rr      xd64[3]
             rr      xd32[0]
             rr      xd32[1]
             rr      xd32[2]
             rr      xd32[3]
             djnz   cnt,mul64_loop            ; 32bit•ªƒ‹[ƒv
             ret
    ;;;;;;;;;;;; wait100;;;;;;;;;;;;
    wait100                                 ; 100ƒÊs * cnt ŽžÂŠÃ”‚ğÃ"ï
    loop_n
             mov      work,#WAIT_CNT
    loop100
             decsz   work
             goto   loop100
             decsz   cnt
             goto   loop_n
             ret
    ;;;;;;;;;;;; eeprom_read;;;;;;;;;;;;
    eeprom_read
             setb   rp0
             setb   eecon1.0
             clrb   rp0
             ret
    ;;;;;;;;;;;; eeprom_write;;;;;;;;;;;;
    eeprom_write
             setb   rp0
             setb   eecon1.2
             mov      eecon2,#55h
             mov      eecon2,#0aah
             setb   eecon1.1
    writeloop
             snb      eecon1.1
             goto   writeloop
             clrb   rp0
             ret
    ;;;;;;;;;;;;;;;;;;; ‚¨‚µ‚Ü‚¢ ;;;;;;;;;;;;;;;;;;;;;;
mesmert
pc isminde türkçe karakter onu değiştirip bir dene ama sanki bu software pic için değil atmel için yazılmış picin asm komutlarını ve atmelin komutlarını incelemeni tavsiye ederim
Analyzer
Alıntı yapılan: "taless"selam..
Selam,
Kullandığın mcu ile program uyuşmuyor. Program/EEPROM data adreslerin, kullandığın işlemci için geçersiz diyor.
Analyzer
Üşeniyorum, öyleyse yarın!
taless
sağol hocam. ama tam olarak anlamadım pc isminde türkçe karakter var derken neden bahsediyorsun?biraz daha açıklarmısın.eğer ateml uyumlu ise bunu pic 16f84 ün anlayabileceği dile çevirebilirmiyiz herhangi bir programla.
iyi çalışmalar...
ipek
taless sikismisin bakiyorum
http://eto.com/d/0103.html sayfasindan
PIC Assembler Version 3.0.5 indiriyorsun xp de canini sikabilir
http://mypaso.com/pic/pa/pa-3.0.5.tar.gz
16f84/4 mhz,de kullanabilirsin calisir yine 20mhz ver
kolay gelsin
not ___aristotales yazarken buyuk i harfi kullanmissin ingilizce karakter tablo setinde bulunmadigi icin su koyar.Anadilimize saygimiz sonsuz ama proteusla oynuyorsan kisa yollardan cagir asla Turkce kullanma ornek
c:\work\work.hex gibi azicik yaz basin azicik agrir....
ipek
tales bana bi uyku borcun var uc saatte bulabildim asembleri ureticisi
2 yil evvel kaldirmis...
http://www.hemenpaylas.com/download/590669/taless.rar.html
kolay gelsin dos programlarini uzun klasorlere acamassin kaprislidirler
ornek
c:\pa\pa.exe yada pa.bat ..  xp değil xxxp de ciksa dos'a mahkumuz...
taless
hocam allah razı olsun benim için uykusuz kalmışsın allah inşallah mükafatını versin.bende elimde olsada sizin için birşeyler yapsam.
ama yine bir sorun var hocam gerçi dediğiniz gibi uzakdoğuda yazılan programlar proteusta çalışamabirir.ben yinede devreyi board üzerine kurup pice programı yüklüyüp çalıştırmayı deniyicem.inşallh çalışır..bide hocam devre hızı m/s olarak ölçüyor.km/saat olarak ölçmesi için ne gibi bir değişiklik yapılması lazım.şimdiden teşekkürler...
