.:.National LM5010 Tasarım.:.
Başlatan e3, 14 Mayıs 2006, 18:14:48
e3
Alıntı yapılan: "Erol"20$ civarında bir bedel ödemiştik...
Erol hocam taksit taksit soruyorum kusura bakmayın. :D Acaba size de shipping ödeyeceksiniz diye mail gelmiş miydi? Gerçi sitesinde yazıyor shipping koşullarını ama çok İngilizcem yok maalesef.Çatpat işte. :P
.eem.
e3
Evet National mail'i gönderdi.Mail'de yazanlar :. :roll:
Thank you for your sample order for the LM5005MH.
PLEASE VERIFY YOUR DELIVERY ADDRESS:
       xxxxxxxxxxxxxxxxx
       NSID: LM5005MH  SPEC: NOPB
       Quantity: 5
If you accept the WARRANTY DISCLAIMER below, we can complete your sample order.
IMPORTANT TERMS:   WARRANTY DISCLAIMER
SAMPLES ARE PROVIDED AS IS WITHOUT WARRANTY OF ANY KIND.  NATIONAL HEREBY
DISCLAIMS ALL WARRANTIES, EXPRESSED, IMPLIED OR OTHERWISE, INCLUDING
WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, AND
NON-INFRINGEMENT OF INTELLECTUAL PROPERTY RIGHTS. NATIONAL DOES NOT
ASSUME OR AUTHORIZE ANY OTHER PERSON TO ASSUME FOR IT ANY OTHER LIABILITY
IN CONNECTION WITH ITS SAMPLES. IN NO EVENT SHALL NATIONAL BE LIABLE TO
RECIPIENT OF SAMPLES, OR ANY SUBSEQUENT USER, INCLUDING THE ULTIMATE
END-USER, IN CONTRACT, TORT, WARRANTY, STRICT LIABILITY, OR OTHERWISE FOR
ANY SPECIAL, INDIRECT, INCIDENTAL OR CONSEQUENTIAL DAMAGES, INCLUDING BUT
NOT LIMITED TO, THE COST OF LABOR, REQUALIFICATION, DELAY, LOSS OF PROFITS
OR GOODWILL, EVEN IF NATIONAL IS ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
TO ACCEPT THESE TERMS AND COMPLETE YOUR ORDER, PLEASE EXECUTE THIS LINK:
http://www.national.com/xxx
Note: Your sample will not be delivered unless you execute the above link.
TO REJECT THESE TERMS AND TO CANCEL THIS ORDER:
You must cancel this order if you found any discrepancies in the
delivery address or wrong part number. Hence, the system will allow you
to reorder the same part number again. To cancel your order:
If you receive an error message or if your email reader does not allow you
to click on links, then please copy the above url and paste it into the
address line of your web browser.
If you have trouble executing the above link, please let us know
through http://wwwd.national.com or simply reply to this email.
Thank you,
National Semiconductor
Geldik National'ın sözleşmesine. 8O Shipping ile ilgili bir ibare göremedim.Bir de sizin incelemenizi rica ediyorum arkadaşlar. :idea:
.eem.
Göktuğ
Bu national ın online seminerleriyle ilgili bir mail gelmişti. 2 haberden birinde  5035 le ilgili bir seminer var. deney kitini  falanda anlatıyor.
Linkini verirdim ama calısmıyor baska makinede. İlgilenirsen online seminer bolumune  biraz bakıver.
Power Designer #112  Power Online Seminar
" Synchronous Rectification in High–Performance Power Converter Design"
Power converters are becoming increasingly commonplace in the electrical industry. Product manufacturers and suppliers of electrical equipment are demanding ever-increasing functionality (i.e., lower input and output voltages, higher currents, faster transient response) from their power supply systems.
To meet these demands, switching power supply designers in the late 1990s began adopting Synchronous Rectification (SR)—the use of MOSFETs to achieve the rectification function typically performed by diodes. SR improves efficiency, thermal performance, power density, manufacturability, and reliability, and decreases the overall system cost of power supply systems. This article will examine the advantages of SR and discuss the challenges encountered in its implementation.
Click on the link above to preview this new edition and watch for your printed copy in these publications: EETimes (May 22, 2006), EDN (June 8, 2006), and Portable Design (June 2006).
Click here, for the complete list of National's Power Designer issues.
" Half-Bridge Power Converter Design Using the LM5035"
Topics covered in this online seminar include:
Half-Bridge Description
Half-Bridge Operation
Loop Compensation
Features of the LM5035
LM5035 Evaluation Board
Overview:
The architecture of a Half-Bridge Power Converter is discussed and related to a National Semiconductor Reference Design for a 48 Volt to 3.3 Volt, 30 Amp Quarter Brick Module. The first section discusses the power flow through the transformer and various parasitic aspects of the transformer. The second section goes into the Type 3 compensation design for Loop Stability. The final section highlights the features of the LM5035 Half-Bridge controller and driver, along with its evaluation board and other applicable topologies for the LM5035.
Who should attend?
This presentation is targeted for experienced Electrical Engineers who need detailed background on the Half-Bridge Switching topology.
onayla, devam et,
Sana kredi kartı numarası soracak.
Sen de kredi kartı var mı diye sormuyorum. Varsayılan durum : VAR :)
e3
Alıntı yapılan: "Erol"onayla, devam et,
Aman hocam yapmayın kredi kartını sorursa halim harap. 8O  :lol: 20$ shipping i nasıl öderim ben? :roll: Ben kısmaya çalışıyom siz de diyorsunuz ki evet de. :D Batırdınız beni hocam.Ama bi evet diyeyim bakalım.İnşallah kredi sormaz. :?
Ayrıca Göktuğ hocam aynı maillerden bana da gelmişti.Şu an National online seminer veriyormuş.Bi iki gündür sitelerinde gezmediğim yer kalmadı. :P Ama dedim ya İngilizce çat pat diye. :cry: Maalesef katılsam bile ancak çok azını anlarım.Yine de tavsiyeniz için teşekkür ederim. ;)
.eem.
e3
Sonuç : Hüsran  8O  :D
Bu shipping parası ( FEE diye geçiyor nedense). Bunu ödeyemeyeceğime göre malzeme ve tarasımlar boşuna gitti. :( Yok mu bi hayırsever shipping'i ortaklaşa ödeyecek :D
.eem.
Göktuğ
Her sample için ayrı shipping odemek gerekiyor sanırsam. Topluca sample isteme olmuyor diye biliyorum :( .
aster
Bence Bob Pease ile tanış, baba adamdır bir kıyak yapar herhalde  ;)
aYe
Bence boşuna uğraşıyorsun, seçtiğin entegre zaten 75v 1A çıkış vermeye uygun değil.
UC3842(25kuruş gibi bir fiyatı olucaktı bakkalda bile var) ile bir smps yapmanı tavsiye ederim.
İyi çalışmalar.
e3
Alıntı yapılan: "tatlisukurnazi"Bence boşuna uğraşıyorsun, seçtiğin entegre zaten 75v 1A çıkış vermeye uygun değil.
İyi çalışmalar.
Hocam dediğim entegre LM5005 (High voltage, 2,5 A Buck Regulator)
Alıntı YapNational 2,5 A Buck Regulator
Entegre 70 V 2,5 A kontrol edebiliyormuş.Bundan mecburen vazgeçicem. :( Sizin bahsettiğiniz entegrenin firması nedir? Ya da elinizde bir şema felan var mı? İyi günler.
.eem.
aster
Daha önce forumda bunu konuşmuştuk kullanalar var ve memnun, biri de benim
http://picproje.org/index.php/topic,3555&postdays=0&postorder=asc&highlight=4970&start=0
http://pdf1.alldatasheet.com/datasheet-pdf/view/22500/STMICROELECTRONICS/L4970.html
monel fiyat listesinde L 4970 7.45 $ilin gözüküyor
Not; artık fantazilerine mos patlatmayıda eklesen iyi olacak :)
e3
Alıntı yapılan: "aster"Daha önce forumda bunu konuşmuştuk kullanalar var ve memnun, biri de benim
Hocam sizin bu fantazinize bayılıyorum. :D Ben de yakında başlıyacağım. :lol:
Alıntı yapılan: "aster"Oynasın kızlar, patlasın Moslar.
Ayrıca verdiğiniz link ve datasheet'e de bakacağım.Saygılar. ;)
.eem.
aster
@protection, konu burada kalmış, neler yaptın?
e3
Alıntı yapılan: "aster"@protection, konu burada kalmış, neler yaptın?
Hocam 2006 Mayıs'tan beri çalışıyorum.Bu dönemde vizeler, programlayıcılar, hobi devreleri derken vakti öldürdük. :D Sizin önerdiğiniz devreyi inceledim.Aslında yapabilirim ama trafo olmasa iyi olacaktı. :) Trafo gibi ağır bir malzemenin olmasını istemiyorum.Param biraz olsun hemen LM siparişi vereceğim.Bu sıralar LM boş durmamıştır heralde. :roll: Yeni modelleri de inceledikten sonra sample isteyeceğim.Sonra tasarıma başlarım. :) Bir de yazın Kesmez hocamın yanında staj yaparken bir GK tasarlamıştık.Birkaç kez PCB denemesi yaptık ama tam randıman alamadık.Pic'le LCD ve kontrol yapacaktık.Kesmez hocam yeni kart tasarlamış.Ben onu pcb'ye dökünce tekrar deneyeceğiz.Çalışır ve randıman alırsak foruma da ekleyeceğiz.Durumlar bu şekilde. :) ADSL denen mereti bir türlü bağlamıyorlar.TTNET işkence gibi geliyor bana.Foruma zar zor bağlanmaya çalışıyorum.Hayat akıp gidiyor işte.Yeni yılınız ve bayramınız şimdiden kutlu olsun.Sağlıcakla kalın.İyi günler. ;)
.eem.
refik1
birde bunun 110 girişli olanını yapsalar harika olacak :)
