MPLAB v6.20 Released
Başlatan byka, 04 Temmuz 2003, 18:47:58
byka
MPLAB(R) IDE v6.20 is released to the web:
http://www.microchip.com/1010/pline/tools/picmicro/devenv/mplabi/mplab6/index.htm
It should be available now, but some worldwide servers may take up to 24
hours to be updated.
This is a full release and replaces v6.10a and all interim releases
(v6.11,v6.12 and v6.13).
MPLAB v6.20 is recommended for all new design projects.  Users of MPLAB
v5.xx are urged to
install v6.20.  v6.20 can be installed on the same PC as v5.xx with no
conflict, so you can return
to v5.xx if you have projects you do not wish to convert.
The following tools are supported in MPLAB v6.20  Software and firmware
versions are as listed:
Development Tools Supplied with                                 Version -
SW                Version - FW
MPLAB IDE
(Software DLL)           (Operating System)
MPASM(tm) Assembler  (mpasmwin.exe)                     3.30
MPLINK(tm) Object Linker                                               3.30
MPLIB(tm) Object Librarian                                             3.30
MPLAB ASM30, LINK30, LIB30                                       1.10 beta
02
MPLAB SIM Simulator
8.20
MPLAB SIM30 Simulator
1.00.06.10
Optional tools available for purchase:                 MPLAB v6.20 Driver
Versions (provided with MPLAB IDE)
MPLAB ICE 2000 In-Circuit Emulator                                 3.20
MPLAB ICE 4000 In-Circuit Emulator                                 1.00.02
MPLAB ICD 2 In-Circuit Debugger                                     1.20
see README
PICSTART(R) Plus Development Programmer                   3.20
3.11
PRO MATE(R) II Device Programmer                                 6.20
see README
MPLAB C17 Compiler
MPLAB C18 Compiler
MPLAB C30 Compiler (check for availability)
Third party language toolsuites integrated into MPLAB v6.20  (plug-in
drivers provided with MPLAB IDE)
Hi-Tech PICC(TM)/PICC-18
microEngineering Labs PicBASIC(TM)/PicBASIC Pro
--others being added regularly - check MPLAB website for the latest
information
DWIN LCD Satış Türkiye email:info@kamantek.com  web:http://www.kamantek.com/shop/index.php
