Assembly bilen
Başlatan Mnemonic, 23 Mayıs 2007, 16:58:32
Mnemonic
Arkadaşlar selamlar
çok fazla asembly bilmediğim için ciddi sıkıntılar çekiyorum elimde bi kod var pic16f84a için yazılmış bunu pic16f628a ya dönüştürmem gereklı bu konuda bana yardımcı olabilecek kimse varmı ?
;	VERSION	1.0,	09/03/99
        PROCESSOR       PIC16F84A
        RADIX           DEC
        INCLUDE         "P16F84A.INC"
        __CONFIG        _XT_OSC & _CP_OFF & _WDT_ON & _PWRTE_ON
;                        PIC16F84A
;                    -------_--------
;            HCSVDD | 1 RA2    RA1 18| CLK      (to HCS slave: S2)
;	            | 2 RA3TC  RA0 17| DATA     (to HCS slave: PWM)
;                   | 3 RA4   OSC1 16| OSCin
;             reset | 4 MCLR  OSC2 15| OSCtest
;               Vss | 5 Vss    Vdd 14| Vdd
;                   | 6 RB0    RB7 13| PROG
;             	    | 7 RB1    RB6 12| LED
;                   | 8 RB2    RB5 11|
;                   | 9 RB3    RB4 10|
; MACROS
#DEFINE BANK0   bcf     STATUS,RP0
#DEFINE BANK1   bsf     STATUS,RP0
; I/O PORT ASSIGNEMENT
; PORTA BIT DEFINITIONS
#DEFINE DATA    PORTA,0                 ; (IN/OUT) Data (PWM) for Programming HCS
#DEFINE CLK     PORTA,1                 ; (OUT)	Clock (S2) for Programming HCS
#DEFINE HCSVDD  PORTA,2                 ; (OUT) HCS Vdd line
; PORTB BIT DEFINITIONS
#DEFINE LED     PORTB,6                 ; (OUT) Program/failure led indicator
#DEFINE PROG    PORTB,7                 ; (IN)	Programming Key
#DEFINE SWRES   PORTB,7                 ; (IN)	Sw reset Key on programming failure
; PORT DIRECTION DEFINE REG
#DEFINE K_MASKPA        B'11111000'	; PORTA: TRI-STATE VALUE
#DEFINE K_MASKPB        B'10111111'	; PORTB: TRI-STATE VALUE
#DEFINE K_MASKPA_PROG   B'11111000'	; PORTB: TRI-STATE FOR PROGRAMMING HCS
#DEFINE K_MASKPA_VERI   B'11111001'	; PORTB: TRI-STATE FOR VERIFY HCS
#DEFINE K_OPTION        B'00000111'     ; OPTION REGISTER SETTING
                                        ; PORTB PULL-UP ON, TMR0 associated to Tcy, Prescaler=1:256
; GENERAL PURPOSE RAM REGISTERS
        CBLOCK	0x0C
; Word clocked into HCS
                WRD_HI,	WRD_LO
; Words to be programmed into HCS (HCS MEMORY MAPPING)
                WORD0:2, WORD1:2, WORD2:2, WORD3:2
                WORD4:2, WORD5:2, WORD6:2, WORD7:2
                WORD8:2, WORD9:2, WORD10:2, WORD11:2
; Other Variable for programming HCS
                TXNUM                                   ; Number of bit clocked
                TMP_CNT                                 ; Temporary Counter
                MYCONT                                  ;       "
                COUNT_HI, COUNT_LO                      ; Counter for Timing
; Generated Encryption KEY
                KEY7, KEY6, KEY5, KEY4
                KEY3, KEY2, KEY1, KEY0
; Circular Buffer used in decryption routine
                CSR4, CSR5, CSR6, CSR7
                CSR0, CSR1, CSR2, CSR3
; Counter used in decryption routine
                CNT0, CNT1
; Mask register used in decryption routine
                MASK
; Temporary Register
                TMP0, TMP1, TMP2, TMP3                  ; Temp register
        ENDC
; End of define general purpose RAM register
; **************  DECRYPTION REGISTER RE-MAPPINGS *******************
; NOTE : INDIRECT ADDRESSING USED, DO NOT CHANGE REGISTER ASSIGNMENT
; 32 BIT HOPCODE BUFFER
#DEFINE HOP1    CSR0
#DEFINE HOP2    CSR1
#DEFINE HOP3    CSR2
#DEFINE HOP4    CSR3
; 28 BIT SERIAL NUMBER
SER_3   EQU     CSR7                    ; LSB
SER_2   EQU     CSR6
SER_1   EQU     CSR5
SER_0   EQU     CSR4                    ; MSB
; MODIFYABLE PROGRAMMING DEFINE
#DEFINE KEY_METHOD 1            ; MUST BE 1 IF NORMAL KEY GENERATION METHOD TO BE USED
                                ; MUST BE 0 IF SIMPLE KEY GENERATION METHOD TO BE USED
                                ; (ENCRYPTION KEY= MANUFACTURER KEY)
#DEFINE HCS30X  1               ; MUST BE 1 IF PROGRAMMING HCS300-301,
                                ; MUST BE 0 IF PROGRAMMING HCS200
#DEFINE MCODE_0 0xCDEF          ; MANUFACTURER CODE, LSWORD
#DEFINE MCODE_1 0x89AB
#DEFINE MCODE_2 0x4567
#DEFINE MCODE_3 0x0123          ; MSWORD
#DEFINE SYNC    0X0000          ; SYNCRONOUS COUNTER
#DEFINE SEED_0  0x0000          ; 2 WORD SEED VALUE
#DEFINE SEED_1  0x0000
#DEFINE ENV_KEY 0x0000          ; ENVELOPE KEY                  ( NOT USED FOR HCS200)
#DEFINE AUTOFF  1               ; AUTO SHUT OFF TIMER           ( NOT USED FOR HCS200)
#DEFINE DISC70  0x00            ; DISCRIMINATION BIT7-BIT0
#DEFINE DISC8   0               ; DISCRIMINATION BIT8
#DEFINE DISC9   0               ; DISCRIMINATION BIT9
#DEFINE OVR0    0               ; OVERFLOW BIT0                 (DISC10 for HCS200)
#DEFINE OVR1    0               ; OVERFLOW BIT1                 (DISC11 for HCS200)
#DEFINE VLOW    1               ; LOW VOLTAGE TRIP POINT SELECT BIT (1=High voltage)
#DEFINE BSL0    0               ; BAUD RATE SELECT BIT0
#DEFINE BSL1    0               ; BAUD RATE SELECT BIT1         (RESERVED for HCS200)
#DEFINE EENC    0               ; ENVELOPE ENCRYPTION SELECT    (RESERVED for HCS200)
#DEFINE DISEQSN	1               ; IF DISEQSN=1 SET DISCRIMINANT EQUAL TO SERNUM BIT10-0
                                ; IF DISEQSN=0 SET DISCRIMINANT AS DEFINED ABOVE
; OTHER EQUATE
#DEFINE NUM_WRD .12             ; NUMBER OF WORD TO PROGRAM INTO HCS
#DEFINE RES     0X0000          ; RESERVED WORD
#DEFINE CONF_HI ((EENC<<7)|(BSL1<<6)|(BSL1<<5)|(VLOW<<4)|(OVR1<<3)|(OVR0<<2)|(DISC9<<1)|DISC8)
; ****** HCS TIME PROGRAMMING EQUATE ********
#DEFINE Tps     .4              ; PROGRAM MODE SETUP TIME 4mS   (3,5mS min, 4,5 max)
#DEFINE Tph1    .4              ; HOLD TIME 1             4mS   (3,5mS min)
#DEFINE Tph2    .19             ; HOLD TIME 2             62uS  (50uS min)
#DEFINE Tpbw    .3              ; BULK WRITE TIME         3mS   (2,2mS min)
#DEFINE Tclkh   .10             ; CLOCK HIGH TIME         35uS  (25uS min)
#DEFINE Tclkl   .10             ; CLOCK LOW TIME          35uS  (25uS min)
#DEFINE Twc     .40             ; PROGRAM CYCLE TIME      40mS  (36mS min)
; NOTE: FOR mS TIME DELAY USE WAIT_WMSEC SUBROUTINE ( W * 1mSec )
;       FOR uS TIME DELAY USE WAIT_uS SUBROUTINE ( 5 + Txxx*3 uS )
; FUNCTION     : RESET ()
; DESCRIPTION  : PROGRAM RESET ROUTINE
        ORG     0x00
RESET_VECTOR
        goto    START
; FUNCTION     : ISR_VECTOR ()
; DESCRIPTION  : INTERRUPT SERVICE ROUTINE VECTOR
        ORG     0x04
ISR_VECTOR
                retfie
; SUBROUTINES   SUBROUTINES     SUBROUTINES     SUBROUTINES     SUBROUTINES
; FUNCTION     : INITREG
; DESCRIPTION  : REGISTER INIZIALIZATION
INITREG         clrf	STATUS
		clrf	INTCON                  ; INTERRUPT DISABLED
		clrf	PORTA                   ; RESET PORTA
		clrf	PORTB                   ; RESET PORTB
	BANK1
		movlw	K_OPTION                ; INT CLK, PRESCALER TO TMR0, ON PULL-UP
		movwf	OPTION_REG
		movlw	K_MASKPA                ; SETUP PORTA
		movwf	TRISA
		movlw	K_MASKPB                ; SETUP PORTB
		movwf	TRISB
	BANK0
		clrf	TMR0
		return
CLEAR_RAM       movlw	0x0C
		movwf	FSR
CLEAR_RAM_LOOP  clrf	INDF
		incf	FSR,F
		movlw	0x50
		xorwf	FSR,W
		skpz
		goto	CLEAR_RAM_LOOP
		return
; FUNCTION     	: WAIT_uS ()
; DESCRIPTION  	: WAIT 5+W*3 MICROSECOND SUBROUTINE
WAIT_uS         movwf	COUNT_LO
WAIT_uS_A       decfsz	COUNT_LO, F
		goto	WAIT_uS_A
		return
; FUNCTION     	: DEBOUNCE - WAIT_16MSEC - WAIT_WMSEC ()
; DESCRIPTION  	: WAIT 16mSec or W mSec SUBROUTINE
DEBOUNCE
WAIT_16MSEC     movlw	.16
WAIT_WMSEC      movwf	COUNT_HI
WAITSET         movlw	.250
		movwf	COUNT_LO
WAITLOOP        clrwdt
		decfsz	COUNT_LO,F
		goto	WAITLOOP
		decfsz	COUNT_HI,F
		goto	WAITSET
		return
; FUNCTION     	: BUTTON RELEASE ()
; DESCRIPTION  	: WAIT FOR BUTTON RELEASE
BUTTON_RELEASE  clrwdt
		btfss	PROG
		goto	BUTTON_RELEASE
		call	DEBOUNCE
		return
; FUNCTION     	: READ_SN ()
; DESCRIPTION  	: READ LAST SERIAL NUMBER STORED IN THE PIC16F84A EEPROM DATA,
;		  AND INCREMENT IT INTO NEW SER_x
READ_SN         movlw	SER_3
		movwf	FSR
		clrf	MYCONT			; COUNTER OF BYTE
						; READ FROM DATA EEPROM
READ_SN_A       clrwdt
		movf	MYCONT,W
		movwf	EEADR
	BANK1
		bsf	EECON1, RD		; do a read
		clrwdt
		btfsc	EECON1, RD		; Read done ?
		goto	$-2
	BANK0
		movf	EEDATA,W
		movwf	INDF
		incf	MYCONT, F
		movlw	.4
		xorwf	MYCONT, W		; TEST IF 4 BYTE READ
		bz	READ_SN_INC
		decf	FSR, F
		goto	READ_SN_A
READ_SN_INC     incfsz	SER_3, F		; LOW BYTE: INCREMENT SN
		goto	READ_SN_X
		incfsz	SER_2, F
		goto	READ_SN_X
		incfsz	SER_1, F
		goto	READ_SN_X
		incf	SER_0, F
READ_SN_X       return
; FUNCTION     	: WRITE_SN ()
; DESCRIPTION  	: SAVE INTO PIC16F84A  EEPROM DATA THE LAST PROGRAMMED SERIAL
;               : NUMBER
WRITE_SN        clrwdt
		movlw	SER_3
		movwf	FSR
						; WRITTEN TO DATA EEPROM
WRITE_SN_BYTE   clrwdt
		movf	MYCONT, W
		movwf	EEADR
		movf	INDF, W
		movwf	EEDATA
	BANK1
		bcf	EECON1, EEIF
		bsf	EECON1, WREN		; enable Write
		movlw	0x55
		movwf	EECON2
		movlw	0xAA
		movwf	EECON2
		bsf	EECON1, WR
WRITE_SN_A      clrwdt
		btfsc	EECON1, WR		; Write complete ?
		goto	WRITE_SN_A
		bcf	EECON1, WREN		; disable Write
VERIFY_WRITE
	BANK0
		movf	EEDATA, W
	BANK1
		clrwdt
		goto	$-2
	BANK0
		xorwf	EEDATA, W
		BNZ	EE_ERR			; EEPROM WRITE ERROR
		incf	MYCONT, F
		movlw	.4
		xorwf	MYCONT, W		; TEST IF WRITTEN ALL THE 4 BYTES
		BZ	WRITE_SN_X
		decf	FSR, F
		goto	WRITE_SN_BYTE
WRITE_SN_X      return
; FUNCTION     	: MEM_MAP ()
; DESCRIPTION  	: PREPARE THE WORDS TO BE PROGRAMMED INTO HCS
MAP_SET         movlw	WORD0
		movwf	FSR
WORD_0                                          ; ENCRYPTION KEY (4 WORD)
WORD_0_LO       movf	KEY0,W
		movwf	INDF
		incf	FSR, F
WORD_0_HI       movf	KEY1,W
		movwf	INDF
		incf	FSR, F
WORD_1
WORD_1_LO       movf	KEY2,W
		movwf	INDF
		incf	FSR, F
WORD_1_HI       movf	KEY3,W
		movwf	INDF
		incf	FSR, F
WORD_2
WORD_2_LO       movf	KEY4,W
		movwf	INDF
		incf	FSR, F
WORD_2_HI       movf	KEY5,W
		movwf	INDF
		incf	FSR, F
WORD_3
WORD_3_LO       movf	KEY6,W
		movwf	INDF
		incf	FSR, F
WORD_3_HI       movf	KEY7,W
		movwf	INDF
		incf	FSR, F
WORD_4                                          ; SYNC COUNTER (1 WORD)
WORD_4_LO       movlw	LOW(SYNC)
		movwf	INDF
		incf	FSR, F
WORD_4_HI       movlw	HIGH(SYNC)
		movwf	INDF
		incf	FSR, F
WORD_5                                          ; RESERVED (1 WORD)
WORD_5_LO       movlw	LOW(RES)
		movwf	INDF
		incf	FSR, F
WORD_5_HI       movlw	HIGH(RES)
		movwf	INDF
		incf	FSR, F
WORD_6                                          ; SERIAL NUMBER (2 WORD)
WORD_6_LO       movf	SER_3, W                ; LSByte
		movwf	INDF
		incf	FSR, F
WORD_6_HI       movf	SER_2, W
		movwf	INDF
		incf	FSR, F
WORD_7
WORD_7_LO       movf	SER_1, W
		movwf	INDF
		incf	FSR, F
WORD_7_HI       movf	SER_0, W                ; MSByte
		andlw	B'00001111'
		iorlw	(AUTOFF<<7)             ; SET THE AUTO SHUT-OFF TIMER
		movwf	INDF
		incf	FSR, F
WORD_8                                          ; SEED VALUE ( 2 WORD)
WORD_8_LO       movlw	LOW(SEED_0)
		movwf	INDF
		incf	FSR, F
WORD_8_HI       movlw	HIGH(SEED_0)
		movwf	INDF
		incf	FSR, F
WORD_9
WORD_9_LO       movlw	LOW(SEED_1)
		movwf	INDF
		incf	FSR, F
WORD_9_HI       movlw	HIGH(SEED_1)
		movwf	INDF
		incf	FSR, F
WORD_10                                         ; ENVELOPE KEY (1 WORD)
                                                ; (RESERVED FOR HCS200 SET TO 0x0000)
WORD_10_LO      movlw	(LOW(ENV_KEY) * HCS30X)
		movwf	INDF
		incf	FSR, F
WORD_10_HI      movlw	(HIGH(ENV_KEY) * HCS30X)
		movwf	INDF
		incf	FSR, F
WORD_11
WORD_11_LO      movf	SER_3, W                ; CONFIGURATION WORD
		movwf	INDF                    ; LOWER BYTE=LOWEST BYTE OF SERIAL NUMBER
		incf	FSR, F
WORD_11_HI      movf	SER_2, W
		ANDLW	B'00000011'             ; MASK BIT OF SER. NUM.
		IORLW	CONF_HI                 ; MASK OTHER BIT OF CONFIG WORD
		movwf	INDF
		incf	FSR, F
		return
; FUNCTION     	: PREPARE_WRD ()
; DESCRIPTION  	: PUT IN WRD_LO & WRD_HI THE WORD TO BE CLOCKED OUT (PWM)
PREPARE_WRD     movf	INDF, W
		movwf	WRD_LO
		incf	FSR, F
		movf	INDF, W
		movwf	WRD_HI
		incf	FSR, F
		return
; FUNCTION     	: DECRYPT ()
; DESCRIPTION  	: DECRYPTS 32 BIT [HOP1:HOP4] USING [CSR0:CSR7]
DECRYPT
	        movlw   .11 +.1			; OUTER LOOP 11+1 TIMES
		movwf	CNT1			; OUTER LOOP 11+1 TIMES
DECRYPT_OUTER
	        movlw   .48			; INNER LOOP 48 TIMES
        	movwf   CNT0			; INNER LOOP 48 TIMES
DECRYPT_INNER
		clrwdt				; RESET WATCHDOG TIMER
        	movfw   CNT1			; LAST 48 LOOPS RESTORE THE KEY
        	xorlw   .1			; LAST 48 LOOPS RESTORE THE KEY
	        skpnz				; LAST 48 LOOPS RESTORE THE KEY
        	goto    ROTATE_KEY		; LAST 48 LOOPS RESTORE THE KEY
        ; THE LOOKUP TABLE IS COMPRESSED INTO IN 4 BYTES TO SAVE SPACE
        ; USE THE 3 LOW INDEX BITS TO MAKE UP AN 8-BIT BIT MASK
        ; USE THE 2 HIGH INDEX BITS TO LOOK UP THE VALUE IN THE TABLE
        ; USE THE BIT MASK TO ISOLATE THE CORRECT BIT IN THE BYTE
        ; PART OF THE REASON FOR THIS SCHEME IS BECAUSE NORMAL TABLE
        ; LOOKUP REQUIRES AN ADDITIONAL STACK LEVEL
	        clrc				; CLEAR CARRY (FOR THE LEFT SHIFT)
        	movlw   .1			; INITIALISE MASK = 1
	        btfsc   HOP3,3			; SHIFT MASK 4X IF BIT 2 SET
        	movlw   b'10000'		; SHIFT MASK 4X IF BIT 2 SET
        	movwf   MASK			; INITIALISE MASK = 1
	        btfss   HOP2,0			; SHIFT MASK ANOTHER 2X IF BIT 1 SET
        	goto    $+3
	        rlf     MASK,F
        	rlf     MASK,F
	        btfsc   HOP1,0			; SHIFT MASK ANOTHER 1X IF BIT 0 SET
        	rlf     MASK,F
        ; MASK HAS NOW BEEN SHIFTED 0-7 TIMES ACCORDING TO BITS 2:1:0
        	movlw   0			; TABLE INDEX = 0
        	btfsc   HOP4,1
        	iorlw   .2			; IF BIT 3 SET ADD 2 TO THE TABLE INDEX
        	btfsc   HOP4,6
        	iorlw   .4			; IF BIT 4 SET ADD 4 TO THE TABLE INDEX
        	addwf   PCL,F			; ADD THE INDEX TO THE PROGRAM COUNTER
						;  [ MUST BE IN LOWER HALF OF PAGE ]
TABLE
	        movlw   0x2E			; BITS 4:3 WERE 00
	        goto    TABLE_END		; END OF LOOKUP
        	movlw   0x74			; BITS 4:3 WERE 01
        	movlw   0x5C			; BITS 4:3 WERE 10
        	movlw   0x3A			; BITS 4:3 WERE 11
TABLE_END
        	andwf   MASK,F			; ISOLATE THE CORRECT BIT
        	movlw   .0			; COPY THE BIT TO BIT 7
        	skpz				; COPY THE BIT TO BIT 7
        	movlw   b'10000000'		; COPY THE BIT TO BIT 7
        	xorwf   HOP2,W			; ONLY INTERESTED IN BIT HOP2,7
        	xorwf   HOP4,W			; ONLY INTERESTED IN BIT HOP4,7
        	xorwf   KEY1,W			; ONLY INTERESTED IN BIT KEYREG1,7
        	movwf   MASK			; STORE W TEMPORARILY (WE NEED BIT 7)
        	rlf     MASK,F			; LEFT ROTATE MASK TO GET BIT 7 INTO CARRY
        	rlf     HOP1,F			; SHIFT IN THE NEW BIT
        	rlf     HOP2,F
        	rlf     HOP3,F
        	rlf     HOP4,F
ROTATE_KEY
        	clrc				; CLEAR CARRY
        	btfsc   KEY7,7			; SET CARRY IF LEFTMOST BIT SET
        	setc				; SET CARRY IF LEFTMOST BIT SET
        	rlf     KEY0,F			; LEFT-ROTATE THE 64-BIT KEY
        	rlf     KEY1,F
        	rlf     KEY2,F
        	rlf     KEY3,F
        	rlf     KEY4,F
        	rlf     KEY5,F
        	rlf     KEY6,F
        	rlf     KEY7,F
        	decfsz  CNT0,F			; INNER LOOP 48 TIMES
        	goto    DECRYPT_INNER		; INNER LOOP 48 TIMES
        	decfsz  CNT1,F			; OUTER LOOP 12 TIMES (11+1 TO RESTORE KEY)
        	goto    DECRYPT_OUTER		; OUTER LOOP 12 TIMES (11+1 TO RESTORE KEY)
        	retlw	.0			; RETURN
; FUNCTION     	: CALC_KEY ()
; DESCRIPTION  	: GENERATE 32 BITS ENCRYPTION KEY USING THE MANUFACTURER CODE STORED IN ROM
CALC_KEY	iorwf	SER_0,W			; PATCH 28 BIT SERIAL NUMBER
		movwf	CSR3			; ... AND COPY TO DECRYPT BUFFER
		movf	SER_1,W
		movwf	CSR2
		movf	SER_2,W
		movwf	CSR1
		movf	SER_3,W
		movwf	CSR0
CALC_KEY2	call	DECRYPT 		; DECRYPT 32 BIT USING MASTER KEY
		return
; FUNCTION     	: NORMAL_KEY_GEN ()
; DESCRIPTION  	: GENERATE THE 64 BITS ENCRYPTION KEY USING THE MANUFACTURER CODE STORED IN ROM
NORMAL_KEY_GEN					; COPY THE MANUFACTURER CODE INTO
		movlw	HIGH(MCODE_3)		; ENCRYPTION KEY (BYTE)
		movwf	KEY7
		movlw	LOW(MCODE_3)
		movwf	KEY6
		movlw	HIGH(MCODE_2)
		movwf	KEY5
		movlw	LOW(MCODE_2)
		movwf	KEY4
		movlw	HIGH(MCODE_1)
		movwf	KEY3
		movlw	LOW(MCODE_1)
		movwf	KEY2
		movlw	HIGH(MCODE_0)
		movwf	KEY1
		movlw	LOW(MCODE_0)
		movwf	KEY0
NORMAL_KEY_GEN_PATCH1				; DERIVE LOWER 32 BITS OF DECRYPTION KEY FROM SN
		movlw	0x20			; PATCH REQUIRED FOR HCS NORMAL ENCODER
		call	CALC_KEY
		movf	CSR3,W			; TEMPORARY STORE LOWER 32 BITS
		movwf	TMP3
		movfw	CSR2
		movwf	TMP2
		movfw	CSR1
		movwf	TMP1
		movfw	CSR0
		movwf	TMP0
NORMAL_KEY_GEN_PATCH2				; PATCH REQUIRED FOR HCS NORMAL ENCODER
		movlw	0x60
		call	CALC_KEY
		movfw	CSR3			; STORE UPPER 32 BITS OF DERIVED KEY
		movwf	KEY7			; .... IN 64 BIT KEY BUFFER
		movfw	CSR2
		movwf	KEY6
		movfw	CSR1
		movwf	KEY5
		movfw	CSR0
		movwf	KEY4
NORMAL_KEY_GEN_REC
		movfw	TMP3			; RECOVER LOWER 32 BITS OF DERIVED KEY
		movwf	KEY3			; ... AND STORE IN 64 BIT KEY BUFFER
		movfw	TMP2
		movwf	KEY2
		movfw	TMP1
		movwf	KEY1
		movfw	TMP0
		movwf	KEY0
		return
; FUNCTION     	: GET KEY or SIMPLE_KEY_GEN ()
; DESCRIPTION  	: ENCRYPTION KEY =  MANUFACTURER CODE STORED IN ROM
SIMPLE_KEY_GEN  movlw	HIGH(MCODE_3)		; COPY THE MANUFACTURER CODE INTO
		movwf	KEY7			; ENCRYPTION KEY (BYTE)
		movlw	LOW(MCODE_3)
		movwf	KEY6
		movlw	HIGH(MCODE_2)
		movwf	KEY5
		movlw	LOW(MCODE_2)
		movwf	KEY4
		movlw	HIGH(MCODE_1)
		movwf	KEY3
		movlw	LOW(MCODE_1)
		movwf	KEY2
		movlw	HIGH(MCODE_0)
		movwf	KEY1
		movlw	LOW(MCODE_0)
		movwf	KEY0
		return
;       END SUBROUTINES       END SUBROUTINES        END SUBROUTINES
; FUNCTION     : START ()
; DESCRIPTION  : PROGRAM START ROUTINE
START           call	INITREG
		call	CLEAR_RAM
		bsf	LED			; LED ON PWUP
		movlw	.250			; WAIT 250Msec with LED ON
		call	WAIT_WMSEC
		bcf	LED			; LED OFF
		goto	M_LOOP
; FUNCTION     	: M_LOOP ()
; DESCRIPTION  	: MAIN PROGRAM ROUTINE
M_LOOP          clrwdt				; WAIT FOR PROGRAMMING BUTTON PRESS
		btfsc	PROG
		goto	M_LOOP
		call	DEBOUNCE
; PROGRAMMING ROUTINES
M_KEY_GEN       call	READ_SN			; READ FROM EE SN TO BE PROGRAMMED
		clrwdt
        if      KEY_METHOD==1
		call	NORMAL_KEY_GEN
		call	SIMPLE_KEY_GEN
        endif
		call	MAP_SET			; PREPARE EEPROM MEMORY MAP
;---------------				; ENTER IN PROGRAMMING MODE AND BULK ERASE
M_PROGRAMMING
M_PROG_INIT     bcf	DATA			; DATA=0
		bcf	CLK			; CLK=0
		bsf	HCSVDD			; HCS POWER ON
	BANK1
		movlw	K_MASKPA_PROG
		movwf	TRISA
	BANK0
		call	WAIT_16MSEC
M_PROG_SETUP    bsf	CLK			; DATA=0, CLK=1
		movlw	Tps			; WAIT Program mode Setup Time (Tps)
		call	WAIT_WMSEC
		bsf	DATA			; DATA=1, CLK=1
		movlw	Tph1			; WAIT Program Hold Time 1 (Tph1)
		call	WAIT_WMSEC
		bcf	DATA			; DATA=0, CLK=1
		movlw	Tph2			; WAIT Program Hold Time 2 (Tph2)
		call	WAIT_uS
M_PROG_BULK_ER  bcf	CLK			; DATA=0, CLK=0
		movlw	Tpbw			; WAIT Program Bulk Write Time (Tpbw)
		call	WAIT_WMSEC
;---------------				; CLOCK INTO HCS THE WORDS TO BE PROGRAMMED
		clrf	TMP_CNT			; NUMBER OF WORD TRASMITTED
		movlw	WORD0			; SET INDIRECT PONTER TO INIT EE MAP
		movwf	FSR
M_NEW_WORD      call	PREPARE_WRD
;---------------				; OUTPUT WORD ROTATE
		clrf	TXNUM			; NUMBER OF BIT TRASMITTED FOR EACH WORD
M_TX_BIT        bsf	CLK			; CLK=1
		clrc
		rrf	WRD_HI, F		; ROTATE BIT TO OUTPUT
		rrf	WRD_LO, F		;  into CARRY FLAG
		skpnc
		goto	M_PROG_DHI
		nop
M_PROG_DLO      bcf	DATA			; DATA=0
		goto	M_PROG_BIT
M_PROG_DHI      bsf	DATA			; DATA=1
M_PROG_BIT      movlw	Tclkh
		call	WAIT_uS			; DELAY
		bcf	CLK			; CLK=0
		movlw	Tclkl
M_PROG_CHK_WORD incf	TXNUM, F		; INCREMENT NUMBER OF BIT TRASMITTED
		movlw	.16			; CHECK IF END OF WORD TRASMITTED (16 BITS)
		xorwf	TXNUM, W
		skpz
		goto	M_TX_BIT		; TRASMIT NEXT BIT
;---------------				; END OUTPUT WORD
M_END_WORD      bcf	DATA			; DATA=0
		movlw	Twc			; WAIT FOR WORD Write Cycle Time (Twc)
		call	WAIT_WMSEC
M_CECHK_PRG_END incf	TMP_CNT, F		; INCREMENT NUMBER OF WORD PROGRAMMED
		movlw	NUM_WRD			; CHECK NUMBER OF WORD TRASMITTED
		xorwf	TMP_CNT, W
		skpz
		goto	M_NEW_WORD		; PROGRAM NEW WORD
; VERIFY ROUTINE
M_VERIFY
	BANK1
		movlw	K_MASKPA_VERI           ; I/O TRISTATE FOR VERIFY
		movwf	TRISA
	BANK0
		clrwdt
		movlw	WORD0			; SET INDIRECT POINTER TO INIT EE MAP
		movwf	FSR
		clrf	TMP_CNT			; NUMBER OF WORDS RECIVED
		clrf	TXNUM			; NUMBER OF BIT RECEIVED FOR EACH WORD
M_VER_BITIN     clrc				; RECIVE DATA BIT FROM HCS FOR VERIFY
		btfsc	DATA			; TEST and ROTATE RECEIVED BIT INTO WORD BUFFER
		setc
		rrf	WRD_HI, F
		rrf	WRD_LO, F
		incf	TXNUM, F
		movlw	.16
		xorwf	TXNUM, W		; TEST IF RECEIVED A COMPLETE WORD
		skpz
		goto	M_VER_CLKHI
M_VERIFY_WORD   movf	WRD_LO, W		; 16th BIT RECIVED (WORD) -> VERIFY WORD
		xorwf	INDF, W
		skpz
		goto	PROG_ERR		; WORD LOW VERIFY ERROR
		incf	FSR, F
		movf	WRD_HI, W
		xorwf	INDF, W
		skpz
		goto	PROG_ERR		; WORD HIGH VERIFY ERROR
		incf	FSR, F
		incf	TMP_CNT, F
		movlw	NUM_WRD
		xorwf	TMP_CNT, W		; TEST IF RECEIVED ALL THE WORDS PROGRAMMED
		skpnz
		goto	PROG_SUCCESS		; ALL 12 WORDS VERIFIED WITH SUCCESS
		clrf	TXNUM
M_VER_CLKHI     bsf	CLK			; CLK=1
		movlw	Tclkh			; WAIT TIME CLOCK HIGH
		call	WAIT_uS
M_VER_CLKLO     bcf	CLK			; CLK=0
		movlw	Tclkl			; WAIT TIME CLOCK LOW
		call	WAIT_uS
		goto	M_VER_BITIN
PROG_SUCCESS    call	WRITE_SN		; WRITE LAST SN PROGRAMMED INTO
						; PIC16F84A EEPROM DATA
		bsf	LED			; LED ON FOR 0,4SEC
		movlw	.200
		call	WAIT_WMSEC		; DELAY
		movlw	.200
		goto	PROG_END
; HCS PROGRAMMING ERROR
; WAIT FOR BUTTON PRESS
PROG_ERR        clrf	PORTA
		movlw	.20			; 20 * 0,2SEC = 4SEC LED BLINKING
		movwf	TMP_CNT
PROG_ERR_LEDON  bsf	LED			; LED ON FOR 0,1SEC
		movlw	.100
PROG_ERR_LEDOFF bcf	LED			; LED OFF FOR 0,1SEC
		movlw	.100
		decfsz	TMP_CNT,F
		goto	PROG_ERR_LEDON
PROG_ERR_X      bcf	LED
		goto	PROG_END
PROG_END        bcf	LED
		bcf	HCSVDD
		call	BUTTON_RELEASE
		goto	M_LOOP
; PIC16F84A DATA EEPROM WRITE ERROR; LED ON FOREVER
EE_ERR          clrf	PORTA
		bsf	LED			; LED ON
		clrwdt
		goto	$-1
; INIZIALIZE THE SER NUM STORED IN THE FIRST 4 BYTES OF THE INTERNAL EE DATA MEMORY
        ORG     0x2100
                DE	0x00
                DE	0x00
                DE	0x00
                DE	0x00
; END OF FILE
        END
ground
628 le 84 arasında register adresleri farklıdır..
16f84  0x0C den başlarken
16f628 0x20 dan başlar..
Eğer f84 le yazılmış programda değişkenler 0x20 den başlarsa bu program 628 e rahatca uyarlanabilir..
| 田︱田田|
Picproje - Sözde değil özde paylaşım..
Mnemonic
o kısmı yapıldı ama genede dogru calısmıyor
SpeedyX
XX_CİHAN_XX
start etiketinin altına
movlw   0x07
movwf   CMCON
satırlarını ekle.
CBLOCK   0x0C
satırını
CBLOCK   0x20
olarak degıstır
      PROCESSOR       PIC16F84A
       RADIX           DEC
satırlarınıda 16f628 ıle degıstır.
Normal şartlrda çalışması gerekır ancak programın ıcersınde indirect adrsleme yapılmış dolayııyla fsr felan kullanılmış bu sebepten dolayı yukarıdakı degısıklıklerı yapmak yeterlı olmıyabılır.Ama yinede bir dene.
Mnemonic
teşekkür edeirm bu sekılde calıstı :)
