Derleme Sorunu
Başlatan agora_meyhanesi42, 04 Ağustos 2008, 09:16:02
agora_meyhanesi42
Pic Basic Derleyicim var ama ne yaptıysam derleyemedim eger zahmet olmazsa su programı derleyen arkadaslarım olursa cok sevinirim. Saat yapmak istiyorum ama derleyemiyorum
DEVICE 16F84A
TrisA=0
TrisB=192
Dim Tick as Byte
Dim Saat as Byte
Dim Dakika as Byte
Dim Saniye as Byte
Dim i as Byte
Dim k as Byte
Dim l as Byte
Dim s as Byte
Dim a as Byte
Dim b as Byte
Dim c as Byte
Dim d as Byte
Dim e as Byte
Dim f as Byte
Saat=0:Dakika=0:Saniye=0:k=22
OPTION_REG = $55
INTCON =
On Interrupt Goto tickint
PORTB=192
BAS:
If s=1 Then Inc l
If l=40 Then l=0 : k=22
If PORTB.7 = 0 Then
a=0:b=0:c=0:d=0:e=0:f=0
Else
a=32:b=16:c=8:d=4:e=2:f=1
EndIf
If PORTB.6 = 0 Then
DEC k
If k = 0 Then k = 1
s = 0
Goto Dakikayi_Artir
Else s = 1
EndIf
PORTB=0
PORTA=DIG Saniye, 0
PORTB=a
DELAYMS 2
PORTB=0
PORTA=DIG Saniye, 1
PORTB=b
DELAYMS 2
PORTB=0
PORTA=DIG Dakika, 0
PORTB=c
DELAYMS 2
PORTB=0
PORTA=DIG Dakika, 1
PORTB=d
DELAYMS 2
PORTB=0
PORTA=DIG Saat, 0
PORTB=e
DELAYMS 2
PORTB=0
PORTA=DIG Saat, 1
PORTB=f
DELAYMS 2
GOTO BAS
Dakikayi_Artir:
Dakika = Dakika + 1
If Dakika >= 60 Then
Dakika = 0:Saat = Saat + 1
If Saat = 24 Then Saat = 0
Saniye = 0
Endif
Goto debounce
debounce:
For i = 1 to k
PORTB=0
PORTA=DIG Saniye, 0
PORTB=a
DELAYMS 2
PORTB=0
PORTA=DIG Saniye, 1
PORTB=b
DELAYMS 2
PORTB=0
PORTA=DIG Dakika, 0
PORTB=c
DELAYMS 2
PORTB=0
PORTA=DIG Dakika, 1
PORTB=d
DELAYMS 2
PORTB=0
PORTA=DIG Saat, 0
PORTB=e
DELAYMS 2
PORTB=0
PORTA=DIG Saat, 1
PORTB=f
DELAYMS 2
Next i
Goto BAS
Disable
TickInt:
Tick = Tick + 1
If Tick < 61 Then tiCik
Tick = 0
Saniye = Saniye + 1
If Saniye >= 60 Then
Saniye = 0
Dakika = Dakika + 1
Dakika = 0
Saat = Saat + 1
If Saat >= 24 Then
Saat = 0
Endif
Endif
Endif
tiCik: INTCON.2 = 0
If s = 0 Then Saniye = 0
Resume
Yüksel Türk ! Senin için yükselmenin hududu yoktur...
karbal656
Device 16F84A
TRISA=0
TRISB=192
Dim Tick As Byte
Dim Saat As Byte
Dim Dakika As Byte
Dim Saniye As Byte
Dim i As Byte
Dim k As Byte
Dim l As Byte
Dim s As Byte
Dim a As Byte
Dim b As Byte
Dim c As Byte
Dim d As Byte
Dim e As Byte
Dim f As Byte
OPTION_REG = $55
INTCON = %10100000
On Interrupt GoTo TickInt
PORTB=192
BAS:
If s=1 Then Inc l
If PORTB.7 = 0 Then
Else
EndIf
If PORTB.6 = 0 Then
Dec k
If k = 0 Then k = 1
s = 0
GoTo Dakikayi_Artir
Else s = 1
EndIf
PORTB=0
PORTA=Dig Saniye, 0
PORTB=a
DelayMS 2
PORTB=0
PORTA=Dig Saniye, 1
PORTB=b
DelayMS 2
PORTB=0
PORTA=Dig Dakika, 0
PORTB=c
DelayMS 2
PORTB=0
PORTA=Dig Dakika, 1
PORTB=d
DelayMS 2
PORTB=0
PORTA=Dig Saat, 0
PORTB=e
DelayMS 2
PORTB=0
PORTA=Dig Saat, 1
PORTB=f
DelayMS 2
GoTo BAS
Dakikayi_Artir:
Dakika = Dakika + 1
Saniye = 0
EndIf
GoTo debounce
debounce:
For i = 1 To k
PORTB=0
PORTA=Dig Saniye, 0
PORTB=a
DelayMS 2
PORTB=0
PORTA=Dig Saniye, 1
PORTB=b
DelayMS 2
PORTB=0
PORTA=Dig Dakika, 0
PORTB=c
DelayMS 2
PORTB=0
PORTA=Dig Dakika, 1
PORTB=d
DelayMS 2
PORTB=0
PORTA=Dig Saat, 0
PORTB=e
DelayMS 2
PORTB=0
PORTA=Dig Saat, 1
PORTB=f
DelayMS 2
Next i
GoTo BAS
Disable
TickInt:
Tick = Tick + 1
Tick = 0
Saniye = Saniye + 1
Saniye = 0
Dakika = Dakika + 1
Dakika = 0
Saat = Saat + 1
If Saat >= 24 Then
Saat = 0
EndIf
EndIf
EndIf
tiCik: INTCON.2 = 0
Resume
Birde bu şekilde dene Proton ile derledim. ufak tefek hataların vardı ----- şu çizgilerin önüne (')kesme işareti koymamışsın ve intcon'a değer atamamışsın.
Başarılar.
agora_meyhanesi42
karbal656 emeğin için teşekkürler. Bendeki pc biraz eski ve güç kaynagının yarısı yanık bilgisayar tam derleme yapacakken kendine restart atıyor onun için bir türlü derleyemiyorum. Eğer zahmet olmazsa derlediğin hex dosyasını upload edermisin ama zahmet olmazsa
karbal656
:02000000522884
:0800080008008F018E00FF309B
:100010008E07031C8F07031C4D2803308D00DF3033
:10002000132007288D01E83E8C008D09FC30031C4D
:100030001C288C07031819288C0700008D0F19281D
:100040000C1822288C1C2628000026280800013EB7
:1000500093000A308E008F013120930B2C2810085A
:10006000080091019001103092000D0D900D910D3E
:100070000E0890020F08031C0F0F91020318472867
:100080000E0890070F0803180F0F910703108C0D2F
:100090008D0D920B35280C084D2883138312031302
:1000A0000000080083168501C03086008312950188
:1000B0009601970116309900553083168100A030C3
:1000C0008B008B17831267288B1B0800C5296420BF
:1000D0006420C0308600642001301B02031D72289A
:1000E00064209A0A642028301A02031D7E286420A6
:1000F00064209A0164206420163099006420861BD5
:100100009428642064209C01642064209D01642064
:1001100064209E01642064209F0164206420A0016B
:1001200064206420A101AC286420642020309C005D
:100130006420642010309D006420642008309E00FC
:100140006420642004309F00642064200230A000FA
:10015000642064200130A1006420061BBF286420B5
:10016000990364209908031DB92864206420013094
:100170009900642064209B0164203129C3286420F5
:10018000642001309B006420642086016420642088
:100190008D0117088C000030272085006420642022
:1001A0001C0886006420023005206420642086013B
:1001B000642064208D0117088C0001302720850001
:1001C000642064201D08860064200230052064201D
:1001D00064208601642064208D0116088C000030A4
:1001E00027208500642064201E08860064200230D9
:1001F0000520642064208601642064208D01160897
:100200008C00013027208500642064201F088600B0
:10021000642002300520642064208601642064206C
:100220008D0115088C000030272085006420642093
:1002300020088600642002300520642064208601A6
:10024000642064208D0115088C0001302720850072
:100250006420642021088600642002300520642088
:100260006B2864206420960A64203C301602031C2C
:100270004A2964206420960164206420950A642041
:1002800018301502031D472964206420950164205D
:100290006420970164204C296420013098001808DC
:1002A0001902031CC3296420642086016420642091
:1002B0008D0117088C000030272085006420642001
:1002C0001C0886006420023005206420642086011A
:1002D000642064208D0117088C00013027208500E0
:1002E000642064201D0886006420023005206420FC
:1002F00064208601642064208D0116088C00003083
:1003000027208500642064201E08860064200230B7
:100310000520642064208601642064208D01160875
:100320008C00013027208500642064201F0886008F
:10033000642002300520642064208601642064204B
:100340008D0115088C000030272085006420642072
:100350002008860064200230052064206420860185
:10036000642064208D0115088C0001302720850051
:100370006420642021088600642002300520642067
:10038000980A031D4F2964206B28940A3D301402FB
:100390000318CB29DE299401970A3C301702031C6D
:1003A000DE299701960A3C301602031CDE299601CD
:1003B000950A18301502031CDE2995010B119B08C4
:0803C000031DE3299701090068
:02400E00F13F80
:00000001FF
agora_meyhanesi42
Çok teşekkür ederim büyük bi sıkıntıma çare oldun
