Glcd 320x240 Proton Code
Başlatan gofe, 30 Ağustos 2008, 21:07:49
gofe
Arkadaşlar merhaba
320 240 glcd ekranım var basic plus  ile yazıyorum birşeyler ancak proton ile yazamadım proton için code örneği olan varsa verirse sevinirim.
gofe
Arkadaşlar kendim cevaplayayım dedm kodlar aşağıda.
cdataya istediğiniz resmi yapıştırın yeter.(yatay tarama)
Device = 18F452
    XTAL = 4
    TRISA   = 255
    TRISB   = 0
    TRISD   = 0
    TRISC.7 = 0
    Symbol gl_a0   PORTD.6
    Symbol gl_rd   PORTD.7
    Symbol gl_wr   PORTD.5
    Symbol gl_cs   PORTC.7
    Symbol gl_rst  PORTD.4
    Symbol gl_tris TRISB
    Dim SYS_SET As $40
    Dim SYS_SCROLL As $44
    Dim SYS_CUR_ADDR As $46
    Dim SYS_MWRITE As $42
    Dim IMLECSAGA As $4c
    Dim IMLECASAGI As $4f
    Dim LCD_NORMAL As 0
    Dim LINE1 As 0   'Line 1
    Dim LINE2 As 40   'Line 2
    Dim LINE3 As 80   'Line 3
    Dim LINE4 As 120   'Line 4
    Dim LINE5 As 160   'Line 5
    Dim LINE6 As 200   'Line 6
    Dim LINE7 As 240   'Line 7
    Dim LINE8 As 280   'Line 8
    Dim LINE9 As 320   'Line 9
    Dim LINE10 As 360   'Line 10
    Dim LINE11 As 400   'Line 11
    Dim LINE12 As 440   'Line 12
    Dim LINE13 As 480   'Line 13
    Dim LINE14 As 520   'Line 14
    Dim LINE15 As 560   'Line 15
    Dim LINE16 As 600   'Line 16
    Dim LCD_GRH As 2400   'Graphic home position
    Dim gl_cmd As Byte
    Dim IMLECDURUM As Byte
    Dim EKRANLA As Byte
    Dim SAY1 As Byte
    Dim gl_j As Byte
    Dim gl_x As Word
    Dim gl_y As Word
    Dim LCD_ADRES As Word
    Dim DEGER1 As Word
    Dim DEGER2 As Word
    DelayMS 1000
    Low gl_cs
    DelayMS 100
    High gl_rst
    DelayMS 1000
    GoTo MAIN
YAZ:
    Low gl_wr
    Low gl_a0
    High gl_rd
    PORTB=EKRANLA
    Low gl_rd
Return
send_cmd:
    Low gl_wr
    High gl_a0
    High gl_rd
    PORTB=gl_cmd
    Low gl_rd
Return
'========= GLCD INITILIZING =========
gl_init:
   gl_cmd = SYS_SET
   GoSub send_cmd
   For SAY1 = 0 To 7
   EKRANLA=LookUpL SAY1,[$34,$87,$0F,$27,$42,$EF,$28,$0]
   GoSub YAZ
   Next SAY1
   gl_cmd = SYS_SCROLL
   GoSub send_cmd
   For SAY1 = 0 To 8
   EKRANLA= LookUpL SAY1,[$0,$0,$EF,$60,$09,$EF,$0,$0,$0]
   GoSub YAZ
   Next SAY1
   'Hdot
   gl_cmd = $5A
   GoSub send_cmd
   EKRANLA =$00
   GoSub YAZ
   'Overlay
   gl_cmd = $5B
   GoSub send_cmd
   EKRANLA = $01
   GoSub YAZ
    'DISP OFF
   gl_cmd = $58
   GoSub send_cmd
   EKRANLA = $04
   GoSub YAZ
   gl_cmd = SYS_CUR_ADDR
   GoSub send_cmd
   EKRANLA = $0
   GoSub YAZ
   EKRANLA = $0
   GoSub YAZ
   DelayMS 1000
   'Clear Graphic screen
   GoSub GRFSIL
   'Clear Text screen
   GoSub TXTSIL
    'CSRW set cursor home
   GoSub send_cmd
   EKRANLA = $0
   GoSub YAZ
   EKRANLA = $0
   GoSub YAZ
    gl_cmd = $4C
   GoSub send_cmd
   EKRANLA = $42
   GoSub YAZ
   EKRANLA = $0
   GoSub YAZ
    'CSR FORM
   gl_cmd = $5D
   GoSub send_cmd
   EKRANLA = $0F
   GoSub YAZ
   EKRANLA = $87
   GoSub YAZ
   'CSR DIR
   gl_cmd = $4C
   GoSub send_cmd
      'DISP ON
   gl_cmd = $59
   GoSub send_cmd
   EKRANLA = $14
   GoSub YAZ
   DelayMS 1000
Return
'EKRANI TEMİZLE.
TXTSIL:
   GoSub send_cmd
   EKRANLA = $00
   GoSub YAZ
   EKRANLA = $00
   GoSub YAZ
    gl_cmd = $42
   GoSub send_cmd
    EKRANLA = LCD_NORMAL
   For SAY1 = 1 To 240
      For gl_j = 1 To 40
      GoSub YAZ
      Next gl_j
   Next SAY1
Return
GRFSIL:
   GoSub send_cmd
   EKRANLA = $60
   GoSub YAZ
   EKRANLA = $09
   GoSub YAZ
   gl_cmd = $42
   GoSub send_cmd
   For SAY1 = 1 To 240
      For gl_j = 1 To 40
      EKRANLA = $00
      GoSub YAZ
      Next gl_j
   Next SAY1
Return
gl_setaddr:
   gl_cmd = SYS_CUR_ADDR       'Address command
   GoSub send_cmd
   EKRANLA = LCD_ADRES.BYTE0     'text memory starts at $0 and graphics at $0960
   GoSub YAZ
   EKRANLA = LCD_ADRES.BYTE1
   GoSub YAZ
   gl_cmd = IMLECDURUM               'Set cursor movement to left,right,up or down
   GoSub send_cmd
Return
'End of subroutines
'             BEGIN MAIN PROGRAM
MAIN:
   GoSub gl_init
    DelayMS 1000
   GoSub GRFSIL
   GoSub TXTSIL
   GoSub MSJ1
   DelayMS 2000
   DelayMS 3000
   GoSub GRFSIL
   GoSub TXTSIL
   Cls
   GoSub LOGO
   DelayMS 2000
BEKLE:
DelayMS 1000
GoTo BEKLE
   GoTo  MAIN
MSJ1:
   LCD_ADRES = LINE15+2    'Line 6 and 9 bytes to right
   IMLECDURUM  = IMLECSAGA
   GoSub gl_setaddr
   gl_cmd =SYS_MWRITE
   GoSub send_cmd
   For SAY1 = 0 To 23
   EKRANLA=LookUpL SAY1,["WWW.picproje.ORG"]
   GoSub YAZ
   Next SAY1
LOGO:
  DEGER1=0
    DEGER2=39
    LCD_ADRES = LCD_GRH+40
    GoSub gl_setaddr
    gl_cmd =SYS_MWRITE
    GoSub send_cmd
YURU:
    For gl_x = DEGER1 To DEGER2
    EKRANLA=CRead RESIM1+gl_x
    GoSub YAZ
    Next
    LCD_ADRES =LCD_ADRES+40
    DEGER1=DEGER2+1
    DEGER2=DEGER2+40
    If DEGER2>=8790 Then DelayMS 2000: Return
    GoSub gl_setaddr
    gl_cmd =SYS_MWRITE
    GoSub send_cmd
    GoTo YURU
Return
RESIM1:
CData   $FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0C,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1E,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$3F,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$88,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$73,$80,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$10,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$01,$98,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$E1,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$98,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$01,$98,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$C0,$E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$98,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$03,$B8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$DC,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$03,$B8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07,$00,$38,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$DC,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$07,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0F,$00,$3C,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FE,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$07,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1E,$00,$1E,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FE,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$0F,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$3C,$00,$0F,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FF,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$0F,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$78,$00,$07,$80,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FF,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$1F,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FF,$80,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$1F,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$E0,$00,$01,$E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FF,$80,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$3F,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$C0,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FF,$C0,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$3B,$B8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07,$80,$00,$00,$78,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$DD,$C0,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$7F,$B8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0F,$00,$00,$00,$3C,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$DF,$E0,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$77,$38,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1E,$00,$00,$00,$1E,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$CE,$E0,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$FF,$38,$00,$00,$00,$00,$00,$00,$00,$00,$00,$3C,$00,$00,$00,$0F,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$CF,$F0,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$EE,$38,$00,$00,$00,$00,$00,$00,$00,$00,$00,$78,$00,$00,$00,$07,$80,$00,$00,$00,$00,$00,$00,$00,$00,$01,$C7,$70,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$01,$FE,$38,$00,$00,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$00,$00,$03,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$01,$C7,$F8,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$03,$FC,$38,$00,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$01,$C3,$FC,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$03,$B8,$38,$00,$00,$00,$00,$00,$00,$00,$00,$01,$E0,$00,$00,$00,$01,$E0,$00,$00,$00,$00,$00,$00,$00,$00,$01,$C1,$DC,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$07,$F8,$38,$00,$00,$00,$00,$00,$00,$00,$00,$03,$C0,$00,$00,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$01,$C1,$FE,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$07,$F8,$38,$00,$00,$00,$00,$00,$00,$00,$00,$07,$80,$00,$00,$00,$00,$78,$00,$00,$00,$00,$00,$00,$00,$00,$01,$C1,$FE,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$03,$B8,$38,$00,$00,$00,$00,$00,$00,$00,$00,$0F,$00,$00,$00,$00,$00,$3C,$00,$00,$00,$00,$00,$00,$00,$00,$01,$C1,$DC,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$03,$FC,$38,$00,$00,$00,$00,$00,$00,$00,$00,$1E,$00,$00,$00,$00,$00,$1E,$00,$00,$00,$00,$00,$00,$00,$00,$01,$C3,$FC,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$01,$DC,$38,$00,$00,$00,$00,$00,$00,$00,$00,$3F,$FF,$FF,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$01,$C3,$B8,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$01,$FE,$38,$00,$00,$00,$00,$00,$00,$00,$00,$7F,$FF,$FF,$FF,$FF,$FF,$FF,$80,$00,$00,$00,$00,$00,$00,$00,$01,$C7,$F8,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$EE,$38,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$C0,$00,$00,$00,$00,$00,$00,$00,$01,$C7,$70,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$77,$38,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$CE,$E0,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$77,$38,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$C0,$00,$00,$00,$00,$00,$00,$00,$01,$CE,$E0,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$3B,$B8,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$C0,$00,$00,$00,$00,$00,$00,$00,$01,$DD,$C0,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$3B,$B8,$00,$00,$00,$00,$00,$00,$00,$00,$7F,$FF,$FF,$FF,$FF,$FF,$FF,$80,$00,$00,$00,$00,$00,$00,$00,$01,$DD,$C0,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$1F,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$3F,$FF,$FF,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FF,$80,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$1F,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$1E,$00,$00,$00,$00,$00,$1E,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FF,$80,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$0F,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$0F,$00,$00,$00,$00,$00,$3C,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FF,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$0F,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$07,$80,$00,$00,$00,$00,$78,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FF,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$07,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$03,$C0,$00,$00,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FE,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$07,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$01,$C0,$00,$00,$00,$00,$E0,$00,$00,$00,$00,$00,$00,$00,$00,$01,$FE,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$03,$B8,$00,$00,$00,$00,$00,$00,$00,$00,$01,$E0,$00,$00,$00,$01,$E0,$00,$00,$00,$00,$00,$00,$00,$00,$01,$DC,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$03,$B8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$00,$00,$03,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$01,$DC,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$03,$B8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$78,$00,$00,$00,$07,$80,$00,$00,$00,$00,$00,$00,$00,$00,$01,$DC,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$01,$98,$00,$00,$00,$00,$00,$00,$00,$00,$00,$3C,$00,$00,$00,$0F,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$98,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$01,$98,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1E,$00,$00,$00,$1E,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$98,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$88,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0F,$00,$00,$00,$3C,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$10,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07,$80,$00,$00,$78,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$C0,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$E0,$00,$01,$E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$78,$00,$07,$80,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$3C,$00,$0F,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1E,$00,$1E,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$0F,$00,$3C,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07,$80,$78,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$C0,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$01,$E1,$E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$F3,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$7F,$80,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$04,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$01,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$70,$00,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$01,$C0,$E0,$00,$07
CData   $E0,$00,$00,$01,$C1,$FE,$00,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$0F,$F8,$E0,$00,$07
CData   $E0,$00,$00,$01,$C3,$FF,$00,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$1F,$FC,$E0,$00,$07
CData   $E0,$00,$00,$01,$C7,$FF,$80,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$3F,$FE,$E0,$00,$07
CData   $E0,$00,$00,$01,$CF,$C7,$C0,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$3F,$1F,$E0,$00,$07
CData   $E0,$00,$00,$01,$CF,$C3,$C0,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$7F,$0F,$E0,$00,$07
CData   $E0,$00,$00,$01,$DF,$C1,$C0,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$7F,$07,$E0,$00,$07
CData   $E0,$00,$00,$01,$DF,$C1,$C0,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$77,$07,$E0,$00,$07
CData   $E0,$00,$00,$01,$DE,$01,$C0,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$78,$0F,$E0,$00,$07
CData   $E0,$00,$00,$01,$CF,$03,$C0,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$3C,$0F,$E0,$00,$07
CData   $E0,$00,$00,$01,$CF,$07,$80,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$3C,$1E,$E0,$00,$07
CData   $E0,$00,$00,$01,$C7,$87,$80,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$1E,$3C,$E0,$00,$07
CData   $E0,$00,$00,$01,$C3,$DF,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$0F,$78,$E0,$00,$07
CData   $E0,$00,$00,$01,$C1,$FE,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$07,$F0,$E0,$00,$07
CData   $E0,$00,$00,$01,$C1,$FE,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$07,$F0,$E0,$00,$07
CData   $E0,$00,$00,$01,$C1,$FC,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$07,$F0,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$F8,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$03,$E0,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$07
CData   $E0,$00,$00,$01,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$E0,$00,$07
CData   $E0,$00,$00,$01,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$F0,$00,$03,$80,$30,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$E0,$00,$07
CData   $E0,$00,$00,$01,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$F0,$00,$03,$80,$78,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$E0,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$FC,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$83,$FF,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$87,$FF,$80,$00,$00,$00,$00,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$8F,$FF,$C0,$00,$00,$00,$00,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$9F,$FF,$E0,$00,$00,$00,$00,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$BF,$FF,$F0,$00,$00,$00,$00,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$FF,$FF,$F8,$00,$00,$00,$00,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$FF,$FF,$FC,$00,$00,$00,$00,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$03,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$01,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$F0,$00,$03,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$F0,$00,$03,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$FF,$FF,$F0,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$FF,$FF,$E0,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$BF,$FF,$C0,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$9F,$FF,$80,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$8F,$FF,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$83,$FC,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$81,$F8,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$80,$F0,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$80,$60,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$03,$80,$40,$00,$00,$00,$00,$00,$00,$00,$F0,$00,$03,$80,$00,$00,$00,$00,$00,$00,$00,$00,$E0,$00,$07
CData   $E0,$00,$00,$01,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
CData   $E0,$00,$00,$01,$C0,$00,$00,$00,$00,$00,$00,$00,$00,$70,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$07
End
pcb
plot x,y uygulamasını hangi kodla yapabiliriz acaba ?
oooben
eline sağlık ama proton ide kullanıyorum key hatası veriyor usb key not found yazıyor yardım edersen çok sevinirim benimde bi glcd projem var ve tam aradığım şeyi yayınlamışsın süüüüüpeeeeersin hocam emeğine sağlık...
gofe
bu bir program sorunu yazılan kod ile alakalı değil.
oooben
ilginize teşekkür ederim. key hatasını nasıl çözebilirim derken, aslında bi key kısayolu atan olurmu diye sormak istemiştim lütfen ukalalık olarak almayın "bu arada arşivimden gerekli keyi bulup çaktım " isteyen olursa elimdeki dosyaları paylaşabilirim. Eğer mümkünse proton kod anlatımı veya glcd ve wg320*240c0  serisine ait bi proton örneği olan arkadaş varmı . yardımcı olurmusunuz lütfen
birde, wg320*240 c0 ın çipsetini kullanmayı bilmiyorum yardımcı olurmusunuz saygılar yardımlarınız için şimdiden tşkler...
ahmet2004
gofe arkadaşımızın yazdığı kodu denedinizmi oooben?
oooben
ahmet hocam öncelikle saygılar.
daha önce bu konularda yaptığınız çalışmalarınızdan dolayı sizi kutlarım
elleriniz emekleriniz boşa gitmiyor inanın saatlerce çalışıyoruz size ve sizin gibi ustalarımızı takip edebilmek için saygılar...
goff arkadaşımın yayınladığı kodu denemeyi çok isterim hocam ama isis te "7.4sp3 kullanıyorum" nasıl yapılabilirmi onu araştırıyordum ki hocam siz yazdınız acaba isiste simule edebilirmiyim yoksa direkt olarak yapmam mı gerekir işin doğrusu onu araştırıyordum.şimdiden teşekkür ederim .
ahmet2004
Proteusta 320x240 yok neden proteusla uğraşıyorsunki?
Breadboard üzerine devreni yap çalıştır öncelikle.
oooben
1---- VSS 0V Ground
2---- VDD 5.0V Power supply for Logic
3----- VO (Variable) Driving voltage for LCD
4 -----E H/L Start enable signal to read or write the data
5 -----R/W H/L
R/W signal input is used to select the read/write mode
High = Read mode , Low = Write mode
6 -----A0 H/L
R/W=L, A0=H: Command Write A0=L: Data Write
R/W=H, A0=H: Status Read A0=L: Data Read
7~14 DB0~DB7 H/L Data bus line
15----- CS H/L Chip select ,Active L
16 -----RES H/L Controller reset signal, Active L
17 -----VEE -25V Negative voltage output (Optional)
18 -----FGND Frame Ground
19 NC No connection
20 NC No connection
DELİKLİ PERTİNAX İLE YAPMAYA ÇALIŞIYORUM HOCAM
burada RW VE RD YI BULAMIYORUM
BU ARADA DEVREYİ YAPARKEN 16F877A KULLANICAM PROTON DAN HEXİ ALDIM SORUN OLURMU ACABA
ŞİMDİDEN TEŞEKKÜRLER
PORTD6-( A0 ) -6 YA
PORTB0-7
PB1-8
PB2-9
PB3-10
PB4-11
PB5-12
PB6-13
PB7-14
CS--15
RES-16
WR VE RD NEREYE ANLAYAMADIM
TEKRAR TEŞEKKÜRLER
oooben
ASLINDA GÖZÜMÜZÜN ÖNÜNDE OLAN Bİ ŞEYI GÖREMIYORUZ
BU KONUDA O KADAR ÇOK DÖKÜMAN OKUDUM VE BU KOBUYU ARASTIRIRKEN O KADAR FAZLA BASKA DÖKÜMANA ULASTIM Kİ ANŞLATAMAM OKUMAK İNCELEMEK DERKEN ... Bİ DE BAKICAMIZ YERİ BİLMİYORUZ SAOLUN HOCAM İNANIN ÇOK MUTLU OLDUM ÇOK İYİSİNİZ ..
SAYGILAR ...
oooben
ahmet hocam, gönderdiğiniz açık şema doğrultusunda devreyi delikli pertinaxta burada yayınlanan yazılımla sadece 3 değisiklik yaparak uyguladım
1 frgn ( 18 nolu bacak toprağa )
2 pot 47k
3 18f452 yerine de  16f 877a kullandım protonda düzeltme de yaptım
acaba nasıl bi hata yapmışım veya yapmış olabilirim şimdiden yardımlarınız için teşekkür ederim
oooben
v0 da -2.60 gibi bi değer var acaba doğrumu
teşekkür ederim saygılar hocam
ahmet2004
VEE ~= -24 volt
VO  ~= -19.5 volt
