Örnek Program
Başlatan Mehemet, 20 Ekim 2008, 16:39:03
Mehemet
Bir firma için tasarladığım ilk programım. Belki program yazarken ufakta olsa size katkı sağlayabilir.
'*  Name    : Mehemet.BAS                                *
'*  Author  : [select VIEW...EDITOR OPTIONS]                    *
'*  Notice  : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
'*          : All Rights Reserved                               *
'*  Date    : 16.07.2008                                        *
'*  Version : 1.0                                               *
'*  Notes   : revize edilmedi                                   *
@ DEVICE PIC16F877A
@ DEVICE PIC16F877A, WDT_on
@ DEVICE PIC16F877A, PWRT_ON
@ DEVICE PIC16F877A, PROTECT_OFF
@ DEVICE PIC16F877A, XT_OSC
TRISA = 255 '{PORTA input}'
TRISB = 0
TRISC = %11111110
TRISD = 0
TRISE = %011
PORTC = 0
PORTA = %00000
PORTD = 0
PORTB = 0
PORTE = %000
DEFINE OSC 4
DEFINE LCD_DREG	PORTB
DEFINE LCD_DBIT		4
DEFINE LCD_EREG	PORTB
DEFINE LCD_EBIT		3
define LCD RWREG         PORTB
define LCD_RWBIT      2
DEFINE LCD_RSREG	PORTB
DEFINE LCD_RSBIT	1
DEFINE LCD_BITS		4
DEFINE LCD_LINES	2
pause 500
DEFINE	ADC_BITS	10
DEFINE	ADC_CLOCK	3
DEFINE	ADC_SAMPLEUS 100
DEFINE BUTTON_PAUSE 50
ADCON1 = %10001001 '{ 6/0 PA0-3,PA5,PE0}
  '{Part of Variable }
'___________________________________________________________________
Blg1 VAR WORD
Blg2 VAR WORD
Blg3 VAR WORD
Blg4 VAR WORD
Blg5 VAR WORD
Blg6 VAR WORD
SET1 VAR BYTE
SET2 VAR BYTE
SET3 VAR BYTE
SET4 VAR BYTE
SET5 VAR BYTE
SET6 VAR BYTE
SET VAR BYTE
V1 VAR WORD
V2 VAR WORD
V3 VAR WORD
V4 VAR WORD
V5 VAR WORD
V6 VAR WORD
MOD30 VAR WORD
MOD30A VAR WORD
ADRS VAR BYTE  ' KAYIT ADRESI DEGIŞKENI
ADRS1 VAR BYTE
ADRS2 VAR BYTE  'BOLGE BULUCU
ADRSDOWN  VAR BYTE   'METAL SAYICISI
X1 var byte
bolgeadi var byte
MEM VAR BYTE
SAYI VAR BYTE
ONLAR VAR BYTE
BIRLER VAR BYTE
SN VAR BYTE
DK VAR BYTE
SAAT VAR BYTE
GUN VAR BYTE
AY VAR BYTE
YIL VAR BYTE
HAFTA VAR BYTE
RTCKONTROL VAR BYTE
RESET_TUSU VAR PORTC.1            'RESET PINI
GENEL_ARIZA VAR PORTC.0
RUN VAR PORTD.0
BOLGE1_LED VAR PORTD.1
BOLGE2_LED VAR PORTD.2        'LED PINLERI
BOLGE3_LED VAR PORTD.3
BOLGE4_LED VAR PORTD.4
BOLGE5_LED VAR PORTD.5
BOLGE6_LED VAR PORTD.6
SCLK VAR PORTD.7
IO VAR PORTE.2                 'RTC PİNLERİ
CE VAR PORTB.0
UP VAR PORTC.5
DOWN VAR PORTC.4
ENTER VAR PORTC.6
RIGHT VAR PORTC.3             ' TUŞ PINLERI
LEFT VAR PORTC.2
MENU VAR PORTE.1
ESCAPE VAR PORTC.7
 X VAR BYTE
CNTR2 VAR BYTE
CNTR VAR BYTE
ZMN VAR BYTE
KONTROL VAR BYTE
SIFRE VAR BYTE
SIFRE2 VAR WORD
SIFRE3 VAR BYTE
SIFRE4 VAR WORD
SIFRE5 VAR WORD
SIFRE6 VAR WORD
'WRITE 0,255
'WRITE 1,255
SCLK = 0
Low CE
ADRS = 7
SIFRE3 = 4
SIFRE2 = 0
SIFRE = 0
PORTB.2 = 0               '{ RW bacağını ekrana yazmak}
PAUSE 1000
LCDOUT $FE,1
'GENEL_ARIZA = 1
'goto start1
' **************** OKUMA ALANI **************************
KALIBRASYON :
  FOR ZMN = 1  TO 25
  LCDOUT $FE,1,"KALIBRASYON..."
   BOLGE1_LED = 1
   BOLGE2_LED = 1
    BOLGE3_LED = 1
     BOLGE4_LED = 1
      BOLGE5_LED = 1
       BOLGE6_LED = 1
       RUN = 1
       PAUSE 500
  LCDOUT $FE,1
         BOLGE1_LED = 0
   BOLGE2_LED = 0
    BOLGE3_LED = 0
     BOLGE4_LED = 0
      BOLGE5_LED = 0
       BOLGE6_LED = 0
       RUN = 0
       PAUSE 500
  NEXT
START1 :
ADRS = 7
  READ 2,ADRSDOWN
  IF ADRSDOWN = 255 THEN
     ADRSDOWN = 0
    ENDIF
READ 3,SET1
    IF SET1 = 255 THEN
     SET1 = 20
    ENDIF
READ 4,SET2
    IF SET2 = 255 THEN
     SET2 = 20
    ENDIF
READ 5,SET3
    IF SET3 = 255 THEN
     SET3 = 20
    ENDIF
READ 6,SET4
    IF SET4 = 255 THEN
     SET4 = 20
    ENDIF
READ 7,SET5
    IF SET5 = 255 THEN
     SET5 = 20
    ENDIF
READ 8,SET6
    IF SET6 = 255 THEN
     SET6 = 20
    ENDIF
' **************** ANA PROGRAM BLOĞU ********************
START :
'LCDOUT $FE,1
    LCdout $FE,1,"MODEL"'        RUN"
    LCDOUT $FE,$8C,"RUN"
    LCDOUT $FE,$C0,"FIRMA ISMI."
'____________________________________________________________________
STARTa :
RESET_TUSU = 0
GENEL_ARIZA = 0
RUN = 1
    IF MENU = 1 THEN
        GENEL_ARIZA = 1
        RUN = 0
        SIFRE = 0                 'MENUYE GIRIŞ
        SIFRE2 = 0
        LCDOUT $FE,1
        GOTO SIFRE_ALANI1
'        GOTO MENUGIRIS
    ENDIF
    ADCiN 0,Blg1
V1 = 4 * ((blg1*25) / (1023))
    IF V1 >= SET1 THEN
      BOLGE1_LED = 1
        ADRS2 = 1
        GOTO HATAOKU
    ENDIF
    ADCIN 1,Blg2
V2 = 4 * ((blg2*25) / (1023))
    IF V2 >= SET2 THEN
         HIGH BOLGE2_LED
        ADRS2 = 2
         GOTO HATAOKU
    ENDIF
    ADCIN 2,Blg3
V3 = 4 * ((blg3*25) / (1023))
    IF V3 >= SET3 THEN
        BOLGE3_LED = 1
        ADRS2 = 3
         GOTO HATAOKU
    ENDIF
    ADCIN 3,Blg4
V4 = 4 * ((blg4*25) / (1023))
    IF V4 >= SET4 THEN
        ADRS2 = 4
        BOLGE4_LED = 1
         GOTO HATAOKU
    ENDIF
    ADCIN 4,Blg5
V5 = 4 * ((blg5*25) / (1023))
    IF V5 >= SET5 THEN
    BOLGE5_LED = 1
    ADRS2 = 5
     GOTO HATAOKU
    ENDIF
    ADCIN 5,Blg6
V6 = 4 * ((blg6*25) / (1023))
    IF V6 >= SET6 THEN
        ADRS2 = 6
        BOLGE6_LED = 1
        GOTO HATAOKU
    ENDIF
    GOTO STARTa
' **************** HATA OKUMA ALANI *********************
HATAOKU :
   GENEL_ARIZA = 1
   RUN = 0
  IF ADRS2 = 1 THEN SET = SET1
  IF ADRS2 = 2 THEN SET = SET2
  IF ADRS2 = 3 THEN SET = SET3
  IF ADRS2 = 4 THEN SET = SET4
  IF ADRS2 = 5 THEN SET = SET5
  IF ADRS2 = 6 THEN SET = SET6
HATAOKU1 :
 GOSUB OKUMA
 GOSUB MATCH
  BLG2 = 4 * (( BLG1 * 25 ) / (1023))
  IF SET > BLG2 THEN
   GOTO HATAEKRANI
  ENDIF
 GOTO HATAOKU1
 OKUMA :
  ADCIN (ADRS2 - 1),BLG1
  'PAUSEUS 1
  RETURN
 MATCH :
    IF BLG1 > BLG3 THEN
    BLG3 = BLG1
    ENDIF
    RETURN
HATAEKRANI :
    IF ADRSDOWN = 121 THEN
        LCDOUT $FE,1
        FOR X = 9 TO  218
        WRITE X,255
        LCDOUT $FE,2,"KAYITLAR SILINDI"        '60 KAYIT SONRASINI SİL
        NEXT
        PAUSE 300
        ADRSDOWN = 0
    ENDIF
     BLG2 = 4 * (( BLG3 * 25 ) / (1023))
     IF BLG2 < SET THEN BLG2 = SET
    LCDOUT $FE,1,#ADRS2,".BLG METAL VAR"
    LCDOUT $FE,$C0,"MTL=",#BLG2," SET=",#SET
    ADRSDOWN = ADRSDOWN + 1
    MOD30 = ADRSDOWN
    GOSUB METAL_SAYICI_DUZENLEME
    ADRS = ( ( MOD30 ) * 7 ) + 7
    WRITE ( ADRS - 5 ),ADRS2
    WRITE ( ADRS - 4 ),BLG2
    GOsub RTC_OKU :    ' RTCDEN   ZAMAN OKUMA
    WRITE ( ADRS - 3 ),DK
    WRITE ( ADRS - 2 ),SAAT
    WRITE ( ADRS - 1 ),GUN
    WRITE ADRS,AY
    WRITE ( ADRS + 1 ),YIL
    GOTO SON
SON:
   WRITE 2,ADRSDOWN
    IF PORTC.1 = 1 THEN
     WHILE PORTC.1 = 1
     WEND
       BOLGE1_LED = 0
       BOLGE2_LED = 0
       BOLGE3_LED = 0
       BOLGE4_LED = 0
       BOLGE5_LED = 0
       BOLGE6_LED = 0
        GOTO START
    ENDIF
    GOTO SON
' **************** ŞİFRE ALANII  ************************
SIFRE_ALANI1 :
    READ 0,SIFRE6.LOWBYTE
    READ 1,SIFRE6.HIGHBYTE        ' ŞİFREYİ OKU
    IF SIFRE6 = 65535 THEN
        SIFRE6 = 1956              ' YENI PROGRAMLANMIŞSA 1956 ŞİFRE KABUL ET
    ENDIF
SIFRE_ALANI :
    LCDOUT $FE,$C0,#SIFRE
    LCDOUT $FE,2,"SIFRE:"
    IF ESCAPE = 1 THEN
        GOTO START
    ENDIF
    IF UP = 1 THEN
            WHILE UP = 1 : WEND
            SIFRE = SIFRE + 1
            IF SIFRE = 10 THEN
                    SIFRE = 0
            ENDIF
    ENDIF
  IF DOWN = 1 THEN
       WHILE DOWN = 1 : WEND
       SIFRE = SIFRE - 1
       IF SIFRE = 255 THEN
            SIFRE = 9
       ENDIF
 ENDIF
 IF ENTER = 1 THEN
     WHILE ENTER= 1 : WEND
     SIFRE3 = SIFRE3 - 1
     LCDOUT $FE,1
     IF SIFRE3 = 0 THEN
        GOSUB BIRLER_ALANI
        IF SIFRE2 = SIFRE6  THEN
            LCDOUT $FE,1
 DONGU :
            SIFRE2 = 0
            LCDOUT $FE,2,"MENU"
            LCDOUT $FE,$C0,"YENI SIFRE"
            lcDOUT $FE,$CB,"(ENT)"
            lcDOUT $FE,$8A,"(MENU)"
            IF MENU = 1 THEN MENUGIRIS
                IF ENTER  = 1  THEN
                    WHILE ENTER = 1 :WEND
                    GOTO SIFRE_DEGISTIR1
                ENDIF
                GOTO DONGU
        ELSE
            LCDOUT $FE,1,"HATALI GIRIS"
            PAUSE 1500
            LCDOUT $FE,1
        ENDIF
     ENDIF
     IF SIFRE3 = 1 THEN GOSUB ONLAR_ALANI
     IF SIFRE3 = 2 THEN GOSUB YUZLER_ALANI
     IF SIFRE3 = 3 THEN GOSUB BINLER_ALANI
 ENDIF
'LCDOUT $FE,2,"SIFRE :",DEC4 SIFRE2
 IF SIFRE3 = 0 THEN
  SIFRE2 = 0
  SIFRE3 = 4
  ENDIF
    GOTO SIFRE_ALANI
BIRLER_ALANI :
    LCDOUT $FE,$86,"****"
    SIFRE2 = SIFRE2 + SIFRE
    SIFRE = 0
    RETURN
ONLAR_ALANI :
    LCDOUT $FE,$86,"***"
    SIFRE2 = SIFRE2 + ( 10 * SIFRE)
    SIFRE = 0
    RETURN
YUZLER_ALANI :
    LCDOUT $FE,$86,"**"
    SIFRE2 = SIFRE2 + ( 100 * SIFRE)
    SIFRE = 0
    RETURN
BINLER_ALANI  :
    LCDOUT $FE,$86,"*"
    SIFRE2 = SIFRE2 + ( 1000 * SIFRE)
    SIFRE = 0
    RETURN
SIFRE_DEGISTIR1 :
    LCDOUT $FE,1
    SIFRE3 = 4
    SIFRE2 = 0
    X = 1
SIFRE_DEGISTIR :
    LCDOUT $FE,$8B,"(",#X,")"
    IF UP = 1 THEN
        WHILE UP = 1 : WEND
        SIFRE = SIFRE + 1
        IF SIFRE = 10 THEN
              SIFRE = 0
        ENDIF
    ENDIF
  IF DOWN = 1 THEN
       SIFRE = SIFRE - 1
       IF SIFRE = 255 THEN
            SIFRE = 9
       ENDIF
   ENDIF
   IF ESCAPE = 1 THEN START
   IF ENTER = 1 THEN
        SIFRE3 = SIFRE3 - 1
        LCDOUT $FE,1
        'BRANCHL SIFRE3 , [MOD_BIRLER , MOD_ONLAR, MOD_YUZLER,MOD_BINLER]
        IF SIFRE3 = 0 THEN
                  GOSUB BIRLER_ALANI
                  X = X + 1 ' 2 KEZ DOĞRULATMA SAYACI
                  IF X = 2 THEN
                        SIFRE4 = SIFRE2
                  ENDIF
          IF X >= 3 THEN
             X = 1
            SIFRE5 = SIFRE2
            IF SIFRE4 = SIFRE5 THEN
               WRITE 0, SIFRE5.LOWBYTE
                WRITE 1, SIFRE5.HighBYTE
               LCDOUT $FE,1,"SIFRE KAYIT OK"
               PAUSE 1000
               GOTO MENUGIRIS
            ELSE
              PAUSE 1000
           ENDIF
           LCDOUT $FE,1
        ENDIF
        SIFRE2 = 0
      ENDIF
   ENDIF
  IF SIFRE3 = 0 THEN
  SIFRE2 = 0
  SIFRE3 = 4
  ENDIF
 GOTO SIFRE_DEGISTIR
'***************** menü BOLGE AYARLARI ******************
MENUGIRIS :
MENUSECIM1a :
LCDOUT $FE,1
MENUSECIM1 :
    LCDOUT $FE,2,"BOLGE HASSASIYET"
    LCDOUT $FE,$C0,"AYARLARI"
    IF ENTER = 1 THEN
        WHILE ENTER = 1
        WEND
        bolgeadi = 1
        GOTO  SETMENUBLG
    ENDIF
    IF RIGHT = 1 THEN
         WHILE RIGHT = 1
        WEND
        GOTO  MENUSECIM2a
    ENDIF
    IF LEFT = 1 THEN
         WHILE LEFT = 1
        WEND
        GOTO MENUSECIM4a
    ENDIF
    GOTO MENUSECIM1
' *************** menü ZAMAN AYARLARI *******************
MENUSECIM2a :
LCDOUT $FE,1
MENUSECIM2 :
    LCDOUT $FE,2,"ZAMAN AYARLARI"
    IF ENTER = 1 THEN
    WHILE ENTER = 1
        WEND
        GOTO TIME
    ENDIF
    IF RIGHT = 1 THEN
          WHILE RIGHT = 1
        WEND
         GOTO MENUSECIM3a
    ENDIF
    IF LEFT = 1 THEN
       WHILE LEFT = 1
        WEND
        GOTO MENUSECIM1a
    ENDIF
    GOTO MENUSECIM2
'***************** menü fabrıka ayarları  *******************
MENUSECIM3a :
LCDOUT $FE,1
MENUSECIM3 :
    LCDOUT $FE,2,"FABRIKA AYARLARI"
    IF ENTER = 1 THEN
       WHILE ENTER = 1
        WEND
        LCDOUT $FE,1
        GOTO  SETFABRIKA
    ENDIF
    IF RIGHT = 1 THEN
         WHILE RIGHT = 1
        WEND
        GOTO  MENUSECIM4a
    ENDIF
    IF LEFT = 1 THEN
        WHILE LEFT = 1
        WEND
        GOTO MENUSECIM2a
    ENDIF
    GOTO MENUSECIM3
 '********************** menü  hafıza *******************
MENUSECIM4a :
  LCDOUT $FE,1
MENUSECIM4 :
    LCDOUT $FE,2,"KAYITLAR"
    LCDOUT $FE,$C0,"MTL.AD.:",#ADRSDOWN
    LCDOUT $FE,$CB,"(ENT)"
    IF ENTER = 1 THEN
    WHILE ENTER = 1
    WEND
        GOTO HATAGORUNTULEME
    ENDIF
    IF RIGHT = 1 THEN
        WHILE RIGHT = 1
        WEND
        GOTO MENUSECIM1a
    ENDIF
    IF LEFT = 1 THEN
        WHILE LEFT = 1
        WEND
        GOTO MENUSECIM3a
    ENDIF
    CNTR = 0    '
    GOTO MENUSECIM4
'*************  SET AYARLAMA BÖLÜMÜ **************************
                       'BİRLEŞTİRİLİDİ
'*************  SET BÖLGE DEĞİŞİM BÖLÜMÜ *********************
SETMENUBLG :
        LCDOUT $FE,1
        IF bolgeadi = 1 then CNTR = SET1
        IF bolgeadi = 2 then CNTR = SET2
        IF bolgeadi = 3 then CNTR = SET3
        IF bolgeadi = 4 then CNTR = SET4
        IF bolgeadi = 5 then CNTR = SET5
        IF bolgeadi = 6 then CNTR = SET6
SETMENUBLGA :
    IF ENTER = 1 THEN
       WHILE ENTER = 1
        WEND
      GOTO SETKAYIT
    ENDIF
    LCDOUT $FE,$80,"BOLGE:",#bolgeadi',"   (ENT)"
    LCDOUT $FE,$8B,"(<->)"
    LCDOUT $FE,$C0,"SET  :",#CNTR',"   (ENT)"
    LCDOUT $FE,$CB,"(Y-A)"
    PAUSE 200
    IF RIGHT = 1 THEN BlgdgstrARTAN           'bölge değiştirme şartı
    IF LEFT = 1 THEN BlgdgtrAZAL
    IF UP = 1 THEN
        GOSUB UPER
    ENDIF
    IF DOWN = 1 THEN
        GOSUB DOWNER
    ENDIF
    IF MENU = 1 OR ESCAPE = 1 THEN
     WHILE ESCAPE = 1 : WEND
        GOTO MENUGIRIS
    ENDIF
    GOTO SETMENUBLGA
'*************  SET BÖLGE ARTIRMA BÖLÜMÜ *********************
BlgdgstrARTAN :
    bolgeadi = bolgeadi + 1
    if bolgeadi > 6 then
           bolgeadi = 1
    endif
    GOTO SETMENUBLG
'*************  SET BÖLGE AZALTMA BÖLÜMÜ *********************
BlgdgtrAZAL :
    bolgeadi = bolgeadi - 1
    IF bolgeadi = 0  then
           bolgeadi = 6
    endif
    goto SETMENUBLG
UPER :
    IF CNTR >= 100 THEN
           CNTR = 1
    ENDIF
    CNTR = CNTR + 1
    PAUSE 200
    RETURN
DOWNER :
    IF CNTR = 0 THEN
           CNTR = 101
    ENDIF
    CNTR = CNTR - 1
    PAUSE 200
    RETURN
'*************  SET KAYIT BÖLÜMÜ *****************************
SETKAYIT :
    BRANCHl ( bolgeadi - 1 ),[ST1,ST2,ST3,ST4,ST5,ST6]
ST1 :
    SET1 = CNTR
    write 3,SET1                               'K
    GOTO KAYIT_LCD                             'A
'______________________________________________'Y_____________________
ST2 :                                          'I
    SET2 = CNTR                                'T
    write 4,SET2
    GOTO KAYIT_LCD                             'B
'______________________________________________'Ö_____________________
ST3 :                                          'L
    SET3 = CNTR                                'Ü
    write 5,SET3                               'M
   GOTO KAYIT_LCD                              'Ü
ST4 :
    SET4 = CNTR
    write 6,SET4
   GOTO KAYIT_LCD
ST5 :
    SET5 = CNTR
    write 7,SET5
    GOTO KAYIT_LCD
ST6 :
    SET6 = CNTR
    write 8,SET6
KAYIT_LCD:
    LCDOUT $FE,1,#bolgeadi,".BOLGE KAYIT OK"
    LCDOUT $FE,$C0,"SET:",#CNTR
    pause 2000
    GOTO SETMENUBLG
'*************  HAFIZA  BÖLÜMÜ *******************************
HATAGORUNTULEME :
 LCDOUT $FE,1
HATAGORUNTULEME1 :
    LCDOUT $FE,2,"KAYIT OKU"
    lcDOUT $FE,$8B,"(ENT)"
    LCDOUT $FE,$c0,"KAYIT SIL"
    lcDOUT $FE,$CC,"(<>)"
    IF ENTER = 1 THEN
      WHILE ENTER = 1
      WEND
         CNTR = 1
         ADRS = 14
        GOTO HAFIZABLM2
    ENDIF
    IF LEFT = 1 OR RIGHT = 1 THEN
         WHILE LEFT = 1
         WEND
         LCDOUT $FE,1
         FOR X = 9 TO  217 ' 217 ADRES ALANI SIL
            WRITE X,255
         NEXT
         ADRS = 7
         ADRSDOWN = 0
        GOTO MENUSECIM4
       ENDIF
       IF ESCAPE = 1 THEN
        GOTO MENUSECIM4a
        ENDIF
  GOTO HATAGORUNTULEME1
HAFIZABLM2 :
    IF ADRSDOWN = 0 THEN
       LCDOUT $FE,1,"KAYIT BULUNAMADI"
       PAUSE 2000
       GOTO MENUSECIM4a
    ENDIF
    IF MENU = 1 THEN
        V1 = 0
        V2 = 0
        MOD30 = ADRSDOWN
       ADRS = (( MOD30 * 7 ) + ( 7 ))
        GOTO MENUGIRIS
    ENDIF
    IF ESCAPE = 1 THEN
        V1 = 0
        V2 = 0
        MOD30 = ADRSDOWN
        ADRS = (( MOD30* 7 ) + ( 7 ))
    ENDIF
    IF UP = 1 THEN
     WHILE UP = 1 : WEND
          CNTR = CNTR + 1
          ADRS = ADRS + 7        '2
    ENDIF
    IF DOWN = 1 THEN
              CNTR = CNTR - 1
              ADRS = ADRS - 7
    ENDIF
    IF  CNTR > ADRSDOWN THEN
            ADRS = 14
            CNTR = 1
    ENDIF
    IF ADRSDOWN > 30 THEN
                 MOD30 = CNTR : GOSUB METAL_SAYICI_DUZENLEME
                 MOD30A = MOD30
                 MOD30 = ADRSDOWN : GOSUB METAL_SAYICI_DUZENLEME
              IF MOD30A = MOD30  THEN
                 ADRS = ( 1 + MOD30 )*7
                 CNTR = ADRSDOWN
                ENDIF
               IF CNTR < ADRSDOWN - 30 + 1 THEN
                 CNTR = ADRSDOWN - 29
'                 MOD30 = CNTR : GOSUB METAL_SAYICI_DUZENLEME
'                 ADRS = ( 1 + MOD30 )*7
               ENDIF
               ADRS = (( 1 + MOD30 ) * (7))
'                MOD30 = CNTR
'                GOSUB METAL_SAYICI_DUZENLEME
'               IF MOD30 = 1  THEN
'                 ADRS = 14
'               ENDIF
'               IF MOD30 = 30 THEN
'                 ADRS = 31*7
'               ENDIF
    ENDIF
    GOSUB KYTOKU
    GOTO HAFIZABLM2
KYTOKU :
    IF CNTR = 0 THEN
       CNTR = ADRSDOWN
       MOD30 = ADRSDOWN
    ENDIF
    READ ( ADRS - 5),SET
    READ ( ADRS - 4),SIFRE2
    READ ( ADRS - 3),X1
    READ ( ADRS - 2),ADRS1
    READ ( ADRS - 1),bolgeadi
    READ ( ADRS ),V1
    READ ( ADRS + 1),V2
    LCDOUT $FE,1,DEC3 CNTR,")","BL:",#SET," ","MB:",DEC3 SIFRE2
    LCDOUT $FE,$C0,DEC2 bolgeadi,"/",DEC2 V1,"/",DEC2 V2," ",DEC2 ADRS1,":",DEC2 X1
    PAUSE 300
    RETURN
METAL_SAYICI_DUZENLEME :
     IF MOD30 >= 120 THEN MOD30 = MOD30 - 90
     IF MOD30 >= 90 THEN MOD30 = MOD30 - 60
     IF MOD30 >= 60 THEN MOD30 = MOD30 - 30
     IF  MOD30 > 30 THEN
     MOD30 = MOD30 // 30
     ENDIF
    RETURN
'*************  DİĞER BÖLÜMLER *******************************
TIME :
LCDOUT $FE,1
TIME1 :
    GOsub RTC_OKU
    LCDOUT $FE,2,"SAAT AYARI"
    LCDOUT $FE,$C0,"TARIH AYARI"
    PAUSE 10
    IF RIGHT = 1 THEN
   WHILE RIGHT = 1 : WEND
        GOTO SETDATE
    ENDIF
    IF LEFT = 1 THEN
        WHILE LEFT = 1 : WEND
        GOTO SETDATE
    ENDIF
    IF ENTER = 1 THEN
        WHILE ENTER = 1
        WEND
        GOTO SETSAAT
     ENDIF
    IF ESCAPE = 1 THEN
        GOTO MENUSECIM2a
    ENDIF
GOTO TIME1
DATE1 :
SETSAAT :
    LCDOUT $FE,1
SETSAAT1 :
    Gosub RTC_OKU
    lcdOUT $FE,$C7,"--"
    LCDOUT $FE,2,"SAAT : ",DEC2 SAAT,":",DEC2 DK,":",DEC2 SN
   IF ENTER = 1 THEN
        WHILE ENTER = 1
        WEND
        LCDOUT $FE,1
       GOTO SETDAK
    ENDIF
   IF UP = 1 THEN
        SAAT = SAAT + 1
        IF  SAAT > 23  THEN
        SAAT = 00
        ENDIF
       GOSUB RTC
   ENDIF
   IF DOWN = 1 THEN
     SAAT = SAAT - 1
     IF  SAAT = 255  THEN
         SAAT = 23
     ENDIF
     GOSUB RTC
   ENDIF
   IF ESCAPE = 1 THEN
        WHILE ESCAPE = 1
        WEND
        GOTO TIME
   ENDIF
 GOTO SETSAAT1
SETDAK:
SETDAK1 :
   IF ENTER = 1 THEN
        WHILE ENTER = 1
        WEND
        LCDOUT $FE,1
       GOTO SETSN
    ENDIF
    IF ESCAPE = 1 THEN
        WHILE ESCAPE = 1
        WEND
        GOTO TIME
    ENDIF
   IF UP = 1 THEN
     DK = DK + 1
     IF  DK > 59  THEN
        DK = 00
     ENDIF
     GOSUB RTC
   ENDIF
   IF DOWN = 1 THEN
      DK = DK - 1
        IF DK = 255  THEN
           DK = 59
        ENDIF
   GOSUB RTC
   ENDIF
 GOsub RTC_OKU
 lcdOUT $FE,$CA,"--"
 GOTO SETDAK1
 SETSN:
SETSN1 :
   IF ENTER = 1 THEN
        WHILE ENTER = 1
        WEND
       GOTO SETSAAT
    ENDIF
   IF ESCAPE = 1 THEN
        WHILE ESCAPE = 1
        WEND
        GOTO TIME
    ENDIF
   IF UP = 1 THEN
     SN = SN + 1
     IF  SN > 59  THEN
         SN = 00
     ENDIF
   GOSUB RTC
   ENDIF
   IF DOWN = 1 THEN
     SN = SN - 1
     IF SN = 255  THEN
        SN = 59
     ENDIF
     GOSUB RTC
   ENDIF
 GOSUB RTC_OKU
  lcdOUT $FE,$CD,"--"
GOTO SETSN1
'----------------------- Time Commands Subroutines --------------------------
RTC_OKU :
HIGH CE
 SHIFTOUT IO,SCLK,0,[$BF]
 SHIFTIN IO,SCLK,1,[SN,DK,SAAT,GUN,AY,HAFTA,YIL,RTCKONTROL]
        MEM=SN:GOSUB CEVIR:SN=SAYI
         MEM=DK:GOSUB CEVIR:DK=SAYI
         MEM=SAAT:GOSUB CEVIR:SAAT=SAYI
        MEM=GUN:GOSUB CEVIR:GUN=SAYI
         MEM=AY:GOSUB CEVIR:AY=SAYI
         MEM=YIL:GOSUB CEVIR:YIL=SAYI
LOW CE
 RETURN
RTC_YAZ :
HIGH CE
SHIFTOUT IO,SCLK,0,[$8E,0] 'YAZMA ACILDI
LOW CE
PAUSEUS 10
HIGH CE
SHIFTOUT IO,SCLK,0,[$BE,SN,DK,SAAT,GUN,AY,HAFTA,YIL,RTCKONTROL]
LOW CE
PAUSEUS 10
RETURN
RTC :
   GOSUB YAZIM_CEVIR
   GOSUB RTC_YAZ
   PAUSE 300
   RETURN
YAZIM_CEVIR :
         MEM=SN:GOSUB TERSCEVIR:SN=SAYI
         MEM=DK:GOSUB TERSCEVIR:DK=SAYI
         MEM=SAAT:GOSUB TERSCEVIR:SAAT=SAYI
         MEM=GUN:GOSUB TERSCEVIR:GUN=SAYI
         MEM=AY:GOSUB TERSCEVIR:AY=SAYI
         MEM=YIL:GOSUB TERSCEVIR:YIL=SAYI
         RETURN
CEVIR:
         ONLAR = MEM & %01110000
         ONLAR = ONLAR >> 4
         BIRLER = MEM & %00001111
         SAYI = ( ONLAR * 10 ) + BIRLER
         return
TERSCEVIR:
         ONLAR=MEM DIG 1
         ONLAR=ONLAR<<4
         BIRLER=MEM DIG 0
         SAYI=ONLAR+BIRLER
         RETURN
SETDATE :
       LCDOUT $FE,1
GUNAL:
     Gosub RTC_OKU
    lcdOUT $FE,$C7,"--"
    LCDOUT $FE,2,"TARIH :",DEC2 GUN,"/",DEC2 AY,"/",DEC2 YIL
        IF ENTER = 1 THEN
            WHILE ENTER = 1:WEND
            LCDOUT $FE,1
           GOTO AYAL
      ENDIF
    IF ESCAPE = 1 THEN
    WHILE ESCAPE = 1 :WEND
        GOTO TIME
       ENDIF
       IF UP = 1 THEN
          GUN = GUN + 1
          IF GUN = 32 THEN
             GUN = 1
          ENDIF
          GOSUB RTC
       ENDIF
        IF DOWN = 1 THEN
           GUN = GUN -1
           IF GUN = 255 THEN
              GUN = 1
           ENDIF
          GOSUB RTC
        ENDIF
        GOTO GUNAL
AYBIR:
AYAL:
     GOSUB RTC_OKU
     lcdOUT $FE,$CA,"--"
    IF ESCAPE = 1 THEN
        GOTO TIME
        ENDIF
    IF ENTER = 1 THEN
          LCDOUT $FE,1
          GOTO YILAL
    ENDIF
    IF UP = 1 THEN
        AY = AY + 1
        IF AY = 13 THEN
           AY = 1
        ENDIF
        GOSUB RTC
        ENDIF
        IF DOWN = 1 THEN
           AY = AY - 1
           IF AY = 255 THEN
              AY = 12
           ENDIF
           GOSUB RTC
        ENDIF
        GOTO AYAL
YILBIR:
YILAL:
 GOSUB RTC_OKU
    lcdOUT $FE,$CD,"--"
     IF ESCAPE = 1 THEN
        GOTO TIME
     ENDIF
      IF ENTER = 1 THEN
        LCDOUT $FE,1
       GOTO GUNAL
     ENDIF
        IF UP = 1 THEN
           YIL = YIL + 1
           IF YIL = 100 THEN
              YIL = 0
           ENDIF
           GOSUB RTC
        ENDIF
        IF DOWN = 1 THEN
           YIL = YIL - 1
           IF YIL = 255 THEN
              YIL = 99
           ENDIF
           GOSUB RTC
        ENDIF
        GOTO YILAL
SETFABRIKA :
   FOR KONTROL = 2 TO 217
     WRITE KONTROL,255
   PAUSE 10
   NEXT
   ADRS = 7
   GOTO START1
END
Elektrik Müh.
wsxwsx
Açkıklamamışsın ama her halde çok yararlı bir programdır.. hemen kullanalım. ne işe yaradığı önemli değil.
Mehemet
içinde rtc den tarih saat ayarlamaya menüye girmede şifrelemeye analog okuma  kayıt tutma  ve bir çok işlem var inşallah size yardımcı olur  isteyene  isisinide atabilirim.  Ete Bey e  teşkkürlerimi sunmayıda borç bilirim
Elektrik Müh.
ete
@Mehemet,
Tebrik ederim. İyi ve uzun bir program. Ne işe yaradığında yazsa idin ilgili arkadaşlar için daha uygun olurdu. Öğrenmek isteyenler genelde amaca göre mukayese yaparlar ve bilgi sahibi olurlar.
Bu arada bir iki konuda kusur gördüm ve onlarıda düzelteyim istedim.
Birincisi eeproma bilgi yazarken her yazma işleminden sonra 10 ms lik bir gecikme koyulması gerekir. Yazma İşlemi yaklaşık bu kadar süre tutar ve ardından hemen ikinci yaz emrini verirseniz muhtemelen ikinci emir tam olarak yerine getirilmeyecektir. Bu her zaman olmayabilir ama olma ihtimali yüksektir.
Bu nedenle her write komutundan sonra 10 ms lik bir gecikme koymanızı öneriyorum.
Diğer bir düzeltmeyide ADC okumasından sonra uyguladığınız formül üzerinde yapmak isterim. Biliyorsunuz pic aksine bir komut vermediğiniz taktirde 8 bitlik (veya değişkenler 16 bit ise 16 bitlik) işlemler yapar . Dolayısıyla sizin verdiğiniz formüllerden birini ele alırsak;
işleminde BLG3 ADC den okunan ve 0-1023 arasında değeri Yüzde olarak yada 0-100 arasında bir değer olarak göstermek istiyorsunuz. Yani bu formül maksimum ADC değeri olan 1023 de size 100 değerini vermeli ve teorik olarak 1024/2=511 ADC değerine karşılık da 50 değerini vermelidir.
Ancak formülü 512 (yada 511) değeri ile denerseniz size 48 değerini vereceğini göreceksiniz. Bunun sebebi formüldeki işlemin 16 bitlik matematik hesabına göre yapılıp küsuratların atılması sonucunda 48 değerinin elde edilmesidir.  İşlemi sırası ile yaparsak konu daha iyi anlaşılacaktır.
512 x 25= 12800
12800 / 1023 =12,5 ancak bu 12 olarak alıncaktır dolayısıyla sonuç 12 olacaktır.
12 x 4= 48 olarak sonuç bulunacaktır.
Bu işemi 32 bit matematiği ile yaparsanız formülünüz şöyle olmalıdır,
BLG2 =(BLG3+1) */ 25
Bu formül ile 512 değerine karşılık elde edeceğiniz sonuç 50 çıkacaktır.
Deneyerek görebilirsiniz.
Formülün açılımı ise şöyledir.
(BLG3+1) önce 25 ile çarpılıp 256 ya bölünecektir.  Sizin formülde 4/1023 değerlerini 4 ile sadeleştirirseniz 1/256 değerini bulacaksınız zaten. Tek fark 1023 yerine ben 1024 değerini kullanıyorum. ADC değerleri hesaplanır iken 0-1023 arası kademe sayısı 1024 olarak bulunur. Siz 100 değeri için 1024 kademeli bir okuma yapacaksanız her bir okuma karşılığı bulunacak değer 100/1024 işleminden bulunur. Sonuç 0,09765625 olarak çıkar. 32 bitlik işlem sonucunda biz 256 ya bölünmüş neticeyi aldığımız için bu sayıyı birde 256 ile çarparsam bana 25 sayısını verecektir. İşte kullanacağım formüldeki 25 rakamı buradan gelmektedir.
Biraz detaylı açıklama verdim bilmeyenler öğrensin diye. Sen zaten biliyorsan aldırma.
Ete
hayati
ısıs dosyasını yayınlayabilirmisiniz teşekkürler
Mehemet
http://rapidshare.com/files/156042641/By_Mehemet.rar
isisi
haklısınız hocam adc işlemin o nokta gözümden kacmış. onu düzeltmek lazım.
Bu programın isisi üzerinde çalışınca ne oldugu anlaşılıyor. Kısacası  6 analog girişinden gelen sinyallerin set değerinden büyükse zaman büyüklük ve hangi girişinden hata sinyali geldiğini hafızasında  tutuyor ve istenildiğinde menüden okunabiliyor ayrıca set değiştirilebiliyor. menüye girmek içinde şifre istiyor.
Ne kadar iyi bir program  bilmiyorum ama yaptığım ilk büyük çaplı program belki üzerinde çalışılıp dahada kısaltılabilir ama  o an için elimden geleni bu kadardı.
Şimdi bu programım biraz daha üstün halini yaptım. otolearn kullandım.
Yakında onuda sizlerle paylaşırım.
iyi çalışmalar
Elektrik Müh.
