usart iletisimi
Başlatan selvi, 03 Aralık 2008, 21:35:43
selvi
programi yazdim.derleme hatasi veriyor.ilk defa protonla program yazdim.config ve hserout kisminda hata veriyor.programin farkli yerlerinde hata var mi?
Device  16F628A
XTAL    4
Config XT_OSC,MCLRE_OFF,LVP_OFF,WDT_OFF,PWRTE_ON,BODEN_OFF
Declare LCD_DTPIN PORTB.4	'DATA giri?i PORTB'nin 4. ucundan ba?layacak
Declare LCD_ENPIN PORTA.3	'LCD'nin ENable ucu
Declare LCD_RSPIN PORTA.2	'LCD'nin Register Select ucu
Declare LCD_INTERFACE 4	'LCD veri yolu 4 bit olacak
Declare LCD_LINES 2		'LCD 2 sat?rdan olu?uyor
Cls
SPBRG=25
Declare HSERIAL_BAUD 9600
Declare HSERIAL_RCSTA 90
Declare HSERIAL_TXSTA 24
Declare HSERIAL_CLEAR On
CMCON=7           '16F628 de komparatör pinleri iptal hepsi giriþ çýkýþ
PORTB_PULLUPS = 1
TRISB=%00001011
TRISA=%00110010
PORTB=0
PORTA=0
PORTA.0=0
Dim VER   As  Byte
Dim SAYI  As  Byte
Dim W0    As  Byte
Dim W1    As  Byte
Dim I     As  Byte
Dim M     As  Byte
Print At 1,1, "HEY" 	'ekran?n 1. sat?r,1. sütununa yaz
Print At 2,1, "DUNYA" 	'ekran?n 1. sat?r,1. sütununa yaz
DelayMS 500
SAYI=0
W0=0
W1=0
I=0
M=0
START: PORTA.0=0
       VER=0
       I=0
       M=0
       If PORTB.0=0 Then
       For I=0 To 4
       W0=LookUp I,[73,111,41,217,0]
       Print At 1,1, "AC"
       DelayMS 100
             PORTA.0=1
             VER=W0
             GoSub GONDER
       Print At 2,1, "VER=",@VER
   EKRAN:
           If I=4 And VER=0 And PORTB.0=0 Then
       Print At 1,1, "ACILDI"
        DelayMS  10
            GoTo EKRAN
            EndIf
        Next I
        EndIf
        If PORTA.4=0 Then
        Print At 1,1, "HEDEF"
         DelayMS 10
            SAYI=SAYI+1
            DelayMS 200
        Print At 2,1, "SAYI=",@SAYI
        EndIf
        If PORTA.5=0 Then
            SAYI=SAYI-1
            DelayMS 200
        EndIf
        If PORTB.3=0 Then
            PORTA.0=1
		Print At 1,1, "GONDER"
            VER=SAYI
            GoSub GONDER
            While PORTB.3=0
            GoSub GONDER
            Wend
        EndIf
         If PORTA.1=0 Then
        For M=0 To 4
        W1=LookUp M,[233,3,79,117,61]
		Print At 1,1, "KAPAT"
		DelayMS 10
                PORTA.0=1
                VER=W1
                GoSub GONDER
  EKRAN2:
        If M=4 And VER=61 And PORTA.1=0 Then
            SAYI=0
        Print At 1,1, "KAPANDI"
        DelayMS 10
        GoTo EKRAN2
                EndIf
        Next M
         EndIf
            DelayMS 100
             GoTo START
'-------------------------ALT PROGRAMLAR---------------------------------------
GONDER:
HSerOut [Rep $AA\5,Rep $00\5,Rep $FF\5]'uyandirma sinyali preambl
HSerOut ["A","R","A",Dec VER,123]
Return
End
Yaşam anlamlandırıldıkça kutsaldır....
mikromuh
Helpe bakarsan kod yazilim sekli :   REP c\n
Programinda yapisik bir sekilde yazmisin. Aralarina birer bosluk koyman gerekir.
HSEROUT [REP$AA\5,REP$00\5,REP$FF\5]
GONDER:
Return
End
Config XT_OSC, MCLRE_OFF, LVP_OFF, WDT_OFF, PWRTE_ON,  BODEN_OFF
Config  WDT_OFF,PWRT_ON,PROTECT_OFF,MCLR_OFF,LVP_OFF,BOD_OFF     ' HATALI
Config  WDT_OFF, PWRTE_ON, CP_OFF, MCLRE_OFF, LVP_OFF, BODEN_OFF
'Declare HSER_SPBRG 25   '9600 Baud @ 20MHz, 0,16%
SPBRG=25
'HSEROUT [REP$AA\5,REP$00\5,REP$FF\5]       ' HATALI
HSerOut [Rep $AA\5, Rep $00\5, Rep $FF\5]
Gördüğüm hatalı yazımlar.
selvi
en son belirtiginiz degisiklikleri yaptim derledim.derlemesonucunda su hatayi hale veriyor.programin en son hali ilk mesajdaki yere edit yaparak yeniden yazdim.
HINT[line 13]:ensure that all fuses are placed in the CONFIG list,as picmicros have diffrerring default settings
O hata değil uyarı, config ayarlarında eksik bırakmazsan o uyarı da kalkar.
selvi
asagidaki programi derledim.proteusda simulasyonda sorunlar cikti.ac butonuna basiyorum.ekranda ac yaziyor.ilkin ac sonra acildi yazmasi gerekiyor.ac yazdiktan sonra diger butonlara bastigim halde lcd ekranda ac disinda farkli bir yazi cikmiyor.sanki for next dongusu islemiyor.lookup tablosundaki ilk deger disinda diger degerleri almiyor.onceden pbp ile program yazdigim ayni programda lcd kisminda farkli bir sorun cikmiyordu.proton pbp"e cok yakin.
Device 16F628A
XTAL 4
Cls
SPBRG=25
Declare HSERIAL_RCSTA 90h
Declare HSERIAL_TXSTA 24h
CMCON=7 '16F628 de komparatör pinleri iptal hepsi giri? çyky?
PORTB_PULLUPS = 1
TRISB=%00001011
TRISA=%00110010
PORTB=0
PORTA=0
PORTA.0=0
Dim VER As Byte
Dim SAYI As Byte
Dim W0 As Byte
Dim W1 As Byte
Dim I As Byte
Dim M As Byte
    DelayMS 500
    SAYI=0
    W0=0
    W1=0
    I=0
    M=0
START:
    PORTA.0=0
    VER=0
    I=0
    M=0
    If PORTB.0=0 Then
        For I=0 To 4
            Print $FE , 1
            Print At 1,1, "AC"
            DelayMS 10
            PORTA.0=1
            VER=W0
            GoSub GONDER
    EKRAN:
                DelayMS 30
                GoTo EKRAN
            EndIf
        Next I
    EndIf
    If PORTA.4=0 Then
        Print At 1,1, "SAYAC"
        SAYI=SAYI+1
        DelayMS 200
    EndIf
    If PORTA.5=0 Then
        SAYI=SAYI-1
        DelayMS 200
    EndIf
    If PORTB.3=0 Then
        PORTA.0=1
        VER=SAYI
        GoSub GONDER
        While PORTB.3=0
            GoSub GONDER
        Wend
    EndIf
    If PORTA.1=0 Then
        For M=0 To 4
            PORTA.0=1
            VER=W1
            GoSub GONDER
    EKRAN2:
                SAYI=0
                GoTo EKRAN2
            EndIf
        Next M
    EndIf
DelayMS 100
GoTo START
GONDER:
    HSerOut [Rep $AA\5,Rep $00\5,Rep $FF\5] 'uyandirma sinyali preambl
Return
End
selvi
Device 16F628A
XTAL 4
Cls
SPBRG=25
PORTB_PULLUPS = 1
TRISB=%00001011
TRISA=%00110010
PORTB=0
PORTA=0
Dim VER As Byte
DelayMS 100
START:
VER=0
If PORTB.0=0 Then
print $FE,1
Print At 1,1, "AC"
DelayMS 100
VER=73
GoSub GONDER
EKRAN:
If  VER=73 And PORTB.0=0 Then
Print At 2,1, "ACILDI"
DelayMS 100
GoTo EKRAN
EndIf
EndIf
GONDER:
Return
End
   programi bayagi kuculttum.proton derleyicisi ile derledim.proteus 7.1 versiyonunda simule ettim.portb.0 butonu islevsiz.simulasyonu calistirinca ekranda hey dunya yaziyor.portb.0=0 butonuna bastigim halde ekrana farkli bir yazi gelmiyor.sorun programda mi yoksa derleyici veya proteusdanmi kaynakli oldugunu cozemedim.mumkunse deneyip sonucu aktarabilir misiniz?
a.zorba
42. satırda hata var proton mesaj vermesi gerekırdı
Print At 2,1 "ACILDI"
Print At 2,1, "ACILDI"  olmalı
selvi
Print At 2,1, "ACILDI" onu yanlis yazmisim.sorun devam ediyor.butonlar islevsiz.lcd de hey dunya disinda farkli bir yazi gelmiyor.sema asagidaki linktedir.
http://rapidshare.com/files/170730849/proton_sema.DSN.html
Maxim
birkaç düzeltme yaptım ,
düzelttiğim ve eklediğim satırlara maxiboost yazdım ,
başka hatalar ve problemlerde olabilir ,
şu an vaktim olmadığından bakamadım ,
Device 16F628A
XTAL 4
Cls
Declare HSERIAL_BAUD=9600   'MAXIBOOST
Declare HSERIAL_RCSTA=$90h  'MAXIBOOST
Declare HSERIAL_TXSTA=$24h  'MAXIBOOST
Declare HSERIAL_CLEAR=On    'MAXIBOOST
Declare HSERIAL_SPBRG=25    'MAXIBOOST
PORTB_PULLUPS = 1
TRISB=%00001011
TRISA=%00110010
PORTB=0
PORTA=0
Dim VER As Byte
DelayMS 100
START:
VER=0
If PORTB.0=0 Then
Print $FE,1
Print At 1,1, "AC"
DelayMS 100
VER=73
GoSub GONDER
EKRAN:
DelayMS 100
GoTo EKRAN
EndIf
EndIf
GoTo START   'MAXIBOOST
GONDER:
Return
End
selvi
hocam belirttiginiz degisiklikleri yaptim,calisti.artir yada azalt butonuna bastigimda sorunlar cikiyor.ornegin;sayi=2 degerini gonderdigimde lcd de 22 yaziyor.sayi=3 yazdigimda 33 yaziyor.gecikme koydum sorun cozulmedi.
Maxim
en son kullandığın tam kodu vermelisin ,
böyle konu dağılıyor
bu kodda arttır ve azalt yok
selvi
Device 16F628A
XTAL 4
Cls
PORTB_PULLUPS = 1
TRISB=%00001011
TRISA=%00110010
PORTB=0
PORTA=0
PORTA.0=0
Dim VER As Byte
Dim SAYI As Byte
Dim W0 As Byte
Dim W1 As Byte
Dim I As Byte
Dim M As Byte
DelayMS 500
SAYI=0
W0=0
W1=0
I=0
M=0
START: PORTA.0=0
VER=0
I=0
M=0
If PORTB.0=0 Then
For I=0 To 4
Print $FE , 1
Print At 1,1, "AC"
PORTA.0=1
VER=W0
GoSub GONDER
EKRAN:
GoTo EKRAN
EndIf
Next I
EndIf
If PORTA.4=0 Then
Print $FE , 1
SAYI=SAYI+1
DelayMS 200
DelayMS 100
EndIf
If PORTA.5=0 Then
Print $FE , 1
SAYI=SAYI-1
DelayMS 200
DelayMS 30
EndIf
If PORTB.3=0 Then
PORTA.0=1
DelayMS 30
VER=SAYI
DelayMS 100
GoSub GONDER
While PORTB.3=0
GoSub GONDER
Wend
EndIf
If PORTA.1=0 Then
For M=0 To 4
Print $FE , 1
PORTA.0=1
VER=W1
DelayMS 30
GoSub GONDER
EKRAN2:
SAYI=0
DelayMS 30
GoTo EKRAN2
EndIf
Next M
EndIf
DelayMS 100
GoTo START
GONDER:
Return
End
Maxim
tamam,
ama bu program hiç hoşuma gitmedi ,
Device 16F628A
XTAL 4
Cls
PORTB_PULLUPS = 1
TRISB=%00001011
TRISA=%00110010
PORTB=0
PORTA=0
PORTA.0=0
Dim VER As Byte
Dim SAYI As Byte
Dim W0 As Byte
Dim W1 As Byte
Dim I As Byte
Dim M As Byte
DelayMS 500
SAYI=0
W0=0
W1=0
I=0
M=0
START:
PORTA.0=0
VER=0
I=0
M=0
If PORTB.0=0 Then
For I=0 To 4
Print $FE , 1
Print At 1,1, "AC"
PORTA.0=1
VER=W0
GoSub GONDER
Print At 2,1, "VER=",Dec VER,"  " 'MAXIBOOST
EKRAN:
GoTo EKRAN
EndIf
Next I
EndIf
If PORTA.4=0 Then
Print $FE , 1
SAYI=SAYI+1
DelayMS 200
Print At 2,1, "SAYI=",Dec SAYI,"  "  'MAXIBOOST
DelayMS 100
EndIf
If PORTA.5=0 Then
Print $FE , 1
SAYI=SAYI-1
DelayMS 200
DelayMS 30
EndIf
If PORTB.3=0 Then
PORTA.0=1
DelayMS 30
VER=SAYI
Print At 2,1,"VER=",Dec VER,"  "   'MAXIBOOST
DelayMS 100
GoSub GONDER
While PORTB.3=0
GoSub GONDER
Wend
EndIf
If PORTA.1=0 Then
For M=0 To 4
Print $FE , 1
PORTA.0=1
VER=W1
DelayMS 30
GoSub GONDER
EKRAN2:
SAYI=0
DelayMS 30
GoTo EKRAN2
EndIf
Next M
EndIf
DelayMS 100
GoTo START
GONDER:
Return
End
selvi
hocam teşekkürler.program hangi anlamda hosunuza gitmedi.buna donuk gorusleriniz varsa belirtebilirsiniz.
