ana programda sorun
Başlatan OptimusPrime, 03 Haziran 2009, 08:34:08
ahmet2004
20 Mhz XTAL de çalışan kod. :?:
#include <18F452.h>
#device adc=10
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOOSCSEN                 //Oscillator switching is disabled, main oscillator is source
#FUSES BROWNOUT                 //Reset when brownout detected
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES STVREN                   //Stack full/underflow will cause reset
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                    //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOCPD                    //No EE protection
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPD
#use delay(clock=20M)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#define StepForOneRevolution  400         //Step for one revolution x2
#define Forward               1
#define Backward              0
#define EngineRpmOffset       500
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
#use fast_io(d)
#use fast_io(e)
unsigned int16 uiEngineRpm;
unsigned int16 uiRevolution=(unsigned int16)(1+StepForOneRevolution);
unsigned int8  bDirection=Forward;
unsigned int8  bStepperIsActive=False;
float volt0;
long uiADC;
#int_TIMER2
void  TIMER2_isr(void)
if(bDirection==Forward) output_low(PIN_A3);
   else output_high(PIN_A3);
if(uiRevolution<=(unsigned int16)(StepForOneRevolution)) { output_toggle(PIN_A2); uiRevolution++; bStepperIsActive=TRUE; }
   else bStepperIsActive=FALSE
enable_interrupts(INT_TIMER2);
return;
#int_EXT
void  EXT_isr(void)
//external interrupt on rising edge
if(bStepperIsActive==FALSE) {
                              bDirection=Forward;
                              uiRevolution=(unsigned int16)(1); }
enable_interrupts(INT_EXT);
return;
#int_EXT1
void  EXT1_isr(void)
                              bDirection=Backward;
enable_interrupts(INT_EXT1);
return;
#int_EXT2
void  EXT2_isr(void)
//output_d(0x04);
//output_d((uiEngineRpm>>2));  //burasi çalisiyor
enable_interrupts(INT_EXT2);
return;
#int_AD
void  AD_isr(void)
uiADC=read_adc(ADC_READ_ONLY);
output_d((uiADC>>2));
read_adc(ADC_START_ONLY);
enable_interrupts(INT_AD);
return;
void main(void)
   setup_adc_ports(AN0);
   setup_adc(ADC_CLOCK_DIV_32);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
         setup_timer_0(RTCC_OFF);
         setup_timer_2(T2_DIV_BY_16,200,1);
   enable_interrupts(GLOBAL);
set_tris_a(0b11111111);
set_tris_b(0b00000000);
set_tris_c(0b10000000);
set_tris_d(0b00000000);
set_tris_e(0b00000000);
output_b(0x00);
output_c(0x00);
output_d(0x00);
output_e(0x00);
      set_adc_channel(0);
      delay_us(13);
   while(1)
      //disable_interrupts(GLOBAL);
      //printf(uiEngineRpm);
      volt0 = (uiADC * 4.8828125)/ 1024.0;
      printf("Volt0: %3.5f \n\r",volt0);
OptimusPrime
