PIC Projeleri
Başlatan cozturk, 26 Aralık 2003, 14:09:07
cozturk
http://www.electronic-engineering.ch/microchip/projects/projects.html
PIC Microcontroller Projects
For Non-Commercial Use Only
I
would appreciate to be credited within your project, if you use any of the source code below. If you have an interesting project going on, I'll be glad about feedback.
The software below
comes with no guarantee or warranty except for my good intentions. Further the use of this code implies that the user has a fundamental understanding of electronics and its risks. I'm not
responsible for any harm or damage, caused by inproper use of any of the code below.
Any commercial use of parts or all of this code requires the permission of the author.
"Design
and test of electronic circuits are 1% inspiration and 99% perspiration."
Table of Contents [Toc]
PIC Projects
  Precision Digital Altimeter
  AT Keyboard
Interface V1.xx
  AT Keyboard Interface V2.xx
  AT Keyboard Interface V3.xx
  AT Keyboard Box V2.03
  AT Keyboard Interface with Morse Code Support V1.xx
  AT
Keyboard Interface with Morse Code Support V2.xx
PIC Test Routines
  DCF77 Test Interface
  AT Keyboard Scan Code Debug Routine
  NSC ADC12130 Test
Interface
  RS232 Scope V1.02 Test Interface
  RS232 Communication Test Routine with LCD (1)
  RS232 Communication Test Routine with LCD (2)
  Simple RS232
Interface
  Binary to Decimal Test Routine
  Matrix Needle Printer RS232 Interface
  LCDx Test Routine
  Debugging Routine / Bitstream Visualization
DumrulBey
Dostum bugün foruma ilk girdiğimden beri ilgiyle verdiğin adresleri inceliyorum. Ancak
üzülerek söylemeliyim ki açıklama olmaması büyük bir eksiklik! Düşünüyorum da verdiğiniz adres ile ilgili açıklama, başlık, resim ve dili gibi içeriklere de yer verirseniz çok daha faydalı olur. Tamam,
bu adresi veren için daha fazla vakit harcamak anlamına geliyor. Ama başlığa her bakan kişinin toplam harcadıkları süreyi hesaplarsak belki de o kadar çok vakit ziyan oluyordur ki, tezahür bile
edilemez!
Arkadaşım sözüm sadece sana değil, bunu unutan her üyeyedir. En azında verdiğiniz adresler ile ilgili bir cümle laf etseniz, ilgilenen kişiye rehber olur. Üstelik daha sonra bu
adresi forumda aradığımızda tıpkı keyword(anahtar kelime) özelliği taşıyacak ve bu açıklamalar bizi hedeflerimize daha çabuk ulaşmamız sağlayacak. Ayrıca arama sırasında adresin, aranılan konuyla
çok ilgisi olduğu halde sonuç dışı kalmasına sebep olmaz. Kanaatimce aşağıdaki gibi bir format(biçim) kullanırsanız isabetli
olur:
Büyük puntolu(14) ve altı çizili bir
başlık...
nEğer varsa yukarıdaki gibi bir resim ve hemen altına ilgili adres...
Dili:
İngilizce/Türkçe
Biçimi: HTM/IMG/PDF (Nakledilen bir kitap ise mutlaka
olmalı...)
Açıklama: Eğer site hakkında bir yorum yapamayacaksanız, en azından anahtar sözçüklerden oluşan bir açıklama konulabilir.
