need help in the design display
Başlatan cesar35, 05 Ağustos 2009, 15:00:29
cesar35
when I type the message to squeeze f1 not write the message emprom
someone can help me in the project.
#include <90s8535.h>
#include <delay.h>
// led display
#define LED_RESET		PORTB.0
#define LED_CLOCK		PORTB.1
#define LED_DATA		PORTB.4
#define SCROLL_DELAY	140  // multiple of 7 (use smaller numbers for faster scroll)
// keyboard
#define KBD_CLOCK		PORTD.2  // to be used for host -> keyboard communication
#define KBD_DATA        	PIND.4
#define BUFF_SIZE		64
// lcd
#define LCD_RS			PORTD.5
#define LCD_RW 		PORTD.6
#define LCD_E  		PORTD.7
#define COMMAND_MODE 	0
#define DATA_MODE    	1
#define WRITE_MODE   	0
#define READ_MODE    	1
#define LCD_DATA_PORT	PORTC
// functions
void lcd_init(void);
void lcd_clear(void);
void lcd_putc(unsigned char);
void lcd_putsf(unsigned char flash *);
void lcd_puts(unsigned char *str);
interrupt [EXT_INT0] keyboard_isr(void);
void put_char_kbbuff(unsigned char);
void put_scancode_kbbuff(unsigned char);
int getchar(void);
int kbhit(void);
void decode(unsigned char);
// global variables ***************************
unsigned char kb_buffer[BUFF_SIZE];
unsigned char bitcount;
unsigned char *inpt, *outpt;
unsigned char buffcnt = 0;
// led character definitions
// 5 data columns + 1 space
// for each character
flash unsigned char led_chars[94][6] = {
0x00,0x00,0x00,0x00,0x00,0x00,	// space
0x00,0x00,0xfa,0x00,0x00,0x00,	// !
0x00,0xe0,0x00,0xe0,0x00,0x00,	// "
0x28,0xfe,0x28,0xfe,0x28,0x00,	// #
0x24,0x54,0xfe,0x54,0x48,0x00,  // $
0xc4,0xc8,0x10,0x26,0x46,0x00,  // %
0x6c,0x92,0xaa,0x44,0x0a,0x00,  // &
0x00,0xa0,0xc0,0x00,0x00,0x00,  // '
0x00,0x38,0x44,0x82,0x00,0x00,	// (
0x00,0x82,0x44,0x38,0x00,0x00,  // )
0x28,0x10,0x7c,0x10,0x28,0x00,  // *
0x10,0x10,0x7c,0x10,0x10,0x00,  // +
0x00,0x0a,0x0c,0x00,0x00,0x00,  // ,
0x10,0x10,0x10,0x10,0x10,0x00,  // -
0x00,0x06,0x06,0x00,0x00,0x00,  // .
0x04,0x08,0x10,0x20,0x40,0x00,  // /
0x7c,0x8a,0x92,0xa2,0x7c,0x00,  // 0
0x00,0x42,0xfe,0x02,0x00,0x00,  // 1
0x42,0x86,0x8a,0x92,0x62,0x00,  // 2
0x84,0x82,0xa2,0xd2,0x8c,0x00,	// 3
0x18,0x28,0x48,0xfe,0x08,0x00,	// 4
0xe5,0xa2,0xa2,0xa2,0x9c,0x00,	// 5
0x3c,0x52,0x92,0x92,0x0c,0x00,	// 6
0x80,0x8e,0x90,0xa0,0xc0,0x00,	// 7
0x6c,0x92,0x92,0x92,0x6c,0x00,	// 8
0x60,0x92,0x92,0x94,0x78,0x00,	// 9
0x00,0x6c,0x6c,0x00,0x00,0x00,	// :
0x00,0x6a,0x6c,0x00,0x00,0x00,	// ;
0x10,0x28,0x44,0x82,0x00,0x00,	// <
0x28,0x28,0x28,0x28,0x28,0x00,	// =
0x00,0x82,0x44,0x28,0x10,0x00,	// >
0x40,0x80,0x8a,0x90,0x60,0x00,	// ?
0x4c,0x92,0x9e,0x82,0x7c,0x00,	// @
0x7e,0x88,0x88,0x88,0x7e,0x00,	// A
0xfe,0x92,0x92,0x92,0x6c,0x00,	// B
0x7c,0x82,0x82,0x82,0x44,0x00,	// C
0xfe,0x82,0x82,0x44,0x38,0x00,	// D
0xfe,0x92,0x92,0x92,0x82,0x00,	// E
0xfe,0x90,0x90,0x90,0x80,0x00,	// F
0x7c,0x82,0x92,0x92,0x5e,0x00,	// G
0xfe,0x10,0x10,0x10,0xfe,0x00,	// H
0x00,0x82,0xfe,0x82,0x00,0x00,	// I
0x04,0x02,0x82,0xfc,0x80,0x00,	// J
0xfe,0x10,0x28,0x44,0x82,0x00,	// K
0xfe,0x02,0x02,0x02,0x02,0x00,	// L
0xfe,0x40,0x30,0x40,0xfe,0x00,	// M
0xfe,0x20,0x10,0x08,0xfe,0x00,	// N
0x7c,0x82,0x82,0x82,0x7c,0x00,	// O
0xfe,0x90,0x90,0x90,0x60,0x00,	// P
0x7c,0x82,0x8a,0x84,0x7a,0x00,	// Q
0xfe,0x90,0x98,0x94,0x62,0x00,	// R
0x62,0x92,0x92,0x92,0x8c,0x00,	// S
0x80,0x80,0xfe,0x80,0x80,0x00,	// T
0xfc,0x02,0x02,0x02,0xfc,0x00,	// U
0xf8,0x04,0x02,0x04,0xf8,0x00,	// V
0xfc,0x02,0x1c,0x02,0xfc,0x00,	// W
0xc6,0x28,0x10,0x28,0xc6,0x00,	// X
0xe0,0x10,0x0e,0x10,0xe0,0x00,	// Y
0x86,0x8b,0x92,0xa2,0xc2,0x00,	// Z
0x00,0xfe,0x82,0x82,0x00,0x00,	// [
0x00,0x00,0x00,0x00,0x00,0x00,     // *** do not remove this empty char ***
0x00,0x82,0x82,0xfe,0x00,0x00,	// ]
0x20,0x40,0x80,0x40,0x20,0x00,	// ^
0x02,0x02,0x02,0x02,0x02,0x00,	// _
0x00,0x80,0x40,0x20,0x00,0x00,	// `
0x04,0x2a,0x2a,0x2a,0x1e,0x00,	// a
0xfe,0x12,0x22,0x22,0x1c,0x00,	// b
0x1c,0x22,0x22,0x22,0x04,0x00,	// c
0x1c,0x22,0x22,0x12,0xfe,0x00,	// d
0x1c,0x2a,0x2a,0x2a,0x18,0x00,	// e
0x10,0x7e,0x90,0x80,0x40,0x00,	// f
0x30,0x4a,0x4a,0x4a,0x7c,0x00,	// g
0xfe,0x10,0x20,0x20,0x1e,0x00,	// h
0x00,0x22,0xbe,0x02,0x00,0x00,	// i
0x04,0x02,0x22,0xbc,0x00,0x00,	// j
0xfe,0x08,0x14,0x22,0x00,0x00,	// k
0x00,0x82,0xfe,0x02,0x00,0x00,	// l
0x3e,0x20,0x18,0x20,0x1e,0x00,	// m
0x3e,0x10,0x20,0x20,0x1e,0x00,	// n
0x1c,0x22,0x22,0x22,0x1c,0x00,	// o
0x3e,0x28,0x28,0x28,0x10,0x00,	// p
0x10,0x28,0x28,0x18,0x3e,0x00,	// q
0x3e,0x10,0x20,0x20,0x10,0x00,	// r
0x12,0x2a,0x2a,0x2a,0x04,0x00,	// s
0x20,0xfc,0x22,0x02,0x04,0x00,	// t
0x3c,0x02,0x02,0x04,0x3e,0x00,	// u
0x38,0x04,0x02,0x04,0x38,0x00,	// v
0x3c,0x02,0x0c,0x02,0x3c,0x00,	// w
0x22,0x14,0x08,0x14,0x22,0x00,	// x
0x30,0x0a,0x0a,0x0a,0x3c,0x00,	// y
0x22,0x26,0x2a,0x32,0x22,0x00, 	// z
0x00,0x10,0x6c,0x82,0x00,0x00,	// {
0x00,0x00,0xfe,0x00,0x00,0x00,	// |
0x00,0x82,0x6c,0x10,0x00,0x00 };	// }
// keyboard scan codes (without & with shift key pressed)
flash unsigned char unshifted[67][2] = {
//0x0d,9,
0x0e,'`',0x15,'q',0x16,'1',0x1a,'z',0x1b,'s',0x1c,'a',0x1d,'w',0x1e,'2',0x21,'c',0x22,'x',0x23,'d',0x24,'e',
0x25,'4',0x26,'3',0x29,' ',0x2a,'v',0x2b,'f',0x2c,'t',0x2d,'r',0x2e,'5',0x31,'n',0x32,'b',0x33,'h',0x34,'g',
0x35,'y',0x36,'6',0x39,',',0x3a,'m',0x3b,'j',0x3c,'u',0x3d,'7',0x3e,'8',0x41,',',0x42,'k',0x43,'i',0x44,'o',
0x45,'0',0x46,'9',0x49,'.',0x4a,'/',0x4b,'l',0x4c,';',0x4d,'p',0x4e,'-',0x52,'`',0x54,'[',0x55,'=',0x5a,13,
0x5b,']',0x5d,'/',0x61,'<',0x66,8,  0x69,'1',0x6b,'4',0x6c,'7',0x70,'0',0x71,',',0x72,'2',0x73,'5',0x74,'6',
0x75,'8',0x79,'+',0x7a,'3',0x7b,'-',0x7c,'*',0x7d,'9',0,0 };
flash unsigned char shifted[67][2] = {
//0x0d,9,
0x0e,'`',0x15,'Q',0x16,'!',0x1a,'Z',0x1b,'S',0x1c,'A',0x1d,'W',0x1e,'@',0x21,'C',0x22,'X',0x23,'D',0x24,'E',
0x25,'$',0x26,'#',0x29,' ',0x2a,'V',0x2b,'F',0x2c,'T',0x2d,'R',0x2e,'%',0x31,'N',0x32,'B',0x33,'H',0x34,'G',
0x35,'Y',0x36,'^',0x39,'L',0x3a,'M',0x3b,'J',0x3c,'U',0x3d,'&',0x3e,'*',0x41,'<',0x42,'K',0x43,'I',0x44,'O',
0x45,')',0x46,'(',0x49,'>',0x4a,'?',0x4b,'L',0x4c,':',0x4d,'P',0x4e,'_',0x52,'"',0x54,'{',0x55,'+',0x5a,13,
0x5b,'}',0x5d,'|',0x61,'>',0x66,8,  0x69,'1',0x6b,'4',0x6c,'7',0x70,'0',0x71,',',0x72,'2',0x73,'5',0x74,'6',
void main() {
	int i,j;
    	unsigned char ch,row;
	flash unsigned char *dataPtr, *tmpDataPtr;
	unsigned char messageLength, currentChar, charOffset, tmpCurrentChar, tmpCharOffset, ledArray[23];
	unsigned char message[308];  // 300 chars + 4 spaces at start and end of message
	#asm("cli");    // disable all interrupts
	// initialise ports
	DDRA = 0xff;	// port A output
	DDRB = 0xff;	// port B output
	DDRC = 0xff;	// port C output
	DDRD = 0xeb;	// pins 2 & 4 inputs
	// initialise keyboard variables
	inpt = kb_buffer;
	outpt = kb_buffer;
	buffcnt = 0;
	bitcount = 11;
	// initialise lcd
	lcd_init();
	// initialise LED display (shift registers)
	LED_RESET = 0;
   	LED_CLOCK = 0;
 	LED_RESET = 1;
	// initialise interrupt registers
	GIMSK = 0x40;	// enable INT0 interrupt
	MCUCR = 0x02;	// INT0 interrupt on falling edge
   	#asm("sei");    // enable all interrupts
   	while(1) {
   		ch = 0x00;
    		i = 0;
    		// fill the array with 4 empty spaces at the start and the end of the message
		// as the screen has 4 chars
		// (it looks better if we start scrolling with empty screen and end
		// with empty screen , rather than displaying four chars immediatelly and
		// then start scrolling)
		message[i++] = ' ';
   		message[i++] = ' ';
   		message[i++] = ' ';
   		message[i++] = ' ';
		// enter message until 300 characters entered or <enter> key pressed
    		while((ch != 13) || (i < 308)) {
			ch = getchar();
			if ((ch != 13) && (ch != 'q')) {
				lcd_putc(ch);
				message[i++] = ch;
			// if q is pressed clear the LCD
			// (code only writes to the first LCD line so
			// if the line is longer than 16 chars i cant see the rest of the chars
			// , there will be a menu system in the future software version
			// and the line on the LCD will be scrolled
			// to the left automatically as the cursor gets to the end of the line
			//, for now use this dirty solution:))
			if (ch == 'q')
				lcd_clear();
    		message[i++] = ' ';
   		message[i++] = ' ';
   		message[i++] = ' ';
   		message[i++] = ' ';
    		messageLength = i - 4;
    		charOffset = 0;
    		currentChar = 0;
    		dataPtr = &led_chars[message[0] - 0x20][0];
		// this loop is the heart of the scroll
		// message is scrolled until a key is hit on the keyboard
    		while (!kbhit()) {
    			// load led array
    			tmpDataPtr = dataPtr;
    			tmpCharOffset = charOffset;
    			tmpCurrentChar = currentChar;
    			for (i = 0; i <= 22; i++) {
    				ledArray[i] = *tmpDataPtr++;
    	 			if (++tmpCharOffset==0x06) {
    	  				tmpCharOffset = 0;
    					if (++tmpCurrentChar == messageLength)
    	 					tmpCurrentChar = 0;
    	  				tmpDataPtr = &led_chars[message[tmpCurrentChar] - 0x20][0];
    			if (++charOffset == 0x06) {
    				charOffset = 0;
    				if (++currentChar == messageLength)
    					currentChar = 0;
    			dataPtr = &led_chars[message[currentChar] - 0x20][charOffset];
    			// display led array
    			row = 0x02;
    			for (j = 0;j <= SCROLL_DELAY; j++) {
    					LED_DATA = (ledArray[i] & row) ? 1 : 0;
    					LED_CLOCK = 1;
    					LED_CLOCK = 0;
    				PORTA = row;
 				row <<= 1;      // next line to be switched on
 				if (!row) 	// if last line go back to the first line
 					row = 0x02;
 	  			delay_us(800);
 	    			PORTA = 0x00;
		lcd_clear();
// return 1 if a key is pressed (non blocking)
// else return 0
int kbhit(void) {
	if (buffcnt) {
		// reset buffer variables (flush the buffer)
		inpt = kb_buffer;
		outpt = kb_buffer;
		buffcnt = 0;
		bitcount = 11;
		return 1;
    return 0;
// puts scan code (in hex format) into keyboard buffer
// (used for debugging purposes)
void put_scancode_kbbuff(unsigned char sc) {
	unsigned char h,l;
	// convert hi and low nibbles of the scancode
	// into ascii and store them into keyboard buffer
	h =  ((sc & 0xf0 ) >> 0x04) & 0x0f;
	if ( h > 9)
		h = h + 7;
	h = h + 0x30;
	put_char_kbbuff(h);
	l = sc & 0x0f;
	if ( l > 9)
		l = l + 7;
	l = l + 0x30;
	put_char_kbbuff(l);
// keyboard ISR
interrupt [EXT_INT0] keyboard_isr(void) {
	static unsigned char data;	// holds the received scan code
	// function entered at falling edge of the kbd clock signal
	// if data bit is the next bit to be read
	// (bit 3 to 10 is data, start, stop & parity bis are ignored
	if((bitcount < 11) && (bitcount > 2)) {
		data = (data >> 1);
		if (KBD_DATA)			// if next bit is 1
			data = data | 0x80;	// store a '1'
			data = data & 0x7f; // else store a '0'
	if(--bitcount == 0) {		// all bits received ?
		   	decode(data);       // decode received byte
			bitcount = 11;		// reset bit counter
// decode scan code
void decode(unsigned char sc) {
 	static unsigned char is_up=0, shift = 0, mode = 0;
	unsigned char i;
	if (!is_up) {
		switch (sc) {
			case 0xF0 :// The up-key identifier
				is_up = 1;
				break;
			case 0x12 :// Left SHIFT
				shift = 1;
				break;
			case 0x59 :// Right SHIFT
				shift = 1;
				break;
			case 0x05 :// F1
				if(mode == 0)
					mode = 1;// Enter scan code mode
				if(mode == 2)
					mode = 3;// Leave scan code mode
				break;
			default:
				if(mode == 0 || mode == 3) {// If ASCII mode
					if(!shift) {// If shift not pressed, do a table look-up
						for(i = 0; unshifted[i][0]!=sc && unshifted[i][0]; i++);
							if (unshifted[i][0] == sc) {
								put_char_kbbuff(unshifted[i][1]);
					else {// If shift pressed
						for(i = 0; shifted[i][0]!=sc && shifted[i][0]; i++);
							if (shifted[i][0] == sc) {
								put_char_kbbuff(shifted[i][1]);
				else put_scancode_kbbuff(sc);	// scan code mode (debugging mode)
				break;
	else {
		is_up = 0;// Two 0xF0 in a row not allowed
		switch (sc) {
				shift = 0;
				break;
				shift = 0;
				break;
			case 0x05 :// F1 --  F1 puts you in debugging mode
				   // pressing F1 again gets you out of debugging mode
				   // in debugging mode hex code of the scan codes
				   // are stored in the buffer instead of their ascii codes
				if(mode == 1)
				mode = 2;
				if(mode == 3)
					mode = 0;
				break;
// store character in the keyboard ring buffer
void put_char_kbbuff(unsigned char c) {
	if (buffcnt < BUFF_SIZE) { // if buffer is not full
		*(inpt++) = c;
		buffcnt++;
		if (inpt >= kb_buffer + BUFF_SIZE) // pointer wrapping
			inpt = kb_buffer;
// get next available character from the keyboard ring buffer
// (waits until a character is available in the buffer)
int getchar(void) {
	int byte;
	while (buffcnt == 0); // wait for data
	byte = *outpt; // get byte
	outpt++;
	if (outpt >= kb_buffer + BUFF_SIZE) // pointer wrapping
		outpt = kb_buffer;
	buffcnt--; // decrement buffer count
	return byte;
void lcd_init(void) {
	delay_ms(50);
	LCD_E = 0;
	LCD_RS = COMMAND_MODE;
	LCD_RW = WRITE_MODE;
	delay_ms(1);
	LCD_DATA_PORT = 0x38;	// 8 bit, 2 lines, 5x8 font
	LCD_E = 1;	delay_ms(1);
	LCD_E = 0;	delay_ms(1);
	LCD_DATA_PORT = 0x0f;	// display & cursor ON, blink & underlined
	LCD_E = 0;	delay_ms(2);
	lcd_clear();
void lcd_clear(void) {
    LCD_DATA_PORT = 0x01;	// clear display
// display char on lcd
void lcd_putc(unsigned char ch) {
	LCD_RS = DATA_MODE;
	LCD_DATA_PORT = ch;
	LCD_E = 1;	delay_us(40);
	LCD_E = 0;	delay_us(40);
// display string on lcd
// input: pointer to string stored in flash ROM
void lcd_putsf(unsigned char flash *str) {
	while (*str!= '\0') {
    	lcd_putc(*(str++));
//  same as above except the string is in RAM
void lcd_puts(unsigned char *str) {
    	lcd_putc(*(str++));
ahmet2004
cesar35
Dear ahmet2004
adjusted to 360
 I need help with keyboard display in the project, the project works out normal only when the power is not in the message memory of the AVR, important to me ..
Thanks ........
ahmet2004
I can not now try at90s8535 no. Something on the eeprom can not write a.
Turkish know. Where do you write to forum.
