Hi-Tech C18 9.63 Yardım Lütfen
Başlatan BenC, 28 Ekim 2009, 18:07:20
BenC
Aşağıdaki yazıda tam olarak ne demek istiyor arkadaşlar. Yardımcı olabilirseniz çok sevinirim. Basit bir programı bile derleyemedim. :(
Why do I get "(924) missing argument to -O option" when compiling under MPLAB IDE?
The command-line options passed to the compiler driver changed in version 9
compilers, and you need to be using a new MPLAB IDE compiler plugin to ensure
these new options are used when compiling.
If you're using a version 9 compiler, in MPLAB IDE choose Select Language Toolsuite
from the Project menu and select the "HI-TECH Universal Toolsuite" rather than
one of the older compiler-specific toolsuites, such as the HI-TECH PICC Toolsuite or
the HI-TECH PICC-18 Toolsuite.
Do NOT specify the path of the compiler in the Location field of this dialog; it is not
used. See the webinar:
http://techtrain.microchip.com/webseminars/ArchivedDetail.aspx?Active=193
for more information on creating projects and using the HI-TECH Universal Toolsuite
in MPLAB IDE.Back to top
ŞEHİT KANIYLA ALINMIŞ BU GÜZELİM VATANIN TOPRAKLARI KARIŞ KARIŞ SATILIYOR!!  VATAN HAİNİ OLMA!!
BenC
Arkadaşlar Hi-Tech c18 kullanan yokmu hiç.
BenC
arkadaşlar  hitech c18 9.63 ü kurup sağlıklı bir biçimde mplab ile derleyebilen kimse yok mu forum da??
BenC
