ASSEMBLY PROGRAMIMA YARDIM
Başlatan sercan52, 13 Aralık 2009, 16:39:36
sercan52
arkadaşlar bu program neden hata veriyor bilgilerinizi paylaşabiirmisiniz?
   list        p=16f876a   ; list directive to define processor
   #include    <p16f876a.inc>  ; processor specific variable definitions
   __CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _RC_OSC & _WRT_OFF & _LVP_ON & _CPD_OFF
; '__CONFIG' directive is used to embed configuration data within .asm file.
; The labels following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
;***** VARIABLE DEFINITIONS (examples)
;BANK SEÇMEKSİZİN KULLANILABİLEN DEĞİŞKENLER (MAX 16 ADET)
INT_VAR     UDATA_SHR
w_temp      RES     1       ; variable used for context saving
status_temp RES     1       ; variable used for context saving
pclath_temp RES     1       ; variable used for context saving
; example of using Uninitialized Data Section
TEMP_VAR    UDATA           ; explicit address specified is not required
temp_count  RES     1       ; temporary variable (example)
;bir bank a ait değişkenler
; in this example both variables are assigned the same GPR location by linker
G_DATA      UDATA_OVR       ; explicit address can be specified
flag        RES   2       ; temporary variable (shared locations - G_DATA)
FILTER:      UDATA   0x30                                     ;*
N           res    8      ;//  bank 1 de 0x30 adresinden başlayan toplamda
TOPLAM      res     2      ;//11 adet değişken tanımladık (filitre işlemi için)
SONUC      RES     1
G_DATA      UDATA_OVR
count       RES     2       ; temporary variable (shared locations - G_DATA)
RESET_VECTOR    CODE    0x0000  ; processor reset vector
   nop                         ; nop for icd
   pagesel start
   goto    start               ; go to beginning of program
INT_VECTOR      CODE    0x0004  ; interrupt vector location
INTERRUPT
;KESMEDEN ÖNCE SİSTEM ÇALIŞMASI BOZULMAMASI İÇİN
;W REGISTER, STATUS, VE PROGRAM COUNTER VE PROGRAM COUNTER
; YÜKSEK BYTE GEÇİCİ DEĞİŞKENLERDE SAKLANIR
   movwf   w_temp          ; save off current W register contents
   movf    STATUS,w        ; move status register into W register
   movwf   status_temp     ; save off contents of STATUS register
   movf    PCLATH,w        ; move pclath register into w register
   movwf   pclath_temp     ; save off contents of PCLATH register
; isr code can go here or be located as a call subroutine elsewhere
;KESME İŞLEMİ****************************************************
BANKSEL PIR1            ;PIR1 Register bankını seç
   BTFSS PIR1,ADIF         ; ADC kesme bayrağını kontrol et
   GOTO adc_kesme_yok      ;ADC bayrağı aktif değilse diğer kesmelere atla
   CALL DIGITAL_FILTER     ;adc kesmesi aktif filitre programına git
adc_kesme_yok:
; diğer kesme işlemleri
; KESME İŞLEMİ BİTTİ PROGRAM AKIŞINA GERİ DÖN
   movf    pclath_temp,w       ; retrieve copy of PCLATH register
   movwf   PCLATH          ; restore pre-isr PCLATH register contents
   movf    status_temp,w       ; retrieve copy of STATUS register
   movwf   STATUS          ; restore pre-isr STATUS register contents
   swapf   w_temp,f
   swapf   w_temp,w        ; restore pre-isr W register contents
   retfie              ; return from interrupt
;ANA PROGRAM
MAIN_PROG       CODE
start
   call adc_ayar
   movlw b'11000000'
   movwf INTCON
TEKRAR:
   call sinyal_cikis
;DİĞER YAPACAĞIN DİĞER İŞLEMLER
   goto TEKRAR
sinyal_cikis
banksel SONUC
movf SONUC,w
banksel PORTB
MOVWF PORTB
RETURN
;filitre alt programı
;NOT: sürekli tekrarlanan işlemler programın daha kısa sürede bitmesini
;sağlamak için düngüsüz olarak yazılmıştır isteğe bağlı olarak döngü içerisine
;yazılabilir
;ALT PROGRAM FİLİTRELEME İŞLEMİNİ TAMAMLAYIP ELDE EDİLEN DEĞERİ
; "SONUC" DEĞİŞKENİNE ATAR İSTENİLEN İŞLEMLER "SONUC"
;DEĞİŞKENİ KOPYALANARAK YAPILABİLİR
DIGITAL_FILTER:
            ;____________________________________
              ;N8 <= N7 <= N6 ... N1<= N0 <= ADRESH
              nop
            BANKSEL N      ; FILTER değişkenlerinin buluntuğu bank seçildi
            ;N8=N7
            MOVF N+6,w
              MOVWF N+7
              ;N7=N6
            MOVF N+5,w
              MOVWF N+6
              ;N6=N5
            MOVF N+4,w
              MOVWF N+5
            ;N5=N4
            MOVF N+3,w
              MOVWF N+4
            ;N4=N3
            MOVF N+2,w
              MOVWF N+3
              ;N3=N2
            MOVF N+1,w
              MOVWF N+2
              ;N2=N1
            MOVF N+0,w
              MOVWF N+1
              ;N0=N1
            MOVF ADRESH,w
              MOVWF N+0
; TOPLAM =N1+N2+...N8
 CLRF TOPLAM      ; TOPLAM(LOW BYTE)
 CLRF TOPLAM+1    ; TOPLAM(HIGH BYTE)
;_________
 MOVF N+0 ,w
 ADDWF TOPLAM,F
BTFSC STATUS,C
INCF TOPLAM+1,f
  MOVF N+1 ,w
 ADDWF TOPLAM,F
BTFSC STATUS,C
INCF TOPLAM+1,F
  MOVF N+2 ,w
 ADDWF TOPLAM,F
BTFSC STATUS,C
INCF TOPLAM+1,f
  MOVF N+3  ,w
 ADDWF TOPLAM,F
BTFSC STATUS,C
INCF TOPLAM+1,f
 MOVF N+4 ,w
 ADDWF TOPLAM,F
BTFSC STATUS,C
INCF TOPLAM+1,f
 MOVF N+5  ,w
 ADDWF TOPLAM,F
BTFSC STATUS,C
INCF TOPLAM+1,f
 MOVF N+6   ,w
 ADDWF TOPLAM,F
BTFSC STATUS,C
INCF TOPLAM+1,f
 MOVF N+7 ,w
 ADDWF TOPLAM,F
BTFSC STATUS,C
INCF TOPLAM+1,f
;SONUC =TOPLAM /8
;8'bölme işlemi 3 kere sağa shift yapılarakta elde edilebilir
BCF STATUS,C
RRF TOPLAM+1,f
RRF TOPLAM,f
BCF STATUS,C
RRF TOPLAM+1,f
RRF TOPLAM,f
BCF STATUS,C
RRF TOPLAM+1,f
RRF TOPLAM,f
MOVF TOPLAM,w
MOVWF SONUC
BANKSEL ADCON0
BSF ADCON0,GO_DONE
BANKSEL PIR1
BCF PIR1,ADIF
RETURN ; geri dön
 ;adc ayarları
adc_ayar:
   banksel TRISA       ;TRISA NIN BANKINI SEÇ
   BSF TRISA,0         ;PORTA,0 GİRİŞ
   CLRF TRISB          ; PORTB CIKIŞ
BANKSEL ADCON0          ; pic16f876a DATA SHEET ten bitlerin anlamlarını öğrenebilirsin
   MOVLW B'10000001'   ;ADCS1 ADCS0 CHS2 CHS1 CHS0 GO/DONE — ADON
   MOVWF ADCON0
BANKSEL ADCON1
  MOVLW B'00001110'         ;ADFM — — — PCFG3 PCFG2 PCFG1 PCFG0
  MOVWF ADCON1
banksel PIE1
   BSF PIE1,ADIE
BANKSEL PIR1
   BCF PIR1,ADIF
BANKSEL ADCON0
BSF ADCON0,GO_DONE
  return
   END                       ; directive 'end of program'
ipek
http://rapidshare.com/files/320441415/filter.rar.html
dosyada bir hata yok linker scrpt oluşturmamışsın  projene 16f876a_g.lkr de ilave et
sercan52
çok sağolun ayrıca be den dolayı da özür "bu" yazacaktım yalnış olmuş hemen düzeltiyorum
