bir dizi de indis okuma problemi
Başlatan picman, 11 Nisan 2010, 20:10:51
picman
const char TABLO5[255] = { 	0X81,0X81,0X91,0X91,0X91,0XFF,0XFF, //6-E
							0X80,0X80,0X88,0X88,0X88,0XFF,0XFF, //13-F
							0X4E,0XCF,0X89,0X89,0X81,0XFF,0X7E, //20-G
							0XFF,0XFF,0X10,0X10,0X10,0XFF,0XFF, //27-H
							0X00,0X81,0XFF,0XFF,0X81,0X00,0X00, //34-I
							0X80,0XFE,0XFF,0X81,0X01,0X07,0X06, //41-J
							0X81,0XC3,0X66,0X3C,0X18,0XFF,0XFF, //48-K
							0X01,0X01,0X01,0X01,0X01,0XFF,0XFF, //55-L
							0XFF,0XFF,0X60,0X30,0X60,0XFF,0XFF, //62-M
							0XFF,0XFF,0X0C,0X18,0X30,0XFF,0XFF, //69-N
							0X7E,0XFF,0X81,0X81,0X81,0XFF,0X7E, //76-O
							0X70,0XF8,0X88,0X88,0X88,0XFF,0XFF, //83-P
							0X7D,0XFE,0X85,0X89,0X81,0XFF,0X7E, //90-Q
							0X61,0XF3,0X96,0X9C,0X98,0XFF,0XFF, //97-R
							0X4E,0X5F,0X91,0X91,0X91,0XF3,0X62, //104-S
							0X00,0X80,0X80,0XFF,0XFF,0X80,0X80, //111-T
							0XFE,0XFF,0X01,0X01,0X01,0XFF,0XFE, //118-U
							0XFC,0XFE,0X03,0X03,0X03,0XFE,0XFC, //125-V
							0XFC,0XFF,0X03,0X0E,0X03,0XFF,0XFC, //132-W
							0XC3,0X66,0X3C,0X18,0X3C,0X66,0XC3, //139-X
							0X00,0XE0,0XF0,0X1F,0X1F,0XF0,0XE0, //146-Y
							0X60,0XE1,0XB1,0X99,0X8D,0X87,0X83, //153-Z
							0X00,0X00,0X81,0X81,0XFF,0XFF,0X00, //160-[
							0X03,0X06,0X0C,0X18,0X30,0X60,0XC0, //167-\
							0X00,0XFF,0XFF,0X81,0X81,0X00,0X00, //174-]
							0X00,0X20,0X60,0XC0,0X60,0X20,0X00, //181-^
							0X01,0X01,0X01,0X01,0X01,0X01,0X01, //188-_
							0X3F,0X3F,0X29,0X29,0X29,0X2F,0X26, //195-a
							0X1E,0X3F,0X21,0X21,0X11,0XFF,0XFF, //202-b
							0X12,0X33,0X21,0X21,0X21,0X3F,0X1E, //209-c
							0XFF,0XFF,0X11,0X21,0X21,0X3F,0X1E, //216-d
							0X1E,0X3F,0X29,0X29,0X29,0X3B,0X1A, //223-e
							0X40,0X80,0X90,0XFF,0X7F,0X10,0X00, //230-f
							0X1E,0X1F,0X25,0X25,0X25,0X3D,0X18, //237-g
							0X1F,0X3F,0X20,0X20,0X10,0XFF,0XFF, //244-h
							0X00,0X01,0XBF,0XBF,0X21,0X00,0X00 //251-i
a
arkadaşlar yukarıdaki tabloda 167. indisten sonraki veriler yanlış okunuyor bu problemin sebebi ne olabilir acaba
mesela 169 uncu veriyi okumak istediğimde 7 sonraki indis değerini okuyor 0xff değeri okunacağı yerde 0x20 değeri okunuyor
programda başka tablolarda var ama sadece bu tabloda böyle bir sorun oluyor nedir bu problemin nedeni acaba bilgisi olan var mı
Bilgi paylaştıkça artar..
picman
arkadaşım o satır / karakterinin lamba yakma kodları o yüzden ama ben o karakterin böyle bir probleme yol açacağını hiç düşünmedim deniyorum şimdi ilgin için çok çok teşekkür ederim
picman
ben derleyici olarak mplab ı kullandığım için o sorunu göremedim ama hi tide de bu sorun gözüküyor sanırım ... devre sayende çalıştı
ilgin için teşekkür .. hayırlı akşamlar..
