WinCE için PSoC USB driver Cy8c24794
Başlatan cornelia, 03 Kasım 2010, 11:38:55
cornelia
Merhaba ,
ben burda yeniyim ve türkcem biraz az. yazilarimda yanlis yaparsam sorry.
Ben Cypress Cy8c24794  ile 3 tane 3 renkli LED'i konrol etmek istiyorum.
Bunu windows xp ile calistirdigim zaman problem yok. cünkü cypres XP ve üzeri Driver i var ama CE yok.
Hyper Terminalle RS-232 ile de kontrol edebiliyorum.
Burda bu konu üzerine birseyler okudum ama fazla birsey anlamadim. Ben Driver yazamam okadar bilgim yok.
sizden rica etsem bana yardimci olabilirniz?
tesekkür
cornelia  ;)
; Windows USB CDC setup file for USBUART User Module
; (c) Copyright 2007 Cypress Semiconductor Corporation
[Version]
Signature="$Windows NT$"
Class=Ports
ClassGuid={4D36E978-E325-11CE-BFC1-08002BE10318}
Provider=%PROVIDER%
LayoutFile=layout.inf
DriverVer=03/05/2007,2.0.0000.0
[Manufacturer]
%MFGNAME%=DeviceList, NTx86, NTia64, NTamd64
[DestinationDirs]
DefaultDestDir=12
[SourceDisksFiles]
[SourceDisksNames]
[DeviceList.NTx86]
%DESCRIPTION%=DriverInstall, USB\VID_04B4&PID_E00A
[DeviceList.NTia64]
[DeviceList.NTamd64]
;  32 bit section for Windows 2000/2003/XP/Vista
[DriverInstall.NTx86]
include=mdmcpq.inf
CopyFiles=DriverCopyFiles
AddReg=DriverInstall.NTx86.AddReg
[DriverCopyFiles]
usbser.sys,,,0x20
[DriverInstall.NTx86.AddReg]
HKR,,DevLoader,,*ntkern
HKR,,NTMPDriver,,usbser.sys
HKR,,EnumPropPages32,,"MsPorts.dll,SerialPortPropPageProvider"
[DriverInstall.NTx86.Services]
AddService=usbser, 0x00000002, DriverService
;  64 bit section for Intel Itanium based systems
[DriverInstall.NTia64]
include=mdmcpq.inf
AddReg=DriverInstall.NTia64.AddReg
[DriverCopyFiles]
usbser.sys,,,0x20
[DriverInstall.NTia64.AddReg]
[DriverInstall.NTia64.Services]
;  64 bit section for AMD64 and Intel EM64T based systems
[DriverInstall.NTamd64]
include=mdmcpq.inf
AddReg=DriverInstall.NTamd64.AddReg
[DriverCopyFiles]
usbser.sys,,,0x20
[DriverInstall.NTamd64.AddReg]
[DriverInstall.NTamd64.Services]
[DriverService]
DisplayName=%SERVICE%
ServiceType=1
StartType=3
ErrorControl=1
ServiceBinary=%12%\usbser.sys
;  String Definitions
[Strings]
PROVIDER="Cypress"
MFGNAME="Cypress"
DESCRIPTION="Cypress"
SERVICE="USB RS-232"
ahmet2004
CE driver'ımı istiyorsunuz?
Siz hangi CE yi kullanıyorsunuz.Nasıl bir cihaz vaya kit var elinizde?
Tam anlamadım sorunuzu biraz daha fazla açabilirseniz...
cornelia
önce cevap verdiyiniz icin tesekkürler. :)
Evet Windows CE icin Driver ariyorum ben. Asagida Schematic benim elektronik. Bu icin PSoC Express 3 le Program yaptim ve Driveri Installieren yaptim , Windows XP ile pefect calisti.
yalniz yanimdaki mini PC ARM9 32bit 400MHz le calismadi Driver istiyor.
        _____________________________________+5V
        I               I                I
        I               I                I
        I               I                I
                         cy8c24794                                    LED            I                I
                         ___________                                 I               I                I
                         I                    I                                I                I                I
                         I                    I________________/              LED             I
                         I                    I                                \                I                I
                         I                    I                                I                I                I
                         I                    I________________I________/              LED
                         I                    I                                I                \                I
                         I                    I                                I                I                I
USBUART---- ---I                    I________________I________I________/
                         I                    I                                I                I                \
                         I                    I                                I                I                I
                         I                    I                                I                I                I
                         I                    I                                I                I                I
                         I__________I                               GND         GND          GND
nasil yapacakkimi bilmiyorum. :(
tesekkürler.
cornelia  ;)
picusta
Surada kolay yoldan yapildi, saglikli çalisiyor  :
https://www.picproje.org/index.php/topic,28592.0.html
Fakat oradaki spesifik, senin ilave etmen gereken USB CDC tanimlama.
Bu basit devre için bence FTDI çiplerine bak, onlarda WinCE driver oluyor. Olmadi FTDI'den sonra mikroislemcini koyarsin.
cornelia
Merhaba,  :)
verilen linkte indirebilek birsey bulamadim. USB CDC ne oluyo anlamadi.
FTDI bende düsündüm ama cy8c74794 ün RS-232 yok. nasil bagayacakimi anlamadim.
Lütfen yardimci olursunuzmu.
tesekkürler
cornelia ;)
cornelia
iki saatir denedim olmadi.  :(    yokmu bana yardim edecek :'(
picusta
Seri portu olmayan islemci olur mu ? olsa bile yazilimsal Seri port yaparsin. Bkz 16F84 örnekleri.
CDC demek Seri portu emule eden USB sinifi demek.
2 saat az daha fazla ugrasmalisin.
Verdigim konuda iyi okuduysan, bir programdan bahsediyorum.  O programin da hangi siteden indirilebilecegini söylüyorum. Bu forumda warez de olmaz garez de.
