ısd 1700 MENÜ NASIL İYİLEŞTİREBİLİRİM
Başlatan fryrmnd, 17 Haziran 2011, 13:53:38
fryrmnd
arkdaşlar sadece device id numarasını okumak için bir kod yazdım... hatalarım nerdedir... yardım erderseniz çok makbule geçecek...
DEFINE LCD_DREG      PORTD
DEFINE LCD_DBIT         4
DEFINE LCD_EREG      PORTD
DEFINE LCD_EBIT         3
DEFINE LCD_RSREG   PORTD
DEFINE LCD_RSBIT      2
DEFINE LCD_BITS         4
DEFINE LCD_LINES      2
ADCON1=7
CMCON=7
SSPEN VAR SSPCON.5
CKP VAR SSPCON.4
SMP VAR SSPSTAT.7
CKE VAR SSPSTAT.6
SSPIF VAR PIR1.3
SS VAR PORTC.6
Isd_Data VAR BYTE[7]  'ISD DEN GELECEK VERİNİN TUTULACAĞI BYTE LAR
bSpi VAR BYTE         'MOSI VE MISO DAN GELEN VERİNİN TUTULACAĞI BYTE
bSpi_Rev var byte     'YOLLANAN VE ALINAN VERİYİ TERSLEYİP ALMAK İÇİN(ISD LSB Yİ İLK YOLLUYO)
SR0A VAR ISD_DATA[0]  'STATUS REGİSTER 0 İLK BYTE
SR0B VAR ISD_DATA[1]  'STATUS REGİSTER 0 İKİNCİ BYTE
SR1 VAR ISD_DATA[2]   'STATUS REGİSTER 1
isCMDERR var SR0A.0   'STATUS REGİSTER 0 COMMAND ERROR BİTİ
isFULL var SR0A.1     '    "      "  MEMORY FULL BİTİ
isPU var SR0A.2       '    "      "  POWER UP BİTİ
isEOM VAR SR0A.3      '  "        "  END OF MESSAGE BİTİ
isINT var SR0A.4      '   "       "  İNTERRUPT BİTİ
isREADY var SR1.0      'STATUS REGİSTER 1 DEVİCE READY BİTİ
TRISD=0
TRISA=0
TRISB=0
TRISC=%00010000
TRISE=0
PORTD=0
PORTA=0
PORTB=0
PORTE=0
PORTC.3=1
PORTC.5=0  'AÇILIŞTA SS=HIGH, MOSI=LOW  VE SCLK HİGH OLABİLİR DİYE YAZIYO
SS=1       'DESGİN NOTE SF 34
SSPEN=1            'SERİ PORT ENABLE
SSPIF=0            'SERİ PORT İNTERRUP FLAG TEMİZLENDİ
smp=0
ckp=1              'İDLE STATE HİGH
cke=0              'İDLE TO ACTİVE CLOCK STATE(ANLADIĞIM DÜŞEN KENARDA VERİ YOLLANACAK)
'DATA TRANSFRE PROTOCOL REQUİRES THAT THE MİCROCONTROLLER'A SPİ SHİFT REGİSTERS ARE CLOCKED OUT
'ON THE FALLİNG EDGE OF SCLK.... DESİGN NOTE SF 31
PAUSE 300
LCDOUT $FE,1
gosub Isd_Pu         'POWER UP KOMUTU
pause 50
gosub Isd_Read_Status 'KOMUT HATASI OLUŞTUMU
if isCMDERR=1 then
lcdout $FE,1,"hatalı komut"
endif
main:
LCDOUT $FE,2,"BASLIYOR"
gosub Isd_Wait_Ready   'SR1 READY BİTİ İNCELENİYO (ISD KOMUT ALMAYA HAZIRMI)
gosub Isd_Read_DeviceId  'ISD 1760 DEVİCE ID... DÖNEN 1 BYTE IN SON 5 BİTİ 10100 OLMALI
LCDOUT $FE,1,BIN Isd_Data[3]
gosub Isd_Read_Status           'HATA OLUŞTUMU VE CİHAZ TEKRAR KOMUT ALMAYA HAZIRMI
if isCMDERR=1 then              'BAŞKA KOMUT YOLLAMIYOM TABİ DE
endif
goto main
Isd_Pu:
SS=0       'SLAVE SELECT LOW
bSpi=$01  'POWER UP KOMUTU İLK BYTE
gosub Isd_Spi
SR0A=bspi_rev  'ISD DEN GELEN İLK BYTE SROA
bspi=$00   'POWER UP KOMUTU 2. BYTE
gosub Isd_Spi
SR0B=bspi_rev  'İKİNCİ BYTE SR0B
SS=1      ' SLAVE SELECT HİGH
return
Isd_Read_DeviceId:
SS=0
bspi=$09            'DEVİCE ID KOMUTU İLK BYTE
gosub Isd_Spi
SR0A=bspi_rev
bspi=$00            '2. BYTE
gosub Isd_Spi
SR0B=bspi_rev
bspi=$00             '3. BYTE
gosub Isd_Spi
Isd_Data[3]=bSpi_ReV
SS=0
return
Isd_Wait_Int:
if isInT=0 then Isd_Wait_Int
return
Isd_Wait_Ready:
gosub Isd_Read_Status    'READ STATUS KOMUTU YOLLANACAK
if isREADY=1 then Isd_Wait_Ready   'DÖNEN SR1DE READY BİTİ 1 OLANA KADA BEKLENİYO
return
Isd_Read_Status:
SS=0
bspi=$05
gosub Isd_Spi
SR0A=bspi_rev
bspi=$00
gosub Isd_Spi
SR0B=bspi_rev
bspi=$00
gosub Isd_Spi
SR1=bspi_rev
SS=1
return
Isd_Int_Clear:
SS=0
bspi=$04
gosub Isd_Spi
SR0A=bspi_rev
bspi=$00
gosub Isd_Spi
SR0B=bspi_rev
SS=1
return
Isd_Spi:
bspi_rev=bspi rev 8
SSPBUF=bspi_rev    'İLK BYTE IN TERLENMİŞ HALİ YOLLANIYOR
gosub letClear     'SERİ PORT İNTERRUP FLAG TEMZİLENİYOR
bspi=SSPBUF        'ISD DEN GELEN İLK VERİ ALINIYO
gosub letclear
bspi_rev=bspi rev 8 'TERSLENİYO
return
letClear:
if SSPIF=0 then letclear
pauseus 25
SSPIF=0
return
fryrmnd
arkdaşlar 8-9 tane telefon hattına bağlayaacağım  pic ve ISD ses entegersiyle bir düzenek kurmaya çalışıyorum... düzenek aktifken çalan telefonun kime ait olcağını hoparlörden verecek... bu kısmı ana döngü içinde vriyorum,burda sorun yok... tabi 2. bir menüye rb0 kesmesi ile girip menüde her telefon için kayıt, silme,kaydettiğini dinleme ve ses seviyesi ayarı yapmaya çalışınca ben de  sstack overflow hatası aldım....   bu menü işi sistemi aktif etmeden kesme içinde halledilebilrmi,,, edilemezse bu işi nasıl yapabilirim... değişik bi yol aklına gelen varsa çok sevinirim... kod aşağıda... teşekkürler
DEFINE LCD_DBIT			4
DEFINE LCD_EBIT			3
DEFINE LCD_RSBIT		2
DEFINE LCD_BITS			4
DEFINE LCD_LINES		2
ON INTERRUPT GOTO KESME
INTCON=%10010000
OPTION_REG.6=0 'DÜŞEN KENAR KESME
ADCON1=7
CMCON=7
OPTION_REG.7=0 'pull up aktif(buton basınca toprağa çekecek)
ANASAY VAR BYTE
ALTSAY VAR BYTE
ALTSAYKALAN VAR BYTE
temp_bit    VAR BIT
temp		VAR BYTE
spi_cnt 	             var byte	' counter for SPI transfer
bSPI 		var byte 	' the byte being transferred on SPI
s_addr		VAR WORD	' Start Address
e_addr		VAR WORD	' End Address
ISD_Data 	var byte[7]	' This array contains data to/from ISD
SR0a 		var ISD_Data[0]
SR0b 		var ISD_Data[1]
SR1 		var ISD_Data[2]    ' only valid after ReadStatus
isCmdErr 	var SR0a.0	             ' 1=previous command failed/ignored
isFull 		var SR0a.1	' 1=memory full
isPU		var SR0a.2	' 1=ISD powered up
isEOM		VAR SR0a.3	' 1=EOM detected (clear by CLR_INT command)
isINT 		var SR0a.4	' 1=current operation completed (clear by CLR_INT command)
isReady 	var SR1.0	' 1=Ready to receive SPI command (only valid after ReadStatus)
				        ' Some SPI commands can still be sent when isReady=0
SYMBOL cikis=PORTB.0
symbol asagitus=PORTB.1
SYMBOL yukaritus=PORTB.2
SYMBOL sec=PORTB.3
SYMBOL INTF=INTCON.1
Symbol ss		= PORTC.3			'ISD1760 SLAVE SELECT
Symbol sclk		= PORTC.4			'ISD1760 SPI CLOCK
Symbol mosi 	= PORTC.5         	'ISD1760 SPI MOSI
Symbol miso		= PORTC.6			'ISD1760 SPI MISO
TRISD=0
TRISA=1
TRISB=1
TRISC=%01000000
TRISE=1
PORTD=0
PORTA=0
PORTB=1
PORTE=0
ANASAY=1
pause 300
LCDOUT $FE,$40,16,8,4,3,4,8,16,0  '> ÖZEL KARAKTERİ... 0 NOLU ADRESTE
lcdout $FE,1
LCDOUT $FE,$84,"BASLIYOR"
BASLA:
'bu kısımda kime telefon gelmişse tespit edip onun kısmını ses entegresinden çalıyorum
GOTO BASLA
disable
KESME:
  GOSUB ANAMENU           '  >KAYIT      ÇIKIS
                           '  CAL        SEC
  WHILE cikis=1  'AKTIF MODA GERI
  IF ASAGITUS=0 THEN     'ANAMENU ASAĞI
     ANASAY=ANASAY+1
     GOSUB ANAMENU
  ENDIF
  WHILE ASAGITUS=0
  WEND
  IF YUKARITUS=0 THEN   'ANAMENU YUKARI
    ANASAY=ANASAY-1
    GOSUB ANAMENU
  ENDIF
  WHILE YUKARITUS=0
  WEND
  IF SEC=0 THEN        'ANAMENUDEN ALT MENUYE           ' >1. KAYIT     BASLA  BU ANASAY DEGERİNE GÖRE DEĞİŞEBİLİYO
   GOSUB ALTMENUSECIMLI  'HANGI MENUYE GIDILCEĞI       '   2. KAYIT     GERİ
  WHILE SEC=0
  WEND
    WHILE CIKIS=0      'GERI SEÇENEGI SEÇİLMEDIĞI SÜRECE ALT MENÜDE
     IF ASAGITUS=0 THEN    'ALT MENÜDE ASAĞI
      ALTSAY=ALTSAY+1
     ENDIF
     WHILE ASAGITUS=0
     WEND
     IF YUKARITUS=0 THEN    'ALTMENÜDE YUKARI
      ALTSAY=ALTSAY-1
     ENDIF
     WHILE YUKARITUS=0
     WEND
     IF SEC=0 THEN           'ALT MENUDE SEÇ (PLAY REC,ERASE,VOL?)
      SELECT CASE ANASAY       'HANGI ALT MENÜDE OLDUĞUMUZA BAKILACAK
       CASE 1
        GOSUB isd_set_rec2
       CASE 2
        GOSUB isd_set_play2
       CASE 3
        GOSUB isd_set_erase2
       CASE 4
        GOSUB isd_set_vol2
      END SELECT
      GOSUB ISD_WAIT_RDY     'RDY BİTİ KONTROL EDİLİYO  (VOLUME İNT DURUMUNA GÖRE İF İLE İŞLEM VOLUME MU  SORGULAMA YAPILIP İNT CLERAR EDİLCEK)
      ALTSAY=1
      ENDIF
   WEND        'CIKIŞ=GERI TUSU
   ANASAY=1
  ENDIF        'SEC İLE ALT MENUYE GİRMİŞTİK
WEND  'ÇIKIŞIN
  WHILE CIKIS=0
  WEND
  INTF=0
RESUME
ENABLE
ANAMENU:
LCDOUT $FE,1
 SELECT CASE ANASAY
  CASE 1
 LCDOUT $FE,$82,0,"KAYIT",$FE,$C0,"CAL",$FE,$8D,"SEC",$FE,$CB,"CIKIS"
  CASE 2
 LCDOUT $FE,$80,"KAYIT",$FE,$C2,0,"CAL",$FE,$8D,"SEC",$FE,$CB,"CIKIS"
  CASE 3
 LCDOUT $FE,$82,0,"SIL",$FE,$C0,"SES AYARI",$FE,$8D,"SEC",$FE,$CB,"CIKIS"
  CASE 4
 LCDOUT $FE,$80,"SIL",$FE,$C2,0,"SES AYARI",$FE,$8D,"SEC",$FE,$CB,"CIKIS"
 END SELECT
RETURN
ALTMENUSECIMLI:
  SELECT CASE ANASAY
   CASE 1
     GOSUB ALTMENUKAYIT
   CASE 2
     GOSUB ALTMENUCAL
   CASE 3
     GOSUB  ALTMENUSIL
   CASE 4
     GOSUB ALTMENUSESAYARI
 END SELECT
RETURN
 ALTMENUKAYIT:
 LCDOUT $FE,1
 ALTSAYKALAN=ALTSAY//2
  IF ALTSAYKALAN=1 THEN
  LCDOUT $FE,$82,0,$FE,$83,#ALTSAY,". KAYIT",$FE,$8B,"BASLA",$FE,$C0,#ALTSAY+1,". KAYIT",$FE,$CC,"GERI"
  ENDIF
  LCDOUT $FE,$80,#ALTSAY,". KAYIT",$FE,$8B,"BASLA",$FE,$C2,0,$FE,$C3,#ALTSAY+1,". KAYIT",$FE,$CC,"GERI"
  ENDIF
 RETURN
 ALTMENUCAL:
  LCDOUT $FE,1
  LCDOUT $FE,$82,0,$FE,$83,#ALTSAY,". KAYIT",$FE,$8B,"DINLE",$FE,$C0,#ALTSAY+1,". KAYIT",$FE,$CC,"GERI"
  ENDIF
  LCDOUT $FE,$80,#ALTSAY,". KAYIT",$FE,$8B,"DINLE",$FE,$C2,0,$FE,$C3,#ALTSAY+1,". KAYIT",$FE,$CC,"GERI"
  ENDIF
 RETURN
 ALTMENUSIL:
  LCDOUT $FE,1
  LCDOUT $FE,$82,0,$FE,$83,#ALTSAY,". KAYIT",$FE,$8D,"SIL",$FE,$C0,#ALTSAY+1,". KAYIT",$FE,$CC,"GERI"
  ENDIF
  LCDOUT $FE,$80,#ALTSAY,". KAYIT",$FE,$8D,"SIL",$FE,$C2,0,$FE,$C3,#ALTSAY+1,". KAYIT",$FE,$CC,"GERI"
  ENDIF
 RETURN
 ALTMENUSESAYARI:
  LCDOUT $FE,1
  LCDOUT $FE,$82,0,$FE,$83,#ALTSAY,". DERECE",$FE,$8B,"KAYDET",$FE,$C0,#ALTSAY+1,". DERECE",$FE,$CC,"GERI"
  ENDIF
  IF ALTSAYKALAN=0 THEN
  LCDOUT $FE,$80,#ALTSAY,". DERECE",$FE,$8B,"KAYDET",$FE,$C2,0,$FE,$FE,$C3,#ALTSAY+1,". KAYIT",$FE,$CC,"GERI"
  ENDIF
 RETURN
'----- bu kısımdan sonrası ses entegeresiyle alakalı fonksiyonlar
isd_set_rec2:
LOW ss
		bSPI = $81		           'Set Record Command (7 bytes)
		GoSub isd_spi
		bSPI = $00
		GoSub isd_spi
		bSPI = s_addr.LowByte 	   'Start Address low byte.
		GoSub isd_spi
		bSPI = s_addr.HighByte 	   'Start Address high byte
		GoSub isd_spi
		bSPI = e_addr.LowByte 	   'End Address low byte
		GoSub isd_spi
		bSPI = e_addr.HighByte 	   'End Address high byte
		GoSub isd_spi
		bSPI = $00		           'Reserved Address - set to "0"
		GoSub isd_spi
HIGH ss
RETURN
isd_set_play2:
	LOW ss
	bSPI = $80		'Set Play Command (7 bytes)
	GoSub isd_spi
	bSPI = $00
	GoSub isd_spi
	bSPI = s_addr.LowByte 	' Start Address low byte.
	GoSub isd_spi
	bSPI = s_addr.HighByte 	' Start Address high byte
	GoSub isd_spi
	bSPI = e_addr.LowByte 	' End Address low byte
	GoSub isd_spi
	bSPI = e_addr.HighByte 	' End Address high byte
	GoSub isd_spi
	bSPI = $00		' Reserved Address - set to "0"
	GoSub isd_spi
	HIGH ss
RETURN
isd_set_erase2:
LOW ss
		bSPI = $82		           'Set Erase Command (7 bytes)
		GoSub isd_spi
		bSPI = $00
		GoSub isd_spi
		GoSub isd_spi
		GoSub isd_spi
		GoSub isd_spi
		GoSub isd_spi
		GoSub isd_spi
		HIGH ss
RETURN
isd_set_vol2:
RETURN
isd_rd_status:				'read status of ISD1700
	LOW ss
	bSPI=$05		'Read Status Command
	gosub isd_spi
	sr0a = bSPI	'SR0a
	bSPI=$00
	gosub isd_spi
	sr0b = bSPI	'SR0b
	bSPI=$00
	gosub isd_spi
	sr1 = bSPI	'SR1
	HIGH ss
RETURN
isd_clr_int:					' CLEAR INTERRUPT AND EOM BITS
	LOW SS
	bSPI=$04		'Clear Interrupt Command
	gosub isd_spi
	bSPI=$00
	gosub isd_spi
	HIGH SS
RETURN
isd_wait_rdy:
gosub isd_rd_status
if isready=0 then isd_wait_rdy
return
isd_wait_int:
	GOSUB isd_rd_status
	IF isINT = 0 THEN isd_wait_int
RETURN
isd_spi:				        ' shift SPI data out and into SPI byte
	FOR spi_cnt = 0 to 7        '
		MOSI = bSPI.0 		    ' shift LSB of byte onto MOSI line
		LOW SCLK 		        ' clock MISO data out to uC (Falling Edge)
		temp_bit = miso         '
		HIGH SCLK		        ' clock MOSI into ISD1700 (Rising Edge)
		bSPI = bSPI >> 1 		' shift SPI byte Right
		bSPI.7 = temp_bit
	NEXT spi_cnt
RETURN
	end
fryrmnd
başlık taşınmış  :D ... çok açıyom farkındayım... kusura bakmayın... gene debelendim durdum.. yetersiz ulvi gibi ben ne malım yaa... ulan aktif olarak menüü kısmını seç... menüde  telefon  kısmını seçenek olarak koy... seçince buton gelene kadar ordan çıkma...kime geldiğini çalsın dursun... yanılıyomuyum arkdaşlar...
Çok sorman önemli değil de aynı konuya farklı başlıklar açarsan silinir. Bilgin olsun.
fryrmnd
ya bide o kodu bıraktım çalıştıramadım... kafada gidiyo işte... dediğin gibi dönüp şöle bi bakmam lazım açtığım başlıklara... ordan devam etmek lazım...
Veli B.
Dilimizi kullanım şekliniz, beni ciddi şekilde rahatsız etti. Bu kadar umarsız olmamalı insanımız!
fryrmnd
katana bey.... umarsız derken çaresizlik anlamında mı söylediniz... yani rahatsız eden kısım ne anlayamadım... "malım " kelimesi mi sadece...
Veli B.
Hayır, imla kurallarını ve kelimeleri kullanım şekliniz rahatsız etti. Aslında sadece şahsınıza değil, genelde yeni nesile bir sitemim. Mesaj yazılırken gösterilen hassasiyet, okuyan kişi için ciddi anlam ifade eder.
Ben bir konuya bakarken bu hususa önem veriyorum.
Soru soran kişi, mesajı yazarken zaman ayırıp hatalarını düzeltmiyorsa/önem vermiyorsa, ben de cevap yazmak için zaman ayırmıyorum yada olması gerektiği kadar ayırmıyorum.
fryrmnd
Dil kullanımına önem vermedeki hassasiyetinizi takdir ediyorum katana bey. Ancak yazdıklarımın aşırı derece anlaşılmayacak olduğunu sanmıyorum. Takdir edersiniz ki dil anlaşmak için vardır. Eğer anlaşılmadıysam özür dilerim. Yüzyüze olsak arada bazı kelime ve heceleri yutup anlaşılmayacak olsam sizi daha iyi anlarım. Ama elektronikle uğraşmak için geç kaldığını düşünen ve gecenin bir saati uzun uzun program yazmaya çalıştıktan sonra klavye başına oturan bir kişi olarak her harfine ve her imla işaretine dikkat edecek ve defalarca kez tashihden geçirecek bir kişi değilim. Bu da benim tercihim. Keza değindiğim gibi anlaşılmayacak derecede kötü yazdığımı sanmıyorum.Anlamını hala bilmediğim değişik kelimeleri de (lol vb) kullanmadım zaten kullanmamaya çalışıyorum. Dile özen göstermek ile klavyede bir kaç harfi atlamanın farklı şeyler oluduğunu düşünüyorum. Hassasiyetiniz için teşekkürler.
fryrmnd
arkadaşlar bir menüm var... ama çok fazla if  then olduğundan mıdır çıkış tuşuna basışım çok geç algılıyor. çok az da olsa diğerlerinde de var aynı sıkıntı... 4 buton kullanıyorum.biraz
açıklama yazdım ama anlaşılıyodur umarım...  anlaşılmıyo ise tekrar düzenleme yapabilirim... teşekkürler...
DEFINE LCD_DBIT         4
DEFINE LCD_EBIT         3
DEFINE LCD_RSBIT      2
DEFINE LCD_BITS         4
DEFINE LCD_LINES      2
ADCON1=7
CMCON=7
ANASAY VAR BYTE
ALTSAY VAR BYTE
temp_bit    VAR BIT
temp      VAR BYTE
SYMBOL cikis=PORTC.0
symbol asagitus=PORTC.1
SYMBOL yukaritus=PORTC.2
SYMBOL sec=PORTC.7
TRISD=0
TRISA=1
TRISB=0
TRISC=%11000111
TRISE=1
PORTD=0
PORTA=0
PORTB=0
PORTE=0
ANASAY=1
ALTSAY=1
pause 500
LCDOUT $FE,$48,2,4,8,24,8,4,2,0
lcdout $FE,1
pause 500
BASLA:
LCDOUT $FE,1
LCDOUT $FE,$80,"AKTIF MOD",$FE,$C9,"AYARLAR"
IF YUKARITUS=0 THEN     'AKTIF MODA DALLAN
GOSUB AKTIFMOD
ENDIF
WHILE YUKARITUS=0
WEND
IF CIKIS=0 THEN         'MENUYE DALLAN
GOSUB ANAMENU
WHILE CIKIS=0
WEND
WHILE cikis=1  '2 SEÇENEKLİ MENÜYE GERİ
     IF ANASAY=4 THEN
      ANASAY=1
     ENDIF
     ANASAY=ANASAY+1
     GOSUB ANAMENU
  ENDIF
  WHILE ASAGITUS=0
  WEND
    IF ANASAY=1 THEN
     ANASAY=4
     ENDIF
    ANASAY=ANASAY-1
    GOSUB ANAMENU
  ENDIF
  WHILE YUKARITUS=0
  WEND
  WHILE SEC=1
  WEND
    WHILE CIKIS=1      'GERI SEÇENEGI SEÇİLMEDIĞI SÜRECE ALT MENÜDE
      IF ALTSAY=8 THEN
       ALTSAY=1
       ENDIF
      ALTSAY=ALTSAY+1
     ENDIF
     WHILE ASAGITUS=0
     WEND
      IF ALTSAY=1 THEN
       ALTSAY=8
      ENDIF
      ALTSAY=ALTSAY-1
     ENDIF
     WHILE YUKARITUS=0
     WEND
      ALTSAY=1
       CASE 1
        PAUSE 100
       CASE 2
        PAUSE 100
       CASE 3
        PAUSE 100
       CASE 4
        PAUSE 100
      END SELECT
      ALTSAY=1
      ENDIF
   ANASAY=1
WEND  'ÇIKIŞIN
  WHILE CIKIS=0
  WEND
ENDIF '2 SEÇENEKLİ MENÜDEN AYAR MENÜSÜNE GİRİŞ SONU
pause 300
GOTO BASLA
AKTIFMOD:
WHILE CIKIS=1
LCDOUT $FE,1
LCDOUT $FE,$80,"AKTIF",$FE,$CB,"CIKIS"
pause 300
WEND
RETURN
ANAMENU:
LCDOUT $FE,1
SELECT CASE ANASAY
  CASE 1
LCDOUT $FE,$81,0,"KAYIT",$FE,$C0,"CAL",$FE,$8D,"SEC",$FE,$CB,"CIKIS"
  CASE 2
LCDOUT $FE,$80,"KAYIT",$FE,$C1,0,"CAL",$FE,$8D,"SEC",$FE,$CB,"CIKIS"
  CASE 3
LCDOUT $FE,$81,0,"SIL",$FE,$C0,"SES",$FE,$8D,"SEC",$FE,$CB,"CIKIS"
  CASE 4
LCDOUT $FE,$80,"SIL",$FE,$C1,0,"SES",$FE,$8D,"SEC",$FE,$CB,"CIKIS"
END SELECT
RETURN
ALTMENUSECIMLI:
  SELECT CASE ANASAY
   CASE 1
     GOSUB ALTMENUKAYIT
   CASE 2
     GOSUB ALTMENUCAL
   CASE 3
     GOSUB  ALTMENUSIL
   CASE 4
END SELECT
RETURN
ALTMENUKAYIT:
LCDOUT $FE,1
  LCDOUT $FE,$81,0,$FE,$82,#ALTSAY,". KAYIT",$FE,$8B,"BASLA",$FE,$C0,#ALTSAY+1,". KAYIT",$FE,$CC,"GERI"
  ENDIF
  LCDOUT $FE,$80,#ALTSAY-1,". KAYIT",$FE,$8B,"BASLA",$FE,$C1,0,$FE,$C2,#ALTSAY,". KAYIT",$FE,$CC,"GERI"
  ENDIF
RETURN
ALTMENUCAL:
  LCDOUT $FE,1
  LCDOUT $FE,$81,0,$FE,$82,#ALTSAY,". KAYIT",$FE,$8B,"DINLE",$FE,$C0,#ALTSAY+1,". KAYIT",$FE,$CC,"GERI"
  ENDIF
  LCDOUT $FE,$80,#ALTSAY-1,". KAYIT",$FE,$8B,"DINLE",$FE,$C1,0,$FE,$C2,#ALTSAY,". KAYIT",$FE,$CC,"GERI"
  ENDIF
RETURN
ALTMENUSIL:
  LCDOUT $FE,1
  LCDOUT $FE,$81,0,$FE,$82,#ALTSAY,". KAYIT",$FE,$8D,"SIL",$FE,$C0,#ALTSAY+1,". KAYIT",$FE,$CC,"GERI"
  ENDIF
  LCDOUT $FE,$80,#ALTSAY-1,". KAYIT",$FE,$8D,"SIL",$FE,$C1,0,$FE,$C2,#ALTSAY,". KAYIT",$FE,$CC,"GERI"
  ENDIF
RETURN
ALTMENUSESAYARI:
  LCDOUT $FE,1
  LCDOUT $FE,$81,0,$FE,$82,#ALTSAY,". DERECE",$FE,$8B,"KAYDET",$FE,$C0,#ALTSAY+1,". DERECE",$FE,$CC,"GERI"
  ENDIF
  LCDOUT $FE,$80,#ALTSAY-1,". DERECE",$FE,$8B,"KAYDET",$FE,$C1,0,$FE,$FE,$C2,#ALTSAY,". KAYIT",$FE,$CC,"GERI"
  ENDIF
RETURN
