..::Çok Ekonomik İzoleli DC DC Converter Şeması:::..
Başlatan Erol YILMAZ, 27 Ekim 2011, 16:22:15
Trafo olarak beslemelerde filtre olarak kullanılan ferit malzemeli trafo uygunmuş.
http://electronicdesign.com/article/power/build_your_own_ultra_low_cost_isolated_dc_dc_converter.aspx
Alıntı YapWhen low cost in small volumes using readily available parts is a primary concern, standard approaches to isolated dc-dc conversion may not be suitable. Integrated switchers from Linear Technology, Maxim Integrated Products, National Semiconductor, or Texas Instruments typically do not provide isolated outputs and so require expensive transformers that are hard to acquire in small volumes. Further, they typically require an opto-isolator and associated drive circuitry to provide feedback from the isolated output to the switch-mode controller.
An alternative using discrete components (see the figure) can provide 50 mA at 5 V from a dc input between 8 and 30 V dc. To avoid the need for feedback components, the power stage uses a constant current source design. This allows a shunt, such as the TL431 or even a simple zener clamp, to provide output voltage regulation.
Because the desired output voltage is less than the minimum input voltage, a simple 1:1 output transformer can provide the needed isolation. Low-cost, common-mode chokes can serve as the transformer. They have low capacitance between windings and excellent high-voltage isolation between the windings and cost only about $0.25 in quantities of hundreds.
A dc-dc converter requires a ramp generator and a comparator driving a power stage. Current feedback comes from a resistor in series with the transformer's primary winding. It's easy to make a ramp generator from an operational amplifier with some resistors and a capacitor. To save component count, however, the second half of the LM393 dual comparator replaces the op amp. A symmetrical ramp will work just fine, so there is no need for steering diodes. The ramp's maximum duty cycle is set to about 50% to reduce the chances of saturating T1.
To drive the chosen transformer with current-mode feedback and achieve minimum loss due the current sampling, the ramp generator needs to run at about 400 kHz with an amplitude of about 0.5 V. The exact amplitude and frequency needed depend on the reference. An ordinary red LED has a forward voltage that is reasonably constant over indoor temperature ranges, so it serves as a low-cost reference.
The pulse-width modulation (PWM) comparator does not have the current capacity to drive the transformer directly. Its open-collector output, though, allows the use of a PNP transistor (Q1) and a single resistor (R12) to act as the power stage. The circuit also acts as a high-voltage clamp. When a transient spike exceeds the comparator's breakdown voltage, the transistor conducts and clamps the spike.
Although the design is completely unorthodox, it works well and Spice simulations match the bread-boarded results. And, it's extremely low cost. Total parts cost in hundreds of units, including the transformer, is about $0.60.
t2
izolasyon tamam da geribesleme yok gibi. Regüle nasıl olmuş anlatıyor ama anlamadım. Bana regülesiz DC DC converter  gibi görünüyor. Çıkıştaki zenerle ne kadar regüle olursa o kadar regüleli. belki de sekonderdeki aşırı akım vs primerden okunabiliyor.
Acaba bu  trafo da kullanılabilir mi?
t2
Tamam şimdi anladım. girişte sabit akım kullanılmış bu sayede  primerde sabit dalga elde ediliyormuş
Alıntı yapılan: t2 - 27 Ekim 2011, 16:35:13
Sabit akım kullanılmasıyla ne alaka. Bal gibi regülesiz işte.
t2
Sabit akım, sabit xL, okulda öğretmişlerdir :)
akım x XL = gerilim
işte bu gerilim karşı taraftan aynen çıkıyor. 1:1 trafo kullanılmış.
Alıntı yapılan: t2 - 27 Ekim 2011, 17:52:47
akım x XL = gerilim
XL yetiyor, yükün hiç günahı yok yani. Zeneri de küpe gibi asmışlar.
Kabil ATICI
Soldaki opamp simetrik ramp oluşturuyor. Bu ramp sinyal ikinci opamp tarafındın kıyılarak transitör  transformatör çiftini sürüyor. ( şu sürekli sözü geçen pwm) Transistörün  bacağındaki R12 direnci üzerinden bi geri besleme alınıyor. İşte bu aynı zamanda transformatörü sekonderinde bir yük olduğu zaman çekilen akım oranında  bir güç alacağını gösterir. Ve oranla gerilim oluşacağını gösterir ve kıyıcı devrenin seviyesini değişeceğini ve yüke göre bir transformatörün sürüleceğini gösterir.
Basitçe  sarım sayısı zaten birebir olduğundan akım ve gerilim değişimle aynen transformatörde yansıtılır.
ambar7
Bu bahsettiğiniz çalışma, "current mode control"  tekniğinde voltaj geribeslemesinin açılması durumu.
Bakınız UC3842..43..vs
Zerre regülasyon olmaz.
refik1
Peki arkadşlar gribeslemesiz
Regüle DC-DC yapmanın yolunu bilen varmı ?
OptimusPrime
Alıntı yapılan: refik1 - 18 Kasım 2011, 07:37:36
ermiş aranıyor... ;D
Doğrultucu çıkış voltajını gereğinden yüksek yapıp analog regülatör takabilirsin.
picmanya
yapmayı denemediğimden habire bir modeline 10TL. diğerinede 14TL. verip alıp kullanıyorum.
bir ara daha ucuz olsun diye farklı bir mal kullandık hemen belli etti kendini. izole diye aldık malesef izole dc dc değilmiş.
aslında 10TL. ye aldığım modelden 100 Adet aynı anda alım yapsam zannediyorum 5,5-6 TL. ye de alınabiliyor.
bahsettiklerim 4,5...5,5 V. dc girişli (besleme filtre kondansatörleri içinde) - tek veya simetrik regülesiz çıkışlı.
1W. - 2W. güçte.
regüleli çıkışlılarından ben kullanmıyorum, ama fiyat farkı regülesizine göre %10 fazla olarak görüyorum.
yinede resimdekinin giriş çalışma voltaj aralığı baya yüksekmiş, gücüde iyiyse ve simetrik çıkış sağlıyorsa ve en önemlisi sekonder / primer arası 1500V. ve üzeri gerilim yalıtımı varsa, regüleli olması benim için önemli değil yapılmaya değer olarak görüyorum. yapmak beni aşar işte bu ayrı konu.
celebrium
0- 200W kadar topolojilerde olduğu gibi Flyback topolojisi
,200W - 2kVA ya kadar half bridge ve full bridge topolojisi
2kVA üzerinde ise sistem biraz karışık hal alıyor.Önce Rectifier katı sonrada İnverter katı kullanarak yüksek verim elde edebilirsiniz. ;)
Bilginlerin aydınlatamadığı toplumu şarlatanlar aydınlatır. Marquis De Condorcet
Flybackden half/Full bridge'e atlamışsın. Aradakilere ne oldu?
