mikrobasic komut yardımı
Başlatan secretagent, 23 Ocak 2012, 15:12:45
secretagent
arkadaşlar elimdeki programda biryer var anlıyamadım yardımcı olurmusunuz
program Usart_Test
include kontrol
  dim sonuc2,sonuc3, kontrol,KONTROL2,n3 as byte
main:
   OSCCON=%01110000
   ANSEL=0
  trisa=0                 ' initialize USART module
  trisb=%11000000
  portb=%11000000
  trisc=%01000000
  sayac[0]=179
  sayac[1]=0
  sayac[2]=0
  sayac[3]=0
  sayac[4]=0
  sayac[5]=0
  sayac[6]=0
  sayac[7]=0
  sayac[8]=0
  sayac[9]=0
  sayac[10]=0
  sayac[11]=0
  sayac[12]=0
  porta=0
   porta.4=1
  trisc.3=0
  portc.3=0
  j=0
  n=0
  n3=0
  n2=1
  kontrol=0
  KONTROL2=0
  sonuc=0
  sonuc2=150
  delay_ms(1500)
  USART_init(9600)
   portb=0
   portc.0=0
   portc.1=0
   Usart_Write(00)                             '  (8 bit, 19200 baud rate, no parity bit...)
  while TRUE
d1:
     if portb.7=1 then
       delay_ms(100)
       goto d1
       end if
d2:
    if portb.7=0 then
       goto d2
       end if
        portc.3=1
        delay_ms(100)
         portc.3=0
      oku
       n2=0
gonder:
      Usart_Write(sayac[n2])
      delay_ms(10)
      inc(n2)
      if n2<13 then
       goto gonder
       end if
        if portb.6=0 then
       Usart_Write(100)
       delay_ms(10)
       Usart_Write(00)
       Usart_Write(200)
       delay_ms(10)
       Usart_Write(00)
       ' kontrol=kontrol or %00100000
       end if
       n2=1
d9:
      if (UsART_Data_Ready() <> 0) then      ' If data is received,
         sonuc2 = USART_Read()                  ' read the received data
       goto d9
     end if
       '   oku
          delay_ms(100)
           inc(n3)
      'if sonuc2=150 then
'      kontrol=kontrol or %10000000
'      end if
'      kontrol=kontrol >> 1
'      if kontrol.3=1 then
'         porta.4=1
'           delay_ms(200)
'         porta.4=0
'         portc.3=0
'         else
'         portc.3=1
'       end if
  select case sonuc2
  case 150
   case 152
  case 154
    if kontrol.5=0 then
      portb.5=1
      portb.5=0
      end if
       if portb.6=1 then
        kontrol.4=1
       end if
  case 156
    if kontrol.5=0 then
      portb.5=1
      portb.5=0
      end if
   if portb.6=1 then
        kontrol.4=1
       end if
  case else
end select
'    sonuc=sonuc2
'      if portc.3=0 then
'         porta.4=1
'         delay_ms(200)
'         porta.4=0
'       end if
       if kontrol.2=1 then
       if n3>3 then
         porta.4=1
          delay_ms(200)
         porta.4=0
         portc.3=1
         delay_ms(500)
           end if
         portc.3=0
         end if
  wend
end.
buda kontrol programı
module kontrol
' dim i as byte[13]
dim sayac as byte[13]
dim j,n,sonuc,n2,hb,lb as byte
dim   karsilastir as word
sub procedure oku
d4:
    select case n
 case 0
    portb.0=1
  case 1
    portb.3=1
  case 2
    portc.1=1
  case 3
    portc.0=1
   case 4
    portb.2=1
  case 5
    portb.1=1
end select
        j=0
 d3:
      sayac[n2] = USART_Read()
      inc(j)
      inc(n2)
       goto d3
       end if
      if j<2 then
         goto d3
      end if
     'karsilastir =256 * hb + lb
'      if karsilastir > 4096 then
'        portb=0
'        goto d4
'        delay_ms(50)
'       end if
     select case n
   case 0
    portb.0=0
  case 1
    portb.3=0
  case 2
    portc.1=0
  case 3
    portc.0=0
   case 4
    portb.2=0
  case 5
    portb.1=0
end select
     ' portb=portb and %11100000
      inc(n)
     if n<6 then
      delay_ms(10)
     goto d4
      end if
       n=0
       n2=1
        porta.1=1
        delay_ms(100)
        porta.1=0
     end sub
end.
SORMAK İSTEDİĞİM ise ana programda kontrol.5 diye bir komut var bu komutun anlamı nedir.daha doğrusu kontrol diye bir register tanımlanmamış ki neden kontrolun 5.biti demiş anlayamadım.
Kabil ATICI
 programında
satıında kontrol diye bir değişken ataman var.
kontrol.5 bu değişkenin 5. biti.
kontrol.2 bu değişkenin 2. biti.
ambar7
secretagent
SÖYLEDİĞİNİZ DOĞRU PEKİ KONTROLUN İÇİNE SAYIYI NERDEN ATIYOR PROGRAMDA ONU BULAMIYORUM :s
SERRO EFE
bu satırla kontrolün içine atama yapıyor.
Kabil ATICI
select case sonuc2
  case 150
   case 152
  case 154
    if kontrol.5=0 then
      portb.5=1
      portb.5=0
      end if
       if portb.6=1 then
        kontrol.4=1
       end if
  case 156
    if kontrol.5=0 then
      portb.5=1
      portb.5=0
      end if
   if portb.6=1 then
        kontrol.4=1
       end if
  case else
end select
'    sonuc=sonuc2
'      if portc.3=0 then
'         porta.4=1
'         delay_ms(200)
'         porta.4=0
'       end if
       if kontrol.2=1 then
       if n3>3 then
         porta.4=1
          delay_ms(200)
         porta.4=0
         portc.3=1
kalın yazıların yazıldığı yerlerde.
ambar7
secretagent
