Mini sumo robot ?
Başlatan kaypic38, 05 Şubat 2012, 20:35:31
kaypic38
Kod bana ait değil bir hocama ait sumo hazır fakat programda bir yerde hata var sanırım robotu çalıştırdım ama sensörden bilgiyi okuyamıyor sanırım veya başka bir sorun var fakat etrafında 2 kez dönüyor hedef bulamazsa duruyor bulursa harekete geçiyor neden olabilir ?
@  Device Pic16F876, HS_Osc, Wdt_Off, Pwrt_On, Bod_On, Lvp_Off, Protect_Off
Include "modedefs.bas"
DEFINE OSC 20
DEFINE	ADC_BITS	8	     ' Set number of bits in result
DEFINE	ADC_CLOCK	3	     ' Set clock source (3=rc)
DEFINE	ADC_SAMPLEUS	50	 ' Set sampling time in uS
'debug is for sending test values over the PIC-KEY to PC screen
DEFINE DEBUG_REG PORTB
DEFINE DEBUG_BIT 7
DEFINE DEBUG_BAUD 9600
DEFINE DEBUG_MODE 1          ' invert level
DEFINE DEBUG_PACING 1000
'Setting up hardware PWM for 56.8KHz operation to drive IRLEDs.
 TRISC.2 = 0            'CCP1 (PortC.2 = Output) 56.8kc output
 PR2 = 87               'Set PWM Period for approximately 56.8KHz
 CCPR1L = 44            'Set PWM Duty-Cycle to 50%
 CCP1CON = %00001100    'Select PWM Mode
 T2CON = %00000100      'Timer2 = ON + 1:1 prescale
 TRISA = %11101111	    'Set PORTA  input/output
 TRISB = %11000101	    'Set PORTB  input/output
 TRISC = %00100000	    'Set PORTC  input/output
 ADCON1 = %00000010	    'Set PORTA analog and right justify result
 righteye   var     word    'right eye line sensors
 lefteye    var     word    'left eye line sensors
 ana2       var     word    'spare adc
 ana3       var     word    'spare adc
 ana4       var     word    'spare adc
 startled   var     portb.1 'start led
 pushstart  var     portb.0 'push button for commands
 yellowled  var     portb.4 'yellow test light
 greenled   var     portb.3 'green test light
 leftpwm    var     portc.0 'speed pwm for left
 rightpwm   var     portb.5 'speed pwm for right
 dlefta     var     portc.1 'left wheel dir logic A
 dleftb     var     portc.6 'left wheel dir logic B
 drighta    var     portc.3 'right wheel dir logic A
 drightb    var     portc.4 'right wheel dir logic B
 n          var     word    'counter byte
 ireye_r    var     portc.5 'right ir sensor
 ireye_l    var     portb.2 'left ir sensor
 flag       var     byte    'last turn a left or right turn flag
 bark       var     byte    'sound value
 reyewhite  var     byte    'right line sensor white value
 reyeblack  var     byte    'right line sensor black value
 leyewhite  var     byte    'left line sensor white value
 leyeblack  var     byte    'left line sensor black value
 rightref   var     byte    'right line sensor level ref. (calibrate value)
 leftref    var     byte    'left line sensor level ref. (calibrate value)
low startled 'reset all lights to off
low yellowled
low greenled
debug ,"  billsbot10.bas",10,13 'print out the name of the program at startup
'put motors in "coast"
low leftpwm
low rightpwm
low dlefta
low dleftb
low drighta
low drightb
read 0, rightref 'read last calibration values in eerom
read 1, leftref
pause 100
sound porta.4, [120,10] 'make a beep when turning on
pause 100
calmode:' hold in start button when turning on for calibrate mode
 if pushstart = 0 then
 goto calibrate
 endif
delay5:
'delay of 5 sec. when starting match light flashs and tone beeps for countdown
 high startled
 if pushstart = 1 then delay5
 low startled
 sound porta.4, [90,10]
 pause 950
 high startled
 sound porta.4, [100,10]
 pause 450
 low startled
 pause 500
 high startled
 sound porta.4, [110,10]
 pause 450
 low startled
 pause 500
 high startled
 sound porta.4, [115,10]
 pause 450
 low startled
 pause 500
 high startled
 pause 450
 low startled
 pause 500
 high startled
bark=120 'tone value for sound generation routines
scanright:
gosub whiteline
gosub rturn
pause 100
gosub voice
gosub allstop
seek: 'find the opponent
low yellowled 'reset test lights
low greenled
gosub  whiteline 'avoid the white line
if (ireye_r = 0)and(ireye_l = 0) then 'if object if straight ahead,go for it
gosub fastforward
gosub voice
endif
if flag = 1 then 'if last was a right turn then check to the right
goto goright
endif
if flag = 2 then 'if last was a left turn then check to the left
goto goleft
endif
goforward:
gosub whiteline
gosub fastforward
gosub voice
endif
goright: 'if only a right sensor detects, then move right
gosub whiteline
if (ireye_r = 0) and (ireye_l = 1) then
high yellowled
gosub rturn
gosub voice
gosub fastforward
flag = 1
gosub voice
endif
goleft:'if only a left sensor detects, then move left
gosub whiteline
if (ireye_l = 0) and (ireye_r = 1) then
high greenled
gosub lturn
gosub voice
gosub fastforward
flag = 2
gosub voice
endif
nothingfound:
'if nothing is found then do a scan and find the opponent
if (ireye_r = 1) and (ireye_l = 1)  then
goto scanright
endif
goto seek
fastforward: 'move the motors full speed forward
    low drighta 'right wheel dir
    high drightb
    low dlefta 'left wheel dir
    high dleftb
    high rightpwm 'full on right and left
    high leftpwm
    return
allstop: 'stop and regenerative brake the motors (shorting the bridge)
    low drightb
    low dleftb
    high leftpwm
    return
fastbackup: 'full speed in reverse
    high drighta 'right wheel dir
    low drightb
    high dlefta 'left wheel dir
    low dleftb
    high leftpwm
    return
rturn: 'do a right turn
    low drightb
    high dleftb
    high leftpwm
    return
lturn: 'do a left turn
    high drightb
    low dleftb
    high leftpwm
    return
 goto scanright
whiteline:
'hunt for the opponent, but first
'watch for white line!
adcin 0, righteye 'enter adc values
adcin 1, lefteye
if (righteye < rightref) and (righteye < rightref)then
gosub allstop
pause 200
gosub voice
gosub fastbackup
pause 700
endif
adcin 0, righteye
if (righteye < rightref) then
gosub allstop
pause 200
gosub voice
gosub fastbackup
pause 700
gosub lturn
pause 500
flag = 0
endif
adcin 1, lefteye
if (lefteye < leftref) then
gosub allstop
pause 200
gosub voice
gosub fastbackup
pause 700
gosub rturn
pause 500
'pause 200
flag = 0
endif
return
calibrate: 'find values of white a black surfaces to calibrate sensors
low yellowled
low greenled
low startled
black:'determine what is black
debug " calibrate black ",10,13
adcin 0, reyeblack
adcin 1, leyeblack
high startled
high yellowled
debug, "leftblack ",dec leyeblack," rightblack ", dec reyeblack, 10,13
releasebutton:'detect when releasing the button
if pushstart = 0 then releasebutton
pause 500
checkbutton:'check for a repush of the button
if pushstart = 0 then white
goto checkbutton
white:'determine what is white
adcin 0, reyewhite
adcin 1, leyewhite
debug, "leftwhite ",dec leyewhite," rightwhite ", dec reyewhite, 10,13
rightref = ((reyeblack - reyewhite)/2) + reyewhite
leftref = ((leyeblack - leyewhite)/2) + leyewhite
debug, "leftref ",dec leftref," rightref ", dec rightref, 10,13
if reyewhite > rightref then alarm
if leyewhite > leftref then alarm
write 0,rightref 'write values in the pic's data errom
write 1,leftref
high greenled
low startled
sound porta.4, [100,20]
pause 100
pause 100
pause 500
goto delay5
alarm:'bad calibrate, the order of black first then white has been volated
sound porta.4, [80,20]
goto alarm
voice: 'sound generation routines
if pushstart = 0 then halt
bark = bark - 5
if bark = 80 then
bark = 125
endif
sound porta.4,[bark,10]
return
halt: 'kill button
gosub allstop
low startled
pause 100
high startled
pause 100
goto halt
Bir şeyi gerçekten öğrenmek, yapmak istiyorsan o şeyi yapmışsın, öğrenmişsin demektir...
XX_CİHAN_XX
Kullanılan sensör hangisi?
Şeman Nerede?
Bu bilgiler olmadan kimse çözüm öneremez.
MrDarK
Alıntı yapılan: kaypic38 - 05 Şubat 2012, 20:35:31
Gayet normal böyle yapması , kodları incelemeye gerek yok. Hocan taktik yapmış , başlangıç anında eğer hedef göremezse etrafında tam 2 tur atmasını söymiş. Eğer hedef bir şekilde onun menziline girerse saldırma komutu vermiş. Yani mini sumo robotun hocanın yazdığı programa göre gayet doğal ve doğru çalışıyor :)
kaypic38
kaypic38
@MrDark
Hocam yanlış anlattım sanırım şimdi robot çalışıyor 2sn içinde hedefi görürse saldırıyor fakat 3.sn den sonra öylece duruyor.Bu arada şema PDF şeklinde ve onu foruma nasıl atarım bilmiyorum.
XX_CİHAN_XX
kaypic38
XX_CİHAN_XX
Program basicte yazılmış ve ben basic ten çok fazla anlamam ama kodlarda şöyle bir kısım var:
halt: 'kill button
gosub allstop
low startled
pause 100
high startled
pause 100
goto halt
Bahsettiğin kitlenme pozisyonu burası olsa gerek. Buraya göre;
Start Ledi yanıp sönerek robotun kilitleniyor. (Gerçektede böyle mi oluyor?)
Programda bir kalibrasyon(ayar) modu gözüküyor. Onu düzgün bir şekilde yapamazsan program yukarıdaki sonsuz döngüde çakılıp kalacak şekilde yazılmış anladığım kadarıyla.
kaypic38
Evet aynen öyle oluyor sanırım hocamın programı verdiğinde neden sende göz at belki bir yanlışlık vardır diyerek göz kırptığını anladım :)
