16f628 2*16 lcd sürme sorunu
Başlatan eozkantar, 12 Nisan 2012, 23:30:15
ferit06
Alıntı yapılan: eozkantar - 27 Nisan 2012, 14:49:47
LVP_OFF  yapınca çalıştı
ne alakaysa.....
Datashets 43 sayfa...
LVP Configuration Bit sets RB4 functionality.
RB4/PGM RB4 TTL CMOS Bidirectional I/O port. Interrupt-on-pin change. Can be
software programmed for internal weak pull-up.
PGM ST — Low voltage programming input pin. When low voltage
programming is enabled, the interrupt-on-pin change
and weak pull-up resistor are disabled.
