LCD ve PORT D sorunu
Başlatan hasansavun, 07 Mart 2013, 08:58:16
hasansavun
Merhaba arkadaşlar,
LCD port b de sorunsuz çalışıyor. Fakat port d ye bağlamak için hangi değişiklikleri yapmam gerekiyor. bir türlü çalıştıramadım.
Extreme
hasansavun,
lcd nin boyutlarını belirtmemişsin ben sana 4x20 flexy lcd driverı veriyorum kendine göre ilk satırları değiştirererk bağlantılarını yapabilirsin
#define LCD_DB4   PIN_D4
#define LCD_DB5   PIN_D5
#define LCD_DB6   PIN_D6
#define LCD_DB7   PIN_D7
#define LCD_RS    PIN_D2
#define LCD_RW    PIN_D1
#define LCD_E     PIN_D3
// To prove that the driver can be used with random
// pins, I also tested it with these pins:
#define LCD_DB5   PIN_B1
#define LCD_DB6   PIN_C5
#define LCD_DB7   PIN_B5
#define LCD_RS    PIN_E2
#define LCD_RW    PIN_B2
#define LCD_E     PIN_D6
// If you want only a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.  Doing so will save one PIC
// pin, but at the cost of losing the ability to read from
// the LCD.  It also makes the write time a little longer
// because a static delay must be used, instead of polling
// the LCD's busy bit.  Normally a 6-pin interface is only
// used if you are running out of PIC pins, and you need
// to use as few as possible for the LCD.
#define USE_RW_PIN   1
// These are the line addresses for most 4x20 LCDs.
#define LCD_LINE_1_ADDRESS 0x00
#define LCD_LINE_2_ADDRESS 0x40
#define LCD_LINE_3_ADDRESS 0x14
#define LCD_LINE_4_ADDRESS 0x54
// These are the line addresses for LCD's which use
// the Hitachi HD66712U controller chip.
#define LCD_LINE_2_ADDRESS 0x20
#define LCD_LINE_3_ADDRESS 0x40
#define LCD_LINE_4_ADDRESS 0x60
#define lcd_type 2   // 0=5x7, 1=5x10, 2=2 lines(or more)
int8 lcd_line;
int8 const LCD_INIT_STRING[4] =
 0x20 | (lcd_type << 2),  // Set mode: 4-bit, 2+ lines, 5x8 dots
 0xc,                     // Display on
 1,                       // Clear display
 6                        // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note:  !! converts an integer expression
// to a boolean (1 or 0).
 output_bit(LCD_DB4, !!(nibble & 1));
 output_bit(LCD_DB5, !!(nibble & 2));
 output_bit(LCD_DB6, !!(nibble & 4));
 output_bit(LCD_DB7, !!(nibble & 8));
 delay_cycles(1);
 output_high(LCD_E);
 delay_us(2);
 output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine.  For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.
#ifdef USE_RW_PIN
int8 lcd_read_nibble(void)
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_us(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
delay_us(1);
return(retval);
#endif
// Read a byte from the LCD and return it.
#ifdef USE_RW_PIN
int8 lcd_read_byte(void)
int8 low;
int8 high;
output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4) | low);
#endif
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_RW_PIN
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60);
#endif
if(address)
   output_high(LCD_RS);
   output_low(LCD_RS);
 delay_cycles(1);
#ifdef USE_RW_PIN
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
lcd_line = 1;
output_low(LCD_RS);
#ifdef USE_RW_PIN
output_low(LCD_RW);
#endif
output_low(LCD_E);
// Some LCDs require 15 ms minimum delay after
// power-up.  Others require 30 ms.  I'm going
// to set it to 35 ms, so it should work with
// all of them.
delay_ms(35);
for(i=0 ;i < 3; i++)
    lcd_send_nibble(0x03);
    delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
    lcd_send_byte(0, LCD_INIT_STRING[i]);
    // If the R/W signal is not used, then
    // the busy bit can't be polled.  One of
    // the init commands takes longer than
    // the hard-coded delay of 50 us, so in
    // that case, lets just do a 5 ms delay
    // after all four of them.
    #ifndef USE_RW_PIN
    delay_ms(5);
    #endif
void lcd_gotoxy(int8 x, int8 y)
int8 address;
switch(y)
   case 1:
     address = LCD_LINE_1_ADDRESS;
     break;
   case 2:
     address = LCD_LINE_2_ADDRESS;
     break;
   case 3:
     address = LCD_LINE_3_ADDRESS;
     break;
   case 4:
     address = LCD_LINE_4_ADDRESS;
     break;
   default:
     break;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
 switch(c)
    case '\f':
      lcd_send_byte(0,1);
      lcd_line = 1;
      delay_ms(2);
      break;
    case '\n':
       lcd_gotoxy(1, ++lcd_line);
       break;
    case '\b':
       lcd_send_byte(0,0x10);
       break;
    default:
       lcd_send_byte(1,c);
       break;
#ifdef USE_RW_PIN
char lcd_getc(int8 x, int8 y)
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7));
value = lcd_read_byte();
output_low(LCD_RS);
return(value);
#endif
hasansavun
hocam kodlar evdeki pcde kaldı.
lcd 16x2
ccs nin içindeki lcd.c driverını kullanıyorum. burada default olarak port b tanımlı. ve burada sorunsuz olarak ekrana yazı yazdırabildim.
fakat d portunu kullanmak istiyorum nasıl yapmam gerekiyor.
Extreme
lcd.c tanımlaman yerine yazılımının yer altığı klasöre driver oluşturman gerekiyor..
bunuda "isim.c" diye kayıt ediceksin.
2x16 driver kodlarıda aşağıda..
#define LCD_DB4   PIN_B4
#define LCD_DB5   PIN_B5
#define LCD_DB6   PIN_B6
#define LCD_DB7   PIN_B7
#define LCD_E     PIN_B1
#define LCD_RS    PIN_B3
// If you only want a 6-pin interface to your LCD, then
//#define USE_LCD_RW   1
////  lcd_putc(c)  Will display c on the next position of the LCD.     ////
////                     The following have special meaning:           ////
////                      \f  Clear display                            ////
////                      \n  Go to start of second line               ////
////                      \b  Move back one position                   ////
////  lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)    ////
////  lcd_getc(x,y)   Returns character at position x,y on LCD         ////
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
 0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
 0x0C,//0xf,                    // Display on
 1,                      // Clear display
byte CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xC, 1,6};
Value   Cursor  Blink
0x0C     Off      Off
0x0D     Off      On
0x0E     On       Off
0x0F     On       On
 delay_cycles(1);
 output_high(LCD_E);
 delay_us(2);
 output_low(LCD_E);
#ifdef USE_LCD_RW
int8 retval;
retval = 0;
output_high(LCD_E);
delay_cycles(1);
output_low(LCD_E);
return(retval);
#endif
#ifdef USE_LCD_RW
int8 low;
int8 high;
delay_cycles(1);
#endif
output_low(LCD_RS);
#ifdef USE_LCD_RW
#else
delay_us(60);
#endif
if(address)
   output_low(LCD_RS);
 delay_cycles(1);
#ifdef USE_LCD_RW
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
void lcd_setcursor_vb(short visible, short blink) {
  lcd_send_byte(0, 0xC|(visible<<1)|blink);
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
#endif
output_low(LCD_E);
delay_ms(15);
    delay_ms(5);
    // the hard-coded delay of 60 us, so in
    #ifndef USE_LCD_RW
    delay_ms(5);
    #endif
int8 address;
if(y != 1)
   address = lcd_line_two;
   address=0;
address += x-1;
 switch(c)
    case '\f':
      lcd_send_byte(0,1);
      delay_ms(2);
      break;
    case '\n':
       lcd_gotoxy(1,2);
       break;
    case '\b':
       break;
    default:
       lcd_send_byte(1,c);
       break;
#ifdef USE_LCD_RW
char value;
lcd_gotoxy(x,y);
output_low(lcd_RS);
return(value);
#endif
hasansavun
   Hangi mikrodenetleyiciyi kullandığın önemli, eğer portd analogsa digital yapman gerekir yoksa çıkış yapsanda lcd yi kullanmanda veya başka durumlarda yine sıkıntı çıkar.
hasansavun
16F877 kullanıyorum.  analog var mı yok mu bilmiyorum ama akşama bakayım.
Var, ccs c de nasıl kuruluyor net bilmiyorum ama void main de """  setup_adc_ports(NO_ANALOGS);    // ANALOG giriş yok """ şeklinde bir ayarlama yapmalısınız,  ama bu porte gibi analog portları digital yapmak için portd de psp (parallel slave port) olabiliyor belki bundan sıkıntı çıkabilir bunun içinde """setup_psp(PSP_DISABLED);        // PSP birimi devre dışı"""demelisiniz,  bununla ilgili açıklama için datasheet de portE (yanlış yok portE) regster ına bakın porte,bit4 pspmode seçimi içindir buda portd nin digital input output  veya PSP modülü olarak kullanılmasını ayarlar, sonra yine trisd yi kullanıp portd yi çıkış yaparsınız.
ek:
porte derken TRISE registerını kastediyorum.
Extreme
hasansavun,
sen adc uygulaması mı yapıyorsun ?
sen sadece lcd yi port değiştirtirmeyi sordun sana driver oluşturman için gerekli kodları verdim kafanı başka şeylerle karıştırmana gerek yok .
hasansavun
hocam ben RFID uygulaması yapıyorum.
LCD driver çalıştı teşekkür ederim. şimdi RFID çalıştırmayı deniyorum. inşallah çalışır.
mesaj birleştirme:: 07 Mart 2013, 21:08:52
malsef RFID çalımıyor... :(((((
Extreme
bu konu lcd driver için açılmış lcd sorunun çözüldü rfıd sorunun için yeni konu açıp kodlarını göstermelisin ki çözüm bulabilisin.
hasansavun
Dün akşam RF ID yi çalıştırabildim.
CCS nin içinde örnek kod vardı o kod ile çalıştırabildim.
Teşekkürler.
