ccs c kesme hatası ve pic not erased hatasi
Başlatan elmariacci, 12 Mart 2013, 21:32:04
elmariacci
arkadaşlar nabiz ölçer devresi yapiyorum.kullandiğim pic 16f877a sigorta ayarlarini yapiyorum ama pic'e programi atarken fulse:not erased diyor.kaç gündür programi pic'e atamadim.
ccs c de derlemeye çaliştiğim program kesmelerde uyari veriyor.ondan kaynaklanabilir mi??
program bu şekilde;
#include "sw2.h"
#zero_ram
#ignore_warnings 203
unsigned long int display[10];
unsigned long int a,heart_rate;
#define LCD_EN PIN_B2
#define LCD_RS PIN_B1
#define LCD_D0 PIN_D3
#define LCD_D1 PIN_B3
#define LCD_D2 PIN_D2
#define LCD_D3 PIN_B4
#define ROLE   PIN_B5
#include "lcd_mini.h"
#int_ext
void  ext_isr(void)
unsigned long int b,c;
   b=a;
   c=a;
   c=50000/c;
   if((c<200) && (c>40)){
      display[0]=display[1];
      display[1]=display[2];
      display[2]=display[3];
      display[3]=display[4];
      display[4]=display[5];
      display[5]=display[6];
      display[6]=display[7];
      display[7]=display[8];
      display[8]=display[9];
      display[9]=40000/b;
      heart_rate=(display[0]+display[1]+display[2]+display[3]+display[4]+display[5]+display[6]+display[7]+display[8]+display[9])/10;
      printf(lcd_putc,"\1NABIZ=%3Lu A=%3Lu \2NABIZ OLCER",heart_rate,display[9]);
      if(heart_rate>=120) output_high(ROLE); else output_low(ROLE);
   a=0;
void main()
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_CLOCK_DIV_2);
   setup_timer_0(RTCC_EXT_H_TO_L|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_4,200,12);
   setup_ccp1(CCP_OFF);
   delay_ms(1000);
//   input(PIN_A4);
   lcd_init();
   printf(lcd_putc,"\1NABIZ  \2OLCER");
   delay_ms(1000);
   printf(lcd_putc,"\f");
   enable_interrupts(INT_EXT);
   enable_interrupts(GLOBAL);
   while(1){
      delay_ms(1);
      a++;
//      if(a>=3000){
//         a=3000;
//         output_high(ROLE);
//      else
//         output_low(ROLE);
bu da lcd;
void lcd_delay(int data){
int i;
         for(i=0; i<data; ++i);
void LCD_PulseEnable (){
                     output_high ( LCD_EN );
                     delay_ms(2);
                     output_low  ( LCD_EN );
                     delay_ms(2);
void LCD_SetData (int cX ){
                        output_bit ( LCD_D0, cX & 0x01 );
                        output_bit ( LCD_D1, cX & 0x02 );
                        output_bit ( LCD_D2, cX & 0x04 );
                        output_bit ( LCD_D3, cX & 0x08 );
void lcd_adr ( int cX ){
                     LCD_SetData ( swap ( cX ) | 0x08 );
                     LCD_PulseEnable();
                     LCD_SetData ( swap ( cX ) );
                     LCD_PulseEnable();
void LCD_PutCmd ( int cX ){
                        LCD_PulseEnable();
                        LCD_PulseEnable();
void lcd_putc ( int cX ){
                     switch (cx) {
                           case '\f'   :  LCD_PutCmd ( 0x01 ); delay_ms(2); break;
                           case '\1'   :  lcd_adr( 0x00 );     delay_ms(2); break;
                           case '\2'   :  lcd_adr(0x40);       delay_ms(2); break;
                           default     :
                                       output_high ( LCD_RS );
                                       LCD_PulseEnable();
                                       LCD_PulseEnable();
                                       output_low ( LCD_RS );
void lcd_init (){
//               output_low        ( LCD_rw );
               LCD_SetData       ( 0x00 );
               delay_ms          ( 100 );       //    wait enough time after Vdd rise
               LCD_SetData       ( 0x03 );      //    init with specific nibbles to start 4-bit mode
               LCD_PulseEnable   ();
               LCD_PulseEnable   ();
               LCD_PulseEnable   ();
               LCD_SetData       ( 0x02 );      //*    set 4-bit interface
               LCD_PulseEnable   ();            //*    send dual nibbles hereafter, MSN first
               LCD_PutCmd        ( 0x2C );      //*    function set (all lines, 5x7 characters)
               LCD_PutCmd        ( 0x0C );      //*    display ON, cursor off, no blink
               LCD_PutCmd        ( 0x01 );      //*    clear display
               LCD_PutCmd        ( 0x06 );      //*    entry mode set, increment & scroll left
void lcd_refresh(void){
               LCD_PulseEnable   ();
               //LCD_PulseEnable   ();
               //LCD_PutCmd        ( 0x01 );      //*    clear display
void lcd_gotoxy(int8 x, int8 y){
   if(y==1){
      lcd_adr( 0x00+x-1 );     delay_ms(2);
   }else{
      lcd_adr( 0x40+x-1 );     delay_ms(2);
hatalar kesme kısmında
elmariacci
elmariacci
arkadaşlar kaç gündür pice programi atamiyorum devre çalişiyor ama picten dolayi nabzi alamiyorum.bi yardim edin programda hata var mi derlediğimde sadece uyari veriyor hata yok .
