Kod Derleme Hatası
Başlatan oongit, 26 Mart 2013, 15:46:13
oongit
Merhaba Arkadaşlar...
Seri iletişimle ilgili bir devre yapmaya çalışıyorum. Devre şu:
http://c1303.hizliresim.com/17/u/lgtyb.png
Bu da programın kodları:
INCLUDE "MODEDEFS.BAS"
@ DEVICE pic16F877A,
@ DEVICE pic16F877A, WDT_OFF
@ DEVICE pic16F877A, PWRT_ON
@ DEVICE pic16F877A, PROTECT_OFF
@ DEVICE pic16F877A, XT_OSC
@ DEVICE pic16F877A, BOD_OFF
@ DEVICE pic16F877A, LVP_OFF
@ DEVICE pic16F877A, CPD_OFF
ADCON1 = 7
TRISA = %000000
TRISB = %11111111
TRISC = %11111100
TRISD = %11111111
TRISE = %000
CIKIS   VAR PORTA.0
VER     VAR BYTE
VER = 0
BASLA:
    IF PORTC.3 = 0 THEN POT1_ARTTIR
    IF PORTD.0 = 0 THEN POT1_ORTALA
    IF PORTD.1 = 0 THEN POT1_AZALT
    IF PORTD.2 = 0 THEN POT2_ARTTIR
    IF PORTD.3 = 0 THEN POT2_ORTALA
    IF PORTC.4 = 0 THEN POT2_AZALT
    IF PORTC.5 = 0 THEN POT3_ARTTIR
    IF PORTC.6 = 0 THEN POT3_ORTALA
    IF PORTC.7 = 0 THEN POT3_AZALT
    IF PORTD.4 = 0 THEN POT4_ARTTIR
    IF PORTD.5 = 0 THEN POT4_ORTALA
    IF PORTD.6 = 0 THEN POT4_AZALT
    IF PORTD.7 = 0 THEN POT5_ARTTIR
    IF PORTB.0 = 0 THEN POT5_ORTALA
    IF PORTB.1 = 0 THEN POT5_AZALT
    IF PORTB.2 = 0 THEN POT6_ARTTIR
    IF PORTB.3 = 0 THEN POT6_ORTALA
    IF PORTB.4 = 0 THEN POT6_AZALT
    IF PORTB.5 = 0 THEN POT7_ARTTIR
    IF PORTB.6 = 0 THEN POT7_ORTALA
    IF PORTB.7 = 0 THEN POT7_AZALT
    IF PORTC.2 = 0 THEN LCD_BL
    GOTO BASLA
POT1_ARTTIR:
    VER = 10 : GOTO EXIT
POT1_ORTALA:
    VER = 11 : GOTO EXIT
POT1_AZALT:
    VER = 12 : GOTO EXIT
POT2_ARTTIR:
    VER = 20 : GOTO EXIT
POT2_ORTALA:
    VER = 21 : GOTO EXIT
POT2_AZALT:
    VER = 22 : GOTO EXIT
POT3_ARTTIR:
    VER = 30 : GOTO EXIT
POT3_ORTALA:
    VER = 31 : GOTO EXIT
POT3_AZALT:
    VER = 32 : GOTO EXIT
POT4_ARTTIR:
    VER = 40 : GOTO EXIT
POT4_ORTALA:
    VER = 41 : GOTO EXIT
POT4_AZALT:
    VER = 42 : GOTO EXIT
POT5_ARTTIR:
    VER = 50 : GOTO EXIT
POT5_ORTALA:
    VER = 51 : GOTO EXIT
POT5_AZALT:
    VER = 52 : GOTO EXIT
POT6_ARTTIR:
    VER = 60 : GOTO EXIT
POT6_ORTALA:
    VER = 61 : GOTO EXIT
POT6_AZALT:
    VER = 62 : GOTO EXIT
POT7_ARTTIR:
    VER = 70 : GOTO EXIT
POT7_ORTALA:
    VER = 71 : GOTO EXIT
POT7_AZALT:
    VER = 72 : GOTO EXIT
LCD_BL:
    VER = 80 : GOTO EXIT
EXIT:
    SEROUT CIKIS,N2400,[("A"),VER,13,10]
    GOTO BASLA
    END
Programı derlemeye kalktığımda, "numeric constant or symbol name expected" hatasını veriyor. Sorunun nereden kaynaklandığını anlayamadım. Yardımcı olabilir misiniz?
Devrenin orjinalinin bulunduğu link budur:
https://320volt.com/picbasic-dersleri-pic-basic-pro-ile-pic-programlama-7/
Wadek
SEROUT CIKIS,N2400,[("A"),VER,13,10] kısmını SEROUT CIKIS,N2400,["A",VER,13,10] şeklinde dener misiniz?
Maxim
EXIT diye etiket ismi olmaz
hepsini EXIT1 yapın
birde bu hatalı
CIKIS   VAR PORTA.0
dogrusu
Symbol CIKIS =PORTA.0
CIKIS   VAR PORTA.0
Sanıyorum program bu tip syntax da kabul ediyor.
oongit
Alıntı yapılan: Wadek - 26 Mart 2013, 16:49:00
Geç yanıtladığım için üzgünüm. Denedim, ancak aynı uyarıyı veriyor.
mesaj birleştirme:: 28 Mart 2013, 21:16:11
Alıntı yapılan: Maxim - 26 Mart 2013, 17:42:11
hepsini EXIT1 yapın
birde bu hatalı
CIKIS   VAR PORTA.0
dogrusu
EXIT etiketini EXIT1 olarak değiştirip denedim olmadı. Diğer dediğinizi de değiştirdim. Ancak sonuç yine aynı. Bu hatanın kaynağı ne olabilir başka?
Maxim
yeni fark ettim biraz geç olacak
bu kod aynen bu şekilde derlenmektedir.
sadece config satırlarını kaldırdım orada bir sıkıntı var, nedenini bilmiyorum.
'@ DEVICE pic16F877A,
'@ DEVICE pic16F877A, WDT_OFF
'@ DEVICE pic16F877A, PWRT_ON
'@ DEVICE pic16F877A, PROTECT_OFF
'@ DEVICE pic16F877A, XT_OSC
'@ DEVICE pic16F877A, BOD_OFF
'@ DEVICE pic16F877A, LVP_OFF
'@ DEVICE pic16F877A, CPD_OFF
ADCON1 = 7
TRISA = %000000
TRISB = %11111111
TRISC = %11111100
TRISD = %11111111
TRISE = %000
'CIKIS VAR PORTA.0
VER VAR BYTE
VER = 0
BASLA:
    GOTO BASLA
POT1_ARTTIR:
    VER = 10 : GOTO EXIT1
POT1_ORTALA:
    VER = 11 : GOTO EXIT1
POT1_AZALT:
    VER = 12 : GOTO EXIT1
POT2_ARTTIR:
    VER = 20 : GOTO EXIT1
POT2_ORTALA:
    VER = 21 : GOTO EXIT1
POT2_AZALT:
    VER = 22 : GOTO EXIT1
POT3_ARTTIR:
    VER = 30 : GOTO EXIT1
POT3_ORTALA:
    VER = 31 : GOTO EXIT1
POT3_AZALT:
    VER = 32 : GOTO EXIT1
POT4_ARTTIR:
    VER = 40 : GOTO EXIT1
POT4_ORTALA:
    VER = 41 : GOTO EXIT1
POT4_AZALT:
    VER = 42 : GOTO EXIT1
POT5_ARTTIR:
    VER = 50 : GOTO EXIT1
POT5_ORTALA:
    VER = 51 : GOTO EXIT1
POT5_AZALT:
    VER = 52 : GOTO EXIT1
POT6_ARTTIR:
    VER = 60 : GOTO EXIT1
POT6_ORTALA:
    VER = 61 : GOTO EXIT1
POT6_AZALT:
    VER = 62 : GOTO EXIT1
POT7_ARTTIR:
    VER = 70 : GOTO EXIT1
POT7_ORTALA:
    VER = 71 : GOTO EXIT1
POT7_AZALT:
    VER = 72 : GOTO EXIT1
LCD_BL:
    VER = 80 : GOTO EXIT1
EXIT1:
    GOTO BASLA
    END
ekrem12
Alıntı yapılan: Maxim - 16 Nisan 2013, 08:50:01
ADCON1 = 7
TRISA = %000000
TRISB = %11111111
TRISC = %11111100
TRISD = %11111111
TRISE = %000
'CIKIS VAR PORTA.0
VER VAR BYTE
VER = 0
BASLA:
    GOTO BASLA
POT1_ARTTIR:
POT1_ORTALA:
POT1_AZALT:
POT2_ARTTIR:
POT2_ORTALA:
POT2_AZALT:
POT3_ARTTIR:
POT3_ORTALA:
POT3_AZALT:
POT4_ARTTIR:
POT4_ORTALA:
POT4_AZALT:
POT5_ARTTIR:
POT5_ORTALA:
POT5_AZALT:
POT6_ARTTIR:
POT6_ORTALA:
POT6_AZALT:
POT7_ARTTIR:
POT7_ORTALA:
POT7_AZALT:
LCD_BL:
EXIT1:
    GOTO BASLA
    END
@maxim usta, bu cevaba binayen bende bu konuda sürekli problem yaşıyorum. MPLAB'da kodları yazarken alışkanlıktan dolayı kodların başına işlemci ile ilgili config ayarlarını yazıyorum fakat derlenirken sorun oluyor ve bende sizin yaptığınız gibi config satırlarını kaldırıyorum ve o şekilde sıkıntı olmadan derleniyor. anladığım kadarıyla MPLAB 'da işlemciyi seçerken programın kendisi config ayarlarını kendi giriyor. hatta menüsünde config ayarları var fakat o menüden değiştiremiyorum. config ayarlarını nasıl değiştirebileceğim konusunda tavsiyeniz nedir? teşekkürler...
Maxim
konu ile ilgili ete ustanin detayli cevaplarini gordum son gunlerde.
onlara bakmani oneriyorum.
ben normalde picbasic kullanmiyorun
ete
Önce sorunun kaynağını söyleyeyim.
şeklinde yazılmış sigorta satırında dikkat ederseniz en sonda bir virgül koyulmuş. Virgül sonrasında bir başka komut yada parametre gelecek anlamına gelir. Halbuki o satırın bir parametresi yoktur. O halde virgül fazladan koyulmuş olup hata budur.
Kaldırın ,derleyin düzelir.
Bir derleme işleminde derleyici yardımcı bazı ek programlar yada ilaveler kullanır. Bunlardan birisi işlemciye ait INC uzantılı dosyadır. Burada 16F877A.INC dosyası kullanılmaktadır. Derleme işlemini MPASM ile yaparsanız hem bu 16F877A.INC dosyası hemde MPASM klasörü içinde yer alan P16F877A.INC dosyası derleme işleminde kullanılır. Her iki INC dosyasında da sigorta satırları bulunmaktadır. Bir derleme işleminde sgorta satırları yalnızca bir kere işlenmelidir. İkinci defa derleyici bu satırlara rast gelirse hemen hata mesajını basar. Bu nedenle MPASM ile derleme yapacak iseniz yapmanız gereke iki şey var;
- birincisi PBP klasörü içinde yer alan işlemciye ait INC dosyası içinde alt satırlarda yer alan ve derlemenin MPASM ile yapılması durumunda işleme konulan sigorta satırlarının baş kısımlarına birer ; işareti koyarak o satırları kapatmanız yada tamamen silmeniz gerekir. Aksi halde hatadan kurtulamazsınız. Hiç sigorta satırı kullanmazsanız elbette derleme hatasız olur ama sigorta ayarlarınıda programa sokmamış olursunuzki buda yanlış olur bence.
- İkincisi sigorta ayarlarını MPASM formatında vermeniz gerekir. Formatın şeklini ise o kapattığınız satırlardan görebilirsiniz. Muhtemelen bütün sigorta değerleri o satıra verilmemiş olabilir. Aralarına birer  " & " koyarak diğer sigorta ayarlarını peş peşe ekleyebilirsiniz. Formata dikkat. Boşlukların bile önemi vardır.
Ete
