Dış alarm göstergesi
Başlatan ipek, 11 Ekim 2013, 03:33:43
ipek
nette bulduğum bir dosyayı derledim sanki watchdog atıyor sebebini bulamadım.
yazar UAA2022 diye dinazor bir çip kullanmış bende kaskat 595 bağladım haberleşme standardı uymuyor desem
sonuçta aksakta olsa çalışıyor.
http://www.dosya.tc/server17/tor3G0/ledshift5cylon16bit.zip.html
' Ledshift5.BAS   UAA2022 shift register   16 leds driver  Cylon eye - 5 leds
Device=16F628A
Config CPD_OFF,CP_OFF,BODEN_OFF,MCLRE_OFF,PWRTE_ON,WDT_OFF,INTRC_OSC_NOCLKOUT,LVP_OFF
Xtal = 4
SYMBOL Data_In = PORTB.0      ;DI pin UAA2022
SYMBOL ChipSelect = PORTB.1   ;/CS pin UAA2022
                              ;0 before the falling edge of / CLK is
                              ; 1 matches> 1us to the rising edge of / CLK
SYMBOL Clock = PORTB.2        ;/CLK Pin UAA2022, shift op positive  edge
DIM Plates AS BYTE
DIM Plates2 AS BYTE
DIM Plates3 AS BYTE
DIM BitFlag AS BYTE
DIM LedData[16] AS BYTE
DIM CylonData[16] AS BYTE
TRISA=%00000000 :  PORTA = 0
TRISB=%00000000 :  PORTB = 0
 CLEAR                         ;all knowledge RAM memory
        GOSUB ClearArray
  WHILE 1=1
                            ;5 led's residual
 FOR Plates3 = 1 TO 12
 FOR Plates2 = 1 TO 16
        LedData[Plates2]=LREAD Cylon_Data +(16*(Plates3-1))+(Plates2-1)
 NEXT
        GOSUB FillArray
        DELAYMS 50      '10
 NEXT
        DELAYMS 150     '125
 FOR Plates3 = 11 TO 1 STEP -1
        LedData[Plates2]=LREAD Cylon_Data +(16*(Plates3-1))+(Plates2 - 1)
 NEXT
        GOSUB FillArray
        DELAYMS 50      '10
 NEXT
        DELAYMS 150     '750
  WEND
END
ClearArray:
                                        ;Delete the shift register
                                        ;all 16 bits in the shift register to 0
 FOR Plates = 1 TO 16
        LedData[Plates]=0
 NEXT
FillArray:
                                        ;send the array to the shift register
        ChipSelect=0
        Clock=0
        Data_In=LedData[Plates]
        Clock=1                         ;DI is clocked
        ChipSelect=1
 NEXT
    RETURN
END
Cylon_Data:
    LDATA 1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0
    LDATA 0,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0
    LDATA 0,0,1,1,1,1,1,0,0,0,0,0,0,0,0,0
    LDATA 0,0,0,1,1,1,1,1,0,0,0,0,0,0,0,0
    LDATA 0,0,0,0,1,1,1,1,1,0,0,0,0,0,0,0
    LDATA 0,0,0,0,0,1,1,1,1,1,0,0,0,0,0,0
    LDATA 0,0,0,0,0,0,1,1,1,1,1,0,0,0,0,0
    LDATA 0,0,0,0,0,0,0,1,1,1,1,1,0,0,0,0
    LDATA 0,0,0,0,0,0,0,0,1,1,1,1,1,0,0,0
    LDATA 0,0,0,0,0,0,0,0,0,1,1,1,1,1,0,0
    LDATA 0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,0
    LDATA 0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1
