CCS C USB HID ile Caps Lock , Num Lock durumlarını alma sorunu
Başlatan NEINSTEIN, 24 Kasım 2013, 19:18:43
NEINSTEIN
USB hid ile Num Lock , Caps Lock durumlarını almaya çalışıyorum fakat ne denediysem başaramadım keystroke gödermede sıkıntım yok haberleşmeler tamam pc mouse/keyboard olarak görüyor.Tahminimce windows hid driver bu durumları yolluyor olması gerekiyor fakat usb_kbhit() e herhangi bir data gelmiyor yardımcı olabilirseniz çok sevinirim.Teşekkürler. Uygulama aşağıdaki gibidir.
////                        ex_usb_kbmouse.c                         ////
//// An example of creating a mouse and keyboard combo USB device,   ////
//// implemented by using multiple interfaces.  One interface is     ////
//// used for the mouse, another interface for the keyboard.         ////
//// Uses your operating system's HID drivers, which on most systems ////
//// should already be installed.                                    ////
//// Once enumrated, the PIC will move the mouse cursor around in    ////
//// a circle if the button is held down.  Also, whenever the        ////
//// button is held down the PIC will send an 'a' as a keyboard      ////
//// press.  (open a text editor to see the 'a' being sent)          ////
//// For a more generic USB HID example (as well as some HID         ////
//// documentation) see ex_usb_hid.c                                 ////
//// VERSION HISTORY                                                 ////
//// June 20th, 2005: Initial 18fxx5x release.                       ////
//// May 13th, 2005: Initial Beta.  Only works with 18Fxx5x          ////        ////
////        (C) Copyright 1996,2005 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
//set to 1 to use a PIC's internal USB Peripheral
//set to 0 to use a National USBN960x peripheral
#define __USB_PIC_PERIF__ 1
#if __USB_PIC_PERIF__ //use the PIC16C7x5 peripheral
 #DEFINE LED1  PIN_A5
 #if defined(__PCM__)
    #include <16C765.h>
    #device *=16
    #fuses HS,NOWDT,NOPROTECT
    #use delay(clock=24000000)
 #elif defined(__PCH__)
    #include <18F4550.h>
    #fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
    #use delay(clock=48000000)
 #endif
#else //use the National USBN960x peripheral
 #DEFINE LED1  PIN_B3
  #include <16F877A.h>
  #device *=16
  #fuses HS,NOWDT,NOPROTECT,NOLVP
  #include <18F452.h>
 #endif
 #use delay(clock=20000000)
#endif   //endif check to see which peripheral to use
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
// CCS Library dynamic defines.  For dynamic configuration of the CCS Library
// for your application several defines need to be made.  See the comments
// at usb.h for more information
//Tells the CCS PIC USB firmware to include HID handling code.
#DEFINE USB_HID_DEVICE  TRUE
//the following defines needed for the CCS USB PIC driver to enable the TX endpoint 1
#define USB_EP1_TX_ENABLE  USB_ENABLE_INTERRUPT   //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_TX_SIZE 8
   #define USB_EP1_RX_ENABLE  USB_ENABLE_INTERRUPT    //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_RX_SIZE 8
#define USB_EP2_TX_ENABLE  USB_ENABLE_INTERRUPT   //turn on EP2 for IN bulk/interrupt transfers
#define USB_EP2_TX_SIZE 8
   #define USB_EP2_RX_ENABLE  USB_ENABLE_INTERRUPT  //turn on EP2 for IN bulk/interrupt transfers
#define USB_EP2_RX_SIZE 8
// If you are using a USB connection sense pin, define it here.  If you are
// not using connection sense, comment out this line.  Without connection
// sense you will not know if the device gets disconnected.
//       (connection sense should look like this:
//                             100k
//            VBUS-----+----/\/\/\/\/\----- (I/O PIN ON PIC)
//                     +----/\/\/\/\/\-----GND
//                             100k
//        (where VBUS is pin1 of the USB connector)
///only the 18F4550 development kit has this pin
#if __USB_PIC_PERIF__ && defined(__PCH__)
 #define USB_CON_SENSE_PIN PIN_B2
#endif
// Include the CCS USB Libraries.  See the comments at the top of these
// files for more information
  #include <pic_usb.h>   //Microchip PIC16C765 hardware layer for usb.c
 #else
  #include <pic18_usb.h>
 #endif
#else
 #include <usbn960x.c>   //National 960x hardware layer for usb.c
#endif
#include <usb_desc_kbmouse.h>    //USB Configuration and Device descriptors for this UBS device
#include <usb.c>        //handles usb setup tokens and get descriptor reports
// Configure the demonstration I/O
#define BUTTON PIN_A4
#define LED2 PIN_B4
#define LED3 PIN_B5
#define LED_ON output_low
#define LED_OFF output_high
// usb_debug_task()
// When called periodically, displays debugging information over serial
// to display enumeration and connection states.  Also lights LED2 and LED3
// based upon enumeration and connection status.
void usb_debug_task(void) {
   static int8 last_connected;
   static int8 last_enumerated;
   int8 new_connected;
   int8 new_enumerated;
   new_connected=usb_attached();
   new_enumerated=usb_enumerated();
   if (new_connected)
      LED_ON(LED2);
      LED_OFF(LED2);
   if (new_enumerated)
      LED_ON(LED3);
      LED_OFF(LED3);
   if (new_connected && !last_connected)
      printf("\r\n\nUSB connected, waiting for enumaration...");
   if (!new_connected && last_connected)
      printf("\r\n\nUSB disconnected, waiting for connection...");
   if (new_enumerated && !last_enumerated)
      printf("\r\n\nUSB enumerated by PC/HOST");
   if (!new_enumerated && last_enumerated)
      printf("\r\n\nUSB unenumerated by PC/HOST, waiting for enumeration...");
   last_connected=new_connected;
   last_enumerated=new_enumerated;
// usb_mouse_task()
// Sends a packet of data containing mouse information.  The protocol was
// defined in the HID report descriptor (see usb_desc_kbmouse.h), and is:
//   out_data[0]=button state
//   out_data[1]=x delta
//   out_data[2]=y delta
//   out_data[3]=wheel delta
void usb_mouse_task(void) {
   #define MOUSE_SEQUENCE_STEPS  16
   const char mouse_seq[MOUSE_SEQUENCE_STEPS]=
      {0, 1, 3, 4, 4, 4, 3, 1, 0, -1, -3, -4, -4, -4, -3, -1};
   int8 out_data[4];
   static int8 x_seq=0;  static int8 y_seq=MOUSE_SEQUENCE_STEPS/4;
   static int8 skip=0;
   if (input(BUTTON)) {
      out_data[1]=mouse_seq[x_seq];
      out_data[2]=mouse_seq[y_seq];
   else {
      out_data[1]=0;
      out_data[2]=0;
   out_data[0]=0;
   out_data[3]=0;
   if (usb_put_packet(1,out_data,4,USB_DTS_TOGGLE)) {
      skip++;
      if (skip>10) {
         if (++x_seq>=MOUSE_SEQUENCE_STEPS) {x_seq=0;}
         if (++y_seq>=MOUSE_SEQUENCE_STEPS) {y_seq=0;}
         skip=0;
// usb_keyboard_task()
// Sends a packet of keyboard data.  The protocol was specified in the HID
// report descriptor (see usb_desc_kbmouse.h), and is:
//     tx_msg[0] = modifier (an 8bit bitmap of shift, tab, alt keypress)
//     tx_msg[1] = const 0
//     tx_msg[2:6] = an array of held down keys.  a=4, b=5, etc.
//                   if msg[2:7]={0} then no keys are held down
//     rx_msg[0] = 5bit bitmap of led status
void usb_keyboard_task(void) {
   static int8 tx_msg[7]={0,0,0,0,0,0,0};
   static int8 leds;
    //receive NUM LOCK, CAPS LOCK, etc LED status from PC.
   //we won't do anything with it.
 /*  if (usb_kbhit(2)) {
      usb_get_packet(3, &leds, 1);
       LED_ON(PIN_E0);
       LED_ON(PIN_B7);
       LED_ON(PIN_D4);
  // delay_ms(500);
   if (input(BUTTON))
      tx_msg[2]=4;
      tx_msg[2]=0;
   usb_put_packet(2,tx_msg,sizeof(tx_msg),USB_DTS_TOGGLE);
   void usb_rx_task(void) {
   int8 rx_msg[USB_EP1_RX_SIZE];
   if (usb_kbhit(1)) {
      usb_get_packet(1, rx_msg, sizeof(rx_msg));
      LED_ON(PIN_D5);
      LED_ON(PIN_D0);
      LED_ON(PIN_D1);
void main(void) {
   LED_ON(LED1);
   LED_OFF(LED2);
   LED_OFF(LED3);
   printf("\r\n\nCCS HID Mouse/Keyboard Multiple Interface Demo");
   printf("\r\nPress button to make mouse move in a circle and ");
   printf("send an A over the keyboard");
  #ifdef __PCH__
   printf("\r\nPCH: v");
   printf(__PCH__);
  #else
   printf("\r\n\PCM: v");
   printf(__PCM__);
  #endif
   usb_init_cs();
  #if !(__USB_PIC_PERIF__)
   printf("\r\nUSBN: 0x%X", usbn_get_version());
  #endif
   printf("\r\n");
   while (TRUE) {
      usb_task();
      usb_debug_task();
      if (usb_enumerated()) {
        usb_mouse_task();
         usb_keyboard_task();
          usb_rx_task();
         delay_ms(5);
t2
olemiss
Alıntı yapılan: NEINSTEIN - 24 Kasım 2013, 19:18:43
Çalışmayan kısım tam olarak nedir?  Caps lock tuşunun 0x39 olması gerekiyor, bu tuşun alındığı nerede test ediliyor, kod içinde göremedim.
Yazılım Mühendisi, Çevirmen.
NEINSTEIN
"pic16C765 halen bulunabiliyor mu?"
18f4550 kullanıyorum projede hid olarak görüyor keystroke yollayabiliyorum transmitte sorun yok.
Fakat Receive kısmını yapamıyorum anlamdığım bir şekilde olmuyor
Alıntı yapılan: sabuncu - 24 Kasım 2013, 20:04:00
Aşağıdaki fonksiyonda herhangi bir değer bekliyorum fakat dönen herhangi birşey yok.
   if (usb_kbhit(1)) {
      LED_ON(PIN_D5);
      LED_ON(PIN_D0);
      LED_ON(PIN_D1);
void main(){
usb_rx_task();
olemiss
olemiss
usb_rx_task() fonksiyonu hiç mi çalışmıyor yoksa sadece caps lock için mi çalışmıyor?
NEINSTEIN
Alıntı yapılan: sabuncu - 24 Kasım 2013, 20:34:59
D5, D0, D1 bacaklarının led'leri yanıyor mu?
Ledler hiç yanmıyor. usb_rx_task() fonksiyonuna giriyor fakat usb_kbhit() hep false.
keystroke klavyenin key code ları. txt dosyasına yazabiliyorum CTRL+C, CTRL+V gibi şeyler yapabiliyorum.
Şuan tek amacım Caps Lock vs.  durumlarını almak.
olemiss
Caps lock tuşu algılanması: usb_kbhit(2)
Diğer tuşların algılanması: usb_kbhit(1)
Caps lock bilgisini alan kısım kod içinde comment-out edilmiş:
        LED_ON(PIN_E0);
        LED_ON(PIN_B7);
        LED_ON(PIN_D4);
Niye?
NEINSTEIN
O fonksiyonun benzeri code içinde mevcut ben alternatifleride koydum denediklerimin  neler olduğunu göstermek için bu sebepten comment edilmiş durumda , kodu incelemeden ve denemeden yorum yapmazsak sevinirim!
olemiss
Alıntı yapılan: NEINSTEIN - 25 Kasım 2013, 22:06:42
Yorum yapmaya değil size yardımcı olmaya çalışıyordum.  Ayrıca kodunuzu da inceledim.  Takdir edersiniz ki kodunuzu deneyecek kurulum herkesde bulunmayabilir.
Ben iyi niyetle size yardımcı olmaya çalıştım, başaramadım, çok haklısınız hata bende, size iyi şanslar diliyorum.
