stm32f407vg ı2c hatası
Başlatan electrical, 25 Kasım 2013, 22:34:15
electrical
arkadaşlar merhaba stm32 ile I2C denemesi yapmaya çalışıyorum ama bir türlü olmadı kendi yazdığımda internette hazır bulduğumda çalışmadı
i2c1.c
#include "i2c1.h"
// interne Funktionen
void I2C1_InitI2C(void);
int16_t I2C1_timeout(int16_t wert);
// Definition von I2C1
I2C1_DEV_t I2C1DEV = {
// PORT , PIN      , Clock              , Source
  {GPIOB,GPIO_Pin_6,RCC_AHB1Periph_GPIOB,GPIO_PinSource6}, // SCL an PB6
  {GPIOB,GPIO_Pin_7,RCC_AHB1Periph_GPIOB,GPIO_PinSource7}, // SDA an PB7
// Init von I2C1
void I2C1_Init(void)
  static uint8_t init_ok=0;
  GPIO_InitTypeDef  GPIO_InitStructure;
  // initialisierung darf nur einmal gemacht werden
  if(init_ok!=0) {
    return;
  // I2C-Clock enable
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
  // Clock Enable der Pins
  RCC_AHB1PeriphClockCmd(I2C1DEV.SCL.CLK, ENABLE);
  RCC_AHB1PeriphClockCmd(I2C1DEV.SDA.CLK, ENABLE);
  // I2C reset
  RCC_APB1PeriphResetCmd(RCC_APB1Periph_I2C1, ENABLE);
  RCC_APB1PeriphResetCmd(RCC_APB1Periph_I2C1, DISABLE);
  // I2C Alternative-Funktions mit den IO-Pins verbinden
  GPIO_PinAFConfig(I2C1DEV.SCL.PORT, I2C1DEV.SCL.SOURCE, GPIO_AF_I2C1);
  GPIO_PinAFConfig(I2C1DEV.SDA.PORT, I2C1DEV.SDA.SOURCE, GPIO_AF_I2C1);
  // I2C als Alternative-Funktion als OpenDrain
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
  // SCL-Pin
  GPIO_InitStructure.GPIO_Pin = I2C1DEV.SCL.PIN;
  GPIO_Init(I2C1DEV.SCL.PORT, &GPIO_InitStructure);
  // SDA-Pin
  GPIO_InitStructure.GPIO_Pin = I2C1DEV.SDA.PIN;
  GPIO_Init(I2C1DEV.SDA.PORT, &GPIO_InitStructure);
  // I2C init
  I2C1_InitI2C();
  // init Mode speichern
  init_ok=1;
// Auslesen einer Adresse per I2C von einem Slave
// slave_adr => I2C-Basis-Adresse vom Slave
// adr       => Register Adresse die gelesen wird
// Return_wert :
//  0...255 , Bytewert der gelesen wurde
//  < 0     , Error
int16_t I2C1_ReadByte(uint8_t slave_adr, uint8_t adr)
  int16_t ret_wert=0;
  uint32_t timeout=I2C1_TIMEOUT;
  // Start-Sequenz
  I2C_GenerateSTART(I2C1, ENABLE);
  while (!I2C_GetFlagStatus(I2C1, I2C_FLAG_SB)) {
    if(timeout!=0) timeout--; else return(I2C1_timeout(-1));
  // ACK disable
  I2C_AcknowledgeConfig(I2C1, DISABLE);
  // Slave-Adresse senden (write)
  I2C_Send7bitAddress(I2C1, slave_adr, I2C_Direction_Transmitter);
  while (!I2C_GetFlagStatus(I2C1, I2C_FLAG_ADDR)) {
    if(timeout!=0) timeout--; else return(I2C1_timeout(-2));
  // ADDR-Flag löschen
  I2C1->SR2;
  while (!I2C_GetFlagStatus(I2C1, I2C_FLAG_TXE)) {
    if(timeout!=0) timeout--; else return(I2C1_timeout(-3));
  // Adresse senden
  I2C_SendData(I2C1, adr);
  while ((!I2C_GetFlagStatus(I2C1, I2C_FLAG_TXE)) || (!I2C_GetFlagStatus(I2C1, I2C_FLAG_BTF))) {
    if(timeout!=0) timeout--; else return(I2C1_timeout(-4));
  // Start-Sequenz
    if(timeout!=0) timeout--; else return(I2C1_timeout(-5));
  // Slave-Adresse senden (read)
  I2C_Send7bitAddress(I2C1, slave_adr, I2C_Direction_Receiver);
    if(timeout!=0) timeout--; else return(I2C1_timeout(-6));
  I2C1->SR2;
  while (!I2C_GetFlagStatus(I2C1, I2C_FLAG_RXNE)) {
    if(timeout!=0) timeout--; else return(I2C1_timeout(-7));
  // Stop-Sequenz
  I2C_GenerateSTOP(I2C1, ENABLE);
  // Daten auslesen
  ret_wert=(int16_t)(I2C_ReceiveData(I2C1));
  // ACK enable
  I2C_AcknowledgeConfig(I2C1, ENABLE);
  return(ret_wert);
// Beschreiben einer Adresse per I2C von einem Slave
// adr       => Register Adresse die beschrieben wird
// wert      => Bytewert der geschrieben wird
// Return_wert :
//    0   , Ok
//  < 0   , Error
int16_t I2C1_WriteByte(uint8_t slave_adr, uint8_t adr, uint8_t wert)
  int16_t ret_wert=0;
  // Start-Sequenz
  I2C1->SR2;
  // Adresse senden
  // Daten senden
  I2C_SendData(I2C1, wert);
  // Stop-Sequenz
  ret_wert=0; // alles ok
  return(ret_wert);
// kleine Pause (ohne Timer)
void I2C1_Delay(volatile uint32_t nCount)
  while(nCount--)
// interne Funktion
// Init der I2C-Schnittstelle
  I2C_InitTypeDef  I2C_InitStructure;
  // I2C-Konfiguration
  I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
  I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
  I2C_InitStructure.I2C_OwnAddress1 = 0x00;
  I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
  I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
  I2C_InitStructure.I2C_ClockSpeed = I2C1_CLOCK_FRQ;
  // I2C enable
  I2C_Cmd(I2C1, ENABLE);
  // Init Struktur
  I2C_Init(I2C1, &I2C_InitStructure);
// interne Funktion
// wird bei einem Timeout aufgerufen
// Stop, Reset und reinit der I2C-Schnittstelle
  int16_t ret_wert=wert;
  // Stop und Reset
  I2C_SoftwareResetCmd(I2C1, ENABLE);
  I2C_SoftwareResetCmd(I2C1, DISABLE);
  // I2C deinit
  I2C_DeInit(I2C1);
  // I2C init
  I2C1_InitI2C();
  return(ret_wert);
i2c1.h
// File     : stm32_ub_i2c1.h
#ifndef __STM32F4_UB_I2C1_H
#define __STM32F4_UB_I2C1_H
// Includes
#include "stm32f4xx.h"
// I2C-Clock
// Grundfrequenz (I2C1)= APB1 (APB1=42MHz)
// Mögliche Einstellungen = 100000 = 100 kHz
#define   I2C1_CLOCK_FRQ   100000  // I2C-Frq in Hz (100 kHz)
// Defines
#define   I2C1_TIMEOUT     0x3000  // Timeout Zeit
// Struktur eines I2C-Pins
typedef struct {
  GPIO_TypeDef* PORT;     // Port
  const uint16_t PIN;     // Pin
  const uint32_t CLK;     // Clock
  const uint8_t SOURCE;   // Source
}I2C1_PIN_t;
// Struktur vom I2C-Device
typedef struct {
  I2C1_PIN_t  SCL;       // Clock-Pin
  I2C1_PIN_t  SDA;       // Data-Pin
}I2C1_DEV_t;
// Globale Funktionen
void I2C1_Init(void);
int16_t I2C1_ReadByte(uint8_t slave_adr, uint8_t adr);
int16_t I2C1_WriteByte(uint8_t slave_adr, uint8_t adr, uint8_t wert);
void I2C1_Delay(volatile uint32_t nCount);
#endif // __STM32F4_UB_I2C1_H
kodlar hep
satırında sonsuz döngüye giriyor ve çıkmıyor bu kodda timeout olmasına rağmen genede çalışmadı acaba nerede hata var yardım ederseniz sevinirm.
iyi çalışmalar.
Bu durumda takilan kisim I2C1_timeout() fonksiyonu.
Bir sekilde I2C donanimi stop edilip yeni bastan init edilemiyor.
