pic 16f690 spi haberleşme sorunu
Başlatan atillaa, 11 Aralık 2013, 21:21:59
atillaa
merhaba arkadaşlar, uygulamamda pic 16f690 ile spi haberleşmesi gerçekleştirmek istiyorum. Ayarları yaptım ancak simülasyonda giden veri sürekli 0 gözüküyor. Nerede hata yaptım acaba yardım edebilir misiniz .
spi.h
#define SCK      RB6
#define SDI      RB4
#define SDO      RC7
#define nSEL   RC6
extern void SPICmd8bit(unsigned char WrPara);
extern void SPIWrite(unsigned int WrPara);
spi.c
#include "RFM69H.h"
#include <pic.h>
**Name:     SPICmd8bit
**Function: SPI Write one byte
**Input:    WrPara
**Output:   none
**note:     use for burst mode
 unsigned char bitcnt;
 nSEL = 0;
 SCK  = 0;
 for(bitcnt=8; bitcnt!=0; bitcnt--)
 	SCK = 0;
 	if(WrPara&0x80)
 		SDI = 1;
 		SDI = 0;
 	SCK = 1;
 	WrPara <<= 1;
 SCK = 0;
 SDI = 1;
**Name:     SPIWrite
**Function: SPI Write CMD
**Input:    WrPara -> address & data
**Output:   None
 SCK  = 0;
 nSEL = 0;
 WrPara |= 0x8000;                                        //MSB must be "1" for write
 for(bitcnt=16; bitcnt!=0; bitcnt--)
 	SCK = 0;
 	if(WrPara&0x8000)
 		SDI = 1;
 		SDI = 0;
	SCK = 1;
 	WrPara <<= 1;
 SCK = 0;
 SDI = 1;
 nSEL= 1;
main
void main()
led=0;
//unsigned char kontrol;
init();
for(SysTime=0;SysTime<16;);   //delay for stabilize
//RFM69H_Config(2);   // FREQ_SEL: 0-----315MHz   FREQ_SEL: 1-----434MHz    FREQ_SEL: 2-----868MHz  FREQ_SEL: 3-----915MHz
Tx_Drm=0;
Rx_Drm=0;
SPICmd8bit(0xf2);
SPICmd8bit(0xf2);
SPICmd8bit(0xf2);
//BurstWrite(0x00,RxData, 21);
	while(1);
init
void init(void)
ANSEL=0x00;
ANSELH=0x00;
/////////////spi ayarları//////////
SSPM3=0;  // Fosc/64
SSPM2=0;
SSPM1=0;
SSPM0=0;
SSPEN=1;
WCOL=0;
SSPOV=0;
////////////port ayarları ////////////
TRISA=0x00;
TRISB=0xB0;
TRISC=0x20;
///////////interrupt ayarları ////////
GIE     = 1;         //Enable GIE
PEIE    = 1;        //Enable PEIE
T0IE	= 1;        //Enable TMR0
RCIE	= 1;
RABIE=1;
RABIF=0;
IOCB=0b10100000;
//////timer0 ayarları////////////
T0CS=0;
PSA=0;
PS2=1;
PS1=1;
PS0=1;
TMR0=130;
////////////////////diğer ayarlar////////////
WDTCON=0;
OSCCON=0x70;  // krsital 8Mhz seçiliyor
ADCON0=0;
ADCON1=0;
