C standart kütüphanesi
Başlatan एक होना, 10 Temmuz 2014, 02:19:19
एक होना
net de gezinirken tesadüfen gördüm belki işe yarar. umarım doğru bölüme koymuşumdur.
bulduğum adres. http://tr.wikipedia.org/wiki/C_standart_k%C3%BCt%C3%BCphanesi
ANSI C kütüphanesi öncü dosyalar
<assert.h>   Assert makrolarını içerir.
<complex.h>   Karmaşık sayılarla işlem yapmak için fonksyionlar içerir.
<ctype.h>   Contains functions used to classify characters by their types or to convert between upper and lower case in a way that is independent of the used character set (typically ASCII or one of its extensions, although implementations utilizing EBCDIC are also known).
<errno.h>   Hata kodlarının denemek içindir.
<fenv.h>   Kayan noktalı sayıları denetlemek içindir.
<float.h>   Contains defined constants specifying the implementation-specific properties of the floating-point library, such as the minimum difference between two different floating-point numbers (_EPSILON), the maximum number of digits of accuracy (_DIG) and the range of numbers which can be represented (_MIN, _MAX).
<inttypes.h>   For precise conversion between integer types. (New with C99)
<iso646.h>   For programming in ISO 646 variant character sets. (New with NA1)
<limits.h>   Contains defined constants specifying the implementation-specific properties of the integer types, such as the range of numbers which can be represented (_MIN, _MAX).
<locale.h>   For setlocale() and related constants. This is used to choose an appropriate locale.
<math.h>   Yaygın matematik fonksiyonlarını içerir.
<setjmp.h>   Declares the macros setjmp and longjmp, which are used for non-local exits
<signal.h>   For controlling various exceptional conditions
<stdarg.h>   For accessing a varying number of arguments passed to functions.
<stdbool.h>   For a boolean data type. (New with C99)
<stdint.h>   For defining various integer types. (New with C99)
<stddef.h>   Yeni bazı tipler ve makrolar yaratmak içindir.
<stdio.h>   Provides the core input and output capabilities of the C language. This file includes the venerable printf function.
<stdlib.h>   For performing a variety of operations, including conversion, pseudo-random numbers, memory allocation, process control, environment, signalling, searching, and sorting.
<string.h>   Dizelerle işlemler yapmak içindir.
<tgmath.h>   For type-generic mathematical functions. (New with C99)
<time.h>   Zaman ve tarih biçimlerini dönüştürmek içindir.
<wchar.h>   For manipulating wide streams and several kinds of strings using wide characters - key to supporting a range of languages. (New with NA1)
<wctype.h>   For classifying wide characters. (New with NA1)
