ı2c ile bh1750 lüxmetre yardım ?
Başlatan mstbzr, 30 Aralık 2014, 17:39:51
mstbzr
sayın ustalar sürücü dosyasını indirdim ekledim fakat sistemi çalıştıramadım ı2c protokolunu pek bilmiyorum nette bununla ilgili örnekde bulamadım yardımcı olabilirseniz sevinirim...
BH1750.c
#include "BH1750.h"
 void BH1750_init()
    delay_ms(100);
    BH1750_write(power_down);
 void BH1750_write(unsigned char cmd)
    I2C_start();
    I2C_write(BH1750_address_w);
    I2C_write(cmd);
    I2C_stop();
 unsigned long BH1750_read_word()
    register unsigned long value = 0;
    unsigned char lb = 0;
    unsigned char hb = 0;
    I2C_start();
    I2C_write(BH1750_address_r);
    hb = I2C_read(1);
    lb = I2C_read(0);
    I2C_stop();
    value = make16(hb, lb);
    return value;
 unsigned long get_lux_value(unsigned char mode, unsigned long delay_time)
    register unsigned long lux_value = 0;
    BH1750_write(power_up);
    BH1750_write(mode);
    lux_value = BH1750_read_word();
    delay_ms(delay_time);
    return lux_value;
BH1750.h
#use I2C (Master, SDA = PIN_A0, SCL = PIN_A1)
 #define  BH1750_address_w 0x46
 #define  BH1750_address_r 0x47
 #define  power_down 0x00
 #define  power_up 0x01
 #define  reset 0x07
 #define  cont_H_res_mode1 0x10
 #define  cont_H_res_mode2 0x11
 #define  cont_L_res_mode 0x13
 #define  one_time_H_res_mode1 0x20
 #define  one_time_H_res_mode2 0x21
 #define  one_time_L_res_mode 0x23
 void BH1750_init();
 void BH1750_write(unsigned char cmd);
 unsigned long BH1750_read_word();
 unsigned long get_lux_value(unsigned char mode, unsigned long delay_time);
benim kod
#include <16F676.h>
#fuses NOWDT ,NOBROWNOUT, INTRC_IO, NOMCLR
#use delay(clock=4000000)
#define USE_PORTC_LCD TRUE
#include <4x20 LCD1.c>
#include <BH1750.c>
void main()
unsigned long luxx;
lcd_init();
BH1750_init();
while(TRUE)
     get_lux_value(luxx,100);
     lcd_gotoxy(5,1);
     printf(lcd_putc,"LuX Metre");
     lcd_gotoxy(4,2);
     printf(lcd_putc,"LUX %5Ld",luxx);
Kabil ATICI
 get_lux_value(luxx,100); //programda kullandığın
unsigned long get_lux_value(unsigned char mode, unsigned long delay_time); //fonksiyon...
sence bu uygun mu?
fonksiyon için;
    BH1750_write(mode);     //>>>>>>>>>>>?????
    return lux_value;
ambar7
mstbzr
usta açıkçası pek bir şey anlamadım. Lüx değerini okumam için nasıl bir şey yazmam gerekir bir örnek verebilirsen çok iyi olur diğer türlü ben bu işi çözemeyeceğim galiba :(
"luxx" değişkeni sensörün modunu belirtiyor anladığım
kadarıyla. bh1750.h dosyasının içinde modlar bulunmakta...
//main içindeki değişken tanımlamaları
unsigned char luxx = cont_H_res_mode1; //örneğin
unsigned long okunan_lux_degeri;
//while satırınıdan sonraki satır
okunan_lux_degeri = get_lux_value(luxx,100);
//en alttaki printf satiri
printf(lcd_putc,"LUX %5Ld", okunan_lux_degeri);
mstbzr
bu şekilde de denedim olmadı maalesef :( başka bir yöntemi var mı acaba ?
Elinizdeki sensörün nasıl çalıştığını öğrenmeniz gerekmekte...
FaTihan
Sensor integer değer üretmekte. Yani 2-byte bilgi. Bu iki byte birleştirilerek integer değer oluşturulması gerekir.
drRobutik
Selam,
Bu da benim kodum çalıştırdım
IOpin.addr=0;
EXT_INT_EDGE(1,L_TO_H);
enable_interrupts(INT_EXT1);
enable_interrupts(INT_EXT2);
disable_interrupts(INT_LOWVOLT);
disable_interrupts(INT_TIMER0);
disable_interrupts(INT_TIMER1);
disable_interrupts(GLOBAL);
BH1750_init();
IOpin.addr=0;
   for(;;)
      lightintensity=get_lux_value(cont_H_res_mode1,1000);
      printf("lux value:%f \n\r",(float)lightintensity/1.2);
      IOpin.cpuLED=1;
      delay_ms(10);
      IOpin.cpuLED=0;
Dr Süleyman CANAN namı diğer drRobutik Elektronik Mühendisi
