error recipe for target
Başlatan ido2323, 13 Ocak 2015, 18:57:29
ido2323
Hayırlı akşamlar bu ne hatası nasıl düzelir.
CLEAN SUCCESSFUL (total time: 33ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'C:/Users/asd/MPLABXProjects/C++.X'
make  -f nbproject/Makefile-default.mk dist/default/production/C__.X.production.hex
make[2]: Entering directory 'C:/Users/asd/MPLABXProjects/C++.X'
make[2]: *** No rule to make target 'build/default/production/c++.o', needed by 'dist/default/production/C__.X.production.hex'.  Stop.
make[2]: Leaving directory 'C:/Users/asd/MPLABXProjects/C++.X'
nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/Users/asd/MPLABXProjects/C++.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
BUİLD FAILED (exit value 2, total time: 233ms)
#include "p18F4550.inc"
#include <xc.h>
#define _XTAL_FREQ 8000000
; CONFIG1L
  CONFIG  PLLDIV = 1            ; PLL Prescaler Selection bits (No prescale (4 MHz oscillator input drives PLL directly))
  CONFIG  CPUDIV = OSC1_PLL2    ; System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
  CONFIG  USBDIV = 1            ; USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes directly from the primary oscillator block with no postscale)
; CONFIG1H
  CONFIG  FOSC = INTOSC_HS      ; Oscillator Selection bits (Internal oscillator, HS oscillator used by USB (INTHS))
  CONFIG  FCMEN = OFF           ; Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
  CONFIG  IESO = OFF            ; Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
; CONFIG2L
  CONFIG  PWRT = OFF            ; Power-up Timer Enable bit (PWRT disabled)
  CONFIG  BOR = ON              ; Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
  CONFIG  BORV = 3              ; Brown-out Reset Voltage bits (Minimum setting)
  CONFIG  VREGEN = OFF          ; USB Voltage Regulator Enable bit (USB voltage regulator disabled)
; CONFIG2H
  CONFIG  WDT = ON              ; Watchdog Timer Enable bit (WDT enabled)
  CONFIG  WDTPS = 32768         ; Watchdog Timer Postscale Select bits (1:32768)
; CONFIG3H
  CONFIG  CCP2MX = ON           ; CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
  CONFIG  PBADEN = ON           ; PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
  CONFIG  LPT1OSC = OFF         ; Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
  CONFIG  MCLRE = ON            ; MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
; CONFIG4L
  CONFIG  STVREN = ON           ; Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
  CONFIG  LVP = ON              ; Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
  CONFIG  ICPRT = OFF           ; Dedicated In-Circuit Debug/Programming Port (ICPORT) Enable bit (ICPORT disabled)
  CONFIG  XINST = OFF           ; Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
; CONFIG5L
  CONFIG  CP0 = OFF             ; Code Protection bit (Block 0 (000800-001FFFh) is not code-protected)
  CONFIG  CP1 = OFF             ; Code Protection bit (Block 1 (002000-003FFFh) is not code-protected)
  CONFIG  CP2 = OFF             ; Code Protection bit (Block 2 (004000-005FFFh) is not code-protected)
  CONFIG  CP3 = OFF             ; Code Protection bit (Block 3 (006000-007FFFh) is not code-protected)
; CONFIG5H
  CONFIG  CPB = OFF             ; Boot Block Code Protection bit (Boot block (000000-0007FFh) is not code-protected)
  CONFIG  CPD = OFF             ; Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
; CONFIG6L
  CONFIG  WRT0 = OFF            ; Write Protection bit (Block 0 (000800-001FFFh) is not write-protected)
  CONFIG  WRT1 = OFF            ; Write Protection bit (Block 1 (002000-003FFFh) is not write-protected)
  CONFIG  WRT2 = OFF            ; Write Protection bit (Block 2 (004000-005FFFh) is not write-protected)
  CONFIG  WRT3 = OFF            ; Write Protection bit (Block 3 (006000-007FFFh) is not write-protected)
; CONFIG6H
  CONFIG  WRTC = OFF            ; Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
  CONFIG  WRTB = OFF            ; Boot Block Write Protection bit (Boot block (000000-0007FFh) is not write-protected)
  CONFIG  WRTD = OFF            ; Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
; CONFIG7L
  CONFIG  EBTR0 = OFF           ; Table Read Protection bit (Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks)
  CONFIG  EBTR1 = OFF           ; Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
  CONFIG  EBTR2 = OFF           ; Table Read Protection bit (Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks)
  CONFIG  EBTR3 = OFF           ; Table Read Protection bit (Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks)
; CONFIG7H
  CONFIG  EBTRB = OFF           ; Boot Block Table Read Protection bit (Boot block (000000-0007FFh) is not protected from table reads executed in other blocks)
int i = 0;
void Delay1Second(void);
void SetupClock(void);
void main(int argc, char** argv) {
    SetupClock();
    TRISAbits.RB7 = 0;
    while(1) //infinite loop
        LATB7 = 1; //Set the PIN RB0 high
        Delay1Second();
        LATB7 = 0; //Set the PIN RB0 low
        Delay1Second();
void Delay1Second()
    for(i=0;i<100;i++)
        __delay_ms(10);
void SetupClock()
    OSCCONbits.IRCF0 = 1;
    OSCCONbits.IRCF1 = 1;
    OSCCONbits.IRCF2 = 1;
