USB Deneme kartı (Bitti)
Başlatan baran123, 09 Mayıs 2015, 22:30:10
baran123
Aslında tam deneme kartı değil ama LCD,LED,sıcaklık ve D portunu kontrol edebileceğiniz bir devre yapmıştım bir ara.Belki birinin işine yarar.Eski bir proje saçma bir şey yapmış olabilirim. :D
main.h
/* Project          : main.c
/* Description      : Home Automation
/* Author           : Baran Ekrem
#IFNDEF __MAIN_H__
#DEFINE __MAIN_H__
#INCLUDE <18F4550.h>
#DEVICE ADC = 10
#FUSES NOWDT
#FUSES WDT128
#FUSES NOLVP
#FUSES NOPROTECT
#FUSES HSPLL
#FUSES NOPROTECT
#FUSES BROWNOUT_NOSL
#FUSES BROWNOUT
#FUSES PUT
#FUSES NOCPD
#FUSES STVREN
#FUSES NODEBUG
#FUSES NOLVP
#FUSES NOWRT
#FUSES NOWRTD
#FUSES NOIESO
#FUSES NOFCMEN
#FUSES NOPBADEN
#FUSES NOWRTC
#FUSES NOWRTB
#FUSES NOEBTR
#FUSES NOEBTRB
#FUSES NOCPB
#FUSES NOMCLR
#FUSES LPT1OSC
#FUSES NOXINST
#FUSES PLL5
#FUSES CPUDIV1
#FUSES USBDIV
#FUSES VREGEN
#USE DELAY(CLOCK = 48MHz, CRYSTAL = 20MHz, USB_FULL)
#DEFINE USB_HID_DEVICE     TRUE
#DEFINE USB_EP1_TX_ENABLE  USB_ENABLE_INTERRUPT
#DEFINE USB_EP1_RX_ENABLE  USB_ENABLE_INTERRUPT
#DEFINE USB_EP1_TX_SIZE    64
#DEFINE USB_EP1_RX_SIZE    64
#INCLUDE "Ds18b20.c"
#INCLUDE "Flex_Lcd.c"
#INCLUDE "USB_Konfigurasyon.h"
#INCLUDE <pic18_usb.h>
#INCLUDE <usb.c>
#USE FAST_IO(B)
#USE FAST_IO(D)
#DEFINE UcNokta1      1
#DEFINE signal        gelen_paket[0]
#DEFINE control       gelen_paket[1]
#DEFINE count         gelen_paket[2]
#DEFINE byteData      gelen_paket[3]
#ENDIF
main.c
/* Project          : main.c
#include "main.h"
static int8 gelen_paket[64];
static int8 giden_paket[32];
static int8 x,tam,onda;
static int16 term;
static float sicaklik;
static void McuInit(void);
static void Outputs(void);
static void SendTemp(void);
static void LcdOperations(char);
static void LedStateChange(char);
static void ProgramConnected(char);
/* Function Name  : main
/* Description    : Main Program
/* Input          : None
/* Return         : None
void main(void)
   McuInit();
   for (;;)
      while(usb_enumerated())
         SendTemp();
         if(usb_kbhit(1))
            usb_get_packet(UcNokta1, gelen_paket, 64);
            if(signal == 'A')
               switch(control)
                  case 'a': ProgramConnected(control); break;
                  case 'b': ProgramConnected(control); break;
                  case 'c': LcdOperations(control);    break;
                  case 'd': LcdOperations(control);    break;
                  case 'e': ProgramConnected(control); break;
                  case 'f': Outputs();                 break;
                  case '0': LedStateChange(control);   break;
                  case '1': LedStateChange(control);   break;
/* Function Name  : sendTemp
/* Description    : Read temp and send
/* Input          : None
/* Return         : None
   sicaklik = ds1820_read();
   term = sicaklik * 10;
   tam = term / 10;
   onda = term % 10;
   giden_paket[0] = tam;
   giden_paket[1] = onda;
   usb_put_packet(UcNokta1, giden_paket, 64, USB_DTS_TOGGLE);
/* Function Name  : ProgramConnected
/* Description    : Determining the Program Connection State
/* Input          : char ConState (a, b)
/* Return         : None
static void ProgramConnected(char ConState)
   if(ConState == 'a')
      printf(lcd_putc,"\fPC Connected");
   if(ConState == 'b')
      printf(lcd_putc,"\fPC Disconnected");
/* Function Name  : LedStateChange
/* Description    : Changing the Status LED
/* Input          : char state (0, 1)
/* Return         : None
static void LedStateChange(char state)
   if(state == '1')
      output_high(pin_b6);
      printf(lcd_putc,"\fLED On");
   if(state == '0')
      output_low(pin_b6);
      printf(lcd_putc,"\fLED Off");
/* Function Name  : LcdOperations
/* Description    : Text is Sending to the Lcd
/* Input          : char Info (c, d, e)
/* Return         : None
static void LcdOperations(char Info)
   if(Info == 'c')
      lcd_gotoxy(1,1);
      for(x = 3; x <= count; x++)
         printf(lcd_putc,"%c",gelen_paket[x]);
   if(Info == 'd')
      lcd_gotoxy(1,2);
   if(Info == 'e')
      printf(lcd_putc,"\f");
/* Function Name  : Outputs
/* Description    : Control the Port D
/* Input          : None
/* Return         : None
   output_d(byteData);
/* Function Name  : McuInit
/* Description    : MCU is Preparing
/* Input          : None
/* Return         : None
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_CCP1(CCP_OFF);
   setup_CCP2(CCP_OFF);
   setup_vref(FALSE);
   set_tris_b(0x00);
   set_tris_d(0x00);
   output_b(0x00);
   output_d(0x00);
   lcd_init();
   usb_init();
   usb_task();
   output_high(pin_b7);
   printf(lcd_putc,"\fUSB Connecting..");
   usb_wait_for_enumeration();
   if(usb_enumerated())
      printf(lcd_putc,"\fUSB Connected");
usb_konfigurasyon
#IFNDEF __USB_DESCRIPTORS__
#DEFINE __USB_DESCRIPTORS__
#include <usb.h>
     const char USB_CLASS_SPECIFIC_DESC[] = {
      6, 0, 255,    // Usage Page = Vendor Defined
      9, 1,            // Usage = IO device
      0xa1, 1,       // Collection = Application
      0x19, 0,        // Usage minimum
      0x29, 800,        // Usage maximum
      0x15, 0x00,        // Logical minimum (-128)
      0x25, 0xFF,        // Logical maximum (127)
      0x75, 8,        // Report size = 8 (bits)
      0x95, 64,        // Report count = 16 bits (2 bytes)
      0x81, 2,        // Input (Data, Var, Abs)
      0x91, 2,        // Output (Data, Var, Abs)
      0xc0            // End Collection
   //if a class has an extra descriptor not part of the config descriptor,
   // this lookup table defines where to look for it in the const
   // USB_CLASS_SPECIFIC_DESC[] array.
   //first element is the config number (if your device has more than one config)
   //second element is which interface number
   //set element to 0xFFFF if this config/interface combo doesn't exist
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP[USB_NUM_CONFIGURATIONS][1] =
   //config 1
      //interface 0
         0
   // this lookup table defines the size of that descriptor.
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[USB_NUM_CONFIGURATIONS][1] =
   //config 1
      //interface 0
         32
///   start config descriptor
///   right now we only support one configuration descriptor.
///   the config, interface, class, and endpoint goes into this array.
   #DEFINE USB_TOTAL_CONFIG_LEN      41  //config+interface+class+endpoint+endpoint (2 endpoints)
   const char USB_CONFIG_DESC[] = {
   //IN ORDER TO COMPLY WITH WINDOWS HOSTS, THE ORDER OF THIS ARRAY MUST BE:
      //    config(s)
      //    interface(s)
      //    class(es)
      //    endpoint(s)
   //config_descriptor for config index 1
         USB_DESC_CONFIG_LEN, //length of descriptor size          ==1
         USB_DESC_CONFIG_TYPE, //constant CONFIGURATION (CONFIGURATION 0x02)     ==2
         USB_TOTAL_CONFIG_LEN,0, //size of all data returned for this config      ==3,4
         1, //number of interfaces this device supports       ==5
         0x01, //identifier for this configuration.  (IF we had more than one configurations)      ==6
         0x00, //index of string descriptor for this configuration      ==7
         0x80, //bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 unused and bit7=1         ==8
         50, //maximum bus power required (maximum milliamperes/2)  (100mA)
   //interface descriptor 1
         USB_DESC_INTERFACE_LEN, //length of descriptor      =10
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)       =11
         0x00, //number defining this interface (IF we had more than one interface)    ==12
         0x00, //alternate setting     ==13
         2, //number of endpoins, except 0 (pic167xx has 3, but we dont have to use all).       ==14
         0x03, //class code, 03 = HID     ==15
         0x00, //subclass code //boot     ==16
         0x00, //protocol code      ==17
         0x00, //index of string descriptor for interface      ==18
   //class descriptor 1  (HID)
         USB_DESC_CLASS_LEN, //length of descriptor    ==19
         USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID)      ==20
         0x11,0x01, //hid class release number (1.0) (try 1.10)      ==21,22
         0x00, //localized country code (0 = none)       ==23
         0x01, //number of hid class descrptors that follow (1)      ==24
         0x22, //report descriptor type (0x22 == HID)                ==25
         USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][0], 0x00, //length of report descriptor            ==26,27
   //endpoint descriptor
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==28
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)          ==29
         0x81, //endpoint number and direction (0x81 = EP1 IN)       ==30
         0x03, //transfer type supported (0x03 is interrupt)         ==31
         USB_EP1_TX_SIZE,0x00, //maximum packet size supported                  ==32,33
         10,  //polling interval, in ms.  (cant be smaller than 10)      ==34
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==35
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)          ==36
         0x01, //endpoint number and direction (0x01 = EP1 OUT)      ==37
         0x03, //transfer type supported (0x03 is interrupt)         ==38
         USB_EP1_RX_SIZE,0x00, //maximum packet size supported                  ==39,40
         10 //polling interval, in ms.  (cant be smaller than 10)    ==41
   //****** BEGIN CONFIG DESCRIPTOR LOOKUP TABLES ********
   //since we can't make pointers to constants in certain pic16s, this is an offset table to find
   //  a specific descriptor in the above table.
   //NOTE: DO TO A LIMITATION OF THE CCS CODE, ALL HID INTERFACES MUST START AT 0 AND BE SEQUENTIAL
   //      FOR EXAMPLE, IF YOU HAVE 2 HID INTERFACES THEY MUST BE INTERFACE 0 AND INTERFACE 1
   #define USB_NUM_HID_INTERFACES   1
   //the maximum number of interfaces seen on any config
   //for example, if config 1 has 1 interface and config 2 has 2 interfaces you must define this as 2
   #define USB_MAX_NUM_INTERFACES   1
   //define how many interfaces there are per config.  [0] is the first config, etc.
   const char USB_NUM_INTERFACES[USB_NUM_CONFIGURATIONS]={1};
   //define where to find class descriptors
   //first dimension is the config number
   //second dimension specifies which interface
   //last dimension specifies which class in this interface to get, but most will only have 1 class per interface
   //if a class descriptor is not valid, set the value to 0xFFFF
   const int16 USB_CLASS_DESCRIPTORS[USB_NUM_CONFIGURATIONS][1][1]=
   //config 1
      //interface 0
         //class 1
         18
   #if (sizeof(USB_CONFIG_DESC) != USB_TOTAL_CONFIG_LEN)
      #error USB_TOTAL_CONFIG_LEN not defined correctly
   #endif
///   start device descriptors
   const char USB_DEVICE_DESC[USB_DESC_DEVICE_LEN] ={
      //starts of with device configuration. only one possible
         USB_DESC_DEVICE_LEN, //the length of this report   ==1
         0x01, //the constant DEVICE (DEVICE 0x01)  ==2
         0x00,0x02, //usb version in bcd
         0x00, //class code ==5
         0x00, //subclass code ==6
         0x00, //protocol code ==7
         USB_MAX_EP0_PACKET_LENGTH, //max packet size for endpoint 0. (SLOW SPEED SPECIFIES 8) ==8
         0x11,0x11, //vendor id (0x04D8 is Microchip, or is it 0x0461 ??)
         0x11,0x11, //product id   ==11,12  //don't use ffff says usb-by-example guy.  oops
         0x00,0x01, //device release number  ==13,14
         0x01, //index of string description of manufacturer. therefore we point to string_1 array (see below)  ==15
         0x02, //index of string descriptor of the product  ==16
         0x00, //index of string descriptor of serial number  ==17
         USB_NUM_CONFIGURATIONS  //number of possible configurations  ==18
///   start string descriptors
///   String 0 is a special language string, and must be defined.  People in U.S.A. can leave this alone.
///   You must define the length else get_next_string_character() will not see the string
///   Current code only supports 10 strings (0 thru 9)
//the offset of the starting location of each string.  offset[0] is the start of string 0, offset[1] is the start of string 1, etc.
char USB_STRING_DESC_OFFSET[]={0,4,12};
char const USB_STRING_DESC[]={
   //string 0
         4, //length of string index
         USB_DESC_STRING_TYPE, //descriptor type 0x03 (STRING)
         0x09,0x04,   //Microsoft Defined for US-English
   //string 1
         8, //length of string index
         'B',0,
         'E',0,
   //string 2
         58,                   //length of string index
         ' ',0,
         'B',0,
         'A',0,
         'R',0,
         'A',0,
         'N',0,
         ' ',0,
         'E',0,
         'K',0,
         'R',0,
         'E',0,
         'M',0,
         ' ',0
#ENDIF
flex_lcd.c
#define LCD_DB4   PIN_B0
#define LCD_DB5   PIN_B1
#define LCD_DB6   PIN_B2
#define LCD_DB7   PIN_B3
#define LCD_E     PIN_B5
#define LCD_RS    PIN_B4
#define lcd_type 2
#define lcd_line_two 0x40
int8 const LCD_INIT_STRING[4] = { 0x20 | (lcd_type << 2), 0xc, 1, 6 };
void lcd_send_nibble(int8 nibble)
   output_bit(LCD_DB4, !!(nibble & 1));
   output_bit(LCD_DB5, !!(nibble & 2));
   output_bit(LCD_DB6, !!(nibble & 4));
   output_bit(LCD_DB7, !!(nibble & 8));
   delay_cycles(1);
   output_high(LCD_E);
   delay_us(2);
   output_low(LCD_E);
#ifdef USE_LCD_RW
int8 lcd_read_nibble(void)
   int8 retval;
   #bit retval_0 = retval.0
   #bit retval_1 = retval.1
   #bit retval_2 = retval.2
   #bit retval_3 = retval.3
   retval = 0;
   output_high(LCD_E);
   delay_cycles(1);
   retval_0 = input(LCD_DB4);
   retval_1 = input(LCD_DB5);
   retval_2 = input(LCD_DB6);
   retval_3 = input(LCD_DB7);
   output_low(LCD_E);
   return(retval);
#endif
#ifdef USE_LCD_RW
int8 lcd_read_byte(void)
   int8 low, high;
   output_high(LCD_RW);
   delay_cycles(1);
   high = lcd_read_nibble();
   low = lcd_read_nibble();
   return( (high<<4) | low);
#endif
void lcd_send_byte(int8 address, int8 n)
   output_low(LCD_RS);
   #ifdef USE_LCD_RW
   while(bit_test(lcd_read_byte(),7)) ;
   #else
   delay_us(60);
   #endif
   if(address)
      output_high(LCD_RS);
      output_low(LCD_RS);
    delay_cycles(1);
   #ifdef USE_LCD_RW
      output_low(LCD_RW);
      delay_cycles(1);
   #endif
   output_low(LCD_E);
   lcd_send_nibble(n >> 4);
   lcd_send_nibble(n & 0xf);
void lcd_init(void)
   int8 i;
   output_low(LCD_RS);
   #ifdef USE_LCD_RW
   output_low(LCD_RW);
   #endif
   output_low(LCD_E);
   delay_ms(15);
   for(i=0 ;i < 3; i++)
      lcd_send_nibble(0x03);
      delay_ms(5);
   lcd_send_nibble(0x02);
   for(i=0; i < sizeof(LCD_INIT_STRING); i++)
      lcd_send_byte(0, LCD_INIT_STRING[i]);
      #ifndef USE_LCD_RW
      delay_ms(5);
      #endif
void lcd_gotoxy(int8 x, int8 y)
   int8 address;
   if(y != 1)
      address = lcd_line_two;
      address=0;
   address += x-1;
   lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
   switch(c)
      case '\f': lcd_send_byte(0,1); delay_ms(2); break;
      case '\n': lcd_gotoxy(1,2); break;
      case '\b': lcd_send_byte(0,0x10); break;
      default: lcd_send_byte(1,c); break;
#ifdef USE_LCD_RW
char lcd_getc(int8 x, int8 y)
   char value;
   lcd_gotoxy(x,y);
   while(bit_test(lcd_read_byte(),7));
   value = lcd_read_byte();
   output_low(lcd_RS);
   return(value);
#endif
Devre şeması : http://i.hizliresim.com/Am7qJX.png
Dosyalar : http://s5.dosya.tc/server2/lgg4i6/PIC_Kontrol.rar.html
ziyaretci
Hocam elinize sağlık, veri gönderimi ve alma kısmında kullanılan fonksiyonun asm tarafındaki bilgiye sahipseniz bilgilendirebilir misiniz?
baran123
Hocam sizin konuyu biliyorum.Fakat o kadar derinden bilgim maalesef yok.
Recep METE
Çalışman için teşekkürler, hemen indirip dosyaladım.Belki lazım olur.
mustafa_temel
bu devre tam olarak ne işe yarıyor acaba ??
"Dünya R-S-T üzerinde döner."
baran123
USB üzerinden PIC ile iletişim kuruyorsunuz.Bilgisayar arayüzünden bilgi göndererek LCD de yazı yazdırabiliyor, ledleri yaka biliyor ve D portunu kontrol edebiliyorsunuz.Sanırım sıcaklık ölçmede vardı ama tam hatırlamıyorum.
mustafa_temel
Alıntı yapılan: Baran Ekrem - 09 Mayıs 2015, 23:40:33
hım anladım güzel bişey o zaman ...
Alıntı yapılan: erkantr67 - 09 Mayıs 2015, 22:37:29
  Sizin konunuzda Baran ın kodlarını mplab ide ile derletip
kolay araştırılabilir hale getirdim,
ufakda bir video hazırladım,
(sessiz videoları hiç sevmem ama)
buradanda konunun linkini vermek istedim:
https://www.picproje.org/index.php/topic,59058.msg457160.html#msg457160
