18F65K22 ADC AYARLARI
Başlatan F.T, 05 Aralık 2015, 17:03:55
F.T
Arkadaşlar ayarları yaptım fakat proteuse bu işlemcide olmayan 15 nolu adc nin ayarlanmış olduğu ikazı veriyor.fakat benim seçimimde yok.Ayarlarla ilgili bir sorunummu var bulamadım.
Device = 18F65K22
Config_Start
  RETEN = On	;Enabled
  INTOSCSEL = High	;LF-INTOSC in High-power mode during Sleep
  SOSCSEL = Dig	;Digital (SCLKI) mode
  XINST = OFF	;Disabled
  FOSC = INTIO2	;Internal RC oscillator
  PLLCFG = On	;Enabled
  FCMEN = OFF	;Disabled
  IESO = OFF	;Disabled
  PWRTEN = On	;Enabled
  BOREN = On	;Controlled with SBOREN bit
  BORV = 0	;3.0V
  BORPWR = ZPBORMV	;ZPBORMV instead of BORMV is selected
  WDTEN = OFF	;WDT disabled in hardware; SWDTEN bit disabled
  WDTPS = 1048576	;1:1048576
  RTCOSC = INTOSCREF	;RTCC uses INTRC
  CCP2MX = PORTC	;RC1
  MSSPMSK = MSK7	;7 Bit address masking mode
  MCLRE = OFF	;MCLR Disabled, RG5 Enabled
  STVREN = On	;Enabled
  BBSIZ = BB1K	;1K word Boot Block size
  Debug = OFF	;Disabled
  CP0 = OFF	;Disabled
  CP1 = OFF	;Disabled
  CP2 = OFF	;Disabled
  CP3 = OFF	;Disabled
  CPB = OFF	;Disabled
  CPD = OFF	;Disabled
  WRT0 = OFF	;Disabled
  WRT1 = OFF	;Disabled
  WRT2 = OFF	;Disabled
  WRT3 = OFF	;Disabled
  WRTC = OFF	;Disabled
  WRTB = OFF	;Disabled
  WRTD = OFF	;Disabled
  EBRT0 = OFF	;Disabled
  EBRT1 = OFF	;Disabled
  EBRT2 = OFF	;Disabled
  EBRT3 = OFF	;Disabled
  EBRTB = OFF	;Disabled
Config_End
;**** End of Fuse Configurator Settings ****
Declare Xtal = 8
TRISA=%11111111:PORTA=0
TRISB=%11111111:PORTB=0
TRISC=%00000000:PORTC=0
TRISD=%00000000:PORTD=0
TRISE=%11111111:PORTE=0
TRISF=%10111110:PORTF=0
TRISG=%00000000:PORTG=0
'--------------------lcd ekran tanımlaması------------------------
Declare All_Digital = True			'bütün çıkışlar dijital
Declare I2C_Slow_Bus On
Declare LCD_Type 0
Declare LCD_RSPin PORTD.4  'LCD register select bit
Declare LCD_ENPin PORTD.5  'LCD enable bit
Declare LCD_Interface 4  'LCD bus size 4 or 8
Declare LCD_Lines 4 'Number lines on LCD
Declare LCD_DTPin PORTD.0 'LCD data port
Declare LCD_CommandUs 2000 'Command delay time in us
Declare LCD_DataUs 50 'Data delay time in us
Symbol T0IF=INTCON.2 ' TMR0 Overflow Interrupt Flag
Symbol T0IE=INTCON.5 ' TMR0 Overflow Interrupt Enable
Symbol GIE=INTCON.7  ' Global Interrupt Enable
GIE=0
T0IE=0
T0IF=0
TMR0L=0
INTCON2=%00000000
INTCON3=%00000000
PADCFG1=%01000000
ADCON0=%00000001
ADCON1=%00000000
ADCON2=%10100011
ANCON0=%11100011  ' açılan adcler  0,1,5,6,7
ANCON1=%00000111  ' açılan adcler       8,9,10
ANCON2=%00000000
CM1CON=%00000000
CM2CON=%00000000
CM3CON=%00000000
CTMUCONH=%00000000
CTMUCONL=%00000000
CTMUICON=%00000000
Maxim
16 tane adc girişi yokmu o işlemcide?
F.T
Maxim hocam var.Kullanmadığım adc kanalını ANCON registerinden kapatmama rağmen açık görüyor ve bu kanalda 18f65k22 serisinde yok.Kullanılmıyor.Sıkıntım bu.
