The Philips ARM Design Contest 2005,$15000
Başlatan koordinat, 19 Eylül 2005, 17:17:54
koordinat
We've squeezed more in...
how much can you squeeze out?
The Philips ARM Design Contest 2005 is your introduction to Philips's powerful LPC213x microcontroller family. These RISC MCUs are based on the high-performance 32-bit ARM7TDMI-S™ microprocessor, which features low-power consumption and 16-bit Thumb code for efficient and flexible designs. Other key features include a wide range of serial communications interfaces, on-chip 8/16/32-KB SRAM, 32-bit timers, single or dual 10-bit eight-channel ADCs, a 10-bit DAC, PWM channels, and 47 GPIO lines. These features coupled with a small footprint make the LPC2131/2132/2134/2136/2138 microcontrollers ideally suited for countless applications, such as access control, point of sale, communication gateways, voice recognition, industrial control, and medical systems.
Don't miss this major opportunity to show off your design talent.
Your design skills could win you a share of $15,000 in cash prizes!
Deadline: October 24, 2005
buraya tıklayın!
[/i][/b]
Macera
Ödül alanlar arasında:
Birisi TV Osilaskopu yapmış.Video sinyalini chip üretiyor.
http://www.jandspromotions.com/philips2005/Winners/AR1755.htm
Ve hatta biriside model uçak için uçuş bilgisayarı üretmiş.
http://www.jandspromotions.com/philips2005/Winners/AR1773.htm
Bu işin sonu yok gibi!
"Art without engineering is dreaming; engineering without art is calculating." -- Steven K. Roberts
kasif
noPC çok hoş bir çalışma, PDF yi okuyun, adamın projesini anlatışı harika. Adamın işlemciye açık olmuş gibi algıladım.
Bir işlemci ile; VGA çıkışı, fare, klavye, 2 tane com port, SD kart okuyucu(ve tabi yazıcısı), bunları 32 KB hafıza ile yapıyor.
