PIC18F25K22 çalışmaması
Başlatan apsis, 26 Kasım 2016, 22:21:57
apsis
Config ayarlarında mı sıkıntı var anlayamadım. Simülasyonda çalışıyor fakat reelde çalışmıyor. Çıkış verdiğim pinler bile bir çalışıyor bir çalışmıyor. İşlemci SMD ve kartı çok önceden basmıştım ancak deneme fırsatı bulabildim. Pickit2 ile ICSP üzerinden program atıyorum.
#include <xc.h>
// PIC18F25K22 Configuration Bit Settings
// 'C' source line config statements
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG1H
#pragma config FOSC = HSMP      // Oscillator Selection bits (HS oscillator (medium power 4-16 MHz))
#pragma config PLLCFG = OFF      // 4X PLL Enable (Oscillator multiplied by 4)
#pragma config PRICLKEN = ON    // Primary clock enable bit (Primary clock enabled)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF       // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRTEN = ON      // Power-up Timer Enable bit (Power up timer enabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable bits (Brown-out Reset disabled in hardware and software)
#pragma config BORV = 190       // Brown Out Reset Voltage bits (VBOR set to 1.90 V nominal)
// CONFIG2H
#pragma config WDTEN = OFF      // Watchdog Timer Enable bits (Watch dog timer is always disabled. SWDTEN has no effect.)
#pragma config WDTPS = 32768    // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = PORTC1  // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = OFF     // PORTB A/D Enable bit (PORTB<5:0> pins are configured as digital I/O on Reset)
#pragma config CCP3MX = PORTB5  // P3A/CCP3 Mux bit (P3A/CCP3 input/output is multiplexed with RB5)
#pragma config HFOFST = OFF     // HFINTOSC Fast Start-up (HFINTOSC output and ready status are not delayed by the oscillator stable status)
#pragma config T3CMX = PORTC0   // Timer3 Clock input mux bit (T3CKI is on RC0)
#pragma config P2BMX = PORTB5   // ECCP2 B output mux bit (P2B is on RB5)
#pragma config MCLRE = EXTMCLR  // MCLR Pin Enable bit (MCLR pin enabled, RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = OFF      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = ON         // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled if MCLRE is also 1)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF        // Code Protection Block 0 (Block 0 (000800-001FFFh) not code-protected)
#pragma config CP1 = OFF        // Code Protection Block 1 (Block 1 (002000-003FFFh) not code-protected)
#pragma config CP2 = OFF        // Code Protection Block 2 (Block 2 (004000-005FFFh) not code-protected)
#pragma config CP3 = OFF        // Code Protection Block 3 (Block 3 (006000-007FFFh) not code-protected)
// CONFIG5H
#pragma config CPB = OFF        // Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
#pragma config CPD = OFF        // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF       // Write Protection Block 0 (Block 0 (000800-001FFFh) not write-protected)
#pragma config WRT1 = OFF       // Write Protection Block 1 (Block 1 (002000-003FFFh) not write-protected)
#pragma config WRT2 = OFF       // Write Protection Block 2 (Block 2 (004000-005FFFh) not write-protected)
#pragma config WRT3 = OFF       // Write Protection Block 3 (Block 3 (006000-007FFFh) not write-protected)
// CONFIG6H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protection Block 0 (Block 0 (000800-001FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection Block 1 (Block 1 (002000-003FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection Block 2 (Block 2 (004000-005FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection Block 3 (Block 3 (006000-007FFFh) not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
#define _XTAL_FREQ 16000000
#define CLK_1 LA2 // LATX Bitleri cikis icin PORTX ise giris okumak icin kullanılıyor(yeni nesil islemciler ve 18 serilerinin bir cogu boyle)
#define DATAI_1 LA0 // LATXbits.LX0 şeklinde de tanımlanabilirler
#define ENB_1 LA1
#define CLK_2 LA3
#define DATAI_2 LA4
#define ENB_2 LA5
void tpic595_1(int rkm, char disp)
    char t;
    ENB_1=0;
        for(t=0;t<8;t++)
            CLK_1=0;
            if((rkm<<t)&0x80)
                DATAI_1=1;
                DATAI_1=0;
            CLK_1=1;
            ENB_1=1;
void tpic595_2(int rkm,char disp)
    char y;
    ENB_2=0;
        for(y=0;y<8;y++)
            CLK_2=0;
            if((rkm<<y)&0x80)
                DATAI_2=1;
                DATAI_2=0;
            CLK_2=1;
            ENB_2=1;
void main(void)
    unsigned int i=0,k=0,d;
    CM1CON0=0x00;
    CM2CON1=0X00;
    PORTA=0x00;
    LATA=0x00;
    ANSELA=0x00;
    TRISA=0x00;
    PORTB=0x00;
    LATB=0x00;
    ANSELB=0x00;
    TRISB=0x00;
    PORTC=0x00;
    LATC=0x00;
    ANSELC=0x00;
    TRISC=0x00;
    while(1)
        tpic595_1(255,0);
        tpic595_2(0,0);
Devre,
"Makineye Beyin" MEKATRONİK
Ansel registerini tris den sonra yazıp
deneyiniz.
apsis
Tık yok hocam. Pinler sanki analog gibi, çıkışlar değişken değerler alıyor(0-2-4.5 gibi)
serdararikan
osilator ayarlarınızı gözden geçirin.
apsis
hocam kodu yayınladım nasıl bir yanlışlık olabilir??
Osilatoru dahili seçtim. Şimdi 32 ledin(matrix) tümü yanması gerekirken her resete basışımda farklı şeyler oluyor ve durdukça keni kendine birşeyler yanıp sönüyor. Gece gece çözemedim ya şunu sinirlerim bozuldu!!!!
Bence biraz ara vermek lazım, aynı noktaya bakınca
kör oluyor insan...
apsis
Bu işlemcinin çıkışları dijital çıkış olarak kullanılmıyor mu nedir ne yaptıysam bir ledi bile yakıp söndüremedim. Led pır pır ediyor.
@mehmet haklısın en iyisi sabah devam edeyim.
apsis
apsis
Şimdi fark ettim ki işlemciyi sildiğimde de aynı tepkiyi veriyor. işlemci start almıyor mu anlayamadım?!
eeburakdemir
@apsis merhaba,
Bu k serisi yeni nesil olarak da geçebilir bazı yerlerde, HFINTOSC gibi kavramlar var. Bunların hazır olana kadar beklemelisiniz. Bu şekilde yapmadan öncede delay koyup beklerseniz tadından yenmez. Ayrıca bunlar gerçekleştirdikten sonra yine pinlerinizin bazıları istediğiniz gibi çalışmıyorsa config ayarlarında pinlerin default ayarları değişik olabiliyor bunları düzeltmeniz gerekir. Sorduğunuz konuların çok benzeri bu hafta ve yakın haftalarda çok kez tartışıldı. Bu şekilde bir deneyin ve forumu aratın eski konularda nasıl yapıldığı direk kod paylaşımları ile mevcut.
Örneğin ;
https://www.picproje.org/index.php/topic,66169.msg516132.html#msg516132
Asla pes etme...
apsis
@eeburakdemir Teşekkür ederim. O konuya yorum da yapmıştım ben. Oradaki çözümü de uyguladım ama nafile.
eeburakdemir
@apsis fırsat bulabilirsem bakarım ilgilencem
Asla pes etme...
apsis
eeburakdemir
@apsis yazdığınız kodda eklemeler çıkarmalar yapmışsınızdır illaki ama son güncel ayarlamalar kısmını koyar mısınız ? Eğer çok özel de değilse yayınlarsanız iyi olur. çümkü ilk paylaştığınız kod örneğinde osc ayarları yok. Şimdilik bakabildiğim kadar baktım ama işlerim var yine ilgilenebilirsem bakacağım.
Asla pes etme...
apsis
#14
#include <xc.h>
// CONFIG1H
#pragma config FOSC = INTIO7      // Oscillator Selection bits (HS oscillator (medium power 4-16 MHz))
#pragma config PLLCFG = ON      // 4X PLL Enable (Oscillator multiplied by 4)
#pragma config FCMEN = ON      // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
// CONFIG2L
#pragma config PWRTEN = OFF      // Power-up Timer Enable bit (Power up timer enabled)
// CONFIG2H
// CONFIG3H
// CONFIG4L
#pragma config LVP = OFF         // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled if MCLRE is also 1)
// CONFIG5L
// CONFIG5H
// CONFIG6L
// CONFIG6H
// CONFIG7L
// CONFIG7H
#define _XTAL_FREQ (64000000UL)
#define CLK_1 LA2 // LATX Bitleri cikis icin PORTX ise giris okumak icin kullan?l?yor(yeni nesil islemciler ve 18 serilerinin bir cogu boyle)
#define DATAI_1 LA0 // LATXbits.LX0 ?eklinde de tan?mlanabilirler
#define ENB_1 LA1
#define CLK_2 LA3
#define DATAI_2 LA4
#define ENB_2 LA5
    char t;
    ENB_1=0;
        for(t=0;t<8;t++)
            CLK_1=0;
            if((rkm<<t)&0x80)
                DATAI_1=1;
                DATAI_1=0;
            CLK_1=1;
            __delay_ms(5);
            ENB_1=1;
    char y;
    ENB_2=0;
        for(y=0;y<8;y++)
            CLK_2=0;
            if((rkm<<y)&0x80)
                DATAI_2=1;
                DATAI_2=0;
            CLK_2=1;
            ENB_2=1;
void main(void)
    OSCCONbits.SCS=0;
      OSCCONbits.IRCF=7;
     while (!OSCCONbits.HFIOFS)
    {  NOP();}
     OSCTUNE = 0b01000000;
    while (!OSCCON2bits.PLLRDY)
            {  NOP();}
    CM1CON0=0x00;
    CM2CON0=0X00;
    CM2CON1=0X00;
    PMD1=0XFF;
    PMD2=0XFF;
    VREFCON0=0x30;
    VREFCON1=0X00;
    CTMUEN=0;
    SRLEN=0;
    ANSELA=0x00;
    ANSELB=0xF0;
    ANSELC=0x00;
    TRISA=0x00;
    TRISB=0x00;
    TRISC=0x00;
    PORTA=0x00;
    LATA=0x00;
    PORTB=0x00;
    LATB=0x00;
    PORTC=0x00;
    LATC=0x00;
    while(1)
        LATCbits.LATC5=0;
        for(d=0;d<500;d++)
            __delay_ms(1);
        LATCbits.LATC5=1;
        for(d=0;d<500;d++)
            __delay_ms(1);
Buradaki program dahili osilator ve pll. Buradan bir problem olacağını sanmıyorum.
