yardım lazım lütfen
Başlatan ahmet4333, 12 Nisan 2020, 18:44:17
ahmet4333
ben çok acemiyim elimdeki c ile yazılmış dosyayı bas dosyaına çevirip protonda hex çıkışı almak istediğimde şöyle bir hata veriyor:
error:[line 28] item threshold not found!(untitled.bas)
error:[line 29] item sensitivity not found!(untitled.bas)
error:[line 49] item target not found!(untitled.bas)
kod şu şekilde: lütfen koddaki yalnış yeri gösterebilirmisiniz
'*  Name    : UNTITLED.BAS                                      *
'*  Author  : [select VIEW...EDITOR OPTIONS]                    *
'*  Notice  : Copyright (c) 2020 [select VIEW...EDITOR OPTIONS] *
'*  Date    : 12.04.2020                                        *
'*  Notes   :                                                   *
Device = 16F876A
Xtal = 4
Config XT_OSC,WDT_OFF,PWRTE_ON,BODEN_OFF,CP_OFF,CPD_OFF,LVP_OFF
Define LCD_Type = 0
Define	LCD_DTPin		PORTC.4
Define	LCD_RSPin		PORTC.0
Define	LCD_ENPin		PORTC.3
Define LCD_Lines		2
Define LCD_Interface	4
Define Adin_Res 10       ' 10-bit result required
Define Adin_Tad 32_FOSC  ' AD conversion clock
Define Adin_Stime 20     ' 20us AD sample time
CCP1_Pin = PORTC.2
threshold As Byte
sensitivity As Byte
duty As Byte
sample1 As Word
sample2 As Word
sample3 As Word
sample4 As Word
gb1 As Word
gb2 As Word
gb3 As Word
gb4 As Word
s1 As Word
s2 As Word
s3 As Word
s4 As Word
temp1 As Float
temp2 As Float
temp3 As Float
battery_voltage As Float
target As Word
size As Word
i As Byte
    PORTB_Pullups = On
    ADCON1 = $84
    TRISA = $0B
    TRISB = $FF
    TRISC = $00
    DelayUS 500
    Clear          'Clear variables
	Print $FE, 1   'Clear display
	duty = 10
	threshold = 2
    DelayUS 500
    Print $FE, 1,   "**  BRN Pi-1  **"
	Print $FE, $C0, "Digital Detector"
	DelayMS 2000
    Print $FE, 1,   "Made in  TURKEY"
	Print $FE, $C0, " ** Baron66 ** "
	DelayMS 2000
	Print $FE, 1
	While 1 = 1
        TRISA.5 = 0
        PORTA.5 = 1
        DelayUS 200
        TRISA.5 = 0
        PORTA.5 = 0
        DelayUS 10
        sample1 = ADIn 0
        DelayUS 790
        TRISA.5 = 0
        PORTA.5 = 1
        DelayUS 200
        TRISA.5 = 0
        PORTA.5 = 0
        DelayUS 50
        sample2 = ADIn 0
        DelayUS 750
        TRISA.5 = 0
        PORTA.5 = 1
        DelayUS 200
        TRISA.5 = 0
        PORTA.5 = 0
        DelayUS 90
        sample3 = ADIn 0
        DelayUS 710
        TRISA.5 = 0
        PORTA.5 = 1
        DelayUS 200
        TRISA.5 = 0
        PORTA.5 = 0
        DelayUS 150
        sample4 = ADIn 0
        DelayUS 650
        temp1 = ADIn 1
        temp2 = temp1 * 0.0048
        temp3 = temp2 * 110
        battery_voltage = temp3 / 10 + 0.3
        'Ground
        If PORTB.0 = 0 Then GoSub GroundBalance
        'Sound+
        If PORTB.2 = 0 Then
            duty = duty + 10
            If duty > 100 Then duty = 100
            GoSub Beep
        End If
        'Sound-
        If PORTB.1 = 0 Then
            duty = duty - 10
            If duty < 0 Then duty = 0
            GoSub Beep
        End If
        'Sens-
        If PORTB.3 = 0 Then
            GoSub Beep
            threshold = threshold + 10
            If threshold > 100 Then threshold = 100
        End If
        'Sens+
        If PORTB.4 = 0 Then
            GoSub Beep
            threshold = threshold - 10
            If threshold < 0 Then threshold = 0
        End If
        sensitivity = (100 - threshold) / 10
        GoSub Calculate
        Print $FE, $80, "V:", Dec duty / 10, " "
        Print $FE, $84, "S:", Dec sensitivity, " "
        If 10.3 < battery_voltage Then
            Print $FE, $88, "B:", Dec2 battery_voltage, "V "
        Else
            Print $FE, $88, "B:LOW   "
        End If
        If target  > threshold Then
            HPWM 1,duty,1260   'Sound On
            size = target / 10
            If size > 15 Then size = 15
             For i = 0 To size
                Print $FE, $C0 + i, ".>---------------"
             Next
        Else
            Print $FE, $C0, "--------------"
            HPWM 1,0,0         'Sound Off
        End If
	Wend
GroundBalance:
	gb1 = sample1 + 2
	gb2 = sample2 + 2
	gb3 = sample3 + 2
	gb4 = sample4 + 2
	DelayMS 150
	Return
Calculate:
	s1 = sample1 - gb1
	s2 = sample2 - gb2
	s3 = sample3 - gb3
	s4 = sample4 - gb4
	If s1 < 0 Then s1 = 0
	If s2 < 0 Then s2 = 0
	If s3 < 0 Then s3 = 0
	If s4 < 0 Then s4 = 0
	target = s4 + s1 + s2 + s3
	Return
Beep:
    HPWM 1,duty,1260
	DelayMS 150
    HPWM 1,0,0
	Return
Syntax hataları var, düzeltilmişi altta.
Kod'un doğru hazırlanıp hazırlanmadığını bilemem.
derledikten sonraki hex de altta
Device = 16F876A
Xtal = 4
Declare LCD_Type = 0
Declare LCD_DTPin PORTC.4
Declare LCD_RSPin PORTC.0
Declare LCD_ENPin PORTC.3
Declare LCD_Lines 2
Declare LCD_Interface 4
Declare Adin_Res 10      ' 10-bit result required
Declare Adin_Tad 32_FOSC  ' AD conversion clock
Declare Adin_Stime 20    ' 20us AD sample time
Declare CCP1_Pin = PORTC.2
Dim threshold As Byte
Dim sensitivity As Byte
Dim duty As Byte
Dim sample1 As Word
Dim sample2 As Word
Dim sample3 As Word
Dim sample4 As Word
Dim gb1 As Word
Dim gb2 As Word
Dim gb3 As Word
Dim gb4 As Word
Dim s1 As Word
Dim s2 As Word
Dim s3 As Word
Dim s4 As Word
Dim temp1 As Float
Dim temp2 As Float
Dim temp3 As Float
Dim battery_voltage As Float
Dim target As Word
Dim size As Word
Dim i As Byte
Declare PORTB_Pullups = On
ADCON1 = $84
TRISA = $0B
TRISB = $FF
TRISC = $00
DelayUS 500
duty = 10
threshold = 2
DelayUS 500
DelayMS 2000
DelayMS 2000
Print $FE, 1
While 1 = 1
    TRISA.5 = 0
    PORTA.5 = 1
    DelayUS 200
    TRISA.5 = 0
    PORTA.5 = 0
    DelayUS 10
    sample1 = ADIn 0
    DelayUS 790
    TRISA.5 = 0
    PORTA.5 = 1
    DelayUS 200
    TRISA.5 = 0
    PORTA.5 = 0
    DelayUS 50
    sample2 = ADIn 0
    DelayUS 750
    TRISA.5 = 0
    PORTA.5 = 1
    DelayUS 200
    TRISA.5 = 0
    PORTA.5 = 0
    DelayUS 90
    sample3 = ADIn 0
    DelayUS 710
    TRISA.5 = 0
    PORTA.5 = 1
    DelayUS 200
    TRISA.5 = 0
    PORTA.5 = 0
    DelayUS 150
    sample4 = ADIn 0
    DelayUS 650
    temp1 = ADIn 1
    temp3 = temp2 * 110
    'Ground
    'Sound+
    If PORTB.2 = 0 Then
        duty = duty + 10
        GoSub Beep
    End If
    'Sound-
    If PORTB.1 = 0 Then
        duty = duty - 10
        GoSub Beep
    End If
    'Sens-
    If PORTB.3 = 0 Then
        GoSub Beep
    End If
    'Sens+
    If PORTB.4 = 0 Then
        GoSub Beep
    End If
    GoSub Calculate
    Else
    End If
        size = target / 10
            For i = 0 To size
            Next
        Else
    End If
Wend
GroundBalance:
    gb1 = sample1 + 2
    gb2 = sample2 + 2
    gb3 = sample3 + 2
    gb4 = sample4 + 2
    DelayMS 150
Return
Calculate:
    s1 = sample1 - gb1
    s2 = sample2 - gb2
    s3 = sample3 - gb3
    s4 = sample4 - gb4
Return
Beep:
    HPWM 1,duty,1260
    DelayMS 150
    HPWM 1,0,0
Return
:10000000000004308A00222CA401AD00AE01A01132
:1000100024080319A0150530A3002730AA001030CA
:100020001D200330AA00E8301D20AA0164301D20E5
:10003000AA010A301D202D082428A9002E08A60098
:100040002D08A500DC212508A500A3030319A01194
:10005000240803192E282302031835282508031D18
:10006000A011A0193528303E0A290800C900BA1F7E
:100070003B282D300A21BC0F4228BB0F4228BA0A68
:100080000319BA0AC101C201C301C401BA176A3017
:10009000B9070310BA0CBB0CBC0CC40CC30CC20CCB
:1000A000C10CB90F49283C083902BC07B9023B080A
:1000B0003A02BB07BA02A40195202E300A21CA01D8
:1000C0000310410DBC00420DBB00430DBA00440DAE
:1000D000B900CA0D0310BC0DBB0DBA0DB90DCA0D88
:1000E0004108BC0742080318420FBB074308031826
:1000F000430FBA0744080318440FB9070318CA0F7F
:100100000310BC0DBB0DBA0DB90DCA0D4A08303E27
:100110000A213C08C1003B08C2003A08C300390864
:10012000C400C90B5F2803100E2AA0112408031D68
:100130009C28A0150A30A4003C08A8003B08A70092
:100140003A08A6003908A500A301B001AF01AE012D
:100150000A30AD00A321A30A23082402031DA52809
:100160002D08031DA011A01DB728240BBA282D08A7
:10017000303E0A21A40B9C280E2AB20087110710DA
:100180008316871107100F30870583123208A018D5
:10019000E7283E30A60080308F213330B100FB20AD
:1001A0001330A60088308F21FB2064308E21FB2085
:1001B00064308E212230B100FB202830E6200C3044
:1001C000E6200630E620A0143208E7282014B1000B
:1001D000201CF5280710033C031CFA28FA200730DE
:1001E000A600D0308F21031408002014FE3C031910
:1001F00008290714201C201087150F3087053108A7
:10020000F03987048711B10E2018FB2832308E2177
:1002100032080E2AA11BBD280800B4004230A500F8
:100220000F30A600DC2103191210031D1214FC3E2E
:10023000031C9210031892144030A5004230A6000F
:100240000F30AD00AE011218452192184521DE2174
:1002500025038316920083122508A9002608AA0008
:100260002208B100B200220FB201F8212E08B40B0F
:10027000452995000C309700AD1B97162D1B1716BE
:1002800083160711831212150E2A46210310AD0C96
:10029000A60CA50C0800A300CB01230803178D00B2
:1002A0000313240803178F005E2103190E2A0A2165
:1002B000A30A0319A40ACB0F4D290E2A831603178C
:1002C0008C170C140000000083120C080E2AB100D9
:1002D000B10DB10D310D3839C1389F0014308E2168
:1002E0001F151F1971291E08BA0083161E088312D4
:1002F000B9000E2A83178001840AFF3E031D7B2963
:100300000E2AAA01A900FF30A907031CAA07031C93
:100310000E2A0330A600DF308F218329A601E83E94
:10032000A500A609FC30031C9829A50703189529E8
:10033000A5070000A60F952925189E29A51CA2290E
:100340000000A2290800BD01BE01BF01C00121308B
:10035000AB00CA29BD0DBE0DBF0DC00D2D083D025D
:100360002E08031C2E0F3E022F08031C2F0F3F02E6
:100370003008031C300F4002031CCA29C0002D089E
:10038000BD022E08031C2E0FBE022F08031C2F0FC8
:10039000BF020314A50DA60DA70DA80DAB0BAA292E
:1003A0004008B0003F08AF003E08AE003D08AD0079
:1003B0000E2AA601AA01A900AE01AD011030B100BC
:1003C000260DAD0DAE0D2908AD022A08031C2A0F1B
:1003D000AE020318F2292908AD072A0803182A0FCC
:1003E000AE070310A50DA60DB10BE02925080800E6
:1003F0001030B800A601A501B20CB10C031C062AEE
:100400002908A5072A0803182A0FA607A60CA50C79
:10041000AE0CAD0CB80BFC292D0808008313831219
:100420000313080046084206CF00CF1B472AC61B0D
:10043000302A45084102031C0034031D01344608DC
:100440004202031C0034031D013447084302031C0D
:100450000034031D013448084402031C00340134F5
:1004600041084502031C0034031D013442084602C2
:10047000031C0034031D013443084702031C0034ED
:10048000031D013444084802031C00340134C21F18
:100490000134003445084102C9000318692AC9091A
:1004A000C90A4108CE004508C1004E08C5004208EF
:1004B000CE004608C2004E08C6004308CE004708DA
:1004C000C3004E08C7004408CE004808C4004E08C8
:1004D000C8001A30490203180E2AC50803190E2A4B
:1004E000BD014208CE004606CD00C217C61708302F
:1004F000C902031C832A4808BD004708C8004608F3
:10050000C700C601772AC90703198F2A0310C60C32
:10051000C70CC80CBD0CC903C908031D862ACD1F12
:10052000D62A4808C4024708031C470FC3024608DE
:10053000031C460FC2020318A72AC209C309C40933
:10054000C40FA52AC30A0319C20A8030CE06BD090A
:10055000BD0A0319B22AC403440FB22AC303430AD3
:100560000319C2030430C900C208031DC62A430888
:10057000C2004408C3003D08C400BD010830C102E8
:10058000031CF52AC9030319F52AB42AC21BD12A70
:100590000310BD0DC40DC30DC20DC1030319F52A0F
:1005A000C62ABD1FD52ABD01EB2AF42A4808C40774
:1005B00047080318470FC30746080318460FC2072A
:1005C000031CE92AC20CC30CC40CBD0CC10A0319DC
:1005D000F72ABD1FF42AC40FF42AC30FF42AC20F4E
:1005E000F42A03144110E22AFE2AC101FA2ACC1689
:1005F000FF30C100C401C3018030C200CE1B012BFB
:10060000C2130E2A4208BF004606CD00C5080319D2
:100610006A2BC10803196D2B4508C1027F300318EE
:10062000152BC107031C6C2B182BC10703186F2B4C
:100630004408BD004308BE00BF17C6171830CE00DF
:10064000C401C301C201262B0318322B48083D0206
:100650004708031C470F3E024608031C460F3F0293
:10066000031C3D2B4808BD024708031C470FBE0270
:100670004608031C460FBF020314C40DC30DC20D70
:10068000BD0DBE0DBF0DCE0B242BC21B4F2BC108C1
:1006900003196C2BCD0CC103CE0ACD0D242B0318EE
:1006A0005D2B4808BD024708031C470FBE024608E1
:1006B000031C460FBF02031C692BC40F692BC30F19
:1006C000692BC20F692BC20CC30CC40CC10A0319DD
:1006D0006F2B762BCC15702B4C15C101722BCC14C3
:1006E000FF30C100C401C3018030C200CD1B792B93
:1006F000C2130E2A4208BF004606CD004108003A48
:10070000031D4508003A0319CA2BC1077E30031C9C
:100710008D2BC1020318CC2B902BC102031CC92BBB
:100720004408BD004308BE00BF17C617C401C3017B
:10073000C2011830CE00BF0CBE0CBD0C031CAA2B8E
:100740004808C40747080318470FC307460803189B
:10075000460FC207C20CC30CC40CCE0B9B2BC21B92
:10076000B92BC40DC30DC20DC1080319C92BC10398
:100770003F0D031CC82BC40FC82BC30FC82BC20FBF
:10078000C82B0314C20CC30CC40CC10A0319CC2B14
:10079000D32B4C15C101CF2BCC14FF30C100C401A9
:1007A000C3018030C200CD1BD62BC2130E2AC30159
:1007B000C401CD13EA2BCD13C41FEA2BC409C3090E
:1007C000C209C109C10FE92BC20FE92BC30A0319E2
:1007D000C40ACD179630CE00C4080319F82B083090
:1007E000CE074208C1004308C2004408C3000D2CD4
:1007F000C308031D0D2C0830CE024208031D092C2E
:100800000830CE024108031D082C4408CE00172CE6
:10081000C101C3004108C200C101C31B152C031054
:10082000C10DC20DC30DCE030D2CCD1FC313410846
:10083000C4004E08C1004308CE004208C3004E0861
:10084000C2000E2A83014030CC00A001073083167D
:100850009F009C00811384309F000B308500FF3087
:100860008600870101308312A600F4308A018F21AF
:100870002030840060308A017B21A0308400503019
:100880008A017B211030840060308A017A21903007
:10089000840060308A017A21FE308A01BD20013057
:1008A0008A01BD200A30D2000230D0000130A600FB
:1008B000F4308A018F21FE308A01BD2001308A0187
:1008C000BD208030A1000730A4003D308A014B21BB
:1008D000FE308A01BD20C0308A01BD208030A100D9
:1008E0000730A4004E308A014B210730AA00D030D7
:1008F0008A018221FE308A01BD2001308A01BD209B
:100900008030A1000730A4005F308A014B21FE3007
:100910008A01BD20C0308A01BD208030A10007308F
:10092000A4006F308A014B210730AA00D0308A0121
:100930008221FE308A01BD2001308A01BD2083164C
:10094000851283128516C8308A018E21831685127E
:10095000831285120330A5008A110A12A50BAE2C52
:10096000000000308A016721D3003A08D400033028
:10097000A60016308A018F218316851283128516F0
:10098000C8308A018E218316851283128512323077
:100990008A018E2100308A016721D5003A08D600ED
:1009A0000230A600EE308A018F2183168512831251
:1009B0008516C8308A018E2183168512831285120E
:1009C0005A308A018E2100308A016721D7003A0807
:1009D000D8000230A600C6308A018F218316851206
:1009E00083128516C8308A018E21831685128312E0
:1009F000851296308A018E2100308A016721D90044
:100A00003A08DA000230A6008A308A018F210130CC
:100A10008A0167213A08C2003908C1008A01D72338
:100A20004408EE004308ED004208EC004108EB00EA
:100A30005230C4004930C3001D30C2007730C100BD
:100A40006E08C8006D08C7006C08C6006B08C500BA
:100A50008A017A234408F2004308F1004208F000BA
:100A60004108EF00C401C3015C30C2008530C10001
:100A70007208C8007108C7007008C6006F08C5007A
:100A80008A017A234408F6004308F5004208F4007E
:100A90004108F300C801C7012030C6008230C500FC
:100AA0007608C4007508C3007408C2007308C1004A
:100AB0008A0102234408BC004308BB004208BA0074
:100AC0004108B9009A30C4009930C3001930C200FF
:100AD0007D30C1003C08C8003B08C7003A08C6008A
:100AE0003908C5008A014A224408FA004308F9007F
:100AF0004208F8004108F7008A110A120618832DEF
:100B00008A110A12B7268A110A120619942D0A3080
:100B1000D207653052028A110A12031C912D6430EB
:100B2000D2008A110A1228278A110A128618A22DC9
:100B30000A30D2028A110A12D21F9F2DD2018A11C5
:100B40000A1228278A110A128619B32D8A110A124D
:100B500028270A30D007653050028A110A12031C78
:100B6000B32D6430D0008A110A12061AC12D8A11E1
:100B70000A1228270A30D0028A110A12D01FC12D6A
:100B8000D0015008643CB9000030031CFF3EBA009D
:100B90003A08A6003908A500AA010A30A9008A016E
:100BA000DC21D1008A110A12D726FE308A01BD202D
:100BB00080308A01BD2056308A01BD203A308A013A
:100BC000BD208030A100A4015208A5000A308A018E
:100BD000D921AD00AE018A01072020308A01BD2055
:100BE000FE308A01BD2084308A01BD2053308A0145
:100BF000BD203A308A01BD208030A10051088A0111
:100C0000042020308A01BD20CD30C400CC30C30088
:100C10002430C2008230C1007A08C8007908C700B9
:100C20007808C6007708C5008A011222013C8A11A3
:100C30000A1203193D2EFE308A01BD2088308A0138
:100C4000BD2042308A01BD203A308A01BD2080306B
:100C5000A1007A08BC007908BB007808BA007708C0
:100C6000B90002308A01362056308A01BD2020307A
:100C70008A01BD208A110A124A2EFE308A01BD2047
:100C800088308A01BD208030A1000730A4007F3069
:100C90008A014B21FC088A110A12031D552E7B087C
:100CA00050028A110A120318A22E8312031352084B
:100CB000A2000430AA00EC30A90001308A010D2105
:100CC0007C08A6007B08A500AA010A30A9008A01B9
:100CD000DC21FD002608FE00FE088A110A12031D11
:100CE000772E10307D028A110A12031C7C2E83128B
:100CF0000313FE010F30FD00FF01FE088A110A12E6
:100D0000031D882E7F087D028A110A12031C9F2E64
:100D1000FE30831203138A01BD20C0307F07AD006F
:100D20008A01BD208030A1000730A40087308A01ED
:100D30004B210130FF078A110A12031C7D2E8A11F4
:100D40000A12B52EFE308A01BD20C0308A01BD20B6
:100D50008030A1000730A40099308A014B21A20104
:100D6000AA01A90101308A010D218A019F2C0230BC
:100D70005307DB0054080318013EDC00023055071E
:100D8000DD0056080318013EDE0002305707DF0081
:100D900058080318013EE00002305907E1005A08E4
:100DA0000318013EE20096308A01812108005B08A9
:100DB0005302E3005C08031C013E5402E4005D089A
:100DC0005502E5005E08031C013E5602E6005F087E
:100DD0005702E7006008031C013E5802E800610862
:100DE0005902E9006208031C013E5A02EA008A1116
:100DF0000A12E41FFD2EE401E3018A110A12E61F24
:100E0000032FE601E5018A110A12E81F092FE80104
:100E1000E7018A110A12EA1F0F2FEA01E9016A08A5
:100E2000BA006908B9006308B90764080318013EED
:100E3000BA076508B90766080318013EBA073908FA
:100E40006707FB003A080318013E6807FC0008002A
:100E50005208A2000430AA00EC30A90001308A0137
:100E60000D2196308A018121A201AA01A901013038
:100E70008A010D2108008A013B2F2A002A00200048
:100E80002000420052004E002000500069002D005A
:100E90003100200020002A002A00000044006900E0
:100EA00067006900740061006C0020004400650068
:100EB00074006500630074006F00720000004D0054
:100EC000610064006500200069006E0020002000C1
:100ED0005400550052004B0045005900000020000E
:100EE0002A002A0020004200610072006F006E009C
:100EF0003600360020002A002A00200000004200B0
:100F00003A004C004F0057002000200000002E0047
:100F10003E002D002D002D002D002D002D002D0058
:100F20002D002D002D002D002D002D002D002D0059
:100F300000002D002D002D002D002D002D002D0076
:100F40002D002D002D002D002D002D002D00000066
:02400E00313F40
:00000001FF
