Senkronize, Frekansı programlanabilen BUCK regülatör.
Başlatan M.Salim GÜLLÜCE, 21 Ekim 2020, 17:54:41
Benim ilgimi çekti ama absürd bir kılıfa koymuşlar.
4MHz 2A Synchronous Buck Regulator with Programmable Frequency
Features
• Input Voltage Range: 2.6V to 5.5V
• Output Voltage Adjustable Down to 0.7V
• Output Load Current Up to 2A
• Full Sequencing and Tracking Ability
• Easy RC Compensation• Power-on-Reset (POR) Output
• Efficiency >90% Across a Broad Load Range
• Operating frequency: Programmable from 800  kHz up to 4MHz
• Ultra-Fast Transient Response• 100% Maximum Duty Cycle
• Fully Integrated MOSFET Switches• Micropower Shutdown
• Thermal Shutdown and Current-Limit Protection
• Available in 12-Pin 3mm x 3mm DFN
• –40°C to +125°C Junction Temperature Range
Applications
• High Power Density Point-of-Load Conversion
• Servers and Routers
• DVD Recorders and Multimedia Players
• Computing Peripherals
• Base Stations
• FPGAs, DSP, and Low Voltage ASIC Devices
https://ww1.microchip.com/downloads/en/DeviceDoc/MIC22200-4MHz-2A-Synchronous-Buck-Regulator-with-Programmable-Frequency-DS20006324A.pdf
