MIC2026 Dual Power Switch Chip: 5.5V 500mA SOIC-8
Başlatan M.Salim GÜLLÜCE, 13 Kasım 2023, 12:09:44
Çoklu MCU lu sistem tasarlayanlar yada çoklu güç denetimi gerektiren yerler için ufacık bir çip.
Features
140 mΩ Maximum On-Resistance per Channel
2.7V to 5.5V Operating Range
500 mA Minimum Continuous Current per Channel
• Short-Circuit Protection with Thermal Shutdown
Thermally Isolated Channels
• Fault Status Flag with 3 ms Filter Eliminates False Assertions
• Undervoltage Lockout
• Reverse Current Flow Blocking (No "Body Diode")
• Circuit Breaker Mode (MIC2076)
• Active-High Enable (MIC20x6-1)
• Active-Low Enable (MIC20x6-2)
• Logic-Compatible Inputs
• Soft-Start Circuit
• Low Quiescent Current
• Pin-Compatible with MIC2526
https://ww1.microchip.com/downloads/aemDocuments/documents/APID/ProductDocuments/DataSheets/MIC2026-Family-Data-Sheet-DS20006443.pdf
